commit 62dfd912ab3b5405b6fe72d0135c37e9648071f1 upstream.
Problem: When IMA and VTPM are both enabled in kernel config,
kernel hangs during bootup on LE OS.
Why?: IMA calls tpm_pcr_read() which results in tpm_ibmvtpm_send
and tpm_ibmtpm_recv getting called. A trace showed that
tpm_ibmtpm_recv was hanging.
Resolution: tpm_ibmtpm_recv was hanging because tpm_ibmvtpm_send
was sending CRQ message that probably did not make much sense
to phype because of Endianness. The fix below sends correctly
converted CRQ for LE. This was not caught before because it
seems IMA is not enabled by default in kernel config and
IMA exercises this particular code path in vtpm.
Tested with IMA and VTPM enabled in kernel config and VTPM
enabled on both a BE OS and a LE OS ppc64 lpar. This exercised
CRQ and TPM command code paths in vtpm.
Patch is against Peter's tpmdd tree on github which included
Vicky's previous vtpm le patches.
Signed-off-by: Joy Latten <jmlatten@linux.vnet.ibm.com>
Reviewed-by: Ashley Lai <ashley@ahsleylai.com>
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
commit 4f6e24ed9de8634d6471ef86b382cba6d4e57ca8 upstream.
when multiport is off, we don't initialize config work,
but we then cancel uninitialized control_work on freeze.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Reviewed-by: Amit Shah <amit.shah@redhat.com>
commit eb71f8a5e33fa1066fb92f0111ab366a341e1f6c upstream.
The tpm_ibmvtpm module is affected by an unaligned access problem.
ibmvtpm_crq_get_version failed with rc=-4 during boot when vTPM is
enabled in Power partition, which supports both little endian and
big endian modes.
We added little endian support to fix this problem:
1) added cpu_to_be64 calls to ensure BE data is sent from an LE OS.
2) added be16_to_cpu and be32_to_cpu calls to make sure data received
is in LE format on a LE OS.
Signed-off-by: Hon Ching(Vicky) Lo <honclo@linux.vnet.ibm.com>
[phuewe: manually applied the patch :( ]
commit 1ba3b0b6f218072afe8372d12f1b6bf26a26008e upstream.
When sending data in tpm_stm_i2c_send, each loop iteration send buf.
Send buf + i instead as the goal of this for loop is to send a number
of byte from buf that fit in burstcnt. Once those byte are sent, we are
supposed to send the next ones.
The driver was working because the burstcount value returns always the maximum size for a TPM
command or response. (0x800 for a command and 0x400 for a response).
Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com>
commit 84eb186bc37c0900b53077ca21cf6dd15823a232 upstream.
There was an oops in tpm_ibmvtpm_get_desired_dma, which caused
kernel panic during boot when vTPM is enabled in Power partition
configured in AMS mode.
vio_bus_probe calls vio_cmo_bus_probe which calls
tpm_ibmvtpm_get_desired_dma to get the size needed for DMA allocation.
The problem is, vio_cmo_bus_probe is called before calling probe, which
for vtpm is tpm_ibmvtpm_probe and it's this function that initializes
and sets up vtpm's CRQ and gets required data values. Therefore,
since this has not yet been done, NULL is returned in attempt to get
the size for DMA allocation.
We added a NULL check. In addition, a default buffer size will
be set when NULL is returned.
Signed-off-by: Hon Ching (Vicky) Lo <honclo@linux.vnet.ibm.com>
commit 448e9c55c12d6bd4fa90a7e31d802e045666d7c8 upstream.
Some machines, such as the Acer C720 and Toshiba CB35, have TPMs that do
not send IRQs while also having an ACPI TPM entry indicating that they
will be sent. These machines freeze on resume while the tpm_tis module
waits for an IRQ, eventually timing out.
When in interrupt mode, the tpm_tis module should receive an IRQ during
module init. Fall back to polling mode if none is received when expected.
Signed-off-by: Scot Doyle <lkml14@scotdoyle.com>
Tested-by: Michael Mullin <masmullin@gmail.com>
[phuewe: minor checkpatch fixed]
commit d4c5efdb97773f59a2b711754ca0953f24516739 upstream.
zatimend has reported that in his environment (3.16/gcc4.8.3/corei7)
memset() calls which clear out sensitive data in extract_{buf,entropy,
entropy_user}() in random driver are being optimized away by gcc.
Add a helper memzero_explicit() (similarly as explicit_bzero() variants)
that can be used in such cases where a variable with sensitive data is
being cleared out in the end. Other use cases might also be in crypto
code. [ I have put this into lib/string.c though, as it's always built-in
and doesn't need any dependencies then. ]
Fixes kernel bugzilla: 82041
Reported-by: zatimend@hotmail.co.uk
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit 8e54caf407b98efa05409e1fee0e5381abd2b088 upstream.
Some Atmel TPMs provide completely wrong timeouts from their
TPM_CAP_PROP_TIS_TIMEOUT query. This patch detects that and returns
new correct values via a DID/VID table in the TIS driver.
Tested on ARM using an AT97SC3204T FW version 37.16
[PHuewe: without this fix these 'broken' Atmel TPMs won't function on
older kernels]
Signed-off-by: "Berg, Christopher" <Christopher.Berg@atmel.com>
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
[bwh: Backported to 3.10:
- Adjust filename, context
- s/chip->ops->/chip->vendor./]
commit 3e14d83ef94a5806a865b85b513b4e891923c19b upstream.
Regression in 41ab999c. Call to tpm_chip_put is missing. This
will cause TPM device driver not to unload if tmp_get_random()
is called.
Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
commit 8bab797c6e5724a43b7666ad70860712365cdb71 upstream.
This is a static checker fix. The "dev" variable is always NULL after
the while statement so we would be dereferencing a NULL pointer here.
Fixes: 819a3eba4233 ('[PATCH] applicom: fix error handling')
commit eb6d78ec213e6938559b801421d64714dafcf4b2 upstream.
The OBF timer in KCS was not reset in one situation when error recovery
was started, resulting in an immediate timeout.
Reported-by: Bodo Stroesser <bstroesser@ts.fujitsu.com>
Signed-off-by: Corey Minyard <cminyard@mvista.com>
commit 48e8ac2979920ffa39117e2d725afa3a749bfe8d upstream.
With recent changes it is possible for the timer handler to detect an
idle interface and not start the timer, but the thread to start an
operation at the same time. The thread will not start the timer in that
instance, resulting in the timer not running.
Instead, move all timer operations under the lock and start the timer in
the thread if it detect non-idle and the timer is not already running.
Moving under locks allows the last timeout to be set in both the thread
and the timer. 'Timer is not running' means that the timer is not
pending and smi_timeout() is not running. So we need a flag to detect
this correctly.
Also fix a few other timeout bugs: setting the last timeout when the
interrupt has to be disabled and the timer started, and setting the last
timeout in check_start_timer_thread possibly racing with the timer
Signed-off-by: Bodo Stroesser <bstroesser@ts.fujitsu.com>
commit a94cdd1f4d30f12904ab528152731fb13a812a16 upstream.
In read_all_bytes, we do
unsigned char i;
bt->read_data[0] = BMC2HOST;
bt->read_count = bt->read_data[0];
for (i = 1; i <= bt->read_count; i++)
bt->read_data[i] = BMC2HOST;
If bt->read_data[0] == bt->read_count == 255, we loop infinitely in the
'for' loop. Make 'i' an 'int' instead of 'char' to get rid of the
overflow and finish the loop after 255 iterations every time.
Reported-and-debugged-by: Rui Hui Dian <rhdian@novell.com>
Cc: Tomas Cech <tcech@suse.cz>
Cc: Corey Minyard <minyard@acm.org>
Cc: <openipmi-developer@lists.sourceforge.net>
commit 5bbb2ae3d6f896f8d2082d1eceb6131c2420b7cf upstream.
bind_get() checks the device number it is called with. It uses
MAX_RAW_MINORS for the upper bound. But MAX_RAW_MINORS is set at compile
time while the actual number of raw devices can be set at runtime. This
means the test can either be too strict or too lenient. And if the test
ends up being too lenient bind_get() might try to access memory beyond
what was allocated for "raw_devices".
So check against the runtime value (max_raw_minors) in this function.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Acked-by: Jan Kara <jack@suse.cz>
commit 747d35bd9bb4ae6bd74b19baa5bbe32f3e0cee11 upstream.
Depending on the implementation strcmp might return the difference between
two strings not only -1,0,1 consequently
if (strcmp (a,b) == -1)
might lead to taking the wrong branch
-> compare with < 0 instead,
which in any case is more canonical.
commit 85c5e0d451125c6ddb78663972e40af810b83644 upstream.
The 'get_burstcount' function can in some circumstances 'return -EBUSY' which
in tpm_stm_i2c_send is stored in an 'u32 burstcnt'
thus converting the signed value into an unsigned value, resulting
in 'burstcnt' being huge.
Changing the type to u32 only does not solve the problem as the signed
value is converted to an unsigned in I2C_WRITE_DATA, resulting in the
same effect.
Thus
-> Change type of burstcnt to u32 (the return type of get_burstcount)
-> Add a check for the return value of 'get_burstcount' and propagate a
potential error.
This makes also sense in the 'I2C_READ_DATA' case, where the there is no
signed/unsigned conversion.
found by coverity
commit df45c712d1f4ef37714245fb75de726f4ca2bf8d upstream.
In function ppi_callback(), memory allocated by acpi_get_name() will get
leaked when current device isn't the desired TPM device, so fix the
memory leak.
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
commit 9aa5b0181bdf335f0b731d8502e128a862884bcd upstream.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=60772
Signed-off-by: Alan Cox <alan@linux.intel.com>
Reported-by: Leho Kraav <leho@kraav.com>
commit 47d06e532e95b71c0db3839ebdef3fe8812fca2c upstream.
The some platforms (e.g., ARM) initializes their clocks as
late_initcalls for some unknown reason. So make sure
random_int_secret_init() is run after all of the late_initcalls are
run.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 96f97a83910cdb9d89d127c5ee523f8fc040a804 upstream.
If a port gets unplugged while a user is blocked on read(), -ENODEV is
returned. However, subsequent read()s returned 0, indicating there's no
host-side connection (but not indicating the device went away).
This also happened when a port was unplugged and the user didn't have
any blocking operation pending. If the user didn't monitor the SIGIO
signal, they won't have a chance to find out if the port went away.
Fix by returning -ENODEV on all read()s after the port gets unplugged.
write() already behaves this way.
Signed-off-by: Amit Shah <amit.shah@redhat.com>
commit 92d3453815fbe74d539c86b60dab39ecdf01bb99 upstream.
SIGIO should be sent when a port gets unplugged. It should only be sent
to prcesses that have the port opened, and have asked for SIGIO to be
delivered. We were clearing out guest_connected before calling
send_sigio_to_port(), resulting in a sigio not getting sent to
processes.
Fix by setting guest_connected to false after invoking the sigio
function.
commit ea3768b4386a8d1790f4cc9a35de4f55b92d6442 upstream.
We used to keep the port's char device structs and the /sys entries
around till the last reference to the port was dropped. This is
actually unnecessary, and resulted in buggy behaviour:
1. Open port in guest
2. Hot-unplug port
3. Hot-plug a port with the same 'name' property as the unplugged one
This resulted in hot-plug being unsuccessful, as a port with the same
name already exists (even though it was unplugged).
This behaviour resulted in a warning message like this one:
-------------------8<---------------------------------------
WARNING: at fs/sysfs/dir.c:512 sysfs_add_one+0xc9/0x130() (Not tainted)
Hardware name: KVM
sysfs: cannot create duplicate filename
'/devices/pci0000:00/0000:00:04.0/virtio0/virtio-ports/vport0p1'
Call Trace:
[<ffffffff8106b607>] ? warn_slowpath_common+0x87/0xc0
[<ffffffff8106b6f6>] ? warn_slowpath_fmt+0x46/0x50
[<ffffffff811f2319>] ? sysfs_add_one+0xc9/0x130
[<ffffffff811f23e8>] ? create_dir+0x68/0xb0
[<ffffffff811f2469>] ? sysfs_create_dir+0x39/0x50
[<ffffffff81273129>] ? kobject_add_internal+0xb9/0x260
[<ffffffff812733d8>] ? kobject_add_varg+0x38/0x60
[<ffffffff812734b4>] ? kobject_add+0x44/0x70
[<ffffffff81349de4>] ? get_device_parent+0xf4/0x1d0
[<ffffffff8134b389>] ? device_add+0xc9/0x650
Instead of relying on guest applications to release all references to
the ports, we should go ahead and unregister the port from all the core
layers. Any open/read calls on the port will then just return errors,
and an unplug/plug operation on the host will succeed as expected.
This also caused buggy behaviour in case of the device removal (not just
a port): when the device was removed (which means all ports on that
device are removed automatically as well), the ports with active
users would clean up only when the last references were dropped -- and
it would be too late then to be referencing char device pointers,
resulting in oopses:
PID: 6162 TASK: ffff8801147ad500 CPU: 0 COMMAND: "cat"
#0 [ffff88011b9d5a90] machine_kexec at ffffffff8103232b
#1 [ffff88011b9d5af0] crash_kexec at ffffffff810b9322
#2 [ffff88011b9d5bc0] oops_end at ffffffff814f4a50
#3 [ffff88011b9d5bf0] die at ffffffff8100f26b
#4 [ffff88011b9d5c20] do_general_protection at ffffffff814f45e2
#5 [ffff88011b9d5c50] general_protection at ffffffff814f3db5
[exception RIP: strlen+2]
RIP: ffffffff81272ae2 RSP: ffff88011b9d5d00 RFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff880118901c18 RCX: 0000000000000000
RDX: ffff88011799982c RSI: 00000000000000d0 RDI: 3a303030302f3030
RBP: ffff88011b9d5d38 R8: 0000000000000006 R9: ffffffffa0134500
R10: 0000000000001000 R11: 0000000000001000 R12: ffff880117a1cc10
R13: 00000000000000d0 R14: 0000000000000017 R15: ffffffff81aff700
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018
#6 [ffff88011b9d5d00] kobject_get_path at ffffffff8126dc5d
#7 [ffff88011b9d5d40] kobject_uevent_env at ffffffff8126e551
#8 [ffff88011b9d5dd0] kobject_uevent at ffffffff8126e9eb
#9 [ffff88011b9d5de0] device_del at ffffffff813440c7
So clean up when we have all the context, and all that's left to do when
the references to the port have dropped is to free up the port struct
itself.
Reported-by: chayang <chayang@redhat.com>
Reported-by: YOGANANTH SUBRAMANIAN <anantyog@in.ibm.com>
Reported-by: FuXiangChun <xfu@redhat.com>
Reported-by: Qunfang Zhang <qzhang@redhat.com>
Reported-by: Sibiao Luo <sluo@redhat.com>
commit 671bdea2b9f210566610603ecbb6584c8a201c8c upstream.
Between open() being called and processed, the port can be unplugged.
Check if this happened, and bail out.
A simple test script to reproduce this is:
while true; do for i in $(seq 1 100); do echo $i > /dev/vport0p3; done; done;
This opens and closes the port a lot of times; unplugging the port while
this is happening triggers the bug.
commit 057b82be3ca3d066478e43b162fc082930a746c9 upstream.
There's a window between find_port_by_devt() returning a port and us
taking a kref on the port, where the port could get unplugged. Fix it
by taking the reference in find_port_by_devt() itself.
Problem reported and analyzed by Mateusz Guzik.
Reported-by: Mateusz Guzik <mguzik@redhat.com>
commit 2b4fbf029dff5a28d9bf646346dea891ec43398a upstream.
Add pipe_lock/unlock for splice_write to avoid oops by following competition:
(1) An application gets fds of a trace buffer, virtio-serial, pipe.
(2) The application does fork()
(3) The processes execute splice_read(trace buffer) and
splice_write(virtio-serial) via same pipe.
<parent> <child>
get fds of a trace buffer,
virtio-serial, pipe
fork()----------create--------+
splice(read) | ---+
splice(write) | +-- no competition
| splice(read) |
| splice(write) ---+
splice(read) |
splice(write) splice(read) ------ competition
| splice(write)
Two processes share a pipe_inode_info structure. If the child execute
splice(read) when the parent tries to execute splice(write), the
structure can be broken. Existing virtio-serial driver does not get
lock for the structure in splice_write, so this competition will induce
oops.
<oops messages>
BUG: unable to handle kernel NULL pointer dereference at 0000000000000018
IP: [<ffffffff811a6b5f>] splice_from_pipe_feed+0x6f/0x130
PGD 7223e067 PUD 72391067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in: lockd bnep bluetooth rfkill sunrpc ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables snd_hda_intel snd_hda_codec snd_hwdep snd_pcm snd_page_alloc snd_timer snd soundcore pcspkr virtio_net virtio_balloon i2c_piix4 i2c_core microcode uinput floppy
CPU: 0 PID: 1072 Comm: compete-test Not tainted 3.10.0ws+ #55
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007
task: ffff880071b98000 ti: ffff88007b55e000 task.ti: ffff88007b55e000
RIP: 0010:[<ffffffff811a6b5f>] [<ffffffff811a6b5f>] splice_from_pipe_feed+0x6f/0x130
RSP: 0018:ffff88007b55fd78 EFLAGS: 00010287
RAX: 0000000000000000 RBX: ffff88007b55fe20 RCX: 0000000000000000
RDX: 0000000000001000 RSI: ffff88007a95ba30 RDI: ffff880036f9e6c0
RBP: ffff88007b55fda8 R08: 00000000000006ec R09: ffff880077626708
R10: 0000000000000003 R11: ffffffff8139ca59 R12: ffff88007a95ba30
R13: 0000000000000000 R14: ffffffff8139dd00 R15: ffff880036f9e6c0
FS: 00007f2e2e3a0740(0000) GS:ffff88007fc00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000018 CR3: 0000000071bd1000 CR4: 00000000000006f0
Stack:
ffffffff8139ca59 ffff88007b55fe20 ffff880036f9e6c0 ffffffff8139dd00
ffff8800776266c0 ffff880077626708 ffff88007b55fde8 ffffffff811a6e8e
ffff88007b55fde8 ffffffff8139ca59 ffff880036f9e6c0 ffff88007b55fe20
Call Trace:
[<ffffffff8139ca59>] ? alloc_buf.isra.13+0x39/0xb0
[<ffffffff8139dd00>] ? virtcons_restore+0x100/0x100
[<ffffffff811a6e8e>] __splice_from_pipe+0x7e/0x90
[<ffffffff8139d739>] port_fops_splice_write+0xe9/0x140
[<ffffffff8127a3f4>] ? selinux_file_permission+0xc4/0x120
[<ffffffff8139d650>] ? wait_port_writable+0x1b0/0x1b0
[<ffffffff811a6fe0>] do_splice_from+0xa0/0x110
[<ffffffff811a951f>] SyS_splice+0x5ff/0x6b0
[<ffffffff8161facf>] tracesys+0xdd/0xe2
Code: 49 8b 87 80 00 00 00 4c 8d 24 d0 8b 53 04 41 8b 44 24 0c 4d 8b 6c 24 10 39 d0 89 03 76 02 89 13 49 8b 44 24 10 4c 89 e6 4c 89 ff <ff> 50 18 85 c0 0f 85 aa 00 00 00 48 89 da 4c 89 e6 4c 89 ff 41
RIP [<ffffffff811a6b5f>] splice_from_pipe_feed+0x6f/0x130
RSP <ffff88007b55fd78>
---[ end trace 24572beb7764de59 ]---
V2: Fix a locking problem for error
V3: Add Reviewed-by lines and stable@ line in sign-off area
Signed-off-by: Yoshihiro YUNOMAE <yoshihiro.yunomae.ez@hitachi.com>
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Amit Shah <amit.shah@redhat.com>
commit 68c034fefe20eaf7d5569aae84584b07987ce50a upstream.
Quit from splice_write if pipe->nrbufs is 0 for avoiding oops in virtio-serial.
When an application was doing splice from a kernel buffer to virtio-serial on
a guest, the application received signal(SIGINT). This situation will normally
happen, but the kernel executed a kernel panic by oops as follows:
BUG: unable to handle kernel paging request at ffff882071c8ef28
IP: [<ffffffff812de48f>] sg_init_table+0x2f/0x50
PGD 1fac067 PUD 0
Oops: 0000 [#1] SMP
Modules linked in: lockd sunrpc bnep bluetooth rfkill ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables snd_hda_intel snd_hda_codec snd_hwdep snd_pcm snd_page_alloc snd_timer snd microcode virtio_balloon virtio_net pcspkr soundcore i2c_piix4 i2c_core uinput floppy
CPU: 1 PID: 908 Comm: trace-cmd Not tainted 3.10.0+ #49
task: ffff880071c64650 ti: ffff88007bf24000 task.ti: ffff88007bf24000
RIP: 0010:[<ffffffff812de48f>] [<ffffffff812de48f>] sg_init_table+0x2f/0x50
RSP: 0018:ffff88007bf25dd8 EFLAGS: 00010286
RAX: 0000001fffffffe0 RBX: ffff882071c8ef28 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff880071c8ef48
RBP: ffff88007bf25de8 R08: ffff88007fd15d40 R09: ffff880071c8ef48
R10: ffffea0001c71040 R11: ffffffff8139c555 R12: 0000000000000000
R13: ffff88007506a3c0 R14: ffff88007c862500 R15: ffff880071c8ef00
FS: 00007f0a3646c740(0000) GS:ffff88007fd00000(0000) knlGS:0000000000000000
CR2: ffff882071c8ef28 CR3: 000000007acbb000 CR4: 00000000000006e0
Stack:
ffff880071c8ef48 ffff88007bf25e20 ffff88007bf25e88 ffffffff8139d6fa
ffff88007bf25e28 ffffffff8127a3f4 0000000000000000 0000000000000000
ffff880071c8ef48 0000100000000000 0000000000000003 ffff88007bf25e08
Call Trace:
[<ffffffff8139d6fa>] port_fops_splice_write+0xaa/0x130
[<ffffffff8161f8c2>] system_call_fastpath+0x16/0x1b
Code: c1 e2 05 48 89 e5 48 83 ec 10 4c 89 65 f8 41 89 f4 31 f6 48 89 5d f0 48 89 fb e8 8d ce ff ff 41 8d 44 24 ff 48 c1 e0 05 48 01 c3 <48> 8b 03 48 83 e0 fe 48 83 c8 02 48 89 03 48 8b 5d f0 4c 8b 65
RIP [<ffffffff812de48f>] sg_init_table+0x2f/0x50
RSP <ffff88007bf25dd8>
---[ end trace 86323505eb42ea8f ]---
It seems to induce pagefault in sg_init_tabel() when pipe->nrbufs is equal to
zero. This may happen in a following situation:
(1) The application normally does splice(read) from a kernel buffer, then does
splice(write) to virtio-serial.
(2) The application receives SIGINT when is doing splice(read), so splice(read)
is failed by EINTR. However, the application does not finish the operation.
(3) The application tries to do splice(write) without pipe->nrbufs.
(4) The virtio-console driver tries to touch scatterlist structure sgl in
sg_init_table(), but the region is out of bound.
To avoid the case, a kernel should check whether pipe->nrbufs is empty or not
when splice_write is executed in the virtio-console driver.
V3: Add Reviewed-by lines and stable@ line in sign-off area.
commit 22e8099f4f6621b8d165e238cdef2a1cf655e159 upstream.
The MODULE_LICENSE macro invocation must use either "GPL" or "GPL v2",
but not "GPLv2" in order to be detected by the module loader.
This fixes the allmodconfig build error:
FATAL: modpost: GPL-incompatible module bcm2835-rng.ko uses GPL-only symbol 'platform_driver_unregister'
Acked-by: Lubomir Rintel <lkundrak@v3.sk>
Cc: Dom Cobley <popcornmix@gmail.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Matt Mackall <mpm@selenic.com>
Cc: linux-rpi-kernel@lists.infradead.org
Cc: Herbert Xu <herbert@gondor.apana.org.au>
commit 06f0cce43a32bd2357cea1d8733bba48693d556b upstream.
Allow binding of user memory to the AGP GART on systems with HP
Quicksilver AGP bus. This resolves 'bind memory failed' error seen in
dmesg:
[29.365973] [TTM] AGP Bind memory failed.
[29.367030] [drm] Forcing AGP to PCI mode
The system doesn't more fail to bind the memory, and hence not falling
back to the PCI mode (if other failures aren't detected).
This is just a simple write down from the following patches:
agp/amd-k7: Allow binding user memory to the AGP GART
agp/hp-agp: Allow binding user memory to the AGP GART
Signed-off-by: Alex Ivanov <gnidorah@p0n4ik.tk>
Signed-off-by: Helge Deller <deller@gmx.de>
Commit 902c098a3663 ("random: use lockless techniques in the interrupt
path") turned IRQ path from being spinlock protected into lockless
cmpxchg-retry update.
That commit removed r->lock serialization between crediting entropy bits
from IRQ context and accounting when extracting entropy on userspace
read path, but didn't turn the r->entropy_count reads/updates in
account() to use cmpxchg as well.
It has been observed, that under certain circumstances this leads to
read() on /dev/urandom to return 0 (EOF), as r->entropy_count gets
corrupted and becomes negative, which in turn results in propagating 0
all the way from account() to the actual read() call.
Convert the accounting code to be the proper lockless counterpart of
what has been partially done by 902c098a3663.
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Greg KH <greg@kroah.com>
Cc: <stable@vger.kernel.org>
Commit ec8f02da9ea5 ("random: prime last_data value per fips
requirements") added priming of last_data per fips requirements.
Unfortuantely, it did so in a way that can lead to multiple threads all
incrementing nbytes, but only one actually doing anything with the extra
data, which leads to some fun random corruption and panics.
The fix is to simply do everything needed to prime last_data in a single
shot, so there's no window for multiple cpus to increment nbytes -- in
fact, we won't even increment or decrement nbytes anymore, we'll just
extract the needed EXTRACT_SIZE one time per pool and then carry on with
the normal routine.
All these changes have been tested across multiple hosts and
architectures where panics were previously encoutered. The code changes
are are strictly limited to areas only touched when when booted in fips
mode.
This change should also go into 3.8-stable, to make the myriads of fips
users on 3.8.x happy.
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Tested-by: Jan Stancek <jstancek@redhat.com>
Tested-by: Jan Stodola <jstodola@redhat.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver fixes from Greg Kroah-Hartman:
"Here are some small char/misc driver fixes for 3.10-rc2.
Nothing major here, just a number of fixes for things that people have
reported, and a MAINTAINERS update for the recent changes for the
hyperv files that went into 3.10-rc1."
* tag 'char-misc-3.10-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
ttyprintk: Fix NULL pointer deref by setting tty_port ops after initializing port
uio: UIO_DMEM_GENIRQ should depend on HAS_DMA
MAINTAINERS: update Hyper-V file list
mei: bus: Reset event_cb when disabling a device
Drivers: hv: Fix a bug in get_vp_index()
mei: fix out of array access to me clients array
Char: lp, protect LPGETSTATUS with port_mutex
dummy-irq: require the user to specify an IRQ number
port
tty_port_init() zeroes out the tty port, which means that we have to set the
ops pointer /after/, not before this call. Otherwise, tty_port_open will crash
when it tries to deref ops, which is now a NULL pointer.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull devm usage cleanup from Wolfram Sang:
"Lately, I have been experimenting how to improve the devm interface to
make writing device drivers easier and less error prone while also
getting rid of its subtle issues. I think it has more potential but
still needs work and definately conistency, especiall in its usage.
The first thing I come up with is a low hanging fruit regarding
devm_ioremap_resouce(). This function already checks if the passed
resource is valid and gives an error message if not. So, we can
remove similar checks from the drivers and get rid of a bit of code
and a number of inconsistent error strings.
This series only removes the unneeded check iff devm_ioremap_resource
follows platform_get_resource directly. The previous version tried to
shuffle code if needed, too, what lead to an embarrasing bug. It
turned out to me that shuffling code for all cases found will make the
automated script too complex, so I am unsure if an automated cleanup
is the proper tool for this case. Removing the easy stuff seems
worthwhile to me, though.
Despite various architectures and platform dependencies, I managed to
compile test 45 out of 57 modified files locally using heuristics and
defconfigs."
Pulled because: 296 deletions, 0 additions.
* 'devm_no_resource_check' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (33 commits)
sound/soc/kirkwood: don't check resource with devm_ioremap_resource
sound/soc/fsl: don't check resource with devm_ioremap_resource
arch/mips/lantiq/xway: don't check resource with devm_ioremap_resource
arch/arm/plat-samsung: don't check resource with devm_ioremap_resource
arch/arm/mach-tegra: don't check resource with devm_ioremap_resource
drivers/watchdog: don't check resource with devm_ioremap_resource
drivers/w1/masters: don't check resource with devm_ioremap_resource
drivers/video/omap2/dss: don't check resource with devm_ioremap_resource
drivers/video/omap2: don't check resource with devm_ioremap_resource
drivers/usb/phy: don't check resource with devm_ioremap_resource
drivers/usb/host: don't check resource with devm_ioremap_resource
drivers/usb/gadget: don't check resource with devm_ioremap_resource
drivers/usb/chipidea: don't check resource with devm_ioremap_resource
drivers/thermal: don't check resource with devm_ioremap_resource
drivers/staging/nvec: don't check resource with devm_ioremap_resource
drivers/staging/dwc2: don't check resource with devm_ioremap_resource
drivers/spi: don't check resource with devm_ioremap_resource
drivers/rtc: don't check resource with devm_ioremap_resource
drivers/pwm: don't check resource with devm_ioremap_resource
drivers/pinctrl: don't check resource with devm_ioremap_resource
The patch fixes a problem in the lp driver that can cause oopses as
follows:
process A: calls lp_write, which in turn calls
parport_ieee1284_write_compat, and that invokes
parport_wait_peripheral
process B: meanwhile does an ioctl(LPGETSTATUS), which call
lp_release_parport when done. This function will set
physport->cad = NULL.
process A: parport_wait_peripheral tries to dereference
physport->cad and dies
So, protect that code with the port_mutex in order to protect against
simultaneous calls to lp_read/lp_write.
Similar protection is probably required for ioctl(LPRESET)...
This patch was done by IBM a while back and we (at suse) have that
since at least 2004 in our repos. Let's make it upstream.
Signed-off-by: okir@suse.de
When a 32 bit version of ipmitool is used on a 64 bit kernel, the
ipmi_devintf code fails to correctly acquire ipmi_mutex. This results in
incomplete data being retrieved in some cases, or other possible failures.
Add a wrapper around compat_ipmi_ioctl() to take ipmi_mutex to fix this.
Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
Cc: stable@vger.kernel.org
When the interrupt enable message returns an error, the messages are
not entirely accurate nor helpful. So improve them.
When calling memcpy, read_data and write_data need additional 2 bytes.
write_data:
for checking: "if (size > IPMI_MAX_MSG_LENGTH)"
for operating: "memcpy(bt->write_data + 3, data + 1, size - 1)"
read_data:
for checking: "if (msg_len < 3 || msg_len > IPMI_MAX_MSG_LENGTH)"
for operating: "memcpy(data + 2, bt->read_data + 4, msg_len - 2)"
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Replaced calls to kmalloc followed by strcpy with a sincle call to
kstrdup. Patch found using coccinelle.
Signed-off-by: Alexandru Gheorghiu <gheorghiuandru@gmail.com>
devm_ioremap_resource does sanity checks on the given resource. No need to
duplicate this in the driver.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Faster kernel compiles by way of fewer unnecessary includes.
[akpm@linux-foundation.org: fix fallout]
[akpm@linux-foundation.org: fix build]
Signed-off-by: Kent Overstreet <koverstreet@google.com>
Cc: Zach Brown <zab@redhat.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
These are handy for measuring the cost of the aio infrastructure with
operations that do very little and complete immediately.
Signed-off-by: Zach Brown <zab@redhat.com>
Acked-by: Jeff Moyer <jmoyer@redhat.com>
Pull crypto update from Herbert Xu:
- XTS mode optimisation for twofish/cast6/camellia/aes on x86
- AVX2/x86_64 implementation for blowfish/twofish/serpent/camellia
- SSSE3/AVX/AVX2 optimisations for sha256/sha512
- Added driver for SAHARA2 crypto accelerator
- Fix for GMAC when used in non-IPsec secnarios
- Added generic CMAC implementation (including IPsec glue)
- IP update for crypto/atmel
- Support for more than one device in hwrng/timeriomem
- Added Broadcom BCM2835 RNG driver
- Misc fixes
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (59 commits)
crypto: caam - fix job ring cleanup code
crypto: camellia - add AVX2/AES-NI/x86_64 assembler implementation of camellia cipher
crypto: serpent - add AVX2/x86_64 assembler implementation of serpent cipher
crypto: twofish - add AVX2/x86_64 assembler implementation of twofish cipher
crypto: blowfish - add AVX2/x86_64 implementation of blowfish cipher
crypto: tcrypt - add async cipher speed tests for blowfish
crypto: testmgr - extend camellia test-vectors for camellia-aesni/avx2
crypto: aesni_intel - fix Kconfig problem with CRYPTO_GLUE_HELPER_X86
crypto: aesni_intel - add more optimized XTS mode for x86-64
crypto: x86/camellia-aesni-avx - add more optimized XTS code
crypto: cast6-avx: use new optimized XTS code
crypto: x86/twofish-avx - use optimized XTS code
crypto: x86 - add more optimized XTS-mode for serpent-avx
xfrm: add rfc4494 AES-CMAC-96 support
crypto: add CMAC support to CryptoAPI
crypto: testmgr - add empty test vectors for null ciphers
crypto: testmgr - add AES GMAC test vectors
crypto: gcm - fix rfc4543 to handle async crypto correctly
crypto: gcm - make GMAC work when dst and src are different
hwrng: timeriomem - added devicetree hooks
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio & lguest updates from Rusty Russell:
"Lots of virtio work which wasn't quite ready for last merge window.
Plus I dived into lguest again, reworking the pagetable code so we can
move the switcher page: our fixmaps sometimes take more than 2MB now..."
Ugh. Annoying conflicts with the tcm_vhost -> vhost_scsi rename.
Hopefully correctly resolved.
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (57 commits)
caif_virtio: Remove bouncing email addresses
lguest: improve code readability in lg_cpu_start.
virtio-net: fill only rx queues which are being used
lguest: map Switcher below fixmap.
lguest: cache last cpu we ran on.
lguest: map Switcher text whenever we allocate a new pagetable.
lguest: don't share Switcher PTE pages between guests.
lguest: expost switcher_pages array (as lg_switcher_pages).
lguest: extract shadow PTE walking / allocating.
lguest: make check_gpte et. al return bool.
lguest: assume Switcher text is a single page.
lguest: rename switcher_page to switcher_pages.
lguest: remove RESERVE_MEM constant.
lguest: check vaddr not pgd for Switcher protection.
lguest: prepare to make SWITCHER_ADDR a variable.
virtio: console: replace EMFILE with EBUSY for already-open port
virtio-scsi: reset virtqueue affinity when doing cpu hotplug
virtio-scsi: introduce multiqueue support
virtio-scsi: push vq lock/unlock into virtscsi_vq_done
virtio-scsi: pass struct virtio_scsi to virtqueue completion function
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
Supply a function (proc_remove()) to remove a proc entry (and any subtree
rooted there) by proc_dir_entry pointer rather than by name and (optionally)
root dir entry pointer. This allows us to eliminate all remaining pde->name
accesses outside of procfs.
Acked-by: Grant Likely <grant.likely@linaro.or>
cc: linux-acpi@vger.kernel.org
cc: openipmi-developer@lists.sourceforge.net
cc: devicetree-discuss@lists.ozlabs.org
cc: linux-pci@vger.kernel.org
cc: netdev@vger.kernel.org
cc: netfilter-devel@vger.kernel.org
cc: alsa-devel@alsa-project.org
Merge third batch of fixes from Andrew Morton:
"Most of the rest. I still have two large patchsets against AIO and
IPC, but they're a bit stuck behind other trees and I'm about to
vanish for six days.
- random fixlets
- inotify
- more of the MM queue
- show_stack() cleanups
- DMI update
- kthread/workqueue things
- compat cleanups
- epoll udpates
- binfmt updates
- nilfs2
- hfs
- hfsplus
- ptrace
- kmod
- coredump
- kexec
- rbtree
- pids
- pidns
- pps
- semaphore tweaks
- some w1 patches
- relay updates
- core Kconfig changes
- sysrq tweaks"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (109 commits)
Documentation/sysrq: fix inconstistent help message of sysrq key
ethernet/emac/sysrq: fix inconstistent help message of sysrq key
sparc/sysrq: fix inconstistent help message of sysrq key
powerpc/xmon/sysrq: fix inconstistent help message of sysrq key
ARM/etm/sysrq: fix inconstistent help message of sysrq key
power/sysrq: fix inconstistent help message of sysrq key
kgdb/sysrq: fix inconstistent help message of sysrq key
lib/decompress.c: fix initconst
notifier-error-inject: fix module names in Kconfig
kernel/sys.c: make prctl(PR_SET_MM) generally available
UAPI: remove empty Kbuild files
menuconfig: print more info for symbol without prompts
init/Kconfig: re-order CONFIG_EXPERT options to fix menuconfig display
kconfig menu: move Virtualization drivers near other virtualization options
Kconfig: consolidate CONFIG_DEBUG_STRICT_USER_COPY_CHECKS
relay: use macro PAGE_ALIGN instead of FIX_SIZE
kernel/relay.c: move FIX_SIZE macro into relay.c
kernel/relay.c: remove unused function argument actor
drivers/w1/slaves/w1_ds2760.c: fix the error handling in w1_ds2760_add_slave()
drivers/w1/slaves/w1_ds2781.c: fix the error handling in w1_ds2781_add_slave()
There are several places in kernel where modules unescapes input to convert
C-Style Escape Sequences into byte codes.
The patch provides generic implementation of such approach. Test cases are
also included into the patch.
[akpm@linux-foundation.org: clarify comment]
[akpm@linux-foundation.org: export get_random_int() to modules]
Cc: Samuel Thibault <samuel.thibault@ens-lyon.org>
Cc: Jason Baron <jbaron@redhat.com>
Cc: William Hubbs <w.d.hubbs@gmail.com>
Cc: Chris Brannon <chris@the-brannons.com>
Cc: Kirk Reiser <kirk@braille.uwo.ca>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem update from James Morris:
"Just some minor updates across the subsystem"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security:
ima: eliminate passing d_name.name to process_measurement()
TPM: Retry SaveState command in suspend path
tpm/tpm_i2c_infineon: Add small comment about return value of __i2c_transfer
tpm/tpm_i2c_infineon.c: Add OF attributes type and name to the of_device_id table entries
tpm_i2c_stm_st33: Remove duplicate inclusion of header files
tpm: Add support for new Infineon I2C TPM (SLB 9645 TT 1.2 I2C)
char/tpm: Convert struct i2c_msg initialization to C99 format
drivers/char/tpm/tpm_ppi: use strlcpy instead of strncpy
tpm/tpm_i2c_stm_st33: formatting and white space changes
Smack: include magic.h in smackfs.c
selinux: make security_sb_clone_mnt_opts return an error on context mismatch
seccomp: allow BPF_XOR based ALU instructions.
Fix NULL pointer dereference in smack_inode_unlink() and smack_inode_rmdir()
Smack: add support for modification of existing rules
smack: SMACK_MAGIC to include/uapi/linux/magic.h
Smack: add missing support for transmute bit in smack_str_from_perm()
Smack: prevent revoke-subject from failing when unseen label is written to it
tomoyo: use DEFINE_SRCU() to define tomoyo_ss
