commit ea7b44c8e6baa1a4507f05ba2c0009ac21c3fe0b upstream
On 9xx chips, bus mastering needs to be enabled at resume time for much of the
chip to function. With this patch, vblank interrupts will work as expected
on resume, along with other chip functions. Fixes kernel bugzilla #10844.
Signed-off-by: Jie Luo <clotho67@gmail.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
upstream commit: eb4e545d4ac82d9018487edb4419b33b9930c857
Packet sending is driven by two flags, tx_ready and tx_queued.
It was possible, that there were queued data for sending and
hardware was flagged as blocked but in fact it was not.
The tx_queued was indicator but should be really a counter else
first fragmented packet resets tx_queued flag, but there may be
pending packets which do not get sent.
New semantics:
tx_ready - set, if hw is ready to send packet, no packet is being
transferred right now
set the flag right at the place where data are copied
into hw memory and not earlier without checking if it
was succesful
tx_queued - count of enqueued packets, including fragments
Tested-by: Michal Rokos <michal.rokos@gmail.com>
Signed-off-by: David Sterba <dsterba@suse.cz>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
commit c1236d31a1b9fc018b85e15a3e58e3601ddc90ae upstream
For e.g. proper TTY canonical support, IUTF8 termios flag has to be set as
appropriate. Linux used to not care about setting that flag for VT TTYs.
This patch fixes that by activating it according to the current mode of the
VT, and sets the default value according to the vt.default_utf8 parameter.
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
Cc: Willy Tarreau <w@1wt.eu>
Now that we're mapping registers in the DRM driver at load time, the
driver actually checks the PCI ID, so we need to make sure the macros
have all the right bits (and longer term use the DRM headers as the sole
copy of the PCI & register definitions).
This patch adds 945GME support to the DRM headers, fixing a regression
reported in http://bugzilla.kernel.org/show_bug.cgi?id=10395.
Tested-by: Alexander Oltu <alexander@all-2.com>
Signed-off-by: Jesse Barnes <jesse.barnes@intel.com>
The commits:
commit 37a47db8d7f0f38dac5acf5a13abbc8f401707fa
Author: Balaji Rao <balajirrao@gmail.com>
Date: Wed Jan 30 13:30:03 2008 +0100
x86: assign IRQs to HPET timers, fix
and
commit e3f37a54f690d3e64995ea7ecea08c5ab3070faf
have been identified to cause a regression on some platforms due to
the assignement of legacy IRQs which makes the legacy devices
connected to those IRQs disfunctional.
Revert them.
This fixes http://bugzilla.kernel.org/show_bug.cgi?id=10382
Add some locks and unlocks to some code paths.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Unlock two grabbed locks on some paths.
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm: fix for non-coherent DMA PowerPC
drm: radeon: fix sparse integer as NULL pointer warnings in radeon_mem.c
drm/i915: fix oops on agp=off
drm/r300: fix bug in r300 userspace hardware wait emission
aka if you see a force-cast, be very suspicious...
Acked-and-tested-by: Frank Seidel <fseidel@suse.de>
This patch fixes bits of the DRM so to make the radeon DRI work on
non-cache coherent PCI DMA variants of the PowerPC processors.
It moves the few places that needs change to wrappers to that
other architectures with similar issues can easily add their
own changes to those wrappers, at least until we have more useful
generic kernel API.
Cc: "Luck, Tony" <tony.luck@intel.com>
Signed-off-by: Dave Airlie <airlied@linux.ie>
drivers/char/drm/radeon_mem.c:91:23: warning: Using plain integer as NULL pointer
drivers/char/drm/radeon_mem.c:116:28: warning: Using plain integer as NULL pointer
drivers/char/drm/radeon_mem.c:124:28: warning: Using plain integer as NULL pointer
drivers/char/drm/radeon_mem.c:177:26: warning: Using plain integer as NULL pointer
drivers/char/drm/radeon_mem.c:177:53: warning: Using plain integer as NULL pointer
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
From Kernel BZ 10289 - not sure why anyone would boot an intel with no agp
but it shouldn't crash.
This interface was originally designed wrong, confusing bit-fields and
integers, major brown paper bag going back many years...
But userspace only ever used 4 values so fix the interface for new
users and fix the implementation to deal with the 4 values userspace
has ever emitted (0x1, 0x2, 0x3, 0x6).
drivers/char/drm/ati_pcigart.c: In function 'drm_ati_pcigart_init':
drivers/char/drm/ati_pcigart.c:125: warning: format '%08X' expects type 'unsigned int', but argument 3 has type 'dma_addr_t'
Cc: Dave Airlie <airlied@linux.ie>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Update documentation for the hw_random support to be current:
- Documentation/hw_random.txt has been updated to reflect the
current code: it's a framework now, a "core" with a small
sysfs interface, that hardware-specific drivers plug in to.
Text specific to Intel hardware is now at the end.
- Kconfig now references the Documentation/hw_random.txt file
and better explains what this really does.
Both chunks of documentation now higlight the fact that the kernel entropy
pool is maintained by "rngd", and this driver has nothing directly to do with
that important task.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
unsigned long != __le32, TYVM, and unsigned char[4] is not guaranteed
to be aligned for u32.
While we are at it, sanitize sOutDW() a bit - have it take Byte_t * and
handle dereferencing internally.
NB: sWriteTxPrioByte() is almost certainly buggered on big-endian and is
missing cpu_to_le16() on assignments to *WordPtr; I've left it alone for now.
Acked-by: "Theodore Ts'o" <tytso@mit.edu>
This fixes a problem on 64-bit with 4GB with ATI RS690 chipsets. It
makes sure the pcigart table is allocated in coherent memory for DMA operations.
This fixes up the RV550 chips which are based on RV515, not RV530.
It also adds another RS690 PCI ID.
It's worth remembering that all new bright ideas on how to make this command reader work properly and according to docs will probably fail :( Bring in some old code.
Also allow a larger SG-DMA download stride, and remove unnecessary waits for
command regulators pauses.
The i915_vblank_swap() function schedules an automatic buffer swap
upon receipt of the vertical sync interrupt. Such an operation is
lengthy so it can't be allowed to happen in normal interrupt context,
thus the DRM implements this by scheduling the work in a kernel
softirq-scheduled tasklet. In order for the buffer swap to work
safely, the DRM's central lock must be taken, via a call to
drm_lock_take() located in drivers/char/drm/drm_irq.c within the
function drm_locked_tasklet_func(). The lock-taking logic uses a
non-interrupt-blocking spinlock to implement the manipulations needed
to take the lock. This semantic would be safe if all attempts to use
the spinlock only happen from process context. However this buffer
swap happens from softirq context which is really a form of interrupt
context. Thus we have an unsafe situation, in that
drm_locked_tasklet_func() can block on a spinlock already taken by a
thread in process context which will never get scheduled again because
of the blocked softirq tasklet. This wedges the kernel hard.
To trigger this bug, run a dual-head cloned mode configuration which
uses the i915 drm, then execute an opengl application which
synchronizes buffer swaps against the vertical sync interrupt. In my
testing, a lockup always results after running anywhere from 5 minutes
to an hour and a half. I believe dual-head is needed to really
trigger the problem because then the vertical sync interrupt handling
is no longer predictable (due to being interrupt-sourced from two
different heads running at different speeds). This raises the
probability of the tasklet trying to run while the userspace DRI is
doing things to the GPU (and manipulating the DRM lock).
The fix is to change the relevant spinlock semantics to be the
interrupt-blocking form. After this change I am no longer able to
trigger the lockup; the longest test run so far was 20 hours (test
stopped after that point).
Note: I have examined the places where this spinlock is being
employed; all are reasonably short bounded sequences and should be
suitable for interrupts being blocked without impacting overall kernel
interrupt response latency.
Signed-off-by: Mike Isely <isely@pobox.com>
In riscom8_init_module, rc_board should be indexed by i, not by 0, otherwise
the loop is useless.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6:
drivers: fix dma_get_required_mask
firmware: provide stubs for the FW_LOADER=n case
nozomi: fix initialization and early flow control access
sysdev: fix problem with sysdev_class being re-registered
Due to some flaws in the initialization and flow control
code kernel oopses could be triggered e.g. when accessing
the card too early after insertion.
See e.g. kernel.org bug #10077.
The main part of the fix is a trivial state management
making sure the card is realy ready to use before allowing
any access.
Signed-off-by: Frank Seidel <fseidel@suse.de>
This has been around for a while but nobody reported it until recently.
Resubmitting the fix as it's appropriate for 2.6.25
Signed-off-by: Alan Cox <alan@redhat.com>
randconfig testing found a bootup lockup in drivers/char/esp.c because
of a spinlock that wasn't correctly initialized.
I'm not sure why it became more prominent in 2.6.25-rc4, the bug seems
rather old and i've been doing allyesconfig bootups for ages with
CONFIG_ESP enabled.
This fixes this bootup lockup:
PM: Adding info for No Bus:ttyP63
ttyP32 at 0x0240 (irq = 0) is an ESP primary port
BUG: spinlock lockup on CPU#0, swapper/1, f56dd004
Pid: 1, comm: swapper Not tainted 2.6.25-rc4-sched-devel.git-x86-latest.git #402 [<c03ac6f4>] _raw_spin_lock+0x134/0x140
[<c08649be>] _spin_lock_irqsave+0x5e/0x80
[<c0b9fbfe>] ? espserial_init+0x2be/0x6e0
[<c0b9fbfe>] espserial_init+0x2be/0x6e0
[<c0b877a3>] kernel_init+0x83/0x260
[<c0b9f940>] ? espserial_init+0x0/0x6e0
[<c010416a>] ? restore_nocheck_notrace+0x0/0xe
[<c0b87720>] ? kernel_init+0x0/0x260
[<c0104507>] kernel_thread_helper+0x7/0x10
kzalloc() is not the way to initialize spinlocks anymore.
In commit e6bafba5b4765a5a252f1b8d31cbf6d2459da337 ("wmi: (!x & y)
strikes again"), a bug was fixed that involved converting !x & y to !(x
& y). The code below shows the same pattern, and thus should perhaps be
fixed in the same way.
This is not tested and clearly changes the semantics, so it is only
something to consider.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@@ expression E1,E2; @@
!E1 & !E2
- !E1 & E2
+ !(E1 & E2)
// </smpl>
Cc: Jiri Slaby <jirislaby@gmail.com>
The Coverity checker spotted the following inconsequent NULL checking in
drivers/char/pcmcia/ipwireless/network.c:ipwireless_network_packet_received()
if (tty && channel_idx == IPW_CHANNEL_RAS
&& (network->ras_control_lines &
IPW_CONTROL_LINE_DCD) != 0
&& ipwireless_tty_is_modem(tty)) {
else
ipwireless_tty_received(tty, data, length);
Cc: Adrian Bunk <bunk@kernel.org>
Cc: "John W. Linville" <linville@tuxdriver.com>
VT notifier callbacks need to be aware of console switches. This is already
partially done from console_callback(), but at that time fg_console, cursor
positions, etc. are not yet updated and hence screen readers fetch the old
values.
This adds an update notify after all of the values are updated in
redraw_screen(vc, 1).
Cc: <stable@kernel.org>
Noticed by sparse, trivial to see:
drivers/char/specialix.c:2112:3: warning: context imbalance in 'sx_throttle' - unexpected unlock
Oddly enough, unsigned int c = '\300'; puts a "negative" value in c, not
0300... This fixes the default unicode compose table by using integers
instead of character constants.
master.kernel.org:/pub/scm/linux/kernel/git/arnd/cell-2.6 into merge
master.kernel.org:/pub/scm/linux/kernel/git/jwboyer/powerpc-4xx into merge
Fix hpet_(un)register_irq_handler() for when CONFIG_HPET_EMULATE_RTC=n. They
are provided macros that substitute value 0, but if they are called as
functions and the return value isn't checked, the following warnings appear:
drivers/char/rtc.c: In function `rtc_init':
drivers/char/rtc.c:1063: warning: statement with no effect
drivers/char/rtc.c: In function `rtc_exit':
drivers/char/rtc.c:1157: warning: statement with no effect
This fixes various items pointed out during a review of the hwicap driver.
Primarily, reversed memcpy calls, re-entrancy issues, and mutex conversion
have been addressed. There are also fixes to comments to use the kerneldoc
format, as well as some sparse annotations.
Signed-off-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com>
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Make sure the restoration correctly restores the AR registers by
flipping the ARX register into index mode before doing anything.
Without this, some people have had the text mode restore all green.
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6
* 'agp-patches' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6:
agp: fix missing casts that produced a warning.
agp: add support for 662/671 to agp driver
fix historic ioremap() abuse in AGP
agp/sis: Suspend support for SiS AGP
agp/sis: Clear bit 2 from aperture size byte as well
fix i915 driver to use state for hibernate save avoidance.
In hibernate, we may end up calling the VGA save regs function twice, so we need to make sure it's idempotent. That means leaving ARX in index mode after the first save operation. Fixes hibernate on 965.
Failing to preserve the MI_ARB_STATE register was causing FIFO underruns on
the VGA output on my HP 2510p after resume.
On many chipsets, the checks for DPLL enable or VGA mode will prevent the pipeconf regs from being restored, which could result in a blank display or X failing to come back after resume. So restore them unconditionally along with actually restoring pipe B's palette correctly.
On resume, if the interrupt state isn't restored correctly, we may end
up with a flood of unexpected or ill-timed interrupts, which could cause
the kernel to disable the interrupt or vblank events to happen at the
wrong time. So save/restore them properly.
Remove redundant vma range checks.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Also applys to recent added new chipset.
Signed-off-by: Zhenyu Wang <zhenyu.z.wang@intel.com>
This adds support for configuring the RS690 GART.
Several AGP drivers right now use ioremap_nocache() on kernel ram in order
to turn a page of regular memory uncached.
There are two problems with this:
1) This is a total nightmare for the ioremap() implementation to keep
various mappings of the same page coherent.
2) It's a total nightmare for the AGP code since it adds a ton of
complexity in terms of keeping track of 2 different pointers to
the same thing, in terms of error handling etc etc.
This patch fixes this by making the AGP drivers use the new
set_memory_XX APIs instead.
Note: amd-k7-agp.c is built on Alpha too, and generic.c is built
on ia64 as well, which do not yet have the set_memory_*() APIs,
so for them some we have a few ugly #ifdefs - hopefully they'll
be fixed soon.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
