[ Upstream commit b0ecf1c6c6e82da4847900fad0272abfd014666d ]
clk_hw_round_rate() may call round rate function of its parents. In case
of SAM9X60 two of USB parrents are PLLA and UPLL. These clocks are
controlled by clk-sam9x60-pll.c driver. The round rate function for this
driver is sam9x60_pll_round_rate() which call in turn
sam9x60_pll_get_best_div_mul(). In case the requested rate is not in the
proper range (rate < characteristics->output[0].min &&
rate > characteristics->output[0].max) the sam9x60_pll_round_rate() will
return a negative number to its caller (called by
clk_core_round_rate_nolock()). clk_hw_round_rate() will return zero in
case a negative number is returned by clk_core_round_rate_nolock(). With
this, the USB clock will continue its rate computation even caller of
clk_hw_round_rate() returned an error. With this, the USB clock on SAM9X60
may not chose the best parent. I detected this after a suspend/resume
cycle on SAM9X60.
Signed-off-by: Claudiu Beznea <claudiu.beznea@microchip.com>
Link: https://lkml.kernel.org/r/1579261009-4573-2-git-send-email-claudiu.beznea@microchip.com
Signed-off-by: Stephen Boyd <sboyd@kernel.org>
We're removing struct clk from the clk provider API, so switch
this code to using the clk_hw based provider APIs.
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Mostly converted with the following semantic patch:
struct clk_hw *E;
-__clk_get_num_parents(E->clk)
+clk_hw_get_num_parents(E)
Cc: Chao Xie <chao.xie@marvell.com>
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Cc: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Cc: Tomasz Figa <tomasz.figa@gmail.com>
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Cc: "Emilio López" <emilio@elopez.com.ar>
Acked-by: Tero Kristo <t-kristo@ti.com>
Cc: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Use of_clk_parent_fill to fill in the parent clock names' array.
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Boris Brezillon <boris.brezillon@free-electrons.com>
Clock rates are stored in an unsigned long field, but ->determine_rate()
(which returns a rounded rate from a requested one) returns a long
value (errors are reported using negative error codes), which can lead
to long overflow if the clock rate exceed 2Ghz.
Change ->determine_rate() prototype to return 0 or an error code, and pass
a pointer to a clk_rate_request structure containing the expected target
rate and the rate constraints imposed by clk users.
The clk_rate_request structure might be extended in the future to contain
other kind of constraints like the rounding policy, the maximum clock
inaccuracy or other things that are not yet supported by the CCF
(power consumption constraints ?).
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
CC: Jonathan Corbet <corbet@lwn.net>
CC: Tony Lindgren <tony@atomide.com>
CC: Ralf Baechle <ralf@linux-mips.org>
CC: "Emilio López" <emilio@elopez.com.ar>
CC: Maxime Ripard <maxime.ripard@free-electrons.com>
CC: Peter De Schrijver <pdeschrijver@nvidia.com>
CC: Prashant Gaikwad <pgaikwad@nvidia.com>
CC: Stephen Warren <swarren@wwwdotorg.org>
CC: Thierry Reding <thierry.reding@gmail.com>
CC: Alexandre Courbot <gnurou@gmail.com>
CC: linux-doc@vger.kernel.org
CC: linux-kernel@vger.kernel.org
CC: linux-arm-kernel@lists.infradead.org
CC: linux-omap@vger.kernel.org
CC: linux-mips@linux-mips.org
CC: linux-tegra@vger.kernel.org
[sboyd@codeaurora.org: Fix parent dereference problem in
__clk_determine_rate()]
Tested-by: Romain Perier <romain.perier@gmail.com>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
[sboyd@codeaurora.org: Folded in fix from Heiko for fixed-rate
clocks without parents or a rate determining op]
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
The at91sam9n12 and at91sam9x5 usb clocks do not propagate rate
modification requests to their parents.
This causes a bug when the PLLB is left uninitialized by the bootloader
(PLL multiplier set to 0, or in other words, PLL rate = 0 Hz).
Implement the determinate_rate method and propagate the change rate
request to the parent clk.
Cc: <stable@vger.kernel.org> # v3.14+
Reported-by: Bo Shen <voice.shen@atmel.com>
Tested-by: Bo Shen <voice.shen@atmel.com>
Signed-off-by: Michael Turquette <mturquette@linaro.org>
First check for rate == 0 in set_rate and round_rate to avoid div by zero.
Then, in order to get the closest rate, round all divisions to the closest
result instead of rounding them down.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
at91rm9200_clk_usb_set_rate might fail depending on the requested rate,
because the parent_rate / rate remainder is not necessarily zero.
Moreover, when rounding down the calculated rate we might alter the
divisor calculation and end up with an invalid divisor.
To solve those problems, accept a non zero remainder, and always round
division to the closest result.
Reported-by: Andreas Henriksson <andreas.henriksson@endian.se>
Tested-by: Andreas Henriksson <andreas.henriksson@endian.se>
Test rate value before calculating the div value to avoid div by zero.
Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
Reported-by: Gaël PORTAY <gael.portay@gmail.com>
Tested-by: Gaël PORTAY <gael.portay@gmail.com>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
The RM9200 USB clock is actually connected to a single parent (the PLLB)
on which we can apply a specific divider.
The USB clock divider does not allow for fine grained control on the USB
clock frequency, hence propagating the set_rate request to the parent is
the only choice we have to properly configure the USB clock rate.
This patch adds new at91 usb clock implementation using common clk framework.
This clock is used to clock usb ports (ohci, ehci and udc).
Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com>
Acked-by: Mike Turquette <mturquette@linaro.org>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
