path: root/drivers/char/synclinkmp.c
2008-04-30char serial: switch drivers to ioremap_nocacheAlan Cox
Simple search/replace except for synclink.c where I noticed a real bug and fixed it too. It was doing NULL + offset, then checking for NULL if the remap failed. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Paul Fulghum <paulkf@microgate.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30synclink series: switch to int put_char methodAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30tty/serial: lay the foundations for the next set of reworksAlan Cox
- Stop drivers calling their own flush method indirectly, it obfuscates code and it will change soon anyway - A few more lock_kernel paths temporarily needed in some driver internal waiting code - Remove private put_char method that does a write call for one char - we have that anyway - Most but not yet all of the termios copy under lock fixing (some has other dependencies to follow) - Note a few locking bugs in drivers found in the process - Kill remaining [ab]users of TIOCG/SSOFTCAR in the driver, these must go to fix the termios locking Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30synclink series: Prepare for BKL pushdownAlan Cox
As these are quite complex I've simply pushed the BKL down into the ioctl handler not tried to do anything neater. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28char: make functions static in synclinkmp.cHarvey Harrison
All were forward declared with static. Fixes sparse warnings: drivers/char/synclinkmp.c:1476:5: warning: symbol 'read_proc' was not declared. Should it be static? drivers/char/synclinkmp.c:2027:5: warning: symbol 'bh_action' was not declared. Should it be static? drivers/char/synclinkmp.c:2058:6: warning: symbol 'bh_handler' was not declared. Should it be static? drivers/char/synclinkmp.c:2103:6: warning: symbol 'bh_receive' was not declared. Should it be static? drivers/char/synclinkmp.c:2112:6: warning: symbol 'bh_transmit' was not declared. Should it be static? drivers/char/synclinkmp.c:2124:6: warning: symbol 'bh_status' was not declared. Should it be static? drivers/char/synclinkmp.c:2136:6: warning: symbol 'isr_timer' was not declared. Should it be static? drivers/char/synclinkmp.c:2162:6: warning: symbol 'isr_rxint' was not declared. Should it be static? drivers/char/synclinkmp.c:2221:6: warning: symbol 'isr_rxrdy' was not declared. Should it be static? drivers/char/synclinkmp.c:2351:6: warning: symbol 'isr_txint' was not declared. Should it be static? drivers/char/synclinkmp.c:2379:6: warning: symbol 'isr_txrdy' was not declared. Should it be static? drivers/char/synclinkmp.c:2410:6: warning: symbol 'isr_rxdmaok' was not declared. Should it be static? drivers/char/synclinkmp.c:2427:6: warning: symbol 'isr_rxdmaerror' was not declared. Should it be static? drivers/char/synclinkmp.c:2445:6: warning: symbol 'isr_txdmaok' was not declared. Should it be static? drivers/char/synclinkmp.c:2463:6: warning: symbol 'isr_txdmaerror' was not declared. Should it be static? drivers/char/synclinkmp.c:2480:6: warning: symbol 'isr_io_pin' was not declared. Should it be static? drivers/char/synclinkmp.c:3420:5: warning: symbol 'alloc_dma_bufs' was not declared. Should it be static? drivers/char/synclinkmp.c:3494:5: warning: symbol 'alloc_buf_list' was not declared. Should it be static? drivers/char/synclinkmp.c:3553:5: warning: symbol 'alloc_frame_bufs' was not declared. Should it be static? drivers/char/synclinkmp.c:3570:6: warning: symbol 'free_dma_bufs' was not declared. Should it be static? drivers/char/synclinkmp.c:3580:5: warning: symbol 'alloc_tmp_rx_buf' was not declared. Should it be static? drivers/char/synclinkmp.c:3588:6: warning: symbol 'free_tmp_rx_buf' was not declared. Should it be static? drivers/char/synclinkmp.c:3594:5: warning: symbol 'claim_resources' was not declared. Should it be static? drivers/char/synclinkmp.c:3681:6: warning: symbol 'release_resources' was not declared. Should it be static? drivers/char/synclinkmp.c:3737:6: warning: symbol 'add_device' was not declared. Should it be static? drivers/char/synclinkmp.c:3860:6: warning: symbol 'device_init' was not declared. Should it be static? drivers/char/synclinkmp.c:4054:6: warning: symbol 'enable_loopback' was not declared. Should it be static? drivers/char/synclinkmp.c:4101:6: warning: symbol 'set_rate' was not declared. Should it be static? drivers/char/synclinkmp.c:4147:6: warning: symbol 'rx_stop' was not declared. Should it be static? drivers/char/synclinkmp.c:4168:6: warning: symbol 'rx_start' was not declared. Should it be static? drivers/char/synclinkmp.c:4225:6: warning: symbol 'tx_start' was not declared. Should it be static? drivers/char/synclinkmp.c:4295:6: warning: symbol 'tx_stop' was not declared. Should it be static? drivers/char/synclinkmp.c:4322:6: warning: symbol 'tx_load_fifo' was not declared. Should it be static? drivers/char/synclinkmp.c:4371:6: warning: symbol 'reset_port' was not declared. Should it be static? drivers/char/synclinkmp.c:4395:6: warning: symbol 'reset_adapter' was not declared. Should it be static? drivers/char/synclinkmp.c:4407:6: warning: symbol 'async_mode' was not declared. Should it be static? drivers/char/synclinkmp.c:4546:6: warning: symbol 'hdlc_mode' was not declared. Should it be static? drivers/char/synclinkmp.c:4748:6: warning: symbol 'tx_set_idle' was not declared. Should it be static? drivers/char/synclinkmp.c:4768:6: warning: symbol 'get_signals' was not declared. Should it be static? drivers/char/synclinkmp.c:4797:6: warning: symbol 'set_signals' was not declared. Should it be static? drivers/char/synclinkmp.c:4826:6: warning: symbol 'rx_reset_buffers' was not declared. Should it be static? drivers/char/synclinkmp.c:4837:6: warning: symbol 'rx_free_frame_buffers' was not declared. Should it be static? drivers/char/synclinkmp.c:4865:5: warning: symbol 'rx_get_frame' was not declared. Should it be static? drivers/char/synclinkmp.c:5040:6: warning: symbol 'tx_load_dma_buffer' was not declared. Should it be static? drivers/char/synclinkmp.c:5080:5: warning: symbol 'register_test' was not declared. Should it be static? drivers/char/synclinkmp.c:5119:5: warning: symbol 'irq_test' was not declared. Should it be static? drivers/char/synclinkmp.c:5211:5: warning: symbol 'init_adapter' was not declared. Should it be static? drivers/char/synclinkmp.c:5270:5: warning: symbol 'loopback_test' was not declared. Should it be static? drivers/char/synclinkmp.c:5335:5: warning: symbol 'adapter_test' was not declared. Should it be static? drivers/char/synclinkmp.c:5397:5: warning: symbol 'memory_test' was not declared. Should it be static? drivers/char/synclinkmp.c:5449:6: warning: symbol 'load_pci_memory' was not declared. Should it be static? drivers/char/synclinkmp.c:5468:6: warning: symbol 'trace_block' was not declared. Should it be static? drivers/char/synclinkmp.c:5503:6: warning: symbol 'tx_timeout' was not declared. Should it be static? drivers/char/synclinkmp.c:5530:6: warning: symbol 'status_timeout' was not declared. Should it be static? drivers/char/synclinkmp.c:5581:15: warning: symbol 'read_reg' was not declared. Should it be static? drivers/char/synclinkmp.c:5586:6: warning: symbol 'write_reg' was not declared. Should it be static? drivers/char/synclinkmp.c:5592:5: warning: symbol 'read_reg16' was not declared. Should it be static? drivers/char/synclinkmp.c:5598:6: warning: symbol 'write_reg16' was not declared. Should it be static? drivers/char/synclinkmp.c:5604:15: warning: symbol 'read_status_reg' was not declared. Should it be static? drivers/char/synclinkmp.c:5610:6: warning: symbol 'write_control_reg' was not declared. Should it be static? Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28synclink drivers bool conversionJoe Perches
Remove more TRUE/FALSE defines and uses Remove == TRUE tests Convert BOOLEAN to bool Convert int to bool where appropriate Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-20drivers/char: minor irq handler cleanupsJeff Garzik
- remove always-false tests - don't overload 'irq' argument, pass data properly via dev_id - remove pointless casts from void* Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-06synclink: standardize format of linux header file include's with "<>"Robert P. J. Day
Use the recommended form of "<>" to include linux header files, and move those includes up to join the rest of the linux includes. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16synclink: remove bogus 'no change' termios optimisation from synclink driversAlan Cox
Again this check is wrong now, and un-needed Signed-off-by: Alan Cox <alan@redhat.com> Cc: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] Char: timers cleanupJiri Slaby
- Use timer macros to set function and data members and to modify expiration time. - Use DEFINE_TIMER for global timers and do not init them at run-time in these cases. - del_timer_sync is common in most cases -- we want to wait for timer function if it's still running. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Cc: Wim Van Sebroeck <wim@iguana.be> Acked-by: Dmitry Torokhov <dtor@mail.ru> (Input bits) Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Char: tty_wakeup cleanupJiri Slaby
tty_wakeup cleanup - remove wake_up_interruptible(&tty->write_wait) surrounding tty_wakup(tty); - substitute tty->ldisc.write_wakeup(tty) + wake_up() by tty_wakeup(tty); Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] generic HDLC synclink config mismatch fixPaul Fulghum
Fix compile errors on mismatch between generic HDLC and synclink drivers. Notes: generic HDLC support for synclink drivers is *optional* so you can't just use depend on in Kconfig This solution is deemed the best after 7 months of review and criticism by many developers including AKPM. Read the threads on LKML before posting about this solution. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-02[PATCH] const struct tty_operationsJeff Dike
As part of an SMP cleanliness pass over UML, I consted a bunch of structures in order to not have to document their locking. One of these structures was a struct tty_operations. In order to const it in UML without introducing compiler complaints, the declaration of tty_set_operations needs to be changed, and then all of its callers need to be fixed. This patch declares all struct tty_operations in the tree as const. In all cases, they are static and used only as input to tty_set_operations. As an extra check, I ran an i386 allyesconfig build which produced no extra warnings. 53 drivers are affected. I checked the history of a bunch of them, and in most cases, there have been only a handful of maintenance changes in the last six months. serial_core.c was the busiest one that I looked at. Signed-off-by: Jeff Dike <jdike@addtoit.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-21[WAN]: Converted synclink drivers to use netif_carrier_*()Krzysztof Halasa
WAN: Converted synclink drivers to use netif_carrier_*() instead of hdlc_set_carrier(). Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-02[PATCH] irq-flags: drivers/char: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] More !tty cleanups in drivers/charEric Sesterhenn
Another bunch of checks in the char drivers .put_char() and .write() routines, where tty can never be NULL. This patch removes these checks to save some code. Coverity choked at those with the following bug ids: isicom.c 767, 766 specialix.c 773, 774 synclink_cs.c 779, 781 synclink_gt.c 784, 785 synclinkmp.c 784, 785 Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Cc: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] s/;;/;/gAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] TTY layer buffering revampAlan Cox
The API and code have been through various bits of initial review by serial driver people but they definitely need to live somewhere for a while so the unconverted drivers can get knocked into shape, existing drivers that have been updated can be better tuned and bugs whacked out. This replaces the tty flip buffers with kmalloc objects in rings. In the normal situation for an IRQ driven serial port at typical speeds the behaviour is pretty much the same, two buffers end up allocated and the kernel cycles between them as before. When there are delays or at high speed we now behave far better as the buffer pool can grow a bit rather than lose characters. This also means that we can operate at higher speeds reliably. For drivers that receive characters in blocks (DMA based, USB and especially virtualisation) the layer allows a lot of driver specific code that works around the tty layer with private secondary queues to be removed. The IBM folks need this sort of layer, the smart serial port people do, the virtualisers do (because a virtualised tty typically operates at infinite speed rather than emulating 9600 baud). Finally many drivers had invalid and unsafe attempts to avoid buffer overflows by directly invoking tty methods extracted out of the innards of work queue structs. These are no longer needed and all go away. That fixes various random hangs with serial ports on overflow. The other change in here is to optimise the receive_room path that is used by some callers. It turns out that only one ldisc uses receive room except asa constant and it updates it far far less than the value is read. We thus make it a variable not a function call. I expect the code to contain bugs due to the size alone but I'll be watching and squashing them and feeding out new patches as it goes. Because the buffers now dynamically expand you should only run out of buffering when the kernel runs out of memory for real. That means a lot of the horrible hacks high performance drivers used to do just aren't needed any more. Description: tty_insert_flip_char is an old API and continues to work as before, as does tty_flip_buffer_push() [this is why many drivers dont need modification]. It does now also return the number of chars inserted There are also tty_buffer_request_room(tty, len) which asks for a buffer block of the length requested and returns the space found. This improves efficiency with hardware that knows how much to transfer. and tty_insert_flip_string_flags(tty, str, flags, len) to insert a string of characters and flags For a smart interface the usual code is len = tty_request_buffer_room(tty, amount_hardware_says); tty_insert_flip_string(tty, buffer_from_card, len); More description! At the moment tty buffers are attached directly to the tty. This is causing a lot of the problems related to tty layer locking, also problems at high speed and also with bursty data (such as occurs in virtualised environments) I'm working on ripping out the flip buffers and replacing them with a pool of dynamically allocated buffers. This allows both for old style "byte I/O" devices and also helps virtualisation and smart devices where large blocks of data suddenely materialise and need storing. So far so good. Lots of drivers reference tty->flip.*. Several of them also call directly and unsafely into function pointers it provides. This will all break. Most drivers can use tty_insert_flip_char which can be kept as an API but others need more. At the moment I've added the following interfaces, if people think more will be needed now is a good time to say int tty_buffer_request_room(tty, size) Try and ensure at least size bytes are available, returns actual room (may be zero). At the moment it just uses the flipbuf space but that will change. Repeated calls without characters being added are not cumulative. (ie if you call it with 1, 1, 1, and then 4 you'll have four characters of space. The other functions will also try and grow buffers in future but this will be a more efficient way when you know block sizes. int tty_insert_flip_char(tty, ch, flag) As before insert a character if there is room. Now returns 1 for success, 0 for failure. int tty_insert_flip_string(tty, str, len) Insert a block of non error characters. Returns the number inserted. int tty_prepare_flip_string(tty, strptr, len) Adjust the buffer to allow len characters to be added. Returns a buffer pointer in strptr and the length available. This allows for hardware that needs to use functions like insl or mencpy_fromio. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] drivers/char: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of ARRAY_SIZE. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-10[PATCH] PCI: removed unneeded .owner field from struct pci_driverGreg Kroah-Hartman
2005-11-07[PATCH] kfree cleanup: drivers/charJesper Juhl
This is the drivers/char/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in drivers/char/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] SyncLink adapters: updates .owner field of struct pci_driverLaurent Riffard
This updates .owner field of struct pci_driver. This allows SYSFS to create the symlink from the driver to the module which provides it. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Cc: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] synclinkmp.c: fix async internal loopbackPaul Fulghum
Fix async internal loopback by not using enable_loopback function which reprograms clocking and should only be used for hdlc mode. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] synclinkmp.c: add statistics clearPaul Fulghum
Add ability to clear statistics. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] synclinkmp.c: disable burst transfersPaul Fulghum
Disable burst transfers on adapter local bus. Hardware feature does not work on latest version of adapter. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] synclinkmp.c: fix double mapping of signalsPaul Fulghum
Serial signals were incorrectly mapped twice to events. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] gratuitous includes of asm/serial.hviro@ZenIV.linux.org.uk
Removed gratuitous includes of asm/serial.h in synklinkmp and ip2main. Allows to remove the rest of "broken on sparc32" in drivers/char - this stuff doesn't break the build anymore. Since it got zero testing, it almost certainly won't work there, though... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
