path: root/drivers/char/rocket_int.h
2008-04-29char: use get_unaligned_* helpersHarvey Harrison
Remove unnecessary temp variable from_buf in snsc_event.c Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19drivers/char/rocket portability fixesAl Viro
unsigned long != __le32, TYVM, and unsigned char[4] is not guaranteed to be aligned for u32. While we are at it, sanitize sOutDW() a bit - have it take Byte_t * and handle dereferencing internally. NB: sWriteTxPrioByte() is almost certainly buggered on big-endian and is missing cpu_to_le16() on assignments to *WordPtr; I've left it alone for now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Char: rocket, remove useless macrosJiri Slaby
Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Char: rocket, printk cleanupJiri Slaby
- add KERN_ level to each print - change some levels appropriately - add \n at the ends where missing - change two complex printks into dev_info, where the original info is printed automatically Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Char: rocket, switch sleep_on to completionJiri Slaby
rocket, switch sleep_on to completion - sleep_on is deprecated and racy, use completion instead - also check retval of interruptible function and return ERESTARTSYS eventually Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11Kill unused sesssion and group values in rocket driverSukadev Bhattiprolu
The process_session() and process_group() values are not really used by the driver. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: <containers@lists.osdl.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08use mutex instead of semaphore in RocketPort driverMatthias Kaehlcke
The RocketPort driver uses a semaphore as mutex. Use the mutex API instead of the (binary) semaphore. Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-06-25[PATCH] drivers/char/rocket.c: cleanupsAdrian Bunk
This patch contains the following cleanups: - make needlessly global code static - remove the TRUE/FALSE macros Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
