toradex_4.14-2.0.x-imx-next
sound/soc/codecs/sgtl5000.c
This is the 4.14.159 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6sx.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/input/keyboard/imx_keypad.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
commit 998174042da229e2cf5841f574aba4a743e69650 upstream.
Going through the uses of timeval in the user space API,
I noticed two bugs in ppdev that were introduced in the y2038
conversion:
* The range check was accidentally moved from ppsettime to
ppgettime
* On sparc64, the microseconds are in the other half of the
64-bit word.
Fix both, and mark the fix for stable backports.
Cc: stable@vger.kernel.org
Fixes: 3b9ab374a1e6 ("ppdev: convert to y2038 safe")
Link: https://lore.kernel.org/r/20191108203435.112759-8-arnd@arndb.de
commit be867f987a4e1222114dd07a01838a17c26f3fff upstream.
Existing RNG data read timeout is 200us but it doesn't cover EIP76 RNG
data rate which takes approx. 700us to produce 16 bytes of output data
as per testing results. So configure the timeout as 1000us to also take
account of lack of udelay()'s reliability.
Fixes: 383212425c92 ("hwrng: omap - Add device variant for SafeXcel IP-76 found in Armada 8K")
Cc: <stable@vger.kernel.org>
Signed-off-by: Sumit Garg <sumit.garg@linaro.org>
commit f1689114acc5e89a196fec6d732dae3e48edb6ad upstream.
devm_kcalloc() can fail and return NULL so we need to check for that.
Fixes: 58472f5cd4f6f ("tpm: validate TPM 2.0 commands")
Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com>
Reviewed-by: Jerry Snitselaar <jsnitsel@redhat.com>
Reviewed-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
Tested-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
For 5.3 we had to revert a nice ext4 IO pattern improvement, because it
caused a bootup regression due to lack of entropy at bootup together
with arguably broken user space that was asking for secure random
numbers when it really didn't need to.
See commit 72dbcf721566 (Revert "ext4: make __ext4_get_inode_loc plug").
This aims to solve the issue by actively generating entropy noise using
the CPU cycle counter when waiting for the random number generator to
initialize. This only works when you have a high-frequency time stamp
counter available, but that's the case on all modern x86 CPU's, and on
most other modern CPU's too.
What we do is to generate jitter entropy from the CPU cycle counter
under a somewhat complex load: calling the scheduler while also
guaranteeing a certain amount of timing noise by also triggering a
timer.
I'm sure we can tweak this, and that people will want to look at other
alternatives, but there's been a number of papers written on jitter
entropy, and this should really be fairly conservative by crediting one
bit of entropy for every timer-induced jump in the cycle counter. Not
because the timer itself would be all that unpredictable, but because
the interaction between the timer and the loop is going to be.
Even if (and perhaps particularly if) the timer actually happens on
another CPU, the cacheline interaction between the loop that reads the
cycle counter and the timer itself firing is going to add perturbations
to the cycle counter values that get mixed into the entropy pool.
As Thomas pointed out, with a modern out-of-order CPU, even quite simple
loops show a fair amount of hard-to-predict timing variability even in
the absense of external interrupts. But this tries to take that further
by actually having a fairly complex interaction.
This is not going to solve the entropy issue for architectures that have
no CPU cycle counter, but it's not clear how (and if) that is solvable,
and the hardware in question is largely starting to be irrelevant. And
by doing this we can at least avoid some of the even more contentious
approaches (like making the entropy waiting time out in order to avoid
the possibly unbounded waiting).
Cc: Ahmed Darwish <darwish.07@gmail.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Nicholas Mc Guire <hofrat@opentech.at>
Cc: Willy Tarreau <w@1wt.eu>
Cc: Alexander E. Patrakov <patrakov@gmail.com>
Cc: Lennart Poettering <mzxreary@0pointer.de>
(cherry picked from commit 50ee7529ec4500c88f8664560770a7a1b65db72b)
commit af0d4442dd6813de6e77309063beb064fa8e89ae upstream.
No remove function implemented yet in the driver.
Without remove function, the pm_runtime implementation
complains when removing and probing again the driver.
Signed-off-by: Lionel Debieve <lionel.debieve@st.com>
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
commit d791cfcbf98191122af70b053a21075cb450d119 upstream.
When we hot unplug a virtserialport and then try to hot plug again,
it fails:
(qemu) chardev-add socket,id=serial0,path=/tmp/serial0,server,nowait
(qemu) device_add virtserialport,bus=virtio-serial0.0,nr=2,\
chardev=serial0,id=serial0,name=serial0
(qemu) device_del serial0
kernel error:
virtio-ports vport2p2: Error allocating inbufs
qemu error:
virtio-serial-bus: Guest failure in adding port 2 for device \
virtio-serial0.0
This happens because buffers for the in_vq are allocated when the port is
added but are not released when the port is unplugged.
They are only released when virtconsole is removed (see a7a69ec0d8e4)
To avoid the problem and to be symmetric, we could allocate all the buffers
in init_vqs() as they are released in remove_vqs(), but it sounds like
a waste of memory.
Rather than that, this patch changes add_port() logic to ignore ENOSPC
error in fill_queue(), which means queue has already been filled.
Fixes: a7a69ec0d8e4 ("virtio_console: free buffers after reset")
Cc: mst@redhat.com
Signed-off-by: Laurent Vivier <lvivier@redhat.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit 1574608f5f4204440d6d9f52b971aba967664764 ]
Looking at logs from systems all over the place, it looks like tons
of broken systems exist that set the base address to zero. I can
only guess that is some sort of non-standard idea to mark the
interface as not being present. It can't be zero, anyway, so just
complain and ignore it.
Signed-off-by: Corey Minyard <cminyard@mvista.com>
[ Upstream commit 340ff31ab00bca5c15915e70ad9ada3030c98cf8 ]
ipmi_thread() uses back-to-back schedule() to poll for command
completion which, on some machines, can push up CPU consumption and
heavily tax the scheduler locks leading to noticeable overall
performance degradation.
This was originally added so firmware updates through IPMI would
complete in a timely manner. But we can't kill the scheduler
locks for that one use case.
Instead, only run schedule() continuously in maintenance mode,
where firmware updates should run.
commit db4d8cb9c9f2af71c4d087817160d866ed572cc9 upstream
TPM 2.0 Shutdown involve sending TPM2_Shutdown to TPM chip and disabling
future TPM operations. TPM 1.2 behavior was different, future TPM
operations weren't disabled, causing rare issues. This patch ensures
that future TPM operations are disabled.
Fixes: d1bd4a792d39 ("tpm: Issue a TPM2_Shutdown for TPM2 devices.")
Signed-off-by: Vadim Sukhomlinov <sukhomlinov@google.com>
[dianders: resolved merge conflicts with mainline]
Signed-off-by: Douglas Anderson <dianders@chromium.org>
commit 2677ca98ae377517930c183248221f69f771c921 upstream
Use tpm_try_get_ops() in tpm-sysfs.c so that we can consider moving
other decorations (locking, localities, power management for example)
inside it. This direction can be of course taken only after other call
sites for tpm_transmit() have been treated in the same way.
Reviewed-by: Stefan Berger <stefanb@linux.ibm.com>
Tested-by: Stefan Berger <stefanb@linux.ibm.com>
Reviewed-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Tested-by: Alexander Steffen <Alexander.Steffen@infineon.com>
commit da379f3c1db0c9a1fd27b11d24c9894b5edc7c75 upstream
Migrated pubek_show to struct tpm_buf and cleaned up its implementation.
Previously the output parameter structure was declared but left
completely unused. Now it is used to refer different fields of the
output. We can move it to tpm-sysfs.c as it does not have any use
outside of that file.
commit 78887832e76541f77169a24ac238fccb51059b63 upstream.
add_early_randomness() is called by hwrng_register() when the
hardware is added. If this hardware and its module are present
at boot, and if there is no data available the boot hangs until
data are available and can't be interrupted.
For instance, in the case of virtio-rng, in some cases the host can be
not able to provide enough entropy for all the guests.
We can have two easy ways to reproduce the problem but they rely on
misconfiguration of the hypervisor or the egd daemon:
- if virtio-rng device is configured to connect to the egd daemon of the
host but when the virtio-rng driver asks for data the daemon is not
connected,
host but the egd daemon doesn't provide data.
The guest kernel will hang at boot until the virtio-rng driver provides
enough data.
To avoid that, call rng_get_data() in non-blocking mode (wait=0)
from add_early_randomness().
Fixes: d9e797261933 ("hwrng: add randomness to system from rng...")
Reviewed-by: Theodore Ts'o <tytso@mit.edu>
commit 8619e5bdeee8b2c685d686281f2d2a6017c4bc15 upstream.
syzbot found that a thread can stall for minutes inside read_mem() or
write_mem() after that thread was killed by SIGKILL [1]. Reading from
iomem areas of /dev/mem can be slow, depending on the hardware.
While reading 2GB at one read() is legal, delaying termination of killed
thread for minutes is bad. Thus, allow reading/writing /dev/mem and
/dev/kmem to be preemptible and killable.
[ 1335.912419][T20577] read_mem: sz=4096 count=2134565632
[ 1335.943194][T20577] read_mem: sz=4096 count=2134561536
[ 1335.978280][T20577] read_mem: sz=4096 count=2134557440
[ 1336.011147][T20577] read_mem: sz=4096 count=2134553344
[ 1336.041897][T20577] read_mem: sz=4096 count=2134549248
Theoretically, reading/writing /dev/mem and /dev/kmem can become
"interruptible". But this patch chose "killable". Future patch will make
them "interruptible" so that we can revert to "killable" if some program
regressed.
[1] https://syzkaller.appspot.com/bug?id=a0e3436829698d5824231251fad9d8e998f94f5e
Cc: stable <stable@vger.kernel.org>
Reported-by: syzbot <syzbot+8ab2d0f39fb79fe6ca40@syzkaller.appspotmail.com>
Link: https://lore.kernel.org/r/1566825205-10703-1-git-send-email-penguin-kernel@I-love.SAKURA.ne.jp
commit 0c7d37f4d9b8446956e97b7c5e61173cdb7c8522 upstream.
The base value in do_div() called by hpet_time_div() is truncated from
unsigned long to uint32_t, resulting in a divide-by-zero exception.
UBSAN: Undefined behaviour in ../drivers/char/hpet.c:572:2
division by zero
CPU: 1 PID: 23682 Comm: syz-executor.3 Not tainted 4.4.184.x86_64+ #4
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
0000000000000000 b573382df1853d00 ffff8800a3287b98 ffffffff81ad7561
ffff8800a3287c00 ffffffff838b35b0 ffffffff838b3860 ffff8800a3287c20
0000000000000000 ffff8800a3287bb0 ffffffff81b8f25e ffffffff838b35a0
Call Trace:
[<ffffffff81ad7561>] __dump_stack lib/dump_stack.c:15 [inline]
[<ffffffff81ad7561>] dump_stack+0xc1/0x120 lib/dump_stack.c:51
[<ffffffff81b8f25e>] ubsan_epilogue+0x12/0x8d lib/ubsan.c:166
[<ffffffff81b900cb>] __ubsan_handle_divrem_overflow+0x282/0x2c8 lib/ubsan.c:262
[<ffffffff823560dd>] hpet_time_div drivers/char/hpet.c:572 [inline]
[<ffffffff823560dd>] hpet_ioctl_common drivers/char/hpet.c:663 [inline]
[<ffffffff823560dd>] hpet_ioctl_common.cold+0xa8/0xad drivers/char/hpet.c:577
[<ffffffff81e63d56>] hpet_ioctl+0xc6/0x180 drivers/char/hpet.c:676
[<ffffffff81711590>] vfs_ioctl fs/ioctl.c:43 [inline]
[<ffffffff81711590>] file_ioctl fs/ioctl.c:470 [inline]
[<ffffffff81711590>] do_vfs_ioctl+0x6e0/0xf70 fs/ioctl.c:605
[<ffffffff81711eb4>] SYSC_ioctl fs/ioctl.c:622 [inline]
[<ffffffff81711eb4>] SyS_ioctl+0x94/0xc0 fs/ioctl.c:613
[<ffffffff82846003>] tracesys_phase2+0x90/0x95
The main C reproducer autogenerated by syzkaller,
syscall(__NR_mmap, 0x20000000, 0x1000000, 3, 0x32, -1, 0);
memcpy((void*)0x20000100, "/dev/hpet\000", 10);
syscall(__NR_openat, 0xffffffffffffff9c, 0x20000100, 0, 0);
syscall(__NR_ioctl, r[0], 0x40086806, 0x40000000000000);
Fix it by using div64_ul().
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Signed-off-by: Zhang HongJun <zhanghongjun2@huawei.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Link: https://lore.kernel.org/r/20190711132757.130092-1-wangkefeng.wang@huawei.com
This is the 4.14.126 stable release
drivers/gpio/gpio-vf610.c:
Follow commit 338aa10750ba gpio: vf610: Do not share irq_chip
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c:
Follow commit 67793bd3b394 drm/bridge: adv7511: Fix low refresh rate selection
Use drm_mode_vrefresh(mode) helper
drivers/net/ethernet/freescale/fec_main.c:
Keep downstream file.
drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c
Follow commit 46953f97224d brcmfmac: fix missing checks for kmemdup
sound/soc/fsl/Kconfig:
Follow commit ea751227c813 ASoC: imx: fix fiq dependencies
Logical Conflicts:
sound/soc/fsl/fsl_sai.c:
Revert upstream d7325abe29b as downstream fixed it differently
drivers/clk/imx/clk-imx6sl.c
Revert upstream bda9f846ae0 as downstream implemented it differently 68c736e9378
[ Upstream commit 62f95ae805fa9e1e84d47d3219adddd97b2654b7 ]
Newer combinations of the glibc, kernel and openssh can result in long initial
startup times on OMAP devices:
[ 6.671425] systemd-rc-once[102]: Creating ED25519 key; this may take some time ...
[ 142.652491] systemd-rc-once[102]: Creating ED25519 key; done.
due to the blocking getrandom(2) system call:
[ 142.610335] random: crng init done
Set the quality level for the omap hwrng driver allowing the kernel to use the
hwrng as an entropy source at boot.
Signed-off-by: Rouven Czerwinski <r.czerwinski@pengutronix.de>
[ Upstream commit 4b0a2c5ff7215206ea6135a405f17c5f6fca7d00 ]
For regular serial ports we do not initialize value of vtermno
variable. A garbage value is assigned for non console ports.
The value can be observed as a random integer with [1].
[1] vim /sys/kernel/debug/virtio-ports/vport*p*
This patch initialize the value of vtermno for console serial
ports to '1' and regular serial ports are initiaized to '0'.
Reported-by: siliu@redhat.com
Signed-off-by: Pankaj Gupta <pagupta@redhat.com>
[ Upstream commit b7d5dc21072cda7124d13eae2aefb7343ef94197 ]
The per-CPU variable batched_entropy_uXX is protected by get_cpu_var().
This is just a preempt_disable() which ensures that the variable is only
from the local CPU. It does not protect against users on the same CPU
from another context. It is possible that a preemptible context reads
slot 0 and then an interrupt occurs and the same value is read again.
The above scenario is confirmed by lockdep if we add a spinlock:
| WARNING: inconsistent lock state
| 5.1.0-rc3+ #42 Not tainted
| inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
| ksoftirqd/9/56 [HC0[0]:SC1[1]:HE0:SE0] takes:
| (____ptrval____) (batched_entropy_u32.lock){+.?.}, at: get_random_u32+0x3e/0xe0
| {SOFTIRQ-ON-W} state was registered at:
| _raw_spin_lock+0x2a/0x40
| new_slab+0x15c/0x7b0
| ___slab_alloc+0x492/0x620
| __slab_alloc.isra.73+0x53/0xa0
| kmem_cache_alloc_node+0xaf/0x2a0
| copy_process.part.41+0x1e1/0x2370
| _do_fork+0xdb/0x6d0
| kernel_thread+0x20/0x30
| kthreadd+0x1ba/0x220
| ret_from_fork+0x3a/0x50
| other info that might help us debug this:
| Possible unsafe locking scenario:
| CPU0
| lock(batched_entropy_u32.lock);
| <Interrupt>
| *** DEADLOCK ***
| stack backtrace:
| Call Trace:
| kmem_cache_alloc_trace+0x20e/0x270
| ipmi_alloc_recv_msg+0x16/0x40
| __do_softirq+0xec/0x48d
| run_ksoftirqd+0x37/0x60
| smpboot_thread_fn+0x191/0x290
| kthread+0xfe/0x130
Add a spinlock_t to the batched_entropy data structure and acquire the
lock while accessing it. Acquire the lock with disabled interrupts
because this function may be used from interrupt context.
Remove the batched_entropy_reset_lock lock. Now that we have a lock for
the data scructure, we can access it from a remote CPU.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit 55be8658c7e2feb11a5b5b33ee031791dbd23a69 upstream.
According to ipmi spec, block number is a number that is incremented,
starting with 0, for each new block of message data returned using the
middle transaction.
Here, the 'blocknum' is data[0] which always starts from zero(0) and
'ssif_info->multi_pos' starts from 1.
So, we need to add +1 to blocknum while comparing with multi_pos.
Fixes: 7d6380cd40f79 ("ipmi:ssif: Fix handling of multi-part return messages").
Reported-by: Kiran Kolukuluru <kirank@ami.com>
Signed-off-by: Kamlakant Patel <kamlakantp@marvell.com>
Message-Id: <1556106615-18722-1-git-send-email-kamlakantp@marvell.com>
[Also added a debug log if the block numbers don't match.]
Cc: stable@vger.kernel.org # 4.4
[ Upstream commit 442601e87a4769a8daba4976ec3afa5222ca211d ]
Return -E2BIG when the transfer is incomplete. The upper layer does
not retry, so not doing that is incorrect behaviour.
Fixes: a2871c62e186 ("tpm: Add support for Atmel I2C TPMs")
commit c7084edc3f6d67750f50d4183134c4fb5712a5c8 upstream.
The n_r3964 line discipline driver was written in a different time, when
SMP machines were rare, and users were trusted to do the right thing.
Since then, the world has moved on but not this code, it has stayed
rooted in the past with its lovely hand-crafted list structures and
loads of "interesting" race conditions all over the place.
After attempting to clean up most of the issues, I just gave up and am
now marking the driver as BROKEN so that hopefully someone who has this
hardware will show up out of the woodwork (I know you are out there!)
and will help with debugging a raft of changes that I had laying around
for the code, but was too afraid to commit as odds are they would break
things.
Many thanks to Jann and Linus for pointing out the initial problems in
this codebase, as well as many reviews of my attempts to fix the issues.
It was a case of whack-a-mole, and as you can see, the mole won.
Reported-by: Jann Horn <jannh@google.com>
[ Upstream commit 24d48a61f2666630da130cc2ec2e526eacf229e3 ]
Commit '3d035f580699 ("drivers/char/hpet.c: allow user controlled mmap for
user processes")' introduced a new kernel command line parameter hpet_mmap,
that is required to expose the memory map of the HPET registers to
user-space. Unfortunately the kernel command line parameter 'hpet_mmap' is
broken and never takes effect due to missing '=' character in the __setup()
code of hpet_mmap_enable.
Before this patch:
dmesg output with the kernel command line parameter hpet_mmap=1
[ 0.204152] HPET mmap disabled
dmesg output with the kernel command line parameter hpet_mmap=0
[ 0.204192] HPET mmap disabled
After this patch:
[ 0.203945] HPET mmap enabled
[ 0.204652] HPET mmap disabled
Fixes: 3d035f580699 ("drivers/char/hpet.c: allow user controlled mmap for user processes")
Signed-off-by: Buland Singh <bsingh@redhat.com>
[ Upstream commit aef027db48da56b6f25d0e54c07c8401ada6ce21 ]
The virtio-rng driver uses a completion called have_data to wait for a
virtio read to be fulfilled by the hypervisor. The completion is reset
before placing a buffer on the virtio queue and completed by the virtio
callback once data has been written into the buffer.
Prior to this commit, the driver called init_completion on this
completion both during probe as well as when registering virtio buffers
as part of a hwrng read operation. The second of these init_completion
calls should instead be reinit_completion because the have_data
completion has already been inited by probe. As described in
Documentation/scheduler/completion.txt, "Calling init_completion() twice
on the same completion object is most likely a bug".
This bug was present in the initial implementation of virtio-rng in
f7f510ec1957 ("virtio: An entropy device, as suggested by hpa"). Back
then the have_data completion was a single static completion rather than
a member of one of potentially multiple virtrng_info structs as
implemented later by 08e53fbdb85c ("virtio-rng: support multiple
virtio-rng devices"). The original driver incorrectly used
init_completion rather than INIT_COMPLETION to reset have_data during
read.
Tested by running `head -c48 /dev/random | hexdump` within crosvm, the
Chrome OS virtual machine monitor, and confirming that the virtio-rng
driver successfully produces random bytes from the host.
Signed-off-by: David Tolnay <dtolnay@gmail.com>
Tested-by: David Tolnay <dtolnay@gmail.com>
commit f5595f5baa30e009bf54d0d7653a9a0cc465be60 upstream.
The send() callback should never return length as it does not in every
driver except tpm_crb in the success case. The reason is that the main
transmit functionality only cares about whether the transmit was
successful or not and ignores the count completely.
Suggested-by: Stefan Berger <stefanb@linux.ibm.com>
commit 3d7a850fdc1a2e4d2adbc95cc0fc962974725e88 upstream.
The current approach to read first 6 bytes from the response and then tail
of the response, can cause the 2nd memcpy_fromio() to do an unaligned read
(e.g. read 32-bit word from address aligned to a 16-bits), depending on how
memcpy_fromio() is implemented. If this happens, the read will fail and the
memory controller will fill the read with 1's.
This was triggered by 170d13ca3a2f, which should be probably refined to
check and react to the address alignment. Before that commit, on x86
memcpy_fromio() turned out to be memcpy(). By a luck GCC has done the right
thing (from tpm_crb's perspective) for us so far, but we should not rely on
that. Thus, it makes sense to fix this also in tpm_crb, not least because
the fix can be then backported to stable kernels and make them more robust
when compiled in differing environments.
Cc: Tomas Winkler <tomas.winkler@intel.com>
Cc: Jerry Snitselaar <jsnitsel@redhat.com>
Fixes: 30fc8d138e91 ("tpm: TPM 2.0 CRB Interface")
Acked-by: Tomas Winkler <tomas.winkler@intel.com>
commit d7ac3c6ef5d8ce14b6381d52eb7adafdd6c8bb3c upstream.
IndexCard is indirectly controlled by user-space, hence leading to
a potential exploitation of the Spectre variant 1 vulnerability.
This issue was detected with the help of Smatch:
drivers/char/applicom.c:418 ac_write() warn: potential spectre issue 'apbs' [r]
drivers/char/applicom.c:728 ac_ioctl() warn: potential spectre issue 'apbs' [r] (local cap)
Fix this by sanitizing IndexCard before using it to index apbs.
Notice that given that speculation windows are large, the policy is
to kill the speculation on the first load and not worry if it can be
completed with a dependent load/store [1].
[1] https://lore.kernel.org/lkml/20180423164740.GY17484@dhcp22.suse.cz/
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Bank0/Bank1 are not in ECC mode, so no need to check.
Each bank contains 8 words, so we check (phy_index > 15).
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Add ULP1 OTP support.
No timing required for ULP1 OTP.
The CTRL_ADDR is 8 bits width.
When finished access to OTP, gate the power to OTP memory to save power.
Fix store, when invalid args, not return 0, but return the error values.
To ULP, fuse only support being programmed once, so add a check before
program.
Test log:
root@imx6qdlsolo:/sys/fsl_otp# cat HW_OCOTP_GP84
0x0
root@imx6qdlsolo:/sys/fsl_otp# echo 1 > HW_OCOTP_GP84
0x1
-sh: echo: write error: Operation not permitted
root@imx6qdlsolo:/sys/fsl_otp# echo fg > HW_OCOTP_GP84
-sh: echo: write error: Invalid argument
Support i.MX6SLL OTP.
There are 4 works in bank7/bank8.
When read, use address offset.
When prog, use bank/index, note that bank7/bank8 we treat
them a single bank when prog.
Tested GP41 and GP31 read/write on eng sample chip.
(cherry picked from commit f8698b66fcbec7409b738a4c5b05ba87f0342cf8)
Add ocotp support for i.MX6ULL.
ENGR00292341 imx6sl hwrng
Add hwrng support for i.MX6SL.
1. Add RNG driver. This driver originated as fsl-rngc.c. It
has been modified to support device tree. The name has been
changed since it supports both b and c variants of RNG.
2. Added clock and compatible info to the device tree data.
3. Added the entry in the options in the Kconfig for hwrng.
(cherry picked from commit 1f3f2c0647b7319c4e23293a61512e4191593513)
[<vicki.milhoan@freescale.com>: Edited to apply to 3.14]
Signed-off-by: Dan Douglass <dan.douglass@freescale.com>
Signed-off-by: Victoria Milhoan <vicki.milhoan@freescale.com>
Fix the out of bounds write, and the dereference before
null check.
Signed-off-by: Richard Zhu <Richard.Zhu@freescale.com>
(cherry picked from commit 775ff0727166535e9b1ba1f70167e6a33fee5f13)
This is porting of fsl_otp driver from imx_3.14.y to imx_4.1.y.
This patch mainly from the following:
commit:292eff6d2c9064ecf15ed457140c1d743c2ead67
"ENGR00269945: char: add fsl_otp deivce driver"
This is a porting of fsl_otp driver from 3.0.35 kernel to 3.10. It
cleans up the driver a little bit and adds device tree probe support.
shawn.guo: cherry-pick commit 850237dccde7 from imx_3.10.y.
commit:057a50039fac872fd19fe6c129a94face4231ae8
"MLK-10979-4 imx: ocotp add i.MX7D support and fix hole"
1. Add i.MX7D support
2. Fix hole addressing.
There is a hole in shadow registers address map of size 0x100
between bank 5 and bank 6 on iMX6QP, iMX6DQ, iMX6SDL, iMX6SX and
iMX6UL. Bank 5 ends at 0x6F0 and Bank 6 starts at 0x800. When reading
the fuses, should account for this hole in address space.
Similar hole exists between bank 14 and bank 15 of size 0x80 on
iMX6QP, iMX6DQ, iMX6SDL and iMX6SX.
Note: iMX6SL has only 0-7 banks and there is no hole.
Note: iMX6UL doesn't have this one.
When reading, the hole need to be considered to calculated the physical
address offset.
When writing, since only word index for i.MX6 and bank
index for i.MX7, there is no need to take the hole into consideration,
still use the bank/word index from fuse map.
3. Add i.MX6SL i.MX6UL fuse map table.
4. Tested read/write on mx6ul-14x14-ddr3-arm2 and mx7d-12x12-lpddr3-arm2 board.
Tested read on mx6sxsabresd board.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
- add linux sema4 driver.
- use volatile types in sema4 structure.
- align the port definiton a9 is 1, m4 is 2.
Signed-off-by: Anson Huang <b20788@freescale.com>
Signed-off-by: Richard Zhu <r65037@freescale.com>
commit 701956d4018e5d5438570e39e8bda47edd32c489 upstream.
ipcnum is indirectly controlled by user-space, hence leading to
drivers/char/mwave/mwavedd.c:299 mwave_ioctl() warn: potential spectre issue 'pDrvData->IPCs' [w] (local cap)
Fix this by sanitizing ipcnum before using it to index pDrvData->IPCs.
[1] https://marc.info/?l=linux-kernel&m=152449131114778&w=2
commit 7d6380cd40f7993f75c4bde5b36f6019237e8719 upstream.
The block number was not being compared right, it was off by one
when checking the response.
Some statistics wouldn't be incremented properly in some cases.
Check to see if that middle-part messages always have 31 bytes of
data.
commit bc48fa1b9d3b04106055b27078da824cd209865a upstream.
Realtek has some sort of "Virtual" IPMI device on the PCI bus as a
KCS controller, but whatever it is, it's not one. Ignore it if seen.
[ Commit 13d0b35c (ipmi_si: Move PCI setup to another file) from Linux
4.15-rc1 has not been back ported, so the PCI code is still in
`drivers/char/ipmi/ipmi_si_intf.c`, requiring to apply the commit
manually.
This fixes a 100 s boot delay on the HP EliteDesk 705 G4 MT with Linux
4.14.94. ]
Reported-by: Chris Chiu <chiu@endlessm.com>
Tested-by: Daniel Drake <drake@endlessm.com>
Signed-off-by: Paul Menzel <pmenzel@molgen.mpg.de>
commit 2ba5780ce30549cf57929b01d8cba6fe656e31c5 upstream.
tpm_i2c_nuvoton calculated commands duration using TPM 1.x
values via tpm_calc_ordinal_duration() also for TPM 2.x chips.
Call tpm2_calc_ordinal_duration() for retrieving ordinal
duration for TPM 2.X chips.
Cc: Nayna Jain <nayna@linux.vnet.ibm.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
Reviewed-by: Nayna Jain <nayna@linux.ibm.com>
Tested-by: Nayna Jain <nayna@linux.ibm.com> (For TPM 2.0)
commit 01f54664a4db0d612de0ece8e0022f21f9374e9b upstream.
First, rename out_no_locality to out_locality for bailing out on
both tpm_cmd_ready() and tpm_request_locality() failure.
Second, ignore the return value of go_to_idle() as it may override
the return value of the actual tpm operation, the go_to_idle() error
will be caught on any consequent command.
Last, fix the wrong 'goto out', that jumped back instead of forward.
Fixes: 627448e85c76 ("tpm: separate cmd_ready/go_idle from runtime_pm")
commit e487a0f52301293152a6f8c4e217f2a11dd808e3 upstream.
Functionality of the xen-tpmfront driver was lost secondary to
the introduction of xenbus multi-page support in commit ccc9d90a9a8b
("xenbus_client: Extend interface to support multi-page ring").
In this commit pointer to location of where the shared page address
is stored was being passed to the xenbus_grant_ring() function rather
then the address of the shared page itself. This resulted in a situation
where the driver would attach to the vtpm-stubdom but any attempt
to send a command to the stub domain would timeout.
A diagnostic finding for this regression is the following error
message being generated when the xen-tpmfront driver probes for a
device:
<3>vtpm vtpm-0: tpm_transmit: tpm_send: error -62
<3>vtpm vtpm-0: A TPM error (-62) occurred attempting to determine
the timeouts
This fix is relevant to all kernels from 4.1 forward which is the
release in which multi-page xenbus support was introduced.
Daniel De Graaf formulated the fix by code inspection after the
regression point was located.
Fixes: ccc9d90a9a8b ("xenbus_client: Extend interface to support multi-page ring")
Signed-off-by: Dr. Greg Wettstein <greg@enjellic.com>
[boris: Updated commit message, added Fixes tag]
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: stable@vger.kernel.org # v4.1+
[ Upstream commit 0d6d0d62d9505a9816716aa484ebd0b04c795063 ]
For TPM 1.2 chips the system setup utility allows to set the TPM device in
one of the following states:
* Active: Security chip is functional
* Inactive: Security chip is visible, but is not functional
* Disabled: Security chip is hidden and is not functional
When choosing the "Inactive" state, the TPM 1.2 device is enumerated and
registered, but sending TPM commands fail with either TPM_DEACTIVATED or
TPM_DISABLED depending if the firmware deactivated or disabled the TPM.
Since these TPM 1.2 error codes don't have special treatment, inactivating
the TPM leads to a very noisy kernel log buffer that shows messages like
the following:
tpm_tis 00:05: 1.2 TPM (device-id 0x0, rev-id 78)
tpm tpm0: A TPM error (6) occurred attempting to read a pcr value
tpm tpm0: TPM is disabled/deactivated (0x6)
tpm tpm0: A TPM error (6) occurred attempting get random
ima: No TPM chip found, activating TPM-bypass! (rc=6)
Let's just suppress error log messages for the TPM_{DEACTIVATED,DISABLED}
return codes, since this is expected when the TPM 1.2 is set to Inactive.
In that case the kernel log is cleaner and less confusing for users, i.e:
Reported-by: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Javier Martinez Canillas <javierm@redhat.com>
commit 0711e8c1b4572d076264e71b0002d223f2666ed7 upstream.
Please note that below oops is from an older kernel, but the same
race seems to be present in the upstream kernel too.
---8<---
The following panic was encountered during removing the ipmi_ssif
module:
[ 526.352555] Unable to handle kernel paging request at virtual address ffff000006923090
[ 526.360464] Mem abort info:
[ 526.363257] ESR = 0x86000007
[ 526.366304] Exception class = IABT (current EL), IL = 32 bits
[ 526.372221] SET = 0, FnV = 0
[ 526.375269] EA = 0, S1PTW = 0
[ 526.378405] swapper pgtable: 4k pages, 48-bit VAs, pgd = 000000008ae60416
[ 526.385185] [ffff000006923090] *pgd=000000bffcffe803, *pud=000000bffcffd803, *pmd=0000009f4731a003, *pte=0000000000000000
[ 526.396141] Internal error: Oops: 86000007 [#1] SMP
[ 526.401008] Modules linked in: nls_iso8859_1 ipmi_devintf joydev input_leds ipmi_msghandler shpchp sch_fq_codel ib_iser rdma_cm iw_cm ib_cm ib_core iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi ip_tables x_tables autofs4 btrfs zstd_compress raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c raid1 raid0 multipath linear i2c_smbus hid_generic usbhid uas hid usb_storage ast aes_ce_blk i2c_algo_bit aes_ce_cipher qede ttm crc32_ce ptp crct10dif_ce drm_kms_helper ghash_ce syscopyarea sha2_ce sysfillrect sysimgblt pps_core fb_sys_fops sha256_arm64 sha1_ce mpt3sas qed drm raid_class ahci scsi_transport_sas libahci gpio_xlp i2c_xlp9xx aes_neon_bs aes_neon_blk crypto_simd cryptd aes_arm64 [last unloaded: ipmi_ssif]
[ 526.468085] CPU: 125 PID: 0 Comm: swapper/125 Not tainted 4.15.0-35-generic #38~lp1775396+build.1
[ 526.476942] Hardware name: To be filled by O.E.M. Saber/Saber, BIOS 0ACKL022 08/14/2018
[ 526.484932] pstate: 00400009 (nzcv daif +PAN -UAO)
[ 526.489713] pc : 0xffff000006923090
[ 526.493198] lr : call_timer_fn+0x34/0x178
[ 526.497194] sp : ffff000009b0bdd0
[ 526.500496] x29: ffff000009b0bdd0 x28: 0000000000000082
[ 526.505796] x27: 0000000000000002 x26: ffff000009515188
[ 526.511096] x25: ffff000009515180 x24: ffff0000090f1018
[ 526.516396] x23: ffff000009519660 x22: dead000000000200
[ 526.521696] x21: ffff000006923090 x20: 0000000000000100
[ 526.526995] x19: ffff809eeb466a40 x18: 0000000000000000
[ 526.532295] x17: 000000000000000e x16: 0000000000000007
[ 526.537594] x15: 0000000000000000 x14: 071c71c71c71c71c
[ 526.542894] x13: 0000000000000000 x12: 0000000000000000
[ 526.548193] x11: 0000000000000001 x10: ffff000009b0be88
[ 526.553493] x9 : 0000000000000000 x8 : 0000000000000005
[ 526.558793] x7 : ffff80befc1f8528 x6 : 0000000000000020
[ 526.564092] x5 : 0000000000000040 x4 : 0000000020001b20
[ 526.569392] x3 : 0000000000000000 x2 : ffff809eeb466a40
[ 526.574692] x1 : ffff000006923090 x0 : ffff809eeb466a40
[ 526.579992] Process swapper/125 (pid: 0, stack limit = 0x000000002eb50acc)
[ 526.586854] Call trace:
[ 526.589289] 0xffff000006923090
[ 526.592419] expire_timers+0xc8/0x130
[ 526.596070] run_timer_softirq+0xec/0x1b0
[ 526.600070] __do_softirq+0x134/0x328
[ 526.603726] irq_exit+0xc8/0xe0
[ 526.606857] __handle_domain_irq+0x6c/0xc0
[ 526.610941] gic_handle_irq+0x84/0x188
[ 526.614679] el1_irq+0xe8/0x180
[ 526.617822] cpuidle_enter_state+0xa0/0x328
[ 526.621993] cpuidle_enter+0x34/0x48
[ 526.625564] call_cpuidle+0x44/0x70
[ 526.629040] do_idle+0x1b8/0x1f0
[ 526.632256] cpu_startup_entry+0x2c/0x30
[ 526.636174] secondary_start_kernel+0x11c/0x130
[ 526.640694] Code: bad PC value
[ 526.643800] ---[ end trace d020b0b8417c2498 ]---
[ 526.648404] Kernel panic - not syncing: Fatal exception in interrupt
[ 526.654778] SMP: stopping secondary CPUs
[ 526.658734] Kernel Offset: disabled
[ 526.662211] CPU features: 0x5800c38
[ 526.665688] Memory Limit: none
[ 526.668768] ---[ end Kernel panic - not syncing: Fatal exception in interrupt
Prevent mod_timer from arming a timer that was already removed by
del_timer during module unload.
Signed-off-by: Jan Glauber <jglauber@cavium.com>
Cc: <stable@vger.kernel.org> # 3.19
[ Upstream commit 1fbad3028664e114d210dc65d768947a3a553eaa ]
In crb_map_io() function, __crb_request_locality() is called prior
to crb_cmd_ready(), but if one of the consecutive function fails
the flow bails out instead of trying to relinquish locality.
This patch adds goto jump to __crb_relinquish_locality() on the error path.
Fixes: 888d867df441 (tpm: cmd_ready command can be issued only after granting locality)
[ Upstream commit 92980756979a9c51be0275f395f4e89c42cf199a ]
Commit e2fb992d82c6 ("tpm: add retry logic") introduced a new loop to
handle the TPM2_RC_RETRY error. The loop retries the command after
sleeping for the specified time, which is incremented exponentially in
every iteration.
Unfortunately, the loop doubles the time before sleeping, causing the
initial sleep to be doubled. This patch fixes the initial sleep time.
Fixes: commit e2fb992d82c6 ("tpm: add retry logic")
Signed-off-by: Nayna Jain <nayna@linux.vnet.ibm.com>
Reviewed-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
commit 0745dde62835be7e2afe62fcdb482fcad79cb743 upstream.
The SSIF driver was removing any client that came in through the
platform interface, but it should only remove clients that it
added. On a failure in the probe function, this could result
in the following oops when the driver is removed and the
client gets unregistered twice:
CPU: 107 PID: 30266 Comm: rmmod Not tainted 4.18.0+ #80
Hardware name: Cavium Inc. Saber/Saber, BIOS Cavium reference firmware version 7.0 08/04/2018
pstate: 60400009 (nZCv daif +PAN -UAO)
pc : kernfs_find_ns+0x28/0x120
lr : kernfs_find_and_get_ns+0x40/0x60
sp : ffff00002310fb50
x29: ffff00002310fb50 x28: ffff800a8240f800
x27: 0000000000000000 x26: 0000000000000000
x25: 0000000056000000 x24: ffff000009073000
x23: ffff000008998b38 x22: 0000000000000000
x21: ffff800ed86de820 x20: 0000000000000000
x19: ffff00000913a1d8 x18: 0000000000000000
x17: 0000000000000000 x16: 0000000000000000
x15: 0000000000000000 x14: 5300737265766972
x13: 643d4d4554535953 x12: 0000000000000030
x11: 0000000000000030 x10: 0101010101010101
x9 : ffff800ea06cc3f9 x8 : 0000000000000000
x7 : 0000000000000141 x6 : ffff000009073000
x5 : ffff800adb706b00 x4 : 0000000000000000
x3 : 00000000ffffffff x2 : 0000000000000000
x1 : ffff000008998b38 x0 : ffff000008356760
Process rmmod (pid: 30266, stack limit = 0x00000000e218418d)
Call trace:
sysfs_unmerge_group+0x2c/0x6c
dpm_sysfs_remove+0x34/0x70
device_del+0x58/0x30c
device_unregister+0x30/0x7c
i2c_unregister_device+0x84/0x90 [i2c_core]
ssif_platform_remove+0x38/0x98 [ipmi_ssif]
platform_drv_remove+0x2c/0x6c
device_release_driver_internal+0x168/0x1f8
driver_detach+0x50/0xbc
bus_remove_driver+0x74/0xe8
driver_unregister+0x34/0x5c
platform_driver_unregister+0x20/0x2c
cleanup_ipmi_ssif+0x50/0xd82c [ipmi_ssif]
__arm64_sys_delete_module+0x1b4/0x220
el0_svc_handler+0x104/0x160
el0_svc+0x8/0xc
Code: aa1e03e0 aa0203f6 aa0103f7 d503201f (7940e280)
---[ end trace 09f0e34cce8e2d8c ]---
CPU features: 0x23800c38
So track the clients that the SSIF driver adds and only remove
those.
Reported-by: George Cherian <george.cherian@cavium.com>
Tested-by: George Cherian <george.cherian@cavium.com>
Cc: <stable@vger.kernel.org> # 4.14.x
[ Upstream commit bb853aac2c478ce78116128263801189408ad2a8 ]
Locking the root adapter for __i2c_transfer will deadlock if the
device sits behind a mux-locked I2C mux. Switch to the finer-grained
i2c_lock_bus with the I2C_LOCK_SEGMENT flag. If the device does not
sit behind a mux-locked mux, the two locking variants are equivalent.
Signed-off-by: Peter Rosin <peda@axentia.se>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
[ Upstream commit 1a339b658d9dbe1471f67b78237cf8fa08bbbeb5 ]
An SPI TPM device managed directly on an embedded board using
the SPI bus and some GPIO or similar line as IRQ handler will
pass the IRQn from the TPM device associated with the SPI
device. This is already handled by the SPI core, so make sure
to pass this down to the core as well.
(The TPM core habit of using -1 to signal no IRQ is dubious
(as IRQ 0 is NO_IRQ) but I do not want to mess with that
semantic in this patch.)
Cc: Mark Brown <broonie@kernel.org>
