path: root/drivers/char
2009-09-05pty: don't limit the writes to 'pty_space()' inside 'pty_write()'Linus Torvalds
The whole write-room thing is something that is up to the _caller_ to worry about, not the pty layer itself. The total buffer space will still be limited by the buffering routines themselves, so there is no advantage or need in having pty_write() artificially limit the size somehow. And what happened was that the caller (the n_tty line discipline, in this case) may have verified that there is room for 2 bytes to be written (for NL -> CRNL expansion), and it used to then do those writes as two single-byte writes. And if the first byte written (CR) then caused a new tty buffer to be allocated, pty_space() may have returned zero when trying to write the second byte (LF), and then incorrectly failed the write - leading to a lost newline character. This should finally fix http://bugzilla.kernel.org/show_bug.cgi?id=14015 Reported-by: Mikael Pettersson <mikpe@it.uu.se> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-05n_tty: do O_ONLCR translation as a single writeLinus Torvalds
When translating CR to CRNL in the n_tty line discipline, we did it as two tty_put_char() calls. Which works, but is stupid, and has caused problems before too with bad interactions with the write_room() logic. The generic USB serial driver had that problem, for example. Now the pty layer had similar issues after being moved to the generic tty buffering code (in commit d945cb9cce20ac7143c2de8d88b187f62db99bdc: "pty: Rework the pty layer to use the normal buffering logic"). So stop doing the silly separate two writes, and do it as a single write instead. That's what the n_tty layer already does for the space expansion of tabs (XTABS), and it means that we'll now always have just a single write for the CRNL to match the single 'tty_write_room()' test, which hopefully means that the next time somebody screws up buffering, it won't cause weeks of debugging. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-25tty: make sure to flush any pending work when halting the ldiscLinus Torvalds
When I rewrote tty ldisc code to use proper reference counts (commits 65b770468e98 and cbe9352fa08f) in order to avoid a race with hangup, the test-program that Eric Biederman used to trigger the original problem seems to have exposed another long-standing bug: the hangup code did the 'tty_ldisc_halt()' to stop any buffer flushing activity, but unlike the other call sites it never actually flushed any pending work. As a result, if you get just the right timing, the pending work may be just about to execute (ie the timer has already triggered and thus cancel_delayed_work() was a no-op), when we then re-initialize the ldisc from under it. That, in turn, results in various random problems, usually seen as a NULL pointer dereference in run_timer_softirq() or a BUG() in worker_thread (but it can be almost anything). Fix it by adding the required 'flush_scheduled_work()' after doing the tty_ldisc_halt() (this also requires us to move the ldisc halt to before taking the ldisc mutex in order to avoid a deadlock with the workqueue executing do_tty_hangup, which requires the mutex). The locking should be cleaned up one day (the requirement to do this outside the ldisc_mutex is very annoying, and weakens the lock), but that's a larger and separate undertaking. Reported-by: Eric W. Biederman <ebiederm@xmission.com> Tested-by: Xiaotian Feng <xtfeng@gmail.com> Tested-by: Yanmin Zhang <yanmin_zhang@linux.intel.com> Tested-by: Dave Young <hidave.darkstar@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-10pty: fix data loss when stopped (^S/^Q)Linus Torvalds
Commit d945cb9cc ("pty: Rework the pty layer to use the normal buffering logic") dropped the test for 'tty->stopped' in pty_write_room(), which then causes the n_tty line discipline thing to not throttle the data properly when the tty is stopped. So instead of pausing the write due to the tty being stopped, the ldisc layer would go ahead and push it down to the pty. The pty write() routine would then refuse to take the data (because it _did_ check 'stopped'), and the data wouldn't actually be written. This whole stopped test should eventually be moved into the tty ldisc layer rather than have low-level tty drivers care about these things, but right now the fix is to just re-instate the missing pty 'stopped' handling. Reported-and-tested-by: Artur Skawina <art.08.09@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: tty-ldisc: be more careful in 'put_ldisc' locking tty-ldisc: turn ldisc user count into a proper refcount tty-ldisc: make refcount be atomic_t 'users' count
2009-08-04tty-ldisc: be more careful in 'put_ldisc' lockingLinus Torvalds
Use 'atomic_dec_and_lock()' to make sure that we always hold the tty_ldisc_lock when the ldisc count goes to zero. That way we can never race against 'tty_ldisc_try()' increasing the count again. Reported-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Tested-by: Sergey Senozhatsky <sergey.senozhatsky@mail.by> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-08-04tty-ldisc: turn ldisc user count into a proper refcountLinus Torvalds
By using the user count for the actual lifetime rules, we can get rid of the silly "wait_for_idle" logic, because any busy ldisc will automatically stay around until the last user releases it. This avoids a host of odd issues, and simplifies the code. So now, when the last ldisc reference is dropped, we just release the ldisc operations struct reference, and free the ldisc. It looks obvious enough, and it does work for me, but the counting _could_ be off. It probably isn't (bad counting in the new version would generally imply that the old code did something really bad, like free an ldisc with a non-zero count), but it does need some testing, and preferably somebody looking at it. With this change, both 'tty_ldisc_put()' and 'tty_ldisc_deref()' are just aliases for the new ref-counting 'put_ldisc()'. Both of them decrement the ldisc user count and free it if it goes down to zero. They're identical functions, in other words. But the reason they still exist as sepate functions is that one of them was exported (tty_ldisc_deref) and had a stupid name (so I don't want to use it as the main name), and the other one was used in multiple places (and I didn't want to make the patch larger just to rename the users). In addition to the refcounting, I did do some minimal cleanup. For example, now "tty_ldisc_try()" actually returns the ldisc it got under the lock, rather than returning true/false and then the caller would look up the ldisc again (now without the protection of the lock). That said, there's tons of dubious use of 'tty->ldisc' without obviously proper locking or refcounting left. I expressly did _not_ want to try to fix it all, keeping the patch minimal. There may or may not be bugs in that kind of code, but they wouldn't be _new_ bugs. That said, even if the bugs aren't new, the timing and lifetime will change. For example, some silly code may depend on the 'tty->ldisc' pointer not changing because they hold a refcount on the 'ldisc'. And that's no longer true - if you hold a ref on the ldisc, the 'ldisc' itself is safe, but tty->ldisc may change. So the proper locking (remains) to hold tty->ldisc_mutex if you expect tty->ldisc to be stable. That's not really a _new_ rule, but it's an example of something that the old code might have unintentionally depended on and hidden bugs. Whatever. The patch _looks_ sensible to me. The only users of ldisc->users are: - get_ldisc() - atomically increment the count - put_ldisc() - atomically decrements the count and releases if zero - tty_ldisc_try_get() - creates the ldisc, and sets the count to 1. The ldisc should then either be released, or be attached to a tty. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Tested-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Tested-by: Sergey Senozhatsky <sergey.senozhatsky@mail.by> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-08-04tty-ldisc: make refcount be atomic_t 'users' countLinus Torvalds
This is pure preparation of changing the ldisc reference counting to be a true refcount that defines the lifetime of the ldisc. But this is a purely syntactic change for now to make the next steps easier. This patch should make no semantic changes at all. But I wanted to make the ldisc refcount be an atomic (I will be touching it without locks soon enough), and I wanted to rename it so that there isn't quite as much confusion between 'ldo->refcount' (ldisk operations refcount) and 'ld->refcount' (ldisc refcount itself) in the same file. So it's now an atomic 'ld->users' count. It still starts at zero, despite having a reference from 'tty->ldisc', but that will change once we turn it into a _real_ refcount. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Tested-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Tested-by: Sergey Senozhatsky <sergey.senozhatsky@mail.by> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-08-02parisc: parisc-agp.c - use correct page_mask functionHelge Deller
Fix those compiler warnings, which indeed point to a bug: drivers/char/agp/parisc-agp.c:228: warning: initialization from incompatible pointer type drivers/char/agp/parisc-agp.c:201: warning: 'parisc_agp_page_mask_memory' defined but not used Signed-off-by: Helge Deller <deller@gmx.de>
2009-07-29sysrq, kdump: make sysrq-c consistentHidetoshi Seto
commit d6580a9f15238b87e618310c862231ae3f352d2d ("kexec: sysrq: simplify sysrq-c handler") changed the behavior of sysrq-c to unconditional dereference of NULL pointer. So in cases with CONFIG_KEXEC, where crash_kexec() was directly called from sysrq-c before, now it can be said that a step of "real oops" was inserted before starting kdump. However, in contrast to oops via SysRq-c from keyboard which results in panic due to in_interrupt(), oops via "echo c > /proc/sysrq-trigger" will not become panic unless panic_on_oops=1. It means that even if dump is properly configured to be taken on panic, the sysrq-c from proc interface might not start crashdump while the sysrq-c from keyboard can start crashdump. This confuses traditional users of kdump, i.e. people who expect sysrq-c to do common behavior in both of the keyboard and proc interface. This patch brings the keyboard and proc interface behavior of sysrq-c in line, by forcing panic_on_oops=1 before oops in sysrq-c handler. And some updates in documentation are included, to clarify that there is no longer dependency with CONFIG_KEXEC, and that now the system can just crash by sysrq-c if no dump mechanism is configured. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Ken'ichi Ohmichi <oomichi@mxs.nes.nec.co.jp> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: Brayan Arraes <brayan@yack.com.br> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29Merge branch 'zero-length' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/misc-2.6 * 'zero-length' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/misc-2.6: Remove zero-length file drivers/char/vr41xx_giu.c
2009-07-29pty: avoid forcing 'low_latency' tty flagOGAWA Hirofumi
We really don't want to mark the pty as a low-latency device, because as Alan points out, the ->write method can be called from an IRQ (ppp?), and that means we can't use ->low_latency=1 as we take mutexes in the low_latency case. So rather than using low_latency to force the written data to be pushed to the ldisc handling at 'write()' time, just make the reader side (or the poll function) do the flush when it checks whether there is data to be had. This also fixes the problem with lost data in an emacs compile buffer (bugzilla 13815), and we can thus revert the low_latency pty hack (commit 3a54297478e6578f96fd54bf4daa1751130aca86: "pty: quickfix for the pty ENXIO timing problems"). Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Tested-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> [ Modified to do the tty_flush_to_ldisc() inside input_available_p() so that it triggers for both read and poll() - Linus] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-28Remove zero-length file drivers/char/vr41xx_giu.cJeff Garzik
2009-07-27pty: quickfix for the pty ENXIO timing problemsAlan Cox
This also makes close stall in the normal case which is apparently needed to fix emacs Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-20tty: fix chars_in_buffersAlan Cox
This function does not have an error return and returning an error is instead interpreted as having a lot of pending bytes. Reported by Jeff Harris who provided a list of some of the remaining offenders. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-20specialix.c: convert nested spin_lock_irqsave to spin_lockJulia Lawall
If spin_lock_irqsave is called twice in a row with the same second argument, the interrupt state at the point of the second call overwrites the value saved by the first call. Indeed, the second call does not need to save the interrupt state, so it is changed to a simple spin_lock. The semantic match that finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression lock1,lock2; expression flags; @@ *spin_lock_irqsave(lock1,flags) ... when != flags *spin_lock_irqsave(lock2,flags) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-20vc: create vcs(a) devices for consolesKay Sievers
The buffer for the consoles are unconditionally allocated at con_init() time, which miss the creation of the vcs(a) devices. Since 2.6.30 (commit 4995f8ef9d3aac72745e12419d7fbaa8d01b1d81, 'vcs: hook sysfs devices into object lifetime instead of "binding"' to be exact) these devices are no longer created at open() and removed on close(), but controlled by the lifetime of the buffers. Reported-by: Gerardo Exequiel Pozzi <vmlinuz386@yahoo.com.ar> Tested-by: Gerardo Exequiel Pozzi <vmlinuz386@yahoo.com.ar> Cc: stable@kernel.org Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-17tty_port: Fix return on interrupted useAlan Cox
Whoops.. fortunately not many people use this yet. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-16n_tty: Fix echo raceAlan Cox
If a tty in N_TTY mode with echo enabled manages to get itself into a state where - echo characters are pending - FASYNC is enabled - tty_write_wakeup is called from either - a device write path (pty) - an IRQ (serial) then it either deadlocks or explodes taking a mutex in the IRQ path. On the serial side it is almost impossible to reproduce because you have to go from a full serial port to a near empty one with echo characters pending. The pty case happens to have become possible to trigger using emacs and ptys, the pty changes having created a scenario which shows up this bug. The code path is n_tty:process_echoes() (takes mutex) tty_io:tty_put_char() pty:pty_write (or serial paths) tty_wakeup (from pty_write or serial IRQ) n_tty_write_wakeup() process_echoes() *KABOOM* Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-16tty: nozomi, fix tty refcounting bugJiri Slaby
Don't forget to drop a tty refererence on fail paths in receive_data(). Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-16vt: drop bootmem/slab memory distinctionJohannes Weiner
Bootmem is not used for the vt screen buffer anymore as slab is now available at the time the console is initialized. Get rid of the now superfluous distinction between slab and bootmem, it's always slab. This also fixes a kmalloc leak which Catalin described thusly: Commit a5f4f52e ("vt: use kzalloc() instead of the bootmem allocator") replaced the alloc_bootmem() with kzalloc() but didn't set vc_kmalloced to 1 and the memory block is later leaked. The corresponding kmemleak trace: unreferenced object 0xdf828000 (size 8192): comm "swapper", pid 0, jiffies 4294937296 backtrace: [<c006d473>] __save_stack_trace+0x17/0x1c [<c000d869>] log_early+0x55/0x84 [<c01cfa4b>] kmemleak_alloc+0x33/0x3c [<c006c013>] __kmalloc+0xd7/0xe4 [<c00108c7>] con_init+0xbf/0x1b8 [<c0010149>] console_init+0x11/0x20 [<c0008797>] start_kernel+0x137/0x1e4 Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Tested-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-16tty: fix close/hangup raceAlan Cox
We can get a situation where a hangup occurs during or after a close. In that case the ldisc gets disposed of by the close and the hangup then explodes. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-08Remove multiple KERN_ prefixes from printk formatsJoe Perches
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up handling of log-levels and newlines") changed printk semantics. printk lines with multiple KERN_<level> prefixes are no longer emitted as before the patch. <level> is now included in the output on each additional use. Remove all uses of multiple KERN_<level>s in formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-08pty: Rework the pty layer to use the normal buffering logicAlan Cox
This fixes the ppp problems and various other issues with call locking caused by one side of a pty called in one locking context trying to match another with differing rules on the other side. We also get a big slack space to work with that means we can bury the flow control deadlock case for any conceivable real world situation. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-03Update Yoichi Yuasa's e-mail addressYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03MIPS: Update VR41xx GPIO driver to use gpiolibYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yyuasa@linux.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-29tty: Fix the leak in tty_ldisc_releaseAlan Cox
Currently we reinit the ldisc on final tty close which is what the old code did to ensure that if the device retained its termios settings then it had the right ldisc. tty_ldisc_reinit does that but also leaves us with the reset ldisc reference which is then leaked. At this point we know the port will be recycled so we can kill the ldisc off completely rather than try and add another ldisc free up when the kref count hits zero. At this point it is safe to keep the ldisc closed as tty_ldisc waiting methods are only used from the user side, and as the final close we are the last such reference. Interrupt/driver side methods will always use the non wait version and get back a NULL. Found with kmemleak and investigated/identified by Catalin Marinas. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-26powerpc/BSR: Fix BSR to allow mmap of small BSR on 64k kernelSonny Rao
On Mon, Nov 17, 2008 at 01:26:13AM -0600, Sonny Rao wrote: > On Fri, Nov 07, 2008 at 04:28:29PM +1100, Paul Mackerras wrote: > > Sonny Rao writes: > > > > > Fix the BSR driver to allow small BSR devices, which are limited to a > > > single 4k space, on a 64k page kernel. Previously the driver would > > > reject the mmap since the size was smaller than PAGESIZE (or because > > > the size was greater than the size of the device). Now, we check for > > > this case use remap_4k_pfn(). Also, take out code to set vm_flags, > > > as the remap_pfn functions will do this for us. > > > > Thanks. > > > > Do we know that the BSR size will always be 4k if it's not a multiple > > of 64k? Is it possible that we could get 8k, 16k or 32k or BSRs? > > If it is possible, what does the user need to be able to do? Do they > > just want to map 4k, or might then want to map the whole thing? > > > Hi Paul, I took a look at changing the driver to reject a request for > mapping more than a single 4k page, however the only indication we get > of the requested size in the mmap function is the vma size, and this > is always one page at minimum. So, it's not possible to determine if > the user wants one 4k page or more. As I noted in my first response, > there is only one case where this is even possible and I don't think > it is a significant concern. > > I did notice that I left out the check to see if the user is trying to > map more than the device length, so I fixed that. Here's the revised > patch. Alright, I've reworked this now so that if we get one of these cases where there's a bsr that's > 4k and < 64k on a 64k kernel we'll only advertise that it is a 4k BSR to userspace. I think this is the best solution since user programs are only supposed to look at sysfs to determine how much can be mapped, and libbsr does this as well. Please consider for 2.6.31 as a fix, thanks. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-26powerpc/BSR: add 4096 byte BSR sizeSonny Rao
Add a 4096 byte BSR size which will be used on new machines. Also, remove the warning when we run into an unknown size, as this can spam the kernel log excessively. Signed-off-by: Sonny Rao <sonnyrao@us.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-24Remove low_latency flag setting from nozomi and mxser driversChuck Ebbert
The kernel oopses if this flag is set. [and neither driver should set it as they call tty_flip_buffer_push from IRQ paths so have always been buggy] Signed-off-by: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24tty: fix tty_port_block_til_ready waitingJiri Slaby
Since commit 3e3b5c087799e536871c8261b05bc28e4783c8da ("tty: use prepare/finish_wait"), tty_port_block_til_ready() is using prepare_to_wait()/finish_wait(). Those functions require that the wait_queue_t be initialised with .func=autoremove_wake_function, via DEFINE_WAIT(). But the conversion from DECLARE_WAITQUEUE() to DEFINE_WAIT() was not made, so this code will oops in finish_wait(). Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24synclink_gt: fix transmit race and timeoutPaul Fulghum
Fix race condition when adding transmit data to active DMA buffer ring that can cause transmit stall. Update transmit timeout when adding data to active DMA buffer ring. Base transmit timeout on amount of buffered data instead of using fixed value. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-22tty: n_hdlc add buffer flushingPaul Fulghum
Add flush_buffer tty callback to flush rx buffers. Add TCFLSH ioctl processing to flush tx buffers. Increase default tx buffers from 1 to 3. Remove unneeded flush_buffer call in open callback. Remove vendor specific CVS version string. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-22vt_ioctl: fix lock imbalanceJiri Slaby
Don't return from switch/case directly in vt_ioctl. Set ret and break instead so that we unlock BKL. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-22pcmcia/cm4000: fix lock imbalanceJiri Slaby
Don't return from switch/case, break instead, so that we unlock BKL. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-22n_r3964: fix lock imbalanceJiri Slaby
There is omitted BKunL in r3964_read. Centralize the paths to one point with one unlock. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-22bfin_jtag_comm: clean up printk usageMike Frysinger
The original patch garned some feedback and a v2 was posted, but that version seems to have been missed when merging the driver. At any rate, this cleans up the printk usage as suggested by Jiri Slaby. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-22Revert "char: moxa, prevent opening unavailable ports"Linus Torvalds
This reverts commit a90b037583d5f1ae3e54e9c687c79df82d1d34a4, which already got fixed as commit f0e8527726b9e56649b9eafde3bc0fbc4dd2dd47: the same patch (trivial differences) got applied twice. Requested-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (35 commits) Input: add driver for Synaptics I2C touchpad Input: synaptics - add support for reporting x/y resolution Input: ALPS - handle touchpoints buttons correctly Input: gpio-keys - change timer to workqueue Input: ads7846 - pin change interrupt support Input: add support for touchscreen on W90P910 ARM platform Input: appletouch - improve finger detection Input: wacom - clear Intuos4 wheel data when finger leaves proximity Input: ucb1400 - move static function from header into core Input: add driver for EETI touchpanels Input: ads7846 - more detailed model name in sysfs Input: ads7846 - support swapping x and y axes Input: ati_remote2 - use non-atomic bitops Input: introduce lm8323 keypad driver Input: psmouse - ESD workaround fix for OLPC XO touchpad Input: tsc2007 - make sure platform provides get_pendown_state() Input: uinput - flush all pending ff effects before destroying device Input: simplify name handling for certain input handles Input: serio - do not use deprecated dev.power.power_state Input: wacom - add support for Intuos4 tablets ...
2009-06-20Merge branch 'drm-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (24 commits) agp/intel: Make intel_i965_mask_memory use dma_addr_t for physical addresses agp: add user mapping support to ATI AGP bridge. drm/i915: enable GEM on PAE. drm/radeon: fix unused variables warning agp: switch AGP to use page array instead of unsigned long array agpgart: detected ALi M???? chipset with M1621 drm/radeon: command stream checker for r3xx-r5xx hardware drm/radeon: Fully initialize LVDS info also when we can't get it from the ROM. radeon: Fix CP byte order on big endian architectures with KMS. agp/uninorth: Handle user memory types. drm/ttm: Add some powerpc cache flush code. radeon: Enable modesetting on non-x86. drm/radeon: Respect AGP cant_use_aperture flag. drm: EDID endianness fixes. drm/radeon: this VRAM vs aperture test is wrong, just remove it. drm/ttm: fix an error path to exit function correctly drm: Apply "Memory fragmentation from lost alignment blocks" ttm: Return -ERESTART when a signal interrupts bo eviction. drm: Remove memory debugging infrastructure. drm/i915: Clear fence register on tiling stride change. ...
2009-06-20agp/intel: Make intel_i965_mask_memory use dma_addr_t for physical addressesPierre Willenbrock
Otherwise, the high bits to be stuffed in the unused lower bits of the page address are lost. Signed-off-by: Pierre Willenbrock <pierre@pirsoft.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-06-19Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (35 commits) powerpc/5121: make clock debug output more readable powerpc/5xxx: Add common mpc5xxx_get_bus_frequency() function powerpc/5200: Update pcm030.dts to add i2c eeprom and delete cruft powerpc/5200: convert mpc52xx_psc_spi to use cs_control callback fbdev/xilinxfb: Fix improper casting and tighen up probe path usb/ps3: Add missing annotations powerpc: Add memory clobber to mtspr() powerpc: Fix invalid construct in our CPU selection Kconfig ps3rom: Use ps3_system_bus_[gs]et_drvdata() instead of direct access powerpc: Add configurable -Werror for arch/powerpc of_serial: Add UPF_FIXED_TYPE flag drivers/hvc: Add missing __devexit_p() net/ps3: gelic - Add missing annotations powerpc: Introduce macro spin_event_timeout() powerpc/warp: Fix ISA_DMA_THRESHOLD default powerpc/bootwrapper: Custom build options for XPedite52xx targets powerpc/85xx: Add defconfig for X-ES MPC85xx boards powerpc/85xx: Add dts files for X-ES MPC85xx boards powerpc/85xx: Add platform support for X-ES MPC85xx boards 83xx: add support for the kmeter1 board. ...
2009-06-19char: moxa, prevent opening unavailable portsDirk Eibach
In moxa.c there are 32 minor numbers reserved for each device. The number of ports actually available per device is stored in moxa_board_conf->numPorts. This number is not considered in moxa_open(). Opening a port that is not available results in a kernel oops. This patch adds a test to moxa_open() that prevents opening unavailable ports. [akpm@linux-foundation.org: avoid multiple returns] Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-19istallion: add missing __devexit markingMike Frysinger
The remove member of the pci_driver stli_pcidriver uses __devexit_p(), so the remove function itself should be marked with __devexit. Even more so considering the probe function is marked with __devinit. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-19dtlk: off by one in {read,write}_tts()Roel Kluin
With a postfix increment retries is incremented beyond DTLK_MAX_RETRIES so the error message is not displayed correctly. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: James R. Van Zandt <jrv@vanzandt.mv.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-19agp: add user mapping support to ATI AGP bridge.Dave Airlie
This should fix TTM/KMS on some of the original ATI IGP chipsets. (rs100/rs200) Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-06-19agp: switch AGP to use page array instead of unsigned long arrayDave Airlie
This switches AGP to use an array of pages for tracking the pages allocated to the GART. This should enable GEM on PAE to work a lot better as we can pass highmem pages to the PAT code and it will do the right thing with them. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-06-19agpgart: detected ALi M???? chipset with M1621Ondrej Zary
Add M1621 chipset name to ali-agp, preventing "Detected ALi M???? chipset" message. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-06-19agp/uninorth: Handle user memory types.Michel Dänzer
This adds support for TTM to the uninorth AGP bridge. Signed-off-by: Dave Airlie <airlied@redhat.com>
