path: root/drivers/char/viotape.c
2009-06-02tape: beyond ARRAY_SIZE of viocd_diskinforoel kluin
Do not go beyond ARRAY_SIZE of tape_device and viotape_unitinfo Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-10-16device create: char: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21device create: char: convert device_create to device_create_drvdataGreg Kroah-Hartman
device_create() is race-prone, so use the race-free device_create_drvdata() instead as device_create() is going away. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-15Merge commit '85082fd7cbe3173198aac0eb5e85ab1edcc6352c' into test-buildBenjamin Herrenschmidt
Manual fixup of: arch/powerpc/Kconfig
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-06-30viotape: Use unlocked_ioctlStephen Rothwell
This pushes the BKL down into the driver. Based on a patch by Alan Cox. We need to do it this way for now as the inode parameter of viotap_ioctl is used internally as a flag. We should do a further cleanup patch. Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-20bkl-removal viotape fixupStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-06-20viotape: cdev lock_kernel pushdown ()Jonathan Corbet
2008-05-23[POWERPC] iSeries: Remove unused mail addressStephen Rothwell
I don't use my IBM email address normally and people can find me in CREDITS. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-29drivers: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12Convert from class_device to device in drivers/chartonyj@suse.de
Convert from class_device to device in drivers/char. Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-11[POWERPC] iSeries: Move detection of virtual tapesStephen Rothwell
Now we will only have entries in the device tree for the actual existing devices (including their OS/400 properties). This way viotape.c gets all the information about the devices from the device tree. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-11[POWERPC] Remove iSeries_vio_devStephen Rothwell
It was only being used to carry around dma_iommu_ops and vio_iommu_table which we can use directly instead. This also means that vio_bus_device doesn't need to refer to them either. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-07-19unregister_chrdev(): ignore the return valueAkinobu Mita
unregister_chrdev() always returns 0. There is no need to check the return value. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10[POWERPC] VIOTAPE: Use designated initializers for fops member structures.Robert P. J. Day
Replace the old-style member initializers with the newer designated initializers. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-12[PATCH] mark struct file_operations const 3Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-20[POWERPC] iSeries: fix viotape initStephen Rothwell
Only initialise viotape on legacy iSeries. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-08[PATCH] struct path: convert char-driversJosef Sipek
2006-07-13[POWERPC] iseries: Small viotape cleanup allowed by devfs removalStephen Rothwell
2006-07-03[PATCH] make more file_operation structs staticArjan van de Ven
Mark the static struct file_operations in drivers/char as const. Making them const prevents accidental bugs, and moves them to the .rodata section so that they no longer do any false sharing; in addition with the proper debug option they are then protected against corruption.. [akpm@osdl.org: build fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] devfs: Remove the devfs_fs_kernel.h file from the treeGreg Kroah-Hartman
Also fixes up all files that #include it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs_remove() function from the kernel treeGreg Kroah-Hartman
Removes the devfs_remove() function and all callers of it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs_mk_cdev() function from the kernel treeGreg Kroah-Hartman
Removes the devfs_mk_cdev() function and all callers of it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs_*_tape() functions from the kernel treeGreg Kroah-Hartman
Removes the devfs_register_tape() and devfs_unregister_tape() functions and all callers of them. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-05-19[PATCH] powerpc: update iSeries viocd and viotape device-treeStephen Rothwell
Make their device_type entries more generic and their compatible entries more specific. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-02merge filename and modify references to iseries/vio.hKelly Daly
Signed-off-by: Kelly Daly <kelly@au.ibm.com>
2005-11-02merge filename and modify references to iseries/hv_lp_event.hKelly Daly
2005-11-02merge filename and modify reference to iseries/hv_lp_config.hKelly Daly
2005-11-02merge filename and modify references to iseries/hv_call_event.hKelly Daly
2005-10-31Merge ../linux-2.6 by handPaul Mackerras
2005-10-28[PATCH] Driver Core: fix up all callers of class_device_create()Greg Kroah-Hartman
The previous patch adding the ability to nest struct class_device changed the paramaters to the call class_device_create(). This patch fixes up all in-kernel users of the function. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-24powerpc: set the driver.owner field for all vio driversStephen Rothwell
2005-10-24powerpc: don't duplicate name between vio_driver and device_driverStephen Rothwell
Just set the name field directly in the device_driver structure contained in the vio_driver struct. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2005-08-30[PATCH] Make MODULE_DEVICE_TABLE work for vio devicesStephen Rothwell
Make MODULE_DEVICE_TABLE work for vio devices. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-06-20[PATCH] class: convert drivers/char/* to use the new class api instead of ↵gregkh@suse.de
class_simple Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
