path: root/drivers/char/virtio_console.c
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-02virtio: console: wait for first console port for early console outputChristian Borntraeger
On s390 I have seen some random "Warning: unable to open an initial console" boot failure. Turns out that tty_open fails, because the hvc_alloc was not yet done. In former times this could not happen, since the probe function automatically called hvc_alloc. With newer versions (multiport) some host<->guest interaction is required before hvc_alloc is called. This might be too late, especially if an initramfs is involved. Lets use a completion if we have multiport and an early console. [Amit: * Use NULL instead of 0 for pointer comparison * Rename 'port_added' to 'early_console_added' * Re-format, re-word commit message * Rebase patch on top of current queue] Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Amit Shah <amit.shah@redhat.com> Acked-by: Chrstian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-11-02virtio: console: add port stats for bytes received, sent and discardedAmit Shah
This commit adds port-specific stats for the number of bytes received, sent and discarded. They're exposed via the debugfs interface. This data can be used to check for data loss bugs (or disprove such claims). It can also be used for accounting, if there's such a need. The stats remain valid throughout the lifetime of the port. Unplugging a port will reset the stats. The numbers are not reset across port opens/closes. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-11-02virtio: console: make discard_port_data() use get_inbuf()Amit Shah
discard_port_data() used virtqueue_get_buf() directly instead of using get_inbuf(). Fix this, so that we get accounting for all received bytes. This also simplifies the code a lot. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-11-02virtio: console: rename variableAmit Shah
'ret' is a misnomer in discard_port_data() since we don't return the value. Rename it to 'err'. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-11-02virtio: console: make get_inbuf() return port->inbuf if presentAmit Shah
Instead of pulling in a buffer from the vq each time it's called, get_inbuf() now checks if the current active buffer, in port->inbuf is valid. If it is, just returns a pointer to it. This ends up simplifying a lot of code calling get_inbuf() since the check for port->inbuf being valid was done by all the callers. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-11-02virtio: console: Fix return type for get_inbuf()Amit Shah
get_inbuf() returns void *. There's no reason to return void pointers instead of the correct struct port_buffer *. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-11-02virtio: console: Use wait_event_freezable instead of _interruptibleAmit Shah
Get ready to support suspend/resume by using the freezable calls so that blocking read/write syscalls are handled properly across suspend/resume. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-11-02virtio: console: Ignore port name update request if name already setAmit Shah
We don't allow port name changes dynamically for a port. So any requests by the host to change the name are ignored. Before this patch, if the hypervisor sent a port name while we had one set already, we would leak memory equivalent to the size of the old name. This scenario wasn't expected so far, but with the suspend-resume support, we'll send the VIRTIO_CONSOLE_PORT_READY message after restore, which can get us into this situation. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-11-02virtio: console: Fix indentationAmit Shah
Convert spaces to tabs and fix indentation for an if statement split into multiple lines. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-11-02virtio-console: Use virtio_config_val() for retrieving configSasha Levin
This patch modifies virtio-console to use virtio_config_val() instead of a 'if(virtio_has_feature()) vdev->config->get()' construct to retrieve optional values from the config space. Cc: Amit Shah <amit.shah@redhat.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: virtualization@lists.linux-foundation.org Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-10-31drivers/char: Add module.h to those who were using it implicitlyPaul Gortmaker
A pending cleanup will mean that module.h won't be implicitly everywhere anymore. Make sure the modular drivers in char are actually calling out for <module.h> explicitly in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-05-30virtio console: don't manually set or finalize VIRTIO_CONSOLE_F_MULTIPORT.Rusty Russell
That's already been done by the virtio infrastructure before the probe function is called. Reported-by: alexey.kardashevskiy@au1.ibm.com Acked-by: Amit Shah <amit.shah@redhat.com> Tested-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-04-21virtio: console: Enable call to hvc_remove() on console port removeAmit Shah
This call was disabled as hot-unplugging one virtconsole port led to another virtconsole port freezing. Upon testing it again, this now works, so enable it. In addition, a bug was found in qemu wherein removing a port of one type caused the guest output from another port to stop working. I doubt it was just this bug that caused it (since disabling the hvc_remove() call did allow other ports to continue working), but since it's all solved now, we're fine with hot-unplugging of virtconsole ports. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-03-06virtio: console: Don't access vqs if device was unpluggedAmit Shah
If a virtio-console device gets unplugged while a port is open, a subsequent close() call on the port accesses vqs to free up buffers. This can lead to a crash. The buffers are already freed up as a result of the call to unplug_ports() from virtcons_remove(). The fix is to simply not access vq information if port->portdev is NULL. Reported-by: juzhang <juzhang@redhat.com> CC: stable@kernel.org Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-10Merge branch 'tty-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: serial: bfin_5xx: split uart RX lock from uart port lock to avoid deadlock 68360serial: Plumb in rs_360_get_icount() n_gsm: copy mtu over when configuring via ioctl interface virtio: console: Move file back to drivers/char/
2011-02-03virtio: console: Move file back to drivers/char/Amit Shah
Commit 728674a7e466628df2aeec6d11a2ae1ef968fb67 moved virtio_console.c to drivers/tty/hvc/ under the perception of this being an hvc driver. It was such once, but these days it has generic communication capabilities as well, so move it to drivers/char/. In the future, the hvc part from this file can be split off and moved under drivers/tty/hvc/. Signed-off-by: Amit Shah <amit.shah@redhat.com> CC: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-13tty: move hvc drivers to drivers/tty/hvc/Greg Kroah-Hartman
As requested by Arnd Bergmann, the hvc drivers are now moved to the drivers/tty/hvc/ directory. The virtio_console.c driver was also moved, as it required the hvc_console.h file to be able to be built, and it really is a hvc driver. Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-24Char: virtio_console, fix memory leakJiri Slaby
Stanse found that in init_vqs, memory is leaked under certain circumstanses (the fail path order is incorrect). Fix that by checking allocations in one turn and free all of them at once if some fails (some may be NULL, but this is OK). Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Amit Shah <amit.shah@redhat.com> Cc: virtualization@lists.linux-foundation.org Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-21virtio: console: Disable lseek(2) for port file operationsAmit Shah
The ports are char devices; do not have seeking capabilities. Calling nonseekable_open() from the fops_open() call and setting the llseek fops pointer to no_llseek ensures an lseek() call from userspace returns -ESPIPE. Signed-off-by: Amit Shah <amit.shah@redhat.com> CC: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-21virtio: console: Send SIGIO in case of port unplugAmit Shah
If a port has registered for SIGIO signals, let the application know that the port is getting unplugged. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-21virtio: console: Send SIGIO on new data arrival on portsAmit Shah
Send a SIGIO signal when new data arrives on a port. This is sent only when the process has requested for the signal to be sent using fcntl(). Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-21virtio: console: Send SIGIO to processes that request it for host eventsAmit Shah
A process can request for SIGIO on host connect / disconnect events using the O_ASYNC file flag using fcntl(). If that's requested, and if the guest-side connection for the port is open, any host-side open/close events for that port will raise a SIGIO. The process can then use poll() within the signal handler to find out which port triggered the signal. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-21virtio: console: Reference counting portdev structs is not neededAmit Shah
Explain in a comment why there's no need to reference-count the portdev struct: when a device is yanked out, we can't do anything more with it anyway so just give up doing anything more with the data or the vqs and exit cleanly. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-21virtio: console: Add reference counting for port structAmit Shah
When a port got hot-unplugged, when a port was open, any file operation after the unplugging resulted in a crash. This is fixed by ref-counting the port structure, and releasing it only when the file is closed. This splits the unplug operation in two parts: first marks the port as unavailable, removes all the buffers in the vqs and removes the port from the per-device list of ports. The second stage, invoked when all references drop to zero, releases the chardev and frees all other memory. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-21virtio: console: Use cdev_alloc() instead of cdev_init()Amit Shah
This moves to using cdev on the heap instead of it being embedded in the ports struct. This helps individual refcounting and will allow us to properly remove cdev structs after hot-unplugs and close operations. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-21virtio: console: Add a find_port_by_devt() functionAmit Shah
To convert to using cdev as a pointer to avoid kref troubles, we have to use a different method to get to a port from an inode than the current container_of method. Add find_port_by_devt() that looks up all portdevs and ports with those portdevs to find the right port. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-21virtio: console: Add a list of portdevs that are activeAmit Shah
The virtio_console.c driver is capable of handling multiple devices at a time. Maintain a list of devices for future traversal. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-21virtio: console: open: Use a common path for error handlingAmit Shah
Just re-arrange code for future patches. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-21virtio: console: remove_port() should return voidAmit Shah
When a port is removed, we have to assume the port is gone. So a success/failure return value doesn't make sense. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-21virtio: console: Make write() return -ENODEV on hot-unplugAmit Shah
When a port is hot-unplugged while an app was blocked on a write() call, the call was unblocked but would not get an error returned. Return -ENODEV to ensure the app knows the port has gone away. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-21virtio: console: Make read() return -ENODEV on hot-unplugAmit Shah
When a port is hot-unplugged while an app was blocked on a read() call, the call was unblocked but would not get an error returned. Return -ENODEV to ensure the app knows the port has gone away. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-21virtio: console: Unblock poll on port hot-unplugAmit Shah
When a port is hot-unplugged while an app is blocked on poll(), unblock the poll() and return. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-21virtio: console: Un-block reads on chardev closeAmit Shah
If a chardev is closed, any blocked read / poll calls should just return and not attempt to use other state. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-21virtio: console: Check if portdev is valid in send_control_msg()Amit Shah
A portdev may have been hot-unplugged while a port was open()ed. Skip sending control messages when the portdev isn't valid. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-21virtio: console: Remove control vq data only if using multiport supportAmit Shah
If a portdev isn't using multiport support, it won't have any control vq data to remove. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-21virtio: console: Reset vdev before removing deviceAmit Shah
The virtqueues should be disabled before attempting to remove the device. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-20virtio: console: Don't block entire guest if host doesn't read dataAmit Shah
If the host is slow in reading data or doesn't read data at all, blocking write calls not only blocked the program that called write() but the entire guest itself. To overcome this, let's not block till the host signals it has given back the virtio ring element we passed it. Instead, send the buffer to the host and return to userspace. This operation then becomes similar to how non-blocking writes work, so let's use the existing code for this path as well. This code change also ensures blocking write calls do get blocked if there's not enough room in the virtio ring as well as they don't return -EAGAIN to userspace. Signed-off-by: Amit Shah <amit.shah@redhat.com> Acked-by: Hans de Goede <hdegoede@redhat.com> CC: stable@kernel.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-21virtio: console: Prevent userspace from submitting NULL buffersAmit Shah
A userspace could submit a buffer with 0 length to be written to the host. Prevent such a situation. This was not needed previously, but recent changes in the way write() works exposed this condition to trigger a virtqueue event to the host, causing a NULL buffer to be sent across. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> CC: stable@kernel.org
2010-09-21virtio: console: Fix poll blocking even though there is data to readHans de Goede
I found this while working on a Linux agent for spice, the symptom I was seeing was select blocking on the spice vdagent virtio serial port even though there were messages queued up there. virtio_console's port_fops_poll checks port->inbuf != NULL to determine if read won't block. However if an application reads enough bytes from inbuf through port_fops_read, to empty the current port->inbuf, port->inbuf will be NULL even though there may be buffers left in the virtqueue. This causes poll() to block even though there is data to be read, this patch fixes this by using will_read_block(port) instead of the port->inbuf != NULL check. Signed-off-By: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: stable@kernel.org
2010-06-03virtio: console: Fix crash when port is unplugged and blocked for writeAmit Shah
When a program that has a virtio port opened and blocked for a write operation, a port hot-unplug event will later led to a crash when SIGTERM was sent to the program. Fix that. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-06-03virtio: console: Fix crash when hot-unplugging a port and read is blockedAmit Shah
When removing a port we don't check if a program was blocked for read. This leads to a crash when SIGTERM is sent to the program after hot-unplugging the port. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-05-19drivers/char: Eliminate use after freeJulia Lawall
In each case, the first argument to send_control_msg or __send_control_msg, respectively, has either not been successfully allocated or has been freed at the point of the call. In the first case, the first argument, port, is only used to access the portdev and id fields, in order to call __send_control_msg. Thus it seems possible instead to call __send_control_msg directly. In the second case, the call to __send_control_msg is moved up to a place where it seems like the first argument, portdev, has been initialized sufficiently to make the call to __send_control_msg meaningful. This has only been compile tested. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @free@ expression E; position p; @@ kfree@p(E) @@ expression free.E, subE<=free.E, E1; position free.p; @@ kfree@p(E) ... ( subE = E1 | * E ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-05-19virtio: console: Accept console size along with resize control messageAmit Shah
The VIRTIO_CONSOLE_RESIZE control message sent to us by the host now contains the new {rows, cols} values for the console. This ensures each console port gets its own size, and we don't depend on the config-space rows and cols values at all now. Signed-off-by: Amit Shah <amit.shah@redhat.com> CC: Christian Borntraeger <borntraeger@de.ibm.com> CC: linuxppc-dev@ozlabs.org CC: Kusanagi Kouichi <slash@ac.auone-net.jp> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-05-19virtio: console: Store each console's size in the console structureAmit Shah
With support for multiple consoles, just using one {rows,cols} pair in the config space is not going to suffice. Store each console's size as part of the console struct. This changes the behaviour for one case when multiport is not enabled: when notifier_add_vio() is called, the console size is taken from that of the last config-space update instead of fetching it afresh from the config space. Also add a helper to update the size in the console struct as we'll need to use the same code to update the size via control messages when multiport support is enabled. Signed-off-by: Amit Shah <amit.shah@redhat.com> CC: Christian Borntraeger <borntraeger@de.ibm.com> CC: linuxppc-dev@ozlabs.org CC: Kusanagi Kouichi <slash@ac.auone-net.jp> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-05-19virtio: console: Resize console port 0 on config intr only if multiport is offAmit Shah
When using multiport, we'll use control messages. Ensure we don't accidentally update port 0 size on config interrupts. Signed-off-by: Amit Shah <amit.shah@redhat.com> CC: Christian Borntraeger <borntraeger@de.ibm.com> CC: linuxppc-dev@ozlabs.org CC: Kusanagi Kouichi <slash@ac.auone-net.jp> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-05-19virtio: console: Add support for nonblocking write()sAmit Shah
If the host port is not open, a write() should either just return if the file is opened in non-blocking mode, or block till the host port is opened. Also, don't spin till host consumes data for nonblocking ports. For non-blocking ports, we can do away with the spinning and reclaim the buffers consumed by the host on the next write call or on the condition that'll make poll return. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-05-19virtio: console: Rename wait_is_over() to will_read_block()Amit Shah
We'll introduce a function that checks if write will block. Have function names that are similar for the two cases. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-05-19virtio: console: Don't always create a port 0 if using multiportAmit Shah
If we're using multiport, there's no point in always creating a console port. Create the console port only if the host doesn't support multiport. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-05-19virtio: console: Use a control message to add portsAmit Shah
Instead of the host and guest independently enumerating ports, switch to a control message to add ports where the host supplies the port number so there's no ambiguity or a possibility of a race between the host and the guest port numbers. We now no longer need the 'nr_ports' config value. Since no kernel has been released with the MULTIPORT changes yet, we have a chance to fiddle with the config space without adding compatibility features. This is beneficial for management software, which would now be able to instantiate ports at known locations and avoid problems that arise with implicit numbering in the host and the guest. This removes the 'guessing game' part of it, and management software can now actually indicate which id to spawn a particular port on. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
