path: root/drivers/char/stallion.c
2009-06-11tty: Add carrier processing on close to the tty_port coreAlan Cox
Some drivers implement this internally, others miss it out. Push the behaviour into the core code as that way everyone will do it consistently. Update the dtr rts method to raise or lower depending upon flags. Having a single method in this style fits most of the implementations more cleanly than two funtions. We need this in place before we tackle the USB side Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01proc tty: switch stallion to ->proc_fopsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02tty: Introduce some close helpers for portsAlan Cox
Again this is a lot of common code we can unify Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02tty: rework stallion to use the tty_port bitsAlan Cox
2009-01-02tty_port: Add a port level carrier detect operationAlan Cox
This is the first step to generalising the various pieces of waiting logic duplicated in all sorts of serial drivers. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16device create: char: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-13tty: Remove lots of NULL checksAlan Cox
Many tty drivers contain 'can't happen' checks against NULL pointers passed in by the tty layer. These have never been possible to occur. Even more importantly if they ever do occur we want to know as it would be a serious bug. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13stallion: Use krefsAlan Cox
Use tty_port_init and krefs in the stallion drivers to protect us from devices going away underneath us. As with the other drives some rearranging is done to pass the tty structure down properly on the user side. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24stallion: removed unused variableAndre Haupt
Signed-off-by: Andre Haupt <andre@bitwigglers.org> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (79 commits) arm: bus_id -> dev_name() and dev_set_name() conversions sparc64: fix up bus_id changes in sparc core code 3c59x: handle pci_name() being const MTD: handle pci_name() being const HP iLO driver sysdev: Convert the x86 mce tolerant sysdev attribute to generic attribute sysdev: Add utility functions for simple int/ulong variable sysdev attributes sysdev: Pass the attribute to the low level sysdev show/store function driver core: Suppress sysfs warnings for device_rename(). kobject: Transmit return value of call_usermodehelper() to caller sysfs-rules.txt: reword API stability statement debugfs: Implement debugfs_remove_recursive() HOWTO: change email addresses of James in HOWTO always enable FW_LOADER unless EMBEDDED=y uio-howto.tmpl: use unique output names uio-howto.tmpl: use standard copyright/legal markings sysfs: don't call notify_change sysdev: fix debugging statements in registration code. kobject: should use kobject_put() in kset-example kobject: reorder kobject to save space on 64 bit builds ...
2008-07-22Fix the (i)Stallion driver's putchar() and break_ctl() opsDavid Howells
Fix the Stallion driver's putchar() and break_ctl() ops and iStallion's putchar() to return values. Is it actually possible for putchar() or break_ctl() to be called with tty == NULL or can the check be discarded? Should stl_write() be returning 0 if tty->driver_data is NULL or tx.buf is NULL? Is this even possible? I've made Stallion's functions return -EINVAL as stli_breakctl() if the checks fail. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21device create: char: convert device_create to device_create_drvdataGreg Kroah-Hartman
device_create() is race-prone, so use the race-free device_create_drvdata() instead as device_create() is going away. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-20stallion: use tty_portAlan Cox
Switch the stallion driver to use the tty_port structure Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30tty/serial: lay the foundations for the next set of reworksAlan Cox
- Stop drivers calling their own flush method indirectly, it obfuscates code and it will change soon anyway - A few more lock_kernel paths temporarily needed in some driver internal waiting code - Remove private put_char method that does a write call for one char - we have that anyway - Most but not yet all of the termios copy under lock fixing (some has other dependencies to follow) - Note a few locking bugs in drivers found in the process - Kill remaining [ab]users of TIOCG/SSOFTCAR in the driver, these must go to fix the termios locking Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30stallion: Prepare for BKL push downAlan Cox
Remove broken softcar functions, wrap ioctl handler in BKL Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-20drivers/char: minor irq handler cleanupsJeff Garzik
- remove always-false tests - don't overload 'irq' argument, pass data properly via dev_id - remove pointless casts from void* Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-07Char: stallion, remove bottomhalfJiri Slaby
- tty_hangup schedules a bottomhalf itself, tty_wakeup doesn't need it - call the CD code (part of work handler previously) directly from the code (it wakes somebody up or calls tty_hangup at worse) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Char: stallion, fix compiler warningsJiri Slaby
Don't emit warnings on 64 bit platforms from min(). sizeof() on those is not uint, neither 2 pointers difference, cast it to uint by min_t in both cases. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12Convert from class_device to device in drivers/chartonyj@suse.de
Convert from class_device to device in drivers/char. Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-19unregister_chrdev(): ignore the return valueAkinobu Mita
unregister_chrdev() always returns 0. There is no need to check the return value. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17stallion: remove unneeded lock_kernelAlan Cox
2007-07-17Char: stallion, remove user class report requestJiri Slaby
stallion, remove user class report request Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-24Char: stallion, fix oops during init with ISA cardsIngo Korb
The stallion driver oopses while initializing ISA cards due to an uninitialized variable. This patch changes the initialisation order to match the PCI code path. Signed-off-by: Ingo Korb <ml@akana.de> Acked-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-08Char: stallion, proper fail return valuesJiri Slaby
do not return 0 in one case and return proper values in other 2. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-08Char: stallion, alloc tty before pci devices initJiri Slaby
this causes oops, because pci probe function calls tty_register_device for each device found. Thanks to Ingo. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: "Ingo Korb" <ingo@akana.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-08Char: stallion, don't fail with less than max panelsJiri Slaby
Since it's not neccesary to have MAX_PANELS on the card, don't fail to let users use this card even in this case. Stop the testing for loop instead. Thanks to Ingo. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: "Ingo Korb" <ingo@akana.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] Char: stallion, use dynamic devJiri Slaby
Use dynamic tty device registering depending on board's port count. (i -> retval change is relevant, since gcc complains about signedness of i) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Char: stallion, variables cleanupJiri Slaby
- fix `gcc -W' un/signed warnings by converting some ints -> uints. - move 3 global variables into functions, where are they used. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Char: stallion, remove syntactic sugarJiri Slaby
Remove useless parenthesis and brackets. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Char: stallion, brd struct lockingJiri Slaby
Since assigning of stl_brds[brdnr] is racy, add locking to this critical section. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Char: stallion, fix fail pathsJiri Slaby
Release everything what was allocated and check return value of isa probing. Release only ISA boards in module exit, since pci have their own pci-probing-remove. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Char: stallion, functions cleanupJiri Slaby
Delete macros and functions, that are implemented in kernel yet (strtoul, min, tolower). Expand one function body in place, where it is called from. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Char: stallion, correct __init macrosJiri Slaby
Some functions are now called from pci probing functiuon which is __devinit, not __init, correct this to not free functions after init if hotplug enabled. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Char: stallion, implement fail pathsJiri Slaby
This driver expect everything to work. Implement fail paths logic to release regions, irq hangler, memory... if something is in bad state. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Char: stallion, prints cleanupJiri Slaby
Too many information is printed out (they may be easily obtained through sysfs), wipe them out in probe function. Convert rest of them to dev_ variants. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Char: stallion, convert to pci probingJiri Slaby
Convert stallion driver to pci probing instead of pci_dev_get iteration. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Char: stallion, remove many prototypesJiri Slaby
Many prototypes are useless, since functions are declared before they are called. Also some code was easy to move to resolve this dependency and delete prototypes. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Char: stallion, mark functions as initJiri Slaby
Use __init macro for functions, that may be freed after initialization. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Char: stallion, uninline functionsJiri Slaby
- Do not inline such long functions, it won't speed up anything. - Remove prototypes of these functions. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Char: stallion, move init/deinitJiri Slaby
- Move code from stl_init into module init function, because calling it was the only one thing, that it did. - Move this code to the end of the driver (usual place for this) to resolve dependencies simply -- without prototypes. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Char: stallion, kill typedefsJiri Slaby
Typedefs are considered ugly in the kernel. Eliminate them. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Char: stallion, remove unneeded castsJiri Slaby
casts of NULL are unnecessary. And so casts to (void *) are. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Char: stallion, use pr_debug macroJiri Slaby
Use pr_debug kernel macro instead of #ifdef DEBUG | printk() | #endif Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-06[PATCH] drivers/{char|isdn}: work_struct-induced breakageAl Viro
part 1 of fsck-knows-how-many Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-02[PATCH] const struct tty_operationsJeff Dike
As part of an SMP cleanliness pass over UML, I consted a bunch of structures in order to not have to document their locking. One of these structures was a struct tty_operations. In order to const it in UML without introducing compiler complaints, the declaration of tty_set_operations needs to be changed, and then all of its callers need to be fixed. This patch declares all struct tty_operations in the tree as const. In all cases, they are static and used only as input to tty_set_operations. As an extra check, I ran an i386 allyesconfig build which produced no extra warnings. 53 drivers are affected. I checked the history of a bunch of them, and in most cases, there have been only a handful of maintenance changes in the last six months. serial_core.c was the busiest one that I looked at. Signed-off-by: Jeff Dike <jdike@addtoit.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] make more file_operation structs staticArjan van de Ven
Mark the static struct file_operations in drivers/char as const. Making them const prevents accidental bugs, and moves them to the .rodata section so that they no longer do any false sharing; in addition with the proper debug option they are then protected against corruption.. [akpm@osdl.org: build fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: drivers/char: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
