path: root/drivers/char/tpm
2009-09-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: SELinux: do not destroy the avc_cache_nodep KEYS: Have the garbage collector set its timer for live expired keys tpm-fixup-pcrs-sysfs-file-update creds_are_invalid() needs to be exported for use by modules: include/linux/cred.h: fix build Fix trivial BUILD_BUG_ON-induced conflicts in drivers/char/tpm/tpm.c
2009-09-23tpm-fixup-pcrs-sysfs-file-updateJason Gunthorpe
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Cc: Debora Velarde <debora@linux.vnet.ibm.com> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: Marcel Selhorst <m.selhorst@sirrix.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-23BUILD_BUG_ON(): fix it and a couple of bogus uses of itJan Beulich
gcc permitting variable length arrays makes the current construct used for BUILD_BUG_ON() useless, as that doesn't produce any diagnostic if the controlling expression isn't really constant. Instead, this patch makes it so that a bit field gets used here. Consequently, those uses where the condition isn't really constant now also need fixing. Note that in the gfp.h, kmemcheck.h, and virtio_config.h cases MAYBE_BUILD_BUG_ON() really just serves documentation purposes - even if the expression is compile time constant (__builtin_constant_p() yields true), the array is still deemed of variable length by gcc, and hence the whole expression doesn't have the intended effect. [akpm@linux-foundation.org: make arch/sparc/include/asm/vio.h compile] [akpm@linux-foundation.org: more nonsensical assertions in tpm.c..] Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: Mimi Zohar <zohar@us.ibm.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23seq_file: constify seq_operationsJames Morris
Make all seq_operations structs const, to help mitigate against revectoring user-triggerable function pointers. This is derived from the grsecurity patch, although generated from scratch because it's simpler than extracting the changes from there. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-10TPM: Fixup boot probe timeout for tpm_tis driverJason Gunthorpe
When probing the device in tpm_tis_init the call request_locality uses timeout_a, which wasn't being initalized until after request_locality. This results in request_locality falsely timing out if the chip is still starting. Move the initialization to before request_locality. This probably only matters for embedded cases (ie mine), a BIOS likely gets the TPM into a state where this code path isn't necessary. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Acked-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-20TPM: get_event_name stack corruptionEric Paris
get_event_name uses sprintf to fill a buffer declared on the stack. It fills the buffer 2 bytes at a time. What the code doesn't take into account is that sprintf(buf, "%02x", data) actually writes 3 bytes. 2 bytes for the data and then it nul terminates the string. Since we declare buf to be 40 characters long and then we write 40 bytes of data into buf sprintf is going to write 41 characters. The fix is to leave room in buf for the nul terminator. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (61 commits) Dynamic debug: fix pr_fmt() build error Dynamic debug: allow simple quoting of words dynamic debug: update docs dynamic debug: combine dprintk and dynamic printk sysfs: fix some bin_vm_ops errors kobject: don't block for each kobject_uevent sysfs: only allow one scheduled removal callback per kobj Driver core: Fix device_move() vs. dpm list ordering, v2 Driver core: some cleanup on drivers/base/sys.c Driver core: implement uevent suppress in kobject vcs: hook sysfs devices into object lifetime instead of "binding" driver core: fix passing platform_data driver core: move platform_data into platform_device sysfs: don't block indefinitely for unmapped files. driver core: move knode_bus into private structure driver core: move knode_driver into private structure driver core: move klist_children into private structure driver core: create a private portion of struct device driver core: remove polling for driver_probe_done(v5) sysfs: reference sysfs_dirent from sysfs inodes ... Fixed conflicts in drivers/sh/maple/maple.c manually
2009-03-24platform driver: fix incorrect use of 'platform_bus_type' with 'struct ↵Ming Lei
device_driver' This patch fixes the bug reported in http://bugzilla.kernel.org/show_bug.cgi?id=11681. "Lots of device drivers register a 'struct device_driver' with the '.bus' member set to '&platform_bus_type'. This is wrong, since the platform_bus functions expect the 'struct device_driver' to be wrapped up in a 'struct platform_driver' which provides some additional callbacks (like suspend_late, resume_early). The effect may be that platform_suspend_late() uses bogus data outside the device_driver struct as a pointer pointer to the device driver's suspend_late() function or other hard to reproduce failures."(Lothar Wassmann) Signed-off-by: Ming Lei <tom.leiming@gmail.com> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24Merge branch 'master' into nextJames Morris
2009-02-11tpm: correct email address for tpm_infineon-driverMarcel Selhorst
Update my email address. Signed-off-by: Marcel Selhorst <m.selhorst@sirrix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-06Merge branch 'master' into nextJames Morris
Conflicts: fs/namei.c Manually merged per: diff --cc fs/namei.c index 734f2b5,bbc15c2..0000000 --- a/fs/namei.c +++ b/fs/namei.c @@@ -860,9 -848,8 +849,10 @@@ static int __link_path_walk(const char nd->flags |= LOOKUP_CONTINUE; err = exec_permission_lite(inode); if (err == -EAGAIN) - err = vfs_permission(nd, MAY_EXEC); + err = inode_permission(nd->path.dentry->d_inode, + MAY_EXEC); + if (!err) + err = ima_path_check(&nd->path, MAY_EXEC); if (err) break; @@@ -1525,14 -1506,9 +1509,14 @@@ int may_open(struct path *path, int acc flag &= ~O_TRUNC; } - error = vfs_permission(nd, acc_mode); + error = inode_permission(inode, acc_mode); if (error) return error; + - error = ima_path_check(&nd->path, ++ error = ima_path_check(path, + acc_mode & (MAY_READ | MAY_WRITE | MAY_EXEC)); + if (error) + return error; /* * An append-only file must be opened in append mode for writing. */ Signed-off-by: James Morris <jmorris@namei.org>
2009-02-06TPM: integrity fixRajiv Andrade
Fix to function which is called by IMA, now tpm_chip_find_get() considers the case in which the machine doesn't have a TPM or, if it has, its TPM isn't enabled. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-02-03TPM: integrity interfaceRajiv Andrade
This patch adds internal kernel support for: - reading/extending a pcr value - looking up the tpm_chip for a given chip number Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-02-03TPM: sysfs functions consolidationRajiv Andrade
According to Dave Hansen's comments on the tpm_show_*, some of these functions present a pattern when allocating data[] memory space and also when setting its content. A new function was created so that this pattern could be consolidated. Also, replaced the data[] command vectors and its indexes by meaningful structures as pointed out by Matt Helsley too. Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-01-09Merge branch 'linus' into releaseLen Brown
2009-01-08tpm: clean up tpm_nsc driver for platform_device suspend/resume complianceDavid Smith
Signed-off-by: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-31ACPI: remove private acpica headers from driver filesLin Ming
External driver files should not include any private acpica headers. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-20tpm: don't export static functionsStephen Rothwell
Today's linux-next build (powerpc_allyesconfig) failed like this: drivers/char/tpm/tpm.c:1162: error: __ksymtab_tpm_dev_release causes a section type conflict Caused by commit 253115b71fa06330bd58afbe01ccaf763a8a0cf1 ("The tpm_dev_release function is only called for platform devices, not pnp") which exported a static function. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16drivers/char/tpm/tpm.c: fix error-path memory leakAndrew Morton
tpm_register_hardware() leaks devname on an error path. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=11425 Reported-by: Daniel Marjamki <danielm77@spray.se> Cc: Debora Velarde <debora@linux.vnet.ibm.com> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16tpm: work around bug in Broadcom BCM0102 chipsetValdis Kletnieks
Patch tpm-correct-tpm-timeouts-to-jiffies-conversion reveals a bug in the Broadcom BCM0102 TPM chipset used in the Dell Latitude D820 - although most of the timeouts are returned in usecs as per the spec, one is apparently returned in msecs, which results in a too-small value leading to a timeout when the code treats it as usecs. To prevent a regression, we check for the known too-short value and adjust it to a value that makes things work. Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Cc: Marcin Obara <marcin_obara@users.sourceforge.net> Cc: Marcel Selhorst <tpm@selhorst.net> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16tpm: correct tpm timeouts to jiffies conversionMarcin Obara
This patch fixes timeouts conversion to jiffies, by replacing msecs_to_jiffies() calls with usecs_to_jiffies(). According to TCG TPM Specification Version 1.2 Revision 103 (pages 166, 167) TPM timeouts and durations are returned in microseconds (usec) not in miliseconds (msec). This fixes a long hang while loading TPM driver, if TPM chip starts in "Idle" state instead of "Ready" state. Without this patch - 'modprobe' may hang for 30 seconds or more. Signed-off-by: Marcin Obara <marcin_obara@users.sourceforge.net> Cc: Marcel Selhorst <tpm@selhorst.net> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-11As pointed out by Jonathan Corbet, the timer must be deleted beforeRajiv Andrade
flushing the work queue in order to avoid a job being submitted after the chip had been released. Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-11The tpm_dev_release function is only called for platform devices, not pnpRajiv Andrade
devices, so we implemented the .remove function for pnp ones. Since it's code is very similar to the one inside tpm_dev_release, we've created a helper function tpm_dev_vendor_release, which is called by both. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-11Protect tpm_chip_list when transversing it.Rajiv Andrade
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-11Renames num_open to is_open, as only one process can open the file at a time.Rajiv Andrade
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-11Remove the BKL calls from the TPM driver, which were added in the overallRajiv Andrade
misc-char-dev-BKL-pushdown.patch, as they are not needed. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-08-28securityfs: do not depend on CONFIG_SECURITYEric Paris
Add a new Kconfig option SECURITYFS which will build securityfs support but does not require CONFIG_SECURITY. The only current user of securityfs does not depend on CONFIG_SECURITY and there is no reason the full LSM needs to be built to build this fs. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-07-26tpm: Use correct data types for sizes in tpm_write() and tpm_read()Michael Halcrow
Use the correct data types for the size parameters in tpm_write() and tpm_read(). Note that rw_verify_area() makes sure that this bug cannot be exploited to produce a buffer overrun. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26tpm: increase size of internal TPM response buffersMarcin Obara
This patch increases size of driver internal response buffers. Some TPM responses defined in TCG TPM Specification Version 1.2 Revision 103 have increased size and do not fit previously defined buffers. Some TPM responses do not have fixed size, so bigger response buffers have to be allocated. 200B buffers should be enough. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Marcin Obara <marcin_obara@users.sourceforge.net> Cc: Marcel Selhorst <tpm@selhorst.net> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26tpm_bios.c: make 2 structs staticAdrian Bunk
This patch makes two needlessly global structs static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26tpm: add support for Broadcom TPM TIS device HIDLE DISEZ Erwan
Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-07-10tpm: add Intel TPM TIS device HIDMarcin Obara
This patch adds Intel TPM TIS device HID: ICO0102 Signed-off-by: Marcin Obara <marcin_obara@users.sourceforge.net> Acked-by: Marcel Selhorst <tpm@selhorst.net> Acked-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-02tpm-tpm: BKL pushdownArnd Bergmann
2008-04-29tpm: change Kconfig dependencies from PNPACPI to PNPBjorn Helgaas
There is no "PNPACPI" driver interface as such. PNPACPI is an internal backend of PNP, and drivers just use the generic PNP interface. The drivers should depend on CONFIG_PNP, not CONFIG_PNPACPI. tpm_nsc.c doesn't use PNP at all, so we can just remove the dependency completely. It probably *should* use PNP to discover the device, but until it does, there's no point in depending on PNP. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Cc: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29tpm: fix section mismatch warningSam Ravnborg
Fix following warning: WARNING: vmlinux.o(.init.text+0x32804): Section mismatch in reference from the function init_nsc() to the function .devexit.text:tpm_nsc_remove() The function tpm_nsc_remove() are used outside __exit, so remove the __exit annotation to make sure the function is always avilable. Note: Trying to compare this module with other users of platform_device gve me the impression that this driver needs some work to match other users. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Kylene Hall <kjhall@us.ibm.com> Cc: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-20drivers/char: minor irq handler cleanupsJeff Garzik
- remove always-false tests - don't overload 'irq' argument, pass data properly via dev_id - remove pointless casts from void* Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-06tpm: infineon section mismatchRandy Dunlap
Fix section mismatch by making the driver template variable name match one of the whitelisted variable names in modpost. WARNING: vmlinux.o(.data+0x7a9e8): Section mismatch: reference to .init.text:tpm_inf_pnp_probe (between 'tpm_inf_pnp' and 'cn_idx') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Marcel Selhorst <tpm@selhorst.net> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06tpm.c: fix crash during device removalRichard MUSIL
The clean up procedure now uses platform device "release" callback to handle memory clean up. For this purpose "release" function callback was added to struct tpm_vendor_specific, so hw device driver provider can get called when it is safe to remove all allocated resources. This is supposed to fix a bug in device removal, where device while in receive function (waiting on timeout) was prone to segfault, if the tpm_chip struct was unallocated before the timeout expired (in tpm_remove_hardware). Acked-by: Marcel Selhorst <tpm@selhorst.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-14TPM: fix suspend and resume failureDavid Smith
The savestate command structure was being overwritten by the result of running the TPM_SaveState command after one run, so make it a local variable to the function instead of a global variable that gets overwritten. Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Kent Yoder <shpedoikal@gmail.com> Cc: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29TPM: fix TIS device driver locality requestMarcel Selhorst
During the initialization of the TPM TIS driver, the necessary locality has to be requested earlier in the init-process. Depending on the used TPM chip, this leads to wrong information. For example: Lenovo X61s with Atmel TPM: tpm_tis 00:0a: 1.2 TPM (device-id 0xFFFF, rev-id 255) But correct is: tpm_tis 00:0c: 1.2 TPM (device-id 0x3203, rev-id 9) This short patch fixes this issue. Signed-off-by: Marcel Selhorst <tpm@selhorst.net> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-23Eliminate pointless casts from void* in a few driver irq handlers.Jeff Garzik
2007-10-17tpm: pay attention to IRQ info from PNPBjorn Helgaas
If we discover the TIS TPM device via PNP, use the PNP IRQ information rather than probing for an IRQ. If PNP shows no IRQ, run the TPM in polling mode. Tested-by: <valdis.kletnieks@vt.edu> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Kylene Hall <kjhall@us.ibm.com> Cc: <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22tpmdd maintainersKent Yoder
Fix up the maintainers info in the tpm drivers. Kylene will be out for some time, so copying the sourceforge list is the best way to get some attention. Cc: Marcel Selhorst <tpm@selhorst.net> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20Fix memory leak in tpm_binary_bios_measurements_open()Reiner Sailer
The same problem that was fixed for tpm_ascii_bios_measurements_open() in commit 178554ae75739e91dc4d7c3e42a3db95448cc5bf also occurs in tpm_binary_bios measurements(). Thanks for noticing this Satyam! I tested the attached patch to fix tpm_binary_bios_measurments as well. Signed-off-by: Reiner Sailer <sailer@watson.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20Memory leak in tpm_ascii_bios_measurements_open()Jesper Juhl
Coverity found a memory leak in tpm_ascii_bios_measurements_open(). If "read_log(log)" fails, then we may leak 'log' and 'log->bios_event_log'. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: Seiji Munetoh <munetoh@jp.ibm.com> Cc: Stefan Berger <stefanb@us.ibm.com> Cc: Reiner Sailer <sailer@watson.ibm.com> Cc: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Use menuconfig objects II - TPMJan Engelhardt
Change Kconfig objects from "menu, config" into "menuconfig" so that the user can disable the whole feature without having to enter the menu first. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Cc: Kylene Hall <kjhall@us.ibm.com> Cc: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-12Missing include file in tpm_atmel.hStephen Rothwell
On PPC64, we need to include asm/prom.h for function definitions. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10[S390] Kconfig: menus with depends on HAS_IOMEM.Martin Schwidefsky
Add "depends on HAS_IOMEM" to a number of menus to make them disappear for s390 which does not have I/O memory. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
