path: root/drivers/char/tty_io.c
2009-06-16tty: fix sanity checkAlan Cox
The WARN_ON() that was added to tty_reopen can be triggered in the specific case of a hangup occurring during a re-open of a tty which is not in the middle of being otherwise closed. In that case however the WARN() is bogus as we don't hold the neccessary locks to make a correct decision. The case we should be checking is "if the ldisc is not changing and reopen is occuring". We could drop the WARN_ON but for the moment the debug is more valuable even if it means taking a mutex as it will find any other cases. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11tty: Move ldisc_flushAlan Cox
We have a tty_ldisc file now so put tty_ldisc_flush in the right place Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11tty: rewrite the ldisc lockingAlan Cox
There are several pretty much unfixable races in the old ldisc code, especially with respect to pty behaviour and also to hangup. It's easier to rewrite the code than simply try and patch it up. This patch - splits the ldisc from the tty (so we will be able to refcount it more cleanly later) - introduces a mutex lock for ldisc changing on an active device - fixes the complete mess that hangup caused - implements hopefully correct setldisc/close/hangup locking There are still some problems around pty pairs that have always been there but at least it is now possible to understand the code and fix further problems. This fixes the following known bugs - hang up can leak ldisc references - hang up may not call open/close on ldisc in a matched way - pty/tty pairs can deadlock during an ldisc change - reading the ldisc proc files can cause every ldisc to be loaded and probably a few other of the mysterious ldisc race reports. I'm sure it also adds the odd new one. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11tty: Extract various bits of ldisc codeAlan Cox
Before trying to tackle the ldisc bugs the code needs to be a good deal more readable, so do the simple extractions of routines first. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11tty: Fix oops when scanning the polling list for kgdbAlan Cox
Costantino Leandro found a bug in tty_find_polling_driver and provided a patch that fixed the crash but not the underlying bug. This fixes the underlying bug where the list walk corrupts the values it is using on a match but then reuses them if the open fails. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02pids: kill signal_struct-> __pgrp/__session and friendsOleg Nesterov
We are wasting 2 words in signal_struct without any reason to implement task_pgrp_nr() and task_session_nr(). task_session_nr() has no callers since 2e2ba22ea4fd4bb85f0fa37c521066db6775cbef, we can remove it. task_pgrp_nr() is still (I believe wrongly) used in fs/autofsX and fs/coda. This patch reimplements task_pgrp_nr() via task_pgrp_nr_ns(), and kills __pgrp/__session and the related helpers. The change in drivers/char/tty_io.c is cosmetic, but hopefully makes sense anyway. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Alan Cox <number6@the-village.bc.nu> [tty parts] Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02__tty_open(): use the correct type for saved_flagsAndrew Morton
filp->f_flags is unsigned, so use that type for the local copy. Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01epoll keyed wakeups: make tty use keyed wakeupsDavide Libenzi
Introduce keyed event wakeups inside the TTY code. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: William Lee Irwin III <wli@movementarian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-16Use f_lock to protect f_flagsJonathan Corbet
Traditionally, changes to struct file->f_flags have been done under BKL protection, or with no protection at all. This patch causes all f_flags changes after file open/creation time to be done under protection of f_lock. This allows the removal of some BKL usage and fixes a number of longstanding (if microscopic) races. Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-01-27tty_open can return to userspace holding tty_mutexEric Paris
__tty_open could return (to userspace) holding the tty_mutex thanks to a regression introduced by 4a2b5fddd53b80efcb3266ee36e23b8de28e761a ("Move tty lookup/reopen to caller"). This was found by bisecting an fsfuzzer problem. Admittedly I have no idea how it managed to tickle this 100% reliably, but it is clearly a regression and when hit leaves the box in a completely unusable state. This patch lets the fsfuzzer test complete every time. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02pty: simplify resizeAlan Cox
We have special case logic for resizing pty/tty pairs. We also have a per driver resize method so for the pty case we should use it. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02tty: Fix sparse static warning for tty_driver_lookup_ttyJason Wessel
Fixed sparse warning: drivers/char/tty_io.c:1216:19: warning: symbol 'tty_driver_lookup_tty' was not declared. Should it be static? Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02n_tty: Fix loss of echoed characters and remove bkl from n_ttyJoe Peterson
Fixes the loss of echoed (and other ldisc-generated characters) when the tty is stopped or when the driver output buffer is full (happens frequently for input during continuous program output, such as ^C) and removes the Big Kernel Lock from the N_TTY line discipline. Adds an "echo buffer" to the N_TTY line discipline that handles all ldisc-generated output (including echoed characters). Along with the loss of characters, this also fixes the associated loss of sync between tty output and the ldisc state when characters cannot be immediately written to the tty driver. The echo buffer stores (in addition to characters) state operations that need to be done at the time of character output (like management of the column position). This allows echo to cooperate correctly with program output, since the ldisc state remains consistent with actual characters written. Since the echo buffer code now isolates the tty column state code to the process_out* and process_echoes functions, we can remove the Big Kernel Lock (BKL) and replace it with mutex locks. Highlights are: * Handles echo (and other ldisc output) when tty driver buffer is full - continuous program output can block echo * Saves echo when tty is in stopped state (e.g. ^S) - (e.g.: ^Q will correctly cause held characters to be released for output) * Control character pairs (e.g. "^C") are treated atomically and not split up by interleaved program output * Line discipline state is kept consistent with characters sent to the tty driver * Remove the big kernel lock (BKL) from N_TTY line discipline Signed-off-by: Joe Peterson <joe@skyrush.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-09Audit: Log TIOCSTIAl Viro
AUDIT_TTY records currently log all data read by processes marked for TTY input auditing, even if the data was "pushed back" using the TIOCSTI ioctl, not typed by the user. This patch records all TIOCSTI calls to disambiguate the input. It generates one audit message per character pushed back; considering TIOCSTI is used very rarely, this simple solution is probably good enough. (The only program I could find that uses TIOCSTI is mailx/nail in "header editing" mode, e.g. using the ~h escape. mailx is used very rarely, and the escapes are used even rarer.) Signed-Off-By: Miloslav Trmac <mitr@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Morris <jmorris@namei.org>
2008-12-01drivers/char/tty_io.c: Avoid panic when no console is configured.Will Newton
When no console is configured tty_open tries to call kref_get on a NULL pointer, return ENODEV instead. Signed-off-by: Will Newton <will.newton@gmail.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16device create: char: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-15tty: make sure that proc_clear_tty stores the cpu flagsArjan van de Ven
proc_clear_tty() gets called with interrupts off (while holding the task list lock) from sys_setid. This means that it needs the _irqsave version of the locking primitives. Reported-by: Marcin Slusarz <marcin.slusarz@gmail.com> Tested-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: tty_io.c shadows sparse fixJason Wessel
drivers/char/tty_io.c:1413:17: warning: symbol 'buf' shadows an earlier one drivers/char/tty_io.c:1379:20: originally declared here Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: simplify ktermios allocationAlan Cox
Copy the simplification from the pty unix98 special case to the generic one. This allows us to kill off driver->termios_locked entirely which is nice. We have to whack bits of the cris driver as it meddles in places it shouldn't providing its own arrays that were never used anyway. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13Add an instance parameter devpts interfacesSukadev Bhattiprolu
Pass-in 'inode' or 'tty' parameter to devpts interfaces. With multiple devpts instances, these parameters will be used in subsequent patches to identify the instance of devpts mounted. The parameters also help simplify devpts implementation. Changelog[v3]: - minor changes due to merge with ttydev updates - rename parameters to emphasize they are ptmx or pts inodes - pass-in tty_struct * to devpts_pty_kill() (this will help cleanup the get_node() call in a subsequent patch) Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13Move tty lookup/reopen to callerSukadev Bhattiprolu
Move tty_driver_lookup_tty() and tty_reopen() from tty_init_dev() into tty_open() (one of the two callers of tty_init_dev()). These calls are not really required in ptmx_open(), the other caller, since ptmx_open() would be setting up a new tty. Changelog[v2]: - remove the lookup and reopen calls from ptmx_open - merge with recent changes to ttydev tree Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: extract the pty init time special casesAlan Cox
The majority of the remaining init_dev code is pty special cases. We refactor this code into the driver->install method. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Finish fixing up the init_dev interface to use ERR_PTRAlan Cox
Original suggestion and proposal from Sukadev Bhattiprolu. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: More driver operationsAlan Cox
We have the lookup operation abstracted which is nice for pty cleanup but we really want to abstract the add/remove entries as well so that we can pull the pty code out of the tty core and create a clear defined interface for the tty driver table. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: kref the tty driver objectAlan Cox
2008-10-13tty: Clean up the tty_init_dev changes furtherAlan Cox
Fix up the naming, style and extract some bits of code into the driver specific code Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Move parts of tty_init_dev into new functionsSukadev Bhattiprolu
Move the 'find-tty' and 'fast-track-open' parts of init_dev() to separate functions. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Remove more special casing and out of place codeAlan Cox
Carry on pushing code out of tty_io when it belongs to other drivers. I'm not 100% happy with some of this and it will be worth revisiting some of the exports later when the restructuring work is done. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: shutdown methodAlan Cox
Right now there are various drivers that try to use tty->count to know when they get the final close. Aristeau Rozanski showed while debugging the vt sysfs race that this isn't entirely safe. Instead of driver side tricks to work around this introduce a shutdown which is called when the tty is being destructed. This also means that the shutdown method is tied into the refcounting. Use this to rework the console close/sysfs logic. Remove lots of special case code from the tty core code. The pty code can now have a shutdown() method that replaces the special case hackery in the tree free up paths. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13pty: If the administrator creates a device for a ptmx slave we should not errorAlan Cox
The open path for ptmx slaves is via the ptmx device. Opening them any other way is not allowed. Vegard Nossum found that previously this was not the case and mknod foo c 128 42; cat foo would produce nasty diagnostics Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Redo current tty lockingAlan Cox
Currently it is sometimes locked by the tty mutex and sometimes by the sighand lock. The latter is in fact correct and now we can hand back referenced objects we can fix this up without problems around sleeping functions. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: the vhangup syscall is racyAlan Cox
We now have the infrastructure to sort this out but rather than teaching the syscall tty lock rules we move the hard work into a tty helper Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Move tty_write_message out of kernel/printkAlan Cox
This is pure tty code so put it in the tty layer where it can be with the locking relevant material it uses Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Make get_current_tty use a krefAlan Cox
We now return a kref covered tty reference. That ensures the tty structure doesn't go away when you have a return from get_current_tty. This is not enough to protect you from most of the resources being freed behind your back - yet. [Updated to include fixes for SELinux problems found by Andrew Morton and an s390 leak found while debugging the former] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: compare the tty winsizeAlan Cox
We always use the real tty one for stuff so the pty one should not be compared. As we propagate window changes to both it doesn't currently matter but will when we tidy up the pty termios logic a bit more Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Termios locking - sort out real_tty confusions and lock readsAlan Cox
This moves us towards sanity and should mean our termios locking is now complete and comprehensive. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: use krefs to protect driver module countsAlan Cox
The tty layer keeps driver module counts that are used so the driver knows when it can be unloaded. For obvious reasons we want to tie that to the refcounting properly. At this point the driver side itself isn't refcounted nicely but we can do that later and kref the drivers. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Add a kref countAlan Cox
Introduce a kref to the tty structure and use it to protect the tty->signal tty references. For now we don't introduce it for anything else. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Split tty_port into its own fileAlan Cox
Not much in it yet but this will grow a lot Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: split the buffering from tty_ioAlan Cox
The two are basically independent chunks of code so lets split them up for readability and sanity. It also makes the API boundaries much clearer. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: move tioclinux from a special caseAlan Cox
Right now we have ifdefs and hooks in the core ioctl handler for TIOCLINUX and then test if its a console. This is brain dead. Instead call the tioclinux helper from the relevant driver ioctl methods. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-26kgdboc,tty: Fix tty polling search to use name correctlyJason Wessel
The tty_find_polling_driver() routine did not correctly check the base part of the tty name. This can lead to kgdboc selecting an incorrect driver, as well as accepting a completely invalid tty such as "echo ffff0 > /sys/module/kgdboc/parameters/kgdboc". Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-08-27tty: Fix termios tty window resize race with pty/tty pairAlan Cox
Kanru Chen posted a patch versus the old code which deals with the case where you resize the pty side of a pty/tty pair. In that situation the termios data is updated for both pty and tty but the locks are not held for the right side. This implements the fix differently against the updated tty code. Patch by self but the hard bit (noticing and fixing the bug) is thanks to Kanru Chen. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15tty: remove resize window special caseAlan Cox
This moves it to being a tty operation. That removes special cases and now also means that resize can be picked up by um and other non vt consoles which may have a resize operation. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-11Fix race/oops in tty layer after BKL pushdownChristian Borntraeger
While testing our KVM code for s390 (starting and killall kvm in a loop) I can reproduce the following oops: Unable to handle kernel pointer dereference at virtual kernel address 6b6b6b6b6b6b6000 Oops: 0038 [#1] SMP Modules linked in: dm_multipath sunrpc qeth_l3 qeth_l2 dm_mod qeth ccwgroup CPU: 1 Not tainted 2.6.27-rc1 #54 Process kuli (pid: 4409, task: 00000000b6aa5940, ksp: 00000000b7343e10) Krnl PSW : 0704e00180000000 00000000002e0b8c (disassociate_ctty+0x1c0/0x288) R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:3 CC:2 PM:0 EA:3 Krnl GPRS: 0000000000000000 6b6b6b6b6b6b6b6b 0000000000000001 00000000000003a6 00000000002e0a46 00000000004b4160 0000000000000001 00000000bbd79758 00000000b7343e58 00000000b8854148 00000000bd34dea0 00000000b7343c20 0000000000000001 00000000004b6d08 00000000002e0a46 00000000b7343c20 Krnl Code: 00000000002e0b7e: eb9fb0a00004 lmg %r9,%r15,160(%r11) 00000000002e0b84: 07f4 bcr 15,%r4 00000000002e0b86: e31090080004 lg %r1,8(%r9) >00000000002e0b8c: d501109cd000 clc 156(2,%r1),0(%r13) 00000000002e0b92: a784ff5d brc 8,2e0a4c 00000000002e0b96: b9040029 lgr %r2,%r9 00000000002e0b9a: c0e5fffff9c3 brasl %r14,2dff20 00000000002e0ba0: a7f4ff56 brc 15,2e0a4c Call Trace: ([<00000000002e0a46>] disassociate_ctty+0x7a/0x288) [<0000000000141fe6>] do_exit+0x212/0x8d4 [<0000000000142708>] do_group_exit+0x60/0xcc [<0000000000150660>] get_signal_to_deliver+0x270/0x3ac [<000000000010bfd6>] do_signal+0x8e/0x8dc [<0000000000113772>] sysc_sigpending+0xe/0x22 [<000001ff0000b134>] 0x1ff0000b134 INFO: lockdep is turned off. Last Breaking-Event-Address: [<00000000002e0a48>] disassociate_ctty+0x7c/0x288 Kernel panic - not syncing: Fatal exception: panic_on_oops It seems that tty was already free in disassocate_ctty when it tries to dereference tty->driver. After moving the lock_kernel before the mutex_unlock, I can no longer reproduce the problem. [ This is a temporary partial fix for the documented and long standing race in disassociate_tty. This stops most problem cases for now. For the next release the -next tree has an initial implementation of kref counting for tty structures and this quickfix will be dropped. - Alan ] Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by; Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25unexport proc_clear_ttyAdrian Bunk
With the removal of the Solaris binary emulation the export of proc_clear_tty became unused. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24remove is_tty()Adrian Bunk
This patch removes the no longer used is_tty(). Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22tty: Fix up escaped characterAlan Cox
Louis Rilling noticed this. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (79 commits) arm: bus_id -> dev_name() and dev_set_name() conversions sparc64: fix up bus_id changes in sparc core code 3c59x: handle pci_name() being const MTD: handle pci_name() being const HP iLO driver sysdev: Convert the x86 mce tolerant sysdev attribute to generic attribute sysdev: Add utility functions for simple int/ulong variable sysdev attributes sysdev: Pass the attribute to the low level sysdev show/store function driver core: Suppress sysfs warnings for device_rename(). kobject: Transmit return value of call_usermodehelper() to caller sysfs-rules.txt: reword API stability statement debugfs: Implement debugfs_remove_recursive() HOWTO: change email addresses of James in HOWTO always enable FW_LOADER unless EMBEDDED=y uio-howto.tmpl: use unique output names uio-howto.tmpl: use standard copyright/legal markings sysfs: don't call notify_change sysdev: fix debugging statements in registration code. kobject: should use kobject_put() in kset-example kobject: reorder kobject to save space on 64 bit builds ...
2008-07-22tty: rework break handlingAlan Cox
Some hardware needs to do break handling itself and may have partial support only. Make break_ctl return an error code. Add a tty driver flag so you can indicate driver hardware side break support. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
