Drivers that register a ->fault handler, but do not range-check the
offset argument, must set VM_DONTEXPAND in the vm_flags in order to
prevent an expanding mremap from overflowing the resource.
I've audited the tree and attempted to fix these problems (usually by
adding VM_DONTEXPAND where it is not obvious).
Signed-off-by: Nick Piggin <npiggin@suse.de>
The APM emulation is currently broken as a result of commit
831441862956fffa17b9801db37e6ea1650b0f69
"Freezer: make kernel threads nonfreezable by default"
that removed the PF_NOFREEZE annotations from apm_ioctl() without
adding the appropriate freezer hooks. Fix it and remove the
unnecessary variable flags from apm_ioctl().
This problem has been fixed in the mainline by
commit cb43c54ca05c01533c45e4d3abfe8f99b7acf624
"Freezer: Fix APM emulation breakage".
patch db99247ac68fc352100090ad7704fb5efb9327b6 in mainline.
Commit 5a52bd4a2dcb570333ce6fe2e16cd311650dbdc8 introduced a subtle logic
change in tty_wait_until_sent(). The original version would only error out
of the 'do { ... } while (timeout)' loop if signal_pending() evaluated to
true; a timeout or break due to an empty buffer would fall out of the loop
and into the tty->driver->wait_until_sent handling. The current
implementation will error out on either a pending signal or an empty
buffer, falling through to the tty->driver->wait_until_sent handling only
on a timeout.
The ->wait_until_sent() will not be reached if the buffer empties before
timeout jiffies have elapsed. This behavior differs from that prior to commit
5a52bd4a2dcb570333ce6fe2e16cd311650dbdc8.
I turned this up while using a little serial download utility to bootstrap an
ARM-based eval board. The util worked fine on 2.6.22.x, but consistently
failed on 2.6.23.x. Once I'd determined that, I narrowed things down with git
bisect, and found the above difference in logic in tty_wait_until_sent() by
inspection.
This change reverts the logic flow in tty_wait_until_sent() to match that
prior to the aforementioned commit.
Signed-off-by: Cory T. Tusar <ctusar@videon-central.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Acked-by: Jiri Slaby <jirislaby@gmail.com>
This reverts commit a6eda373a0fe1c4d169d0ec081518d68323428ab.
It causes a build breakage.
Thanks to Chuck Ebbert <cebbert@redhat.com> for pointing it out.
patch cb43c54ca05c01533c45e4d3abfe8f99b7acf624 in mainline.
that removed the PF_NOFREEZE annotations from apm_ioctl() without adding
the appropriate freezer hooks. Fix it and remove the unnecessary variable flags
from apm_ioctl().
Special thanks to Franck Bui-Huu <vagabon.xyz@gmail.com> for pointing out the
problem.
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Franck Bui-Huu <vagabon.xyz@gmail.com>
Cc: Nigel Cunningham <nigel@nigel.suspend2.net>
Signed-off-by: Len Brown <len.brown@intel.com>
[NET] random : secure_tcp_sequence_number should not assume CONFIG_KTIME_SCALAR
[ Upstream commit: 6dd10a62353a50b30b30e0c18653650975b29c71 ]
All 32 bits machines but i386 dont have CONFIG_KTIME_SCALAR. On these
machines, ktime.tv64 is more than 4 times the (correct) result given
by ktime_to_ns()
Again on these machines, using ktime_get_real().tv64 >> 6 give a
32bits rollover every 64 seconds, which is not wanted (less than the
120 s MSL)
Using ktime_to_ns() is the portable way to get nsecs from a ktime, and
have correct code.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Upstream as 7fc86860cf73e060ab8ed9763010dfe5b5389b1c
This code relied on the CPU and GPU address for the aperture being the same,
On some r5xx hardware I was playing with I noticed that this isn't always true.
This fixes issues seen on some r400 cards. (bugs.freedesktop.org 9957)
patch c43422053bea7a5ce09f18d0c50a606fe1a549f4 in mainline.
moxa, fix and optimise empty timer
don't wait and delete empty timer in empty timer function. Also fire next
empty timer at rounded jiffies to save power.
This fixes a lockup, because we wait for ourselves to finish forever.
(i.e. sync called from the timer itself).
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
patch ac6aec2f5683588361ab408cb3346b08c66bdfbe in mainline.
- register_device unconditionally (non-pci dependent) to have also isa
devices in /dev
- unregister devices on module removal
- don't set TTY_DRIVER_DYNAMIC_DEV twice (removed the one dependent on some
macro)
This is the substantial part of the patch and the previous point is for
not checking which devices to unregister and which not (simply register
and unregister all found no matter on which bus they are plugged).
Cc: Ferenc Wagner <wferi@niif.hu>
This is upstream as 54583bf4efda79388fc13163e35c016c8bc5de81
Oops...
Signed-off-by: Dave Airlie <airlied@linux.ie>
When building a custom keymap, after setting GENERATE_KEYMAP := 1 in
drivers/char/Makefile, the kernel build fails like this:
CC drivers/char/vt.o
make[2]: *** No rule to make target `drivers/char/%.map', needed by `drivers/char/defkeymap.c'. Stop.
make[1]: *** [drivers/char] Error 2
make: *** [drivers] Error 2
This was caused by commit af8b128719f5248e542036ea994610a29d0642a6, which
deleted a necessary colon from the Makefile rule that generates the keymap,
since that rule contains both a target and a target-pattern. The following
patch puts the colon back:
Signed-off-by: Maarten Bressers <mbres@gentoo.org>
Cc: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
We should generally prefer to return ERESTARTNOHAND rather than EINTR,
so that processes with unhandled signals that get ignored don't return
EINTR.
This can help with X startup issues:
Fatal server error:
xf86OpenConsole: VT_WAITACTIVE failed: Interrupted system call
although the real fix is having the X server always retry EINTR
regardless (since EINTR does happen for signals that have handlers
installed). Keithp has a patch for that.
Regardless, ERESTARTNOHAND is the correct thing to use.
This reverts commit f443675affe3f16dd428e46f0f7fd3f4d703eeab, which
breaks horribly if you aren't running an unreleased xf86-video-intel
driver out of git.
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
Cc: Dave Airlie <airlied@linux.ie>
Cc: Zhenyu Wang <zhenyu.z.wang@intel.com>
Acked-by: Keith Packard <keithp@keithp.com>
TCP V4 sequence numbers are 32bits, and RFC 793 assumed a 250 KHz clock.
In order to follow network speed increase, we can use a faster clock, but
we should limit this clock so that the delay between two rollovers is
greater than MSL (TCP Maximum Segment Lifetime : 2 minutes)
Choosing a 64 nsec clock should be OK, since the rollovers occur every
274 seconds.
Problem spotted by Denys Fedoryshchenko
[ This bug was introduced by f85958151900f9d30fa5ff941b0ce71eaa45a7de ]
When calling the RELDISP VT ioctl, we are reading vt_newvt while the
console workqueue could be messing with it (through change_console()). We
fix this race by taking the console semaphore before reading vt_newvt.
Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
Acked-by: Antonino Daplas <adaplas@gmail.com>
The new behaviour of CFS exposes a race which occurs if a switch is
requested when vt_mode.mode is VT_PROCESS.
The process with vc->vt_pid is signaled before vc->vt_newvt is set.
This causes the switch to fail when triggered by the monitoing process
because the target is still -1.
[ If the signal sending fails, the subsequent "reset_vc(vc)" will then
reset vt_newvt to -1, so this works for that case too. - Linus ]
Signed-off-by: Jan Lübbe <jluebbe@lasnet.de>
This code is ported from the DRM git tree and allows the vblank interrupts
to function on the i965 hw. It also requires a change in Mesa's 965 driver
to actually use them.
[ Without this patch, my 965GM drops vblank interrupts - Jesse ]
Acked-by: Jesse Barnes <jesse.barnes@intel.com>
Following patch silents;
drivers/char/hpet.c:72: warning: 'clocksource_hpet' defined but not used
drivers/char/hpet.c:81: warning: 'hpet_clocksource' defined but not used
build warnings on i386, they appeared after commit 3b2b64fd311c92f2137eb7cee7025794cd854057
Signed-off-by: S.Çağlar Onur <caglar@pardus.org.tr>
drivers/char/hpet.c | 3 +++
1 files changed, 3 insertions(+), 0 deletions(-)
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
ACPI: hpet: ACPI Error (utglobal-0126): Unknown exception code: 0xFFFFFFF0
ACPI: CONFIG_ACPI_SLEEP=n power off regression in 2.6.23-rc8 (NOT in rc7)
ACPI: suspend: build-fix for CONFIG_SUSPEND=n and CONFIG_HIBERNATION=y
If hpet has been initialized before registering hpet driver, the callback
function of hpet_resources will return the status code of -EBUSY, which is
not defined in the ACPI exception table. So when ACPI checks the status
code of callback function, it will report the unknown exception code.
So the status code in ACPI is used instead of the generic error code in the
ACPI callback function of hpet_resources.
For example: -EBUSY is replaced by AE_ALREADY_EXISTS
-EINVAL is replaced by AE_NO_MEMORY
http://bugzilla.kernel.org/show_bug.cgi?id=8630
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
The vma_data structure may be shared by vma's from multiple tasks, with no
way of knowing which areas are shared or not shared, so release/clear pages
only when the refcount (of vma's) goes to zero.
Signed-off-by: Cliff Wickman <cpw@sgi.com>
Cc: Jes Sorensen <jes@sgi.com>
The mask on i830 should be 0x70 always, later chips 0xF0 should be okay.
Acked-by: Zhenyu Wang <zhenyu.z.wang@intel.com>
Cc: Michael Haas <laga@laga.ath.cx>
Fix a couple drivers that do not correctly terminate their pci_device_id
lists. This results in garbage being spewed into modules.pcimap when the
module happens to not have 28 NULL bytes following the table, and/or the
last PCI ID is actually truncated from the table when calculating the
modules.alias PCI aliases, cause those unfortunate device IDs to not
auto-load.
Signed-off-by: Kees Cook <kees@ubuntu.com>
Acked-by: Corey Minyard <minyard@acm.org>
Acked-by: Jeff Garzik <jeff@garzik.org>
Cc: Greg KH <greg@kroah.com>
The shrinking of a virtual memory area that is mmap(2)'d to a memory
special file (device drivers/char/mspec.c) can cause a panic.
If the mapped size of the vma (vm_area_struct) is very large, mspec allocates
a large vma_data structure with vmalloc(). But such a vma can be shrunk by
an munmap(2). The current driver uses the current size of each vma to
deduce whether its vma_data structure was allocated by kmalloc() or vmalloc().
So if the vma was shrunk it appears to have been allocated by kmalloc(),
and mspec attempts to free it with kfree(). This results in a panic.
This patch avoids the panic (by preserving the type of the allocation) and
also makes mspec work correctly as the vma is split into pieces by the
munmap(2)'s.
All vma's derived from such a split vma share the same vma_data structure that
represents all the pages mapped into this set of vma's. The mpec driver
must be made capable of using the right portion of the structure for each
member vma. In other words, it must index into the array of page addresses
using the portion of the array that represents the current vma. This is
enabled by storing the vma group's vm_start in the vma_data structure.
The shared vma_data's are not protected by mm->mmap_sem in the fork() case
so the reference count is left as atomic_t.
Acked-by: Jes Sorensen <jes@sgi.com>
Add Guards around TIOCSLCKTRMIOS and TIOCGLCKTRMIOS.
Several architectures are still broken. Put temporary-for-2.6.23 ifdef guards
around the offending code.
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com>
Signed-off-by:: Linus Torvalds <torvalds@linux-foundation.org>
G33 has 1MB GTT table range. Fix GTT mapping in case like 512MB aperture
size.
Signed-off-by: Zhenyu Wang <zhenyu.z.wang@intel.com>
Acked-by: Dave Airlie <airlied@linux.ie>
Cc: Dave Jones <davej@codemonkey.org.uk>
G33 GTT stolen memory is below graphics data stolen memory and be seperate,
so don't subtract it in stolen mem counting.
I ran into a few problems.
n_tty_ioctl() for instance:
drivers/char/tty_ioctl.c:799: error: $,1rxstruct termios$,1ry has no
member named $,1rxc_ispeed$,1ry
This is calling the copy interface that is supposed to be using
a termios2 when the new interfaces are defined, however:
case TIOCGLCKTRMIOS:
if (kernel_termios_to_user_termios((struct termios __user *)arg, real_tty->termios_locked))
return -EFAULT;
return 0;
This is going to write over the end of the userspace
structure by a few bytes, and wasn't caught by you yet
because the i386 implementation is simply copy_to_user()
which does zero type checking.
Signed-off-by: Alan Cox <alan@redhat.com>
The HPET clocksource in drivers/char/hpet.c was written as generic code
for ia64, but it is not yet ready to replace the native HPET clocksource
implementations that the i386/x86-64 architectures use.
On x86[-64], trying to register this clocksource results in potentially
multiple hpet-based clocksources being registered, and if the ia64 one
is chosen on x86_64 some users have experienced hangs.
Eventually all three architectures may end up using the same code, but
that is not the case right now.
Cc: John Stultz <johnstul@us.ibm.com>
Cc: Paolo Ornati <ornati@fastwebnet.it>
Cc: Bob Picco <bob.picco@hp.com>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6
* 'agp-patches' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6:
agp: balance ioremap checks
agp: Add device id for P4M900 to via-agp module
efficeon-agp leaks 'struct agp_bridge_data' in error paths of agp_efficeon_probe()
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-patches' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm: ioremap return value checks
drm/via: Fix dmablit when blit queue is full
drm_rmmap_ioctl(): remove dead code
Signed-off-by: Scott Thompson <postfail <at> hushmail.com>
patchset against 2.6.23-rc3.
corrects missing ioremap return checks and balancing on iounmap calls, integrated changes per list
recommendations on the original set of patches..
drivers/acpi/video.c
kmalloc() hands us a void pointer, we don't need to cast it.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Schedule /proc/acpi/event for removal in 6 months.
Re-name acpi_bus_generate_event() to acpi_bus_generate_proc_event()
to make sure there is no confusion that it is for /proc/acpi/event only.
Add CONFIG_ACPI_PROC_EVENT to allow removal of /proc/acpi/event.
There is no functional change if CONFIG_ACPI_PROC_EVENT=y
Get module reference on open() by generic HDLC to prevent module from
unloading while interface is active.
Signed-off-by: Paul Fulghum <paulkf@microgate.com>
trivial change: fix warning
Signed-off-by: Mijo Safradin <safradin@de.ibm.com>
Acked-by: Christian Krafft <krafft@de.ibm.com>
Signed-off-by: Corey Minyard <cminyard@mvista.com>
m68k/mac: Make mac_hid_mouse_emulate_buttons() declaration visible
drivers/char/keyboard.c: In function 'kbd_keycode':
drivers/char/keyboard.c:1142: error: implicit declaration of function 'mac_hid_mouse_emulate_buttons'
The forward declaration of mac_hid_mouse_emulate_buttons() is not visible on
m68k because it's hidden in the middle of a big #ifdef block.
Move it to <linux/kbd_kern.h>, correct the type of the second parameter, and
include <linux/kbd_kern.h> where needed.
Fix up the maintainers info in the tpm drivers. Kylene will be out for
some time, so copying the sourceforge list is the best way to get some
attention.
Cc: Marcel Selhorst <tpm@selhorst.net>
Cc: Kylene Jo Hall <kjhall@us.ibm.com>
They are apparently pretty close (even lspci combines them). The patch
adds support for 0x1533 bridge in addition to 0x1535.
Tested on Toshiba Portege 4000 with
00:07.0 ISA bridge [0601]: ALi Corporation M1533/M1535 PCI to ISA Bridge
[Aladdin IV/V/V+] [10b9:1533]
00:08.0 Bridge [0680]: ALi Corporation M7101 Power Management Controller
[PMU] [10b9:7101]
with result
[ 2090.906736] PCI: Enabling device 0000:00:08.0 (0000 -> 0001)
[ 2090.914034] ALi_M1535: initialized. timeout=3D60 sec (nowayout=3D0)
Signed-off-by: Andrey Borzenkov <arvidjaar@mail.ru>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Clean-up history and add a comment about the fact that
the watchdog is actually part of the SMSC FDC 37B782
super I/O chipset.
Files using bits from paravirt.h should explicitly include it rather than
relying on it being pulled in by something else.
Signed-off-by: Jes Sorensen <jes@sgi.com>
Patch c5c34d4862e18ef07c1276d233507f540fb5a532 (tty: flush flip buffer on
ldisc input queue flush) introduces a race condition which can lead to memory
leaks.
The problem can be triggered when tcflush() is called when data are being
pushed to the line discipline driver by flush_to_ldisc().
flush_to_ldisc() releases tty->buf.lock when calling the line discipline
receive_buf function. At that poing tty_buffer_flush() kicks in and sets both
tty->buf.head and tty->buf.tail to NULL. When flush_to_ldisc() finishes, it
restores tty->buf.head but doesn't touch tty->buf.tail. This corrups the
buffer queue, and the next call to tty_buffer_request_room() will allocate a
new buffer and overwrite tty->buf.head. The previous buffer is then lost
forever without being released.
(Thanks to Laurent for the above text, for finding, disgnosing and reporting
the bug)
- Use tty->flags bits for the flush status.
- Wait for the flag to clear again before returning
- Fix the doc error noted
- Fix flush of empty queue leaving stale flushpending
[akpm@linux-foundation.org: cleanup]
Acked-by: Paul Fulghum <paulkf@microgate.com>
Cc: Laurent Pinchart <laurentp@cse-semaphore.com>
cm4000_cs.c and cm4040_cs.c call the internal release function with
an argument of wrong type. this fixes bug #8485
Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch>
Cc: Bill McConnaughey <mcconnau@biochem.wustl.edu>
Cc: Natalie Protasevich <protasnb@gmail.com>
Cc: Harald Welte <laforge@gnumonks.org>
This 965G and above chipsets moved the batch buffer non-secure bits to
another place. This means that previous drm's allowed in-secure batchbuffers
to be submitted to the hardware from non-privileged users who are logged
into X and and have access to direct rendering.
(This is a resend of a patch originally submitted on 24-Jul-2007 00:14)
Ok, this is something the coverity checker found (CID: 1813).
I'm not at all intimate with this code, so I'm not sure if this
attempt at a fix is correct (but at least it compiles).
Please look it over and NACK if bad or merge if good ;-)
