path: root/drivers/char/tty_buffer.c
2010-11-05TTY: create drivers/tty and move the tty core files thereGreg Kroah-Hartman
The tty code should be in its own subdirectory and not in the char driver with all of the cruft that is currently there. Based on work done by Arnd Bergmann <arnd@arndb.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21tty: fix obsolete comment on tty_insert_flip_string_fixed_flagJohan Hovold
Comment was not updated when tty_insert_flip_string was generalised. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19tty_buffer: Fix distinct type warningFang Wenqi
CC drivers/char/tty_buffer.o drivers/char/tty_buffer.c: In function ‘tty_insert_flip_string_fixed_flag’: drivers/char/tty_buffer.c:251: warning: comparison of distinct pointer types lacks a cast drivers/char/tty_buffer.c: In function ‘tty_insert_flip_string_flags’: drivers/char/tty_buffer.c:288: warning: comparison of distinct pointer types lacks a cast Fix it by replacing min() with min_t() in tty_insert_flip_string_flags and tty_insert_flip_string_fixed_flag(). Signed-off-by: Fang Wenqi <antonf@turbolinux.com.cn> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (220 commits) USB: backlight, appledisplay: fix incomplete registration failure handling USB: pl2303: remove unnecessary reset of usb_device in urbs USB: ftdi_sio: remove obsolete check in unthrottle USB: ftdi_sio: remove unused tx_bytes counter USB: qcaux: driver for auxiliary serial ports on Qualcomm devices USB: pl2303: initial TIOCGSERIAL support USB: option: add Longcheer/Longsung vendor ID USB: fix I2C API usage in ohci-pnx4008. USB: usbmon: mask seconds properly in text API USB: sisusbvga: no unnecessary GFP_ATOMIC USB: storage: onetouch: unnecessary GFP_ATOMIC USB: serial: ftdi: add CONTEC vendor and product id USB: remove references to port->port.count from the serial drivers USB: tty: Prune uses of tty_request_room in the USB layer USB: tty: Add a function to insert a string of characters with the same flag USB: don't read past config->interface[] if usb_control_msg() fails in usb_reset_configuration() USB: tty: kill request_room for USB ACM class USB: tty: sort out the request_room handling for whiteheat USB: storage: fix misplaced parenthesis USB: vstusb.c: removal of driver for Vernier Software & Technology, Inc., devices and spectrometers ...
2010-03-02USB: tty: Add a function to insert a string of characters with the same flagAlan Cox
The USB drivers often want to insert a series of bytes all with the same flag set - provide a helper for this case. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02tty: Keep the default buffering to sub-page unitsAlan Cox
We allocate during interrupts so while our buffering is normally diced up small anyway on some hardware at speed we can pressure the VM excessively for page pairs. We don't really need big buffers to be linear so don't try so hard. In order to make this work well we will tidy up excess callers to request_room, which cannot itself enforce this break up. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-14tty: use the new 'flush_delayed_work()' helper to do ldisc flushLinus Torvalds
This way all flush_to_ldisc work is always done through the workqueues, and we thus have a single point of serialization. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-14Make flush_to_ldisc properly handle parallel callsLinus Torvalds
2009-07-29pty: avoid forcing 'low_latency' tty flagOGAWA Hirofumi
We really don't want to mark the pty as a low-latency device, because as Alan points out, the ->write method can be called from an IRQ (ppp?), and that means we can't use ->low_latency=1 as we take mutexes in the low_latency case. So rather than using low_latency to force the written data to be pushed to the ldisc handling at 'write()' time, just make the reader side (or the poll function) do the flush when it checks whether there is data to be had. This also fixes the problem with lost data in an emacs compile buffer (bugzilla 13815), and we can thus revert the low_latency pty hack (commit 3a54297478e6578f96fd54bf4daa1751130aca86: "pty: quickfix for the pty ENXIO timing problems"). Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Tested-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> [ Modified to do the tty_flush_to_ldisc() inside input_available_p() so that it triggers for both read and poll() - Linus] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: split the buffering from tty_ioAlan Cox
The two are basically independent chunks of code so lets split them up for readability and sanity. It also makes the API boundaries much clearer. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
