Add clock enable code to driver.
OCOTP driver missed code to enable clock in driver.
Thus if ocotp clock is not enabled in clock.c, ocotp will not work.
Signed-off-by: Terry Lv <r65388@freescale.com>
This is the change for driver files.
Add virtual iim driver.
This driver will be used by MM team.
Add missed ocopt header file
Signed-off-by: Frank Li <Frank.Li@freescale.com>
Add a new driver for On-Chip OTP controller. The driver
will register all the register names of all the banks to /sys/.
You can use the following commands to manipulate the OTP banks:
read:
#cat HW_OCOTP_MAC0
write:
#echo 0x11223344 > HW_OCOTP_MAC0
Add console output for iim value.
When open mxc_iim twice, mxc_iim can't be close twice.
mxc_iim: let mxc_iim work with dd and echo.
mxc_iim can't be open twice.
The reason is that request_irq failed when open mxc_iim again.
So put request_irq function to probe function.
read:
#cat HW_OCOTP_MAC0
write:
Signed-off-by: Huang Shijie <b32955@freescale.com>
Add RNGB driver support by porting fsl_rngc driver from 2.6.35.
Signed-off-by: Anish Trivedi <anish@freescale.com>
add iim driver for 2.6.38
commit 3321c07ae5068568cd61ac9f4ba749006a7185c9 upstream.
Since the buffer might contain security related data it might be a good idea to
zero the buffer after we have copied it to userspace.
This got assigned CVE-2011-1162.
Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
commit 6b07d30aca7e52f2881b8c8c20c8a2cd28e8b3d3 upstream.
This patch changes the call of tpm_transmit by supplying the size of the
userspace buffer instead of TPM_BUFSIZE.
This got assigned CVE-2011-1161.
[The first hunk didn't make sense given one could expect
way less data than TPM_BUFSIZE, so added tpm_transmit boundary
check over bufsiz instead
The last parameter of tpm_transmit() reflects the amount
of data expected from the device, and not the buffer size
being supplied to it. It isn't ideal to parse it directly,
so we just set it to the maximum the input buffer can handle
and let the userspace API to do such job.]
Computers have become a lot faster since we compromised on the
partial MD4 hash which we use currently for performance reasons.
MD5 is a much safer choice, and is inline with both RFC1948 and
other ISS generators (OpenBSD, Solaris, etc.)
Furthermore, only having 24-bits of the sequence number be truly
unpredictable is a very serious limitation. So the periodic
regeneration and 8-bit counter have been removed. We compute and
use a full 32-bit sequence number.
For ipv6, DCCP was found to use a 32-bit truncated initial sequence
number (it needs 43-bits) and that is fixed here as well.
Reported-by: Dan Kaminsky <dan@doxpara.com>
Tested-by: Willy Tarreau <w@1wt.eu>
Konstantin Belousov found an error in the define of G4x_GMCH_SIZE_VT_2M
relative to the GMCH specs, and confirmed that indeed one of his users
with a Q45 reports 0xb not 0xc for a 2/2MiB GATT.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Konstantin Belousov <kostikbel@gmail.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
When interrupts are delayed due to interrupt masking or due to other
interrupts being serviced the HPET periodic-emuation would fail. This
happened because given an interval t and a time for the current interrupt
m we would compute the next time as t + m. This works until we are
delayed for > t, in which case we would be writing a new value which is in
fact in the past.
This can be solved by computing the next time instead as (k * t) + m where
k is large enough to be in the future. The exact computation of k is
described in a comment to the code.
More detail:
Assuming an interval of 5 between each expected interrupt we have a normal
case of
t0: interrupt, read t0 from comparator, set next interrupt t0 + 5
t5: interrupt, read t5 from comparator, set next interrupt t5 + 5
t10: interrupt, read t10 from comparator, set next interrupt t10 + 5
So, what happens when the interrupt is serviced too late?
t11: delayed interrupt serviced, read t5 from comparator, set next
interrupt t5 + 5, which is in the past!
... counter loops ...
t10: Much much later, get the next interrupt.
This can happen either because we have interrupts masked for too long
(some stupid driver goes on a printk rampage) or just because we are
pushing the limits of the interval (too small a period), or both most
probably.
My solution is to read the main counter as well and set the next interrupt
to occur at the right interval, for example:
interrupt t15 as t10 has been missed.
t15: back on track.
Signed-off-by: Nils Carlson <nils.carlson@ericsson.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Clemens Ladisch <clemens@ladisch.de>
That's already been done by the virtio infrastructure before the probe
function is called.
Reported-by: alexey.kardashevskiy@au1.ibm.com
Acked-by: Amit Shah <amit.shah@redhat.com>
Tested-by: Amit Shah <amit.shah@redhat.com>
parport_find_number() calls parport_get_port() on its result, so there
should be a corresponding call to parport_put_port() before dropping the
reference. Similar code is found in the function register_device() in the
same file.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@exists@
local idexpression struct parport * x;
expression ra,rr;
statement S1,S2;
x = parport_find_number(...)
... when != x = rr
when any
when != parport_put_port(x,...)
when != if (...) { ... parport_put_port(x,...) ...}
if(<+...x...+>) S1 else S2
if(...) { ... when != x = ra
when forall
*return...;
// </smpl>
Let memory allocator initialize the allocated memory as null, thus remove
the use of memset.
Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com>
The ->read_proc interface is going away, convert to seq_file.
Cc:Corey Minyard <minyard@acm.org>
Let i8k create an hwmon class device so that libsensors will expose
the CPU temperature and fan speeds to monitoring applications.
Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
Cc: Massimo Dal Zotto <dz@debian.org>
i8k uses lahf to read the flag register in 64-bit code; early x86-64
CPUs, however, lack this instruction and we get an invalid opcode
exception at runtime.
Use pushf to load the flag register into the stack instead.
Signed-off-by: Luca Tettamanti <kronos.it@gmail.com>
Reported-by: Jeff Rickman <jrickman@myamigos.us>
Tested-by: Jeff Rickman <jrickman@myamigos.us>
Tested-by: Harry G McGavran Jr <w5pny@arrl.net>
Cc: stable@kernel.org
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6:
pcmcia: Make struct pcmcia_device_id const, sound drivers edition
staging: pcmcia: Convert pcmcia_device_id declarations to const
pcmcia: Make declaration and uses of struct pcmcia_device_id const
pcmcia/sa1100: put sa11x0_pcmcia_hw_init[] to .devinit.data
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (169 commits)
drivers/gpu/drm/radeon/atom.c: fix warning
drm/radeon/kms: bump kms version number
drm/radeon/kms: properly set num banks for fusion asics
drm/radeon/kms/atom: move dig phy init out of modesetting
drm/radeon/kms/cayman: fix typo in register mask
drm/radeon/kms: fix typo in spread spectrum code
drm/radeon/kms: fix tile_config value reported to userspace on cayman.
drm/radeon/kms: fix incorrect comparison in cayman setup code.
drm/radeon/kms: add wait idle ioctl for eg->cayman
drm/radeon/cayman: setup hdp to invalidate and flush when asked
drm/radeon/evergreen/btc/fusion: setup hdp to invalidate and flush when asked
agp/uninorth: Fix lockups with radeon KMS and >1x.
drm/radeon/kms: the SS_Id field in the LCD table if for LVDS only
drm/radeon/kms: properly set the CLK_REF bit for DCE3 devices
drm/radeon/kms: fixup eDP connector handling
drm/radeon/kms: bail early for eDP in hotplug callback
drm/radeon/kms: simplify hotplug handler logic
drm/radeon/kms: rewrite DP handling
drm/radeon/kms/atom: add support for setting DP panel mode
drm/radeon/kms: atombios.h updates for DP panel mode
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/apm
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/apm:
apm-emulation: apm_mutex breaks ACK; remove it
APM: take over maintainership
apm_mutex is locked by a process (e.g. apm -s) at the start of apm_ioctl() and
remains locked while pm_suspend() is called. Any subsequent process trying to
ACK the suspend (e.g. apmd) is then blocked at the start of apm_ioctl(),
causing the suspend to be delayed for 5 seconds in apm_suspend_notifier()
while the ACK times out. In short, ACKs don't work.
The driver's data structures are sufficiently protected by assorted locks. And
pm_suspend() has its own mutex to prevent reentrancy. Consequently there is no
obvious requirement for apm_mutex, which evolved from earlier BKL calls. So
let's remove it.
Signed-off-by: Paul Parsons <lost.distance@yahoo.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
This was based on a description by Ben Herrenschmidt:
> I've removed that SBA reset from the normal TLB invalidation path and
> left it only once after turning AGP on.
About six months ago, he said:
> I did it a bit differently, but yeah, you get the idea. I'm doing a
> patch series so don't bother pushing things too hard yet.
But I haven't seen anything from him about this since then, and people are
regularly hitting these lockups, so here we are...
Signed-off-by: Michel Dänzer <daenzer@vmware.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Signed-off-by: Dave Airlie <airlied@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (45 commits)
crypto: caam - add support for sha512 variants of existing AEAD algorithms
crypto: caam - remove unused authkeylen from caam_ctx
crypto: caam - fix decryption shared vs. non-shared key setting
crypto: caam - platform_bus_type migration
crypto: aesni-intel - fix aesni build on i386
crypto: aesni-intel - Merge with fpu.ko
crypto: mv_cesa - make count_sgs() null-pointer proof
crypto: mv_cesa - copy remaining bytes to SRAM only when needed
crypto: mv_cesa - move digest state initialisation to a better place
crypto: mv_cesa - fill inner/outer IV fields only in HMAC case
crypto: mv_cesa - refactor copy_src_to_buf()
crypto: mv_cesa - no need to save digest state after the last chunk
crypto: mv_cesa - print a warning when registration of AES algos fail
crypto: mv_cesa - drop this call to mv_hash_final from mv_hash_finup
crypto: mv_cesa - the descriptor pointer register needs to be set just once
crypto: mv_cesa - use ablkcipher_request_cast instead of the manual container_of
crypto: caam - fix printk recursion for long error texts
crypto: caam - remove unused keylen from session context
hwrng: amd - enable AMD hw rnd driver for Maple PPC boards
hwrng: amd - manage resource allocation
Manual merge of arch/powerpc/kernel/smp.c and add missing scheduler_ipi()
call to arch/powerpc/platforms/cell/interrupt.c
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6
* 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (44 commits)
debugfs: Silence DEBUG_STRICT_USER_COPY_CHECKS=y warning
sysfs: remove "last sysfs file:" line from the oops messages
drivers/base/memory.c: fix warning due to "memory hotplug: Speed up add/remove when blocks are larger than PAGES_PER_SECTION"
SYSFS: Fix erroneous comments for sysfs_update_group().
driver core: remove the driver-model structures from the documentation
driver core: Add the device driver-model structures to kerneldoc
Translated Documentation/email-clients.txt
RAW driver: Remove call to kobject_put().
reboot: disable usermodehelper to prevent fs access
efivars: prevent oops on unload when efi is not enabled
Allow setting of number of raw devices as a module parameter
Introduce CONFIG_GOOGLE_FIRMWARE
driver: Google Memory Console
driver: Google EFI SMI
x86: Better comments for get_bios_ebda()
x86: get_bios_ebda_length()
misc: fix ti-st build issues
params.c: Use new strtobool function to process boolean inputs
debugfs: move to new strtobool
Fix up trivial conflicts in fs/debugfs/file.c due to the same patch
being applied twice, and an unrelated cleanup nearby.
* 'timers-clocksource-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
clocksource: convert mips to generic i8253 clocksource
clocksource: convert x86 to generic i8253 clocksource
clocksource: convert footbridge to generic i8253 clocksource
clocksource: add common i8253 PIT clocksource
blackfin: convert to clocksource_register_hz
mips: convert to clocksource_register_hz/khz
sparc: convert to clocksource_register_hz/khz
alpha: convert to clocksource_register_hz
microblaze: convert to clocksource_register_hz/khz
ia64: convert to clocksource_register_hz/khz
x86: Convert remaining x86 clocksources to clocksource_register_hz/khz
Make clocksource name const
Commit b826291c, "drivercore/dt: add a match table pointer to struct
device" added an of_match pointer to struct device to cache the
of_match_table entry discovered at driver match time. This was unsafe
because matching is not an atomic operation with probing a driver. If
two or more drivers are attempted to be matched to a driver at the
same time, then the cached matching entry pointer could get
overwritten.
This patch reverts the of_match cache pointer and reworks all users to
call of_match_device() directly instead.
master.kernel.org:~rmk/linux-2.6-arm into timers/clocksource
arch/ia64/kernel/cyclone.c
arch/mips/kernel/i8253.c
arch/x86/kernel/i8253.c
Reason: Resolve conflicts so further cleanups do not conflict further
Just use the Sandy Bridge routines.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Reviewed-by: Keith Packard <keithp@keithp.com>
Signed-off-by: Keith Packard <keithp@keithp.com>
If cdev_add() fails, there is no justification for subsequently
calling kobject_put().
Allow setting of maximal number of raw devices as a module parameter. This
requires changing of static array into a vmalloced one (the array is going to
be too large for kmalloc).
Saves about 50KB of data.
Old/new size of all objects:
563015 80096 130684 773795 bcea3 (TOTALS)
610916 32256 130632 773804 bceac (TOTALS)
Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> (for drivers/net/can/softing/softing_cs.c)
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Remove the unnecessary initialization of "dev_t bsr_dev" since it's
subsequently used in an "alloc_chrdev_region()" call which uses that
variable in an output-only fashion.
PPC 970FX Evaluation kit (Maple) boards bear AMD8111 southbridge.
Allow this driver to be compiled in if PPC_MAPLE is selected.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Acked-by: Matt Mackall <mpm@selenic.com>
As amd driver doesn't bind to PCI device, we'd better manage reource
allocation on our own to disallow (possible) conflicts.
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus:
virtio: console: Enable call to hvc_remove() on console port remove
virtio_pci: Prevent double-free of pci regions after device hot-unplug
virtio: Decrement avail idx on buffer detach
This call was disabled as hot-unplugging one virtconsole port led to
another virtconsole port freezing.
Upon testing it again, this now works, so enable it.
In addition, a bug was found in qemu wherein removing a port of one type
caused the guest output from another port to stop working. I doubt it
was just this bug that caused it (since disabling the hvc_remove() call
did allow other ports to continue working), but since it's all solved
now, we're fine with hot-unplugging of virtconsole ports.
Signed-off-by: Amit Shah <amit.shah@redhat.com>
pg_start is copied from userspace on AGPIOC_BIND and AGPIOC_UNBIND ioctl
cmds of agp_ioctl() and passed to agpioc_bind_wrap(). As said in the
comment, (pg_start + mem->page_count) may wrap in case of AGPIOC_BIND,
and it is not checked at all in case of AGPIOC_UNBIND. As a result, user
with sufficient privileges (usually "video" group) may generate either
local DoS or privilege escalation.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
page_count is copied from userspace. agp_allocate_memory() tries to
check whether this number is too big, but doesn't take into account the
wrap case. Also agp_create_user_memory() doesn't check whether
alloc_size is calculated from num_agp_pages variable without overflow.
This may lead to allocation of too small buffer with following buffer
overflow.
Another problem in agp code is not addressed in the patch - kernel memory
exhaustion (AGPIOC_RESERVE and AGPIOC_ALLOCATE ioctls). It is not checked
whether requested pid is a pid of the caller (no check in agpioc_reserve_wrap()).
Each allocation is limited to 16KB, though, there is no per-process limit.
This might lead to OOM situation, which is not even solved in case of the
caller death by OOM killer - the memory is allocated for another (faked) process.
make `len' size_t, avoid multiple-assignments.
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Lennart Poettering <lennart@poettering.net>
lines
printk: /dev/kmsg - properly support writev() to avoid interleaved printk lines
We should avoid calling printk() in a loop, when we pass a single
string to /dev/kmsg with writev().
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
This patch fixes information leakage to the userspace by initializing
the data buffer to zero.
Reported-by: Peter Huewe <huewe.external@infineon.com>
Signed-off-by: Peter Huewe <huewe.external@infineon.com>
Signed-off-by: Marcel Selhorst <m.selhorst@sirrix.com>
[ Also removed the silly "* sizeof(u8)". If that isn't 1, we have way
deeper problems than a simple multiplication can fix. - Linus ]
