path: root/drivers/char/rtc.c
2009-11-18sysctl: Drop & in front of every proc_handler.Eric W. Biederman
For consistency drop & in front of every proc_handler. Explicity taking the address is unnecessary and it prevents optimizations like stubbing the proc_handlers to NULL. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-12sysctl drivers: Remove dead binary sysctl supportEric W. Biederman
Now that sys_sysctl is a wrapper around /proc/sys all of the binary sysctl support elsewhere in the tree is dead code. Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Matt Mackall <mpm@selenic.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Neil Brown <neilb@suse.de> Cc: "James E.J. Bottomley" <James.Bottomley@suse.de> Acked-by: Clemens Ladisch <clemens@ladisch.de> for drivers/char/hpet.c Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-10-13headers: Fix build after <linux/sched.h> removalIngo Molnar
Commit d43c36dc6b357fa1806800f18aa30123c747a6d1 ("headers: remove sched.h from interrupt.h") left some build errors in some configurations due to drivers having depended on getting header files "accidentally". Signed-off-by: Ingo Molnar <mingo@elte.hu> [ Combined several one-liners from Ingo into one single patch - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08RTC: Remove the BKL.David John
Remove calls to the BKL since concurrent access is protected by the spin lock rtc_lock. Signed-off-by: David John <davidjon@xenontk.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-11-01saner FASYNC handling on file closeAl Viro
As it is, all instances of ->release() for files that have ->fasync() need to remember to evict file from fasync lists; forgetting that creates a hole and we actually have a bunch that *does* forget. So let's keep our lives simple - let __fput() check FASYNC in file->f_flags and call ->fasync() there if it's been set. And lose that crap in ->release() instances - leaving it there is still valid, but we don't have to bother anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20rtc: use bcd2bin/bin2bcdAdrian Bunk
Change various rtc related code to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16legacy rtc: remove needless/confusing HPET_RTC_IRQ optionDavid Brownell
HPET_RTC_IRQ is no longer needed; HPET_EMULATE_RTC suffices and is more correct. (http://bugzilla.kernel.org/show_bug.cgi?id=11111) Note that when using the legacy RTC driver, platforms don't really do a dynamic switch between HPET and non-HPET modes based on whether HPET hardware actually exists ... only rtc-cmos (using the new RTC framework) currently switches that way. So this reflects bitrot in that legacy code, for x86/ia64: kernels with HPET support configured (e.g. for a clocksource) can't get IRQs from the legacy RTC driver unless they really have HPET hardware. (The obvious workaround is to not use the legacy RTC driver on those platforms when you configure HPET ... unless you know the target really has a HPET.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-30sparc32: Convert PC RTC probing to pure OF driver.David S. Miller
2008-08-12drivers/char/rtc.c: removed duplicated includeHuang Weiyi
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26drivers/char/rtc.c: make 2 functions staticAdrian Bunk
The following functions can now become static: - rtc_interrupt() - rtc_get_rtc_time() Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Bernhard Walle <bwalle@suse.de> Acked-by: Paul Gortmaker <p_gortmaker@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24rtc: remove and clarify unneeded externsCarlos R. Mafra
When CONFIG_HPET_EMULATE_RTC is defined the external declaration of hpet_rtc_interrupt is redundant due to the inclusion of hpet.h. When !CONFIG_HPET_EMULATE_RTC we make it clear that hpet_rtc_interrupt is not used by defining it to return zero. Signed-off-by: Carlos R. Mafra <crmafra@ift.unesp.br> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24rtc: push the BKL down into the driver ioctl methodAlan Cox
For now just wrap the main logic, but this driver is a prime candidate for someone wanting to eliminate the lock entirely [lizf@cn.fujitsu.com: fix build failure] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-07-10rtc: fix reported IRQ rate for when HPET is enabledPaul Gortmaker
The IRQ rate reported back by the RTC is incorrect when HPET is enabled. Newer hardware that has HPET to emulate the legacy RTC device gets this value wrong since after it sets the rate, it returns before setting the variable used to report the IRQ rate back to users of the device -- so the set rate and the reported rate get out of sync. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Brownell <david-b@pacbell.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-02rtc: BKL pushdownArnd Bergmann
2008-04-29drivers: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28drivers/char/rtc.c: use time_before, time_before_eq, etcJulia Lawall
The functions time_before, time_before_eq, time_after, and time_after_eq are more robust for comparing jiffies against other values. A simplified version of the semantic patch making this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @ change_compare_np @ expression E; @@ ( - jiffies <= E + time_before_eq(jiffies,E) | - jiffies >= E + time_after_eq(jiffies,E) | - jiffies < E + time_before(jiffies,E) | - jiffies > E + time_after(jiffies,E) ) @ include depends on change_compare_np @ @@ #include <linux/jiffies.h> @ no_include depends on !include && change_compare_np @ @@ #include <linux/...> + #include <linux/jiffies.h> // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-29Fix hpet_(un)register_irq_handler() for emulationDavid Howells
Fix hpet_(un)register_irq_handler() for when CONFIG_HPET_EMULATE_RTC=n. They are provided macros that substitute value 0, but if they are called as functions and the return value isn't checked, the following warnings appear: drivers/char/rtc.c: In function `rtc_init': drivers/char/rtc.c:1063: warning: statement with no effect drivers/char/rtc.c: In function `rtc_exit': drivers/char/rtc.c:1157: warning: statement with no effect Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30rtc: use the IRQ callback interface in (old) RTC driverBernhard Walle
the previous patch in the old RTC driver. It also removes the direct rtc_interrupt() call from arch/x86/kernel/hpetc.c so that there's finally no (code) dependency to CONFIG_RTC in arch/x86/kernel/hpet.c. Because of this, it's possible to compile the drivers/char/rtc.ko driver as module and still use the HPET emulation functionality. This is also expressed in Kconfig. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Andi Kleen <ak@suse.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Robert Picco <Robert.Picco@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: clean up drivers/char/rtc.cIngo Molnar
tons of style cleanup in drivers/char/rtc.c - no code changed: text data bss dec hex filename 6400 384 32 6816 1aa0 rtc.o.before 6400 384 32 6816 1aa0 rtc.o.after since we seem to have a number of open breakages in this code we might as well start with making the code more readable and maintainable. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-14rtc: fall back to requesting only the ports we actually useBjorn Helgaas
Firmware like PNPBIOS or ACPI can report the address space consumed by the RTC. The actual space consumed may be less than the size (RTC_IO_EXTENT) assumed by the RTC driver. The PNP core doesn't request resources yet, but I'd like to make it do so. If/when it does, the RTC_IO_EXTENT request may fail, which prevents the RTC driver from loading. Since we only use the RTC index and data registers at RTC_PORT(0) and RTC_PORT(1), we can fall back to requesting just enough space for those. If the PNP core requests resources, this results in typical I/O port usage like this: 0070-0073 : 00:06 <-- PNP device 00:06 responds to 70-73 0070-0071 : rtc <-- RTC driver uses only 70-71 instead of the current: 0070-0077 : rtc <-- RTC_IO_EXTENT == 8 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14rtc: release correct region in error pathBjorn Helgaas
The misc_register() error path always released an I/O port region, even if the region was memory-mapped (only mips uses memory-mapped RTC, as far as I can see). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21x86_64: Untangle asm/hpet.h from asm/timex.hChris Wright
When making changes to x86_64 timers, I noticed that touching hpet.h triggered an unreasonably large rebuild. Untangling it from timex.h quiets the extra rebuild quite a bit. Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20[SPARC64]: Stop using drivers/char/rtc.cDavid S. Miller
The existing sparc64 mini_rtc driver can handle CMOS based rtcs trivially with just a few lines of code and the simplifies things tremendously. Tested on SB1500. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-16RTC: Ratelimit "lost interrupts" messageBen Collins
We gets lots of these when the kernel is running on a hypervisor. Zach says "a guest kernel trying to get high frequency RTC will also be inaccurate, and inevitably will have unhidable interrupt lateness." Signed-off-by: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08drivers/char: use __set_current_state()Milind Arun Choudhary
use __set_current_state(TASK_*) instead of current->state = TASK_*, Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove sys_sysctl support from drivers/char/rtc.cEric W. Biederman
The real time clock driver was using the binary number reserved for cdroms in the sysctl binary number interface, which is a no-no. So since the sysctl binary interface is wrong remove it. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] Char: timers cleanupJiri Slaby
- Use timer macros to set function and data members and to modify expiration time. - Use DEFINE_TIMER for global timers and do not init them at run-time in these cases. - del_timer_sync is common in most cases -- we want to wait for timer function if it's still running. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Cc: Wim Van Sebroeck <wim@iguana.be> Acked-by: Dmitry Torokhov <dtor@mail.ru> (Input bits) Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-22[PATCH] rtc warning fixAndrew Morton
drivers/char/rtc.c:116: warning: 'hpet_rtc_interrupt' defined but not used Cc: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] RTC driver init adjustmentJan Beulich
- conditionalizes procfs code upon CONFIG_PROC_FS (to reduce code size when that option is not enabled) - make initialization no longer fail when the procfs entry can't be allocated (namely would initialization always have failed when CONFIG_PROC_FS was not set) - move the formerly file-scope static variable rtc_int_handler_ptr into the only function using it, and makes it automatic. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] rtc: fx error caseJan Beulich
Ensure RTC driver doesn't use its timer when it doesn't get to set it up (as it cannot currently prevent other of its functions to be called from outside when not built as a module - probably this should also be addressed). Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-09[RTC] Consistently use of tabs for formatting.Ralf Baechle
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-29[PATCH] remove unnecessary barrier in rtc_get_rtc_timeSteven Rostedt
Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25[PATCH] rtc: lockdep fix/workaroundPeter Zijlstra
BUG: warning at kernel/lockdep.c:1816/trace_hardirqs_on() (Not tainted) [<c04051ee>] show_trace_log_lvl+0x58/0x171 [<c0405802>] show_trace+0xd/0x10 [<c040591b>] dump_stack+0x19/0x1b [<c043abee>] trace_hardirqs_on+0xa2/0x11e [<c06143c3>] _spin_unlock_irq+0x22/0x26 [<c0541540>] rtc_get_rtc_time+0x32/0x176 [<c0419ba4>] hpet_rtc_interrupt+0x92/0x14d [<c0450f94>] handle_IRQ_event+0x20/0x4d [<c0451055>] __do_IRQ+0x94/0xef [<c040678d>] do_IRQ+0x9e/0xbd [<c0404a49>] common_interrupt+0x25/0x2c DWARF2 unwinder stuck at common_interrupt+0x25/0x2c Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-12[PATCH] lockdep: HPET/RTC fixIngo Molnar
Joseph Fannin reported that hpet_rtc_interrupt() enables hardirqs in irq context: [ 25.628000] [<c014af4e>] trace_hardirqs_on+0xce/0x200 [ 25.628000] [<c036cf21>] _spin_unlock_irq+0x31/0x70 [ 25.628000] [<c0296584>] rtc_get_rtc_time+0x44/0x1a0 [ 25.628000] [<c01198bb>] hpet_rtc_interrupt+0x21b/0x280 [ 25.628000] [<c0161141>] handle_IRQ_event+0x31/0x70 [ 25.628000] [<c0162d37>] handle_edge_irq+0xe7/0x210 [ 25.628000] [<c0106192>] do_IRQ+0x92/0x120 [ 25.628000] [<c0104121>] common_interrupt+0x25/0x2c the call of rtc_get_rtc_time() is highly suspect. At a minimum we need the patch below to save/restore hardirq state. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Joseph Fannin <jfannin@gmail.com> Cc: John Stultz <johnstul@us.ibm.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] char/rtc: Handle memory-mapped chips properlyMaciej W. Rozycki
Handle memory-mapped chips properly, needed for example on DECstations. This support was in Linux 2.4 but for some reason got lost in 2.6. This patch is taken directly from the linux-mips repository. [akpm@osdl.org: cleanup] Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Cc: Paul Gortmaker <penguin@muskoka.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] make more file_operation structs staticArjan van de Ven
Mark the static struct file_operations in drivers/char as const. Making them const prevents accidental bugs, and moves them to the .rodata section so that they no longer do any false sharing; in addition with the proper debug option they are then protected against corruption.. [akpm@osdl.org: build fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: drivers/char: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[SPARC64]: Use in-kernel PROM tree for EBUS and ISA.David S. Miller
2006-06-20[SPARC]: Kill __irq_itoa().David S. Miller
This ugly hack was long overdue to die. It was a way to print out Sparc interrupts in a more freindly format, since IRQ numbers were arbitrary opaque 32-bit integers which vectored into PIL levels. These 32-bit integers were not necessarily in the 0-->NR_IRQS range, but the PILs they vectored to were. The idea now is that we will increase NR_IRQS a little bit and use a virtual<-->real IRQ number mapping scheme similar to PowerPC. That makes this IRQ printing hack irrelevant, and furthermore only a handful of drivers actually used __irq_itoa() making it even less useful. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[PATCH] Allow reading CMOS day of week registerAlan Cox
Someone wanted access to this usually unused (and unused by Linux) value for the day of week. Existing kernels have the field in the struct but return 0 always. This updates the kernel to fill in the field. The usual case of 'not set' conveniently is 0. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] Fix wrong irq enable via rtc_control()Takashi Iwai
rtc_control() may be called in the interrupt context in ALSA rtc-timer driver. The patch fixes the wrong irq enable in rtc.c, and also fixes the possible race of bit flags. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-05[RTC]: Use SA_SHIRQ in sparc specific code.David S. Miller
Based upon a report from Jason Wever. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-05[PATCH] rtc: msleep() cannot be used from interruptPetr Vandrovec
Since the beginning of July my Opteron box was randomly crashing and being rebooted by hardware watchdog. Today it finally did it in front of me, and this patch will hopefully fix it. The problem is that at the end of June (the 28th, to be exact: commit 47f176fdaf8924bc83fddcf9658f2fd3ef60d573, "[PATCH] Using msleep() instead of HZ") rtc_get_rtc_time was converted to use msleep() instead of busy waiting. But rtc_get_rtc_time is used by hpet_rtc_interrupt, and scheduling is not allowed during interrupt. So I'm reverting this part of original change, replacing msleep() back with busy loop. The original code was busy waiting for up to 20ms, but on my hardware in the worst case update-in-progress bit was asserted for at most 363 passes through loop (on 2GHz dual Opteron), much less than even one jiffie, not even talking about 20ms. So I changed code to just wait only as long as necessary. Otherwise when RTC was set to generate 8192Hz timer, it stopped doing anything for 20ms (160 pulses were skipped!) from time to time, and this is rather suboptimal as far as I can tell. Signed-off-by: Petr Vandrovec <vandrove@vc.cvut.cz> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[PATCH] Using msleep() instead of HZLuca Falavigna
Use msleep() in a few places. Signed-off-by: Luca Falavigna <dktrkranz@gmail.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
