path: root/drivers/clk/at91
2014-07-02clk: at91: main: warn when the main crystal frequency is not setAlexandre Belloni
When the main crystal frequency is not set, the main clock is approximated using the MAINF value in the CKGR_MCFR register. Warn the user in that case. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Boris BREZILLON <boris.brezillon@overkiz.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-05-07clk: at91: add slow clks driverBoris BREZILLON
AT91 slow clk is a clk multiplexer. In some SoCs (sam9x5, sama5, sam9g45 families) this multiplexer can choose among 2 sources: an internal RC oscillator circuit and an oscillator using an external crystal. In other Socs (sam9260 family) the multiplexer source is hardcoded with the OSCSEL signal. Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-05-07clk: at91: rework main clk implementationBoris BREZILLON
AT91 main clk is a clk multiplexer and not a simple fixed rate clk as currently implemented. In some SoCs (sam9x5, sama5, sam9g45 families) this multiplexer can choose among 2 sources: an internal RC oscillator circuit and an oscillator using an external crystal. In other Socs (sam9260, rm9200 families) the multiplexer source is hardcoded to the external crystal oscillator. Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-03-19clk: at91: optimization of the set_rate callbackJean-Jacques Hiblot
Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@traphandler.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-03-19clk: at91: fix programmable clk irq handlingJean-Jacques Hiblot
The PCKRDY bit is not set until the system clock is enabled. This patch moves the management of the ready status in the system clock driver. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@traphandler.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-03-19clk: at91: propagate rate change on system clksBoris BREZILLON
System clks are just gates, and thus do not provide any rate operations. Authorize clk rate change to be propagated to system clk parents. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-03-19clk: at91: replace prog clk round_rate with determine_rateBoris BREZILLON
Implement the determine_rate callback to choose the best parent clk that fulfills the requested rate. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-02-26clk:at91: Fix memory leak in of_at91_clk_master_setup()Masanari Iida
cppcheck detected following error [clk-master.c:245]: (error) Memory leak: characteristics The original code forgot to free characteristics when irq_of_parse_and_map() failed. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by Boris BREZILLON <b.brezillon@overkiz.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-14Merge tag 'at91-cleanup2' of git://github.com/at91linux/linux-at91 into ↵Kevin Hilman
next/cleanup From Nicolas Ferre: Second cleanup pull-request for 3.14: - a tiny fix for the recent AT91 CCF implementation - the switch of one platform to DT with board file removal * tag 'at91-cleanup2' of git://github.com/at91linux/linux-at91: ARM: at91: switch Calao QIL-A9260 board to DT clk: at91: fix pmc_clk_ids data type attriubte Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-12-19clk: at91: fix pmc_clk_ids data type attriubteBoris BREZILLON
Fix pmc_clk_ids data type attribute (__initdata -> __initconst). Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-12-12ARM: at91: remove AT91_PROGRAMMABLE_CLOCKS configuration optionNicolas Ferre
This AT91 specific Kconfig option removed the code that dealt with programmable clocks. Each AT91 SoC embeds programmable clocks and there is little gain to remove this code in case that such a clock is not used. If this option is not selected, it causes certain drivers to fail to build. We simply remove this option instead of adding code just to build a workaround. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-12-02clk: at91: add PMC smd clockBoris BREZILLON
This patch adds at91 smd (Soft Modem) clock implementation using common clk framework. Not used by any driver right now. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-12-02clk: at91: add PMC usb clockBoris BREZILLON
This patch adds new at91 usb clock implementation using common clk framework. This clock is used to clock usb ports (ohci, ehci and udc). Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-12-02clk: at91: add PMC utmi clockBoris BREZILLON
This adds new at91 utmi clock implementation using common clk framework. This clock is a pll with a fixed factor (x40). It is used as a source for usb clock. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-12-02clk: at91: add PMC programmable clocksBoris BREZILLON
This patch adds new at91 programmable clocks implementation using common clk framework. A programmable clock is a clock which can be exported on a given pin to clock external devices. Each programmable clock is given an id (from 0 to 8). The number of available programmable clocks depends on the SoC you're using. Programmable clock driver only implements the clock setting (clock rate and parent setting). It must be chained to a system clock in order to enable/disable the generated clock. The PCKX pins used to output the clock signals must be assigned to the appropriate peripheral (see atmel's datasheets). Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-12-02clk: at91: add PMC peripheral clocksBoris BREZILLON
This patch adds new at91 peripheral clock implementation using common clk framework. Almost all peripherals provided by at91 SoCs need a clock to work properly. This clock is enabled/disabled using PCER/PCDR resgisters. Each peripheral is given an id (see atmel's datasheets) which is used to define and reference peripheral clocks. Some new SoCs (at91sam9x5 and sama5d3) provide a new register (PCR) where you can configure the peripheral clock as a division of the master clock. This will help reducing the peripherals power comsumption. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-12-02clk: at91: add PMC system clocksBoris BREZILLON
This patch adds new at91 system clock implementation using common clk framework. Some peripherals need to enable a "system" clock in order to work properly. Each system clock is given an id based on the bit position in SCER/SCDR registers. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-12-02clk: at91: add PMC master clockBoris BREZILLON
This patch adds new at91 master clock implementation using common clk framework. The master clock layout describe the MCKR register layout. There are 2 master clock layouts: - at91rm9200 - at91sam9x5 Master clocks are given characteristics: - min/max clock output rate These characteristics are checked during rate change to avoid over/underclocking. These characteristics are described in atmel's SoC datasheet in "Electrical Characteristics" paragraph. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-12-02clk: at91: add PMC pll clocksBoris BREZILLON
This patch adds new at91 pll clock implementation using common clk framework. The pll clock layout describe the PLLX register layout. There are four pll clock layouts: - at91rm9200 - at91sam9g20 - at91sam9g45 - sama5d3 PLL clocks are given characteristics: - min/max clock source rate - ranges of valid clock output rates - values to set in out and icpll fields for each supported output range These characteristics are checked during rate change to avoid over/underclocking. These characteristics are described in atmel's SoC datasheet in "Electrical Characteristics" paragraph. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-12-02clk: at91: add PMC main clockBoris BREZILLON
This patch adds new at91 main oscillator clock implementation using common clk framework. If rate is not provided during clock registration it is calculated using the slow clock (main clk parent in this case) rate and MCFR register. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-12-02clk: at91: add PMC base supportBoris BREZILLON
This patch adds at91 PMC (Power Management Controller) base support. All at91 clocks managed by the PMC unit will use this framework. This framework provides the following fonctionalities: - define a new struct at91_pmc to hide PMC internals (lock, PMC memory mapping, irq domain, ...) - read/write helper functions (pmc_read/write) to access PMC registers - lock/unlock helper functions (pmc_lock/unlock) to lock/unlock access to pmc registers - a new irq domain and its associated irq chip to request PMC specific interrupts (useful for clk prepare callbacks) The PMC unit is declared as a dt clk provider (CLK_OF_DECLARE), and every clk using this framework will declare a table of of_at91_clk_init_cb_t and add it to the pmc_clk_ids table. When the pmc dt clock setup function is called (by of_clk_init function), it triggers the registration of every supported child clk (those matching the definitions in pmc_clk_ids). This patch copies at91_pmc_base (memory mapping) and at91sam9_idle (function) from arch/arm/mach-at91/clock.c (which is not compiled if COMMON_CLK_AT91 is enabled). Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
