path: root/drivers/clk/at91
2020-04-24clk: at91: usb: continue if clk_hw_round_rate() return zeroClaudiu Beznea
[ Upstream commit b0ecf1c6c6e82da4847900fad0272abfd014666d ] clk_hw_round_rate() may call round rate function of its parents. In case of SAM9X60 two of USB parrents are PLLA and UPLL. These clocks are controlled by clk-sam9x60-pll.c driver. The round rate function for this driver is sam9x60_pll_round_rate() which call in turn sam9x60_pll_get_best_div_mul(). In case the requested rate is not in the proper range (rate < characteristics->output[0].min && rate > characteristics->output[0].max) the sam9x60_pll_round_rate() will return a negative number to its caller (called by clk_core_round_rate_nolock()). clk_hw_round_rate() will return zero in case a negative number is returned by clk_core_round_rate_nolock(). With this, the USB clock will continue its rate computation even caller of clk_hw_round_rate() returned an error. With this, the USB clock on SAM9X60 may not chose the best parent. I detected this after a suspend/resume cycle on SAM9X60. Signed-off-by: Claudiu Beznea <claudiu.beznea@microchip.com> Link: https://lkml.kernel.org/r/1579261009-4573-2-git-send-email-claudiu.beznea@microchip.com Signed-off-by: Stephen Boyd <sboyd@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2016-06-07clk: at91: fix check of clk_register() returned valueVladimir Zapolskiy
commit cb0ceaf77d93964a0d00477c79f4499123f6159c upstream. The clk_register() function returns a valid pointer to struct clk or ERR_PTR() error code, this makes a check for returned NULL value useless and may lead to oops on error path. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Fixes: bcc5fd49a0fd ("clk: at91: add a driver for the h32mx clock") Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-01clk: at91: add generated clock driverNicolas Ferre
Add a new type of clocks that can be provided to a peripheral. In addition to the peripheral clock, this new clock that can use several input clocks as parents can generate divided rates. This would allow a peripheral to have finer grained clocks for generating a baud rate, clocking an asynchronous part or having more options in frequency. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> [sboyd@codeaurora.org: Transition to new clk_hw provider APIs] Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-10-01clk: at91: add PMC sama5d2 supportNicolas Ferre
Add support for the new sama5d2 SoC and adapt capabilities. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-10-01clk: at91: modify PMC peripheral clock to deal with newer register layoutNicolas Ferre
As some more information is added to the PCR register, we'd better use a copy of its content and modify just the peripheral-related bits. Implement a read-modify-write for the enable() and disable() callbacks. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-10-01clk: at91: cleanup PMC header file for PCR register fieldsNicolas Ferre
Add _MASK and _OFFSET values and cleanup register fields layout. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-09-16clk: at91: system: don't try to free_irq when there is no IRQAlexandre Belloni
In the error path of at91_clk_register_system(), sys->irq is freed unconditionally but it may not exist or be request at all. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-09-16clk: at91: utmi: use pmc_read when the at91_pmc is availableAlexandre Belloni
at91_pmc_read is a workaround to allow external drivers to acces some registers of the PMC. There is no need for it in clk-utmi.c as we aready have a pointer to the struct at91_pmc. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-08-24clk: at91: Convert to clk_hw based provider APIsStephen Boyd
We're removing struct clk from the clk provider API, so switch this code to using the clk_hw based provider APIs. Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-08-24clk: Replace __clk_get_num_parents with clk_hw_get_num_parents()Stephen Boyd
Mostly converted with the following semantic patch: @@ struct clk_hw *E; @@ -__clk_get_num_parents(E->clk) +clk_hw_get_num_parents(E) Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Chao Xie <chao.xie@marvell.com> Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com> Cc: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Cc: Tomasz Figa <tomasz.figa@gmail.com> Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: "Emilio López" <emilio@elopez.com.ar> Acked-by: Tero Kristo <t-kristo@ti.com> Cc: Geert Uytterhoeven <geert+renesas@glider.be> Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-07-28clk: kill off set_irq_flags usageRob Herring
set_irq_flags is ARM specific with custom flags which have genirq equivalents. Convert drivers to use the genirq interfaces directly, so we can kill off set_irq_flags. The translation of flags is as follows: IRQF_VALID -> !IRQ_NOREQUEST IRQF_PROBE -> !IRQ_NOPROBE IRQF_NOAUTOEN -> IRQ_NOAUTOEN For IRQs managed by an irqdomain, the irqdomain core code handles clearing and setting IRQ_NOREQUEST already, so there is no need to do this in .map() functions and we can simply remove the set_irq_flags calls. Some users also modify IRQ_NOPROBE and this has been maintained although it is not clear that is really needed. There appears to be a great deal of blind copy and paste of this code. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Mike Turquette <mturquette@baylibre.com> Acked-by: Stephen Boyd <sboyd@codeaurora.org> Cc: linux-clk@vger.kernel.org Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-07-28Merge branch 'cleanup-clk-h-includes' into clk-nextStephen Boyd
* cleanup-clk-h-includes: (62 commits) clk: Remove clk.h from clk-provider.h clk: h8300: Remove clk.h and clkdev.h includes clk: at91: Include clk.h and slab.h clk: ti: Switch clk-provider.h include to clk.h clk: pistachio: Include clk.h clk: ingenic: Include clk.h clk: si570: Include clk.h clk: moxart: Include clk.h clk: cdce925: Include clk.h clk: Include clk.h in clk.c clk: zynq: Include clk.h clk: ti: Include clk.h clk: sunxi: Include clk.h and remove unused clkdev.h includes clk: st: Include clk.h clk: qcom: Include clk.h clk: highbank: Include clk.h clk: bcm: Include clk.h clk: versatile: Remove clk.h and clkdev.h includes clk: ux500: Remove clk.h and clkdev.h includes clk: tegra: Properly include clk.h ...
2015-07-28clk: at91: make use of of_clk_parent_fill helper functionDinh Nguyen
Use of_clk_parent_fill to fill in the parent clock names' array. Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-07-28Merge branch 'clk-determine-rate-struct' into clk-nextStephen Boyd
* clk-determine-rate-struct: clk: fix some determine_rate implementations clk: change clk_ops' ->determine_rate() prototype
2015-07-27clk: change clk_ops' ->determine_rate() prototypeBoris Brezillon
Clock rates are stored in an unsigned long field, but ->determine_rate() (which returns a rounded rate from a requested one) returns a long value (errors are reported using negative error codes), which can lead to long overflow if the clock rate exceed 2Ghz. Change ->determine_rate() prototype to return 0 or an error code, and pass a pointer to a clk_rate_request structure containing the expected target rate and the rate constraints imposed by clk users. The clk_rate_request structure might be extended in the future to contain other kind of constraints like the rounding policy, the maximum clock inaccuracy or other things that are not yet supported by the CCF (power consumption constraints ?). Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Jonathan Corbet <corbet@lwn.net> CC: Tony Lindgren <tony@atomide.com> CC: Ralf Baechle <ralf@linux-mips.org> CC: "Emilio López" <emilio@elopez.com.ar> CC: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Tero Kristo <t-kristo@ti.com> CC: Peter De Schrijver <pdeschrijver@nvidia.com> CC: Prashant Gaikwad <pgaikwad@nvidia.com> CC: Stephen Warren <swarren@wwwdotorg.org> CC: Thierry Reding <thierry.reding@gmail.com> CC: Alexandre Courbot <gnurou@gmail.com> CC: linux-doc@vger.kernel.org CC: linux-kernel@vger.kernel.org CC: linux-arm-kernel@lists.infradead.org CC: linux-omap@vger.kernel.org CC: linux-mips@linux-mips.org CC: linux-tegra@vger.kernel.org [sboyd@codeaurora.org: Fix parent dereference problem in __clk_determine_rate()] Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Tested-by: Romain Perier <romain.perier@gmail.com> Signed-off-by: Heiko Stuebner <heiko@sntech.de> [sboyd@codeaurora.org: Folded in fix from Heiko for fixed-rate clocks without parents or a rate determining op] Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-07-20clk: at91: Include clk.h and slab.hStephen Boyd
This clock provider uses the consumer API, so include clk.h explicitly. Also include slab.h instead of relying on clkdev.h for it. Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-07-07clk: at91: Silence warnings and cleanup __init/extern usageStephen Boyd
Remove useless ifdefs around function prototypes to silence the following sparse warnings when the configs aren't enabled. drivers/clk/at91/clk-h32mx.c:95:13: warning: symbol 'of_sama5d4_clk_h32mx_setup' was not declared. Should it be static? drivers/clk/at91/clk-utmi.c:159:13: warning: symbol 'of_at91sam9x5_clk_utmi_setup' was not declared. Should it be static? Plus, using __init and extern in function prototypes doesn't do anything, so just drop it throughout this file. Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-07-06Merge branch 'clk-fixes' into clk-nextStephen Boyd
* clk-fixes: clk: mediatek: mt8173: Fix enabling of critical clocks drivers: clk: st: Fix mux bit-setting for Cortex A9 clocks drivers: clk: st: Add CLK_GET_RATE_NOCACHE flag to clocks drivers: clk: st: Fix flexgen lock init drivers: clk: st: Fix FSYN channel values drivers: clk: st: Remove unused code clk: qcom: Use parent rate when set rate to pixel RCG clock clk: at91: do not leak resources clk: stm32: Fix out-by-one error path in the index lookup clk: iproc: fix bit manipulation arithmetic clk: iproc: fix memory leak from clock name
2015-07-02clk: at91: do not leak resourcesDavid Dueck
Do not leak memory and free irqs in case of an error. Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: David Dueck <davidcdueck@googlemail.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-07-01Merge tag 'clk-for-linus-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux Pull clock framework updates from Michael Turquette: "The changes to the common clock framework for 4.2 are dominated by new drivers and updates to existing ones, as usual. There are some fixes to the framework itself and several cleanups for sparse warnings, etc" * tag 'clk-for-linus-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (135 commits) clk: stm32: Add clock driver for STM32F4[23]xxx devices dt-bindings: Document the STM32F4 clock bindings cpufreq: exynos: remove Exynos4210 specific cpufreq driver support ARM: Exynos: switch to using generic cpufreq driver for Exynos4210 clk: samsung: exynos4: add cpu clock configuration data and instantiate cpu clock clk: samsung: add infrastructure to register cpu clocks clk: add CLK_RECALC_NEW_RATES clock flag for Exynos cpu clock support doc: dt: add documentation for lpc1850-ccu clk driver clk: add lpc18xx ccu clk driver doc: dt: add documentation for lpc1850-cgu clk driver clk: add lpc18xx cgu clk driver clk: keystone: add support for post divider register for main pll clk: mvebu: flag the crypto clk as CLK_IGNORE_UNUSED clk: cygnus: remove Cygnus dummy clock binding clk: cygnus: add clock support for Broadcom Cygnus clk: Change bcm clocks build dependency clk: iproc: add initial common clock support clk: iproc: define Broadcom iProc clock binding MAINTAINERS: update email for Michael Turquette clk: meson: add some error handling in meson_clk_register_cpu() ...
2015-06-19Merge branch 'ccf/atmel-fixes-for-4.1' of ↵Michael Turquette
https://github.com/bbrezillon/linux-at91 into clk-fixes
2015-06-19clk: at91: fix h32mx prototype inclusion in pmc headerNicolas Ferre
Trivial fix that prevents to compile this pmc clock driver if h32mx clock is present but smd clock isn't. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Fixes: bcc5fd49a0fd ("clk: at91: add a driver for the h32mx clock") Cc: <stable@vger.kernel.org> # 3.18+
2015-06-19clk: at91: fix PERIPHERAL_MAX_SHIFT definitionBoris Brezillon
Fix the PERIPHERAL_MAX_SHIFT definition (3 instead of 4) and adapt the round_rate and set_rate logic accordingly. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Reported-by: "Wu, Songjun" <Songjun.Wu@atmel.com>
2015-06-19clk: at91: pll: fix input range validity checkBoris Brezillon
The PLL impose a certain input range to work correctly, but it appears that this input range does not apply on the input clock (or parent clock) but on the input clock after it has passed the PLL divisor. Fix the implementation accordingly. Cc: <stable@vger.kernel.org> # v3.14+ Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Reported-by: Jonas Andersson <jonas@microbit.se>
2015-06-04clk: at91: Use of_clk_get_parent_count() instead of open codingGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-05-01clk: at91: Constify irq_domain_opsKrzysztof Kozlowski
The irq_domain_ops are not modified by the driver and the irqdomain core code accepts pointer to a const data. Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com> Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-04-21Merge tag 'clk-for-linus-4.1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux Pull clock framework updates from Michael Turquette: "The changes to the common clock framework for 4.0 are mostly new clock drivers and updates to existing ones for feature enhancements and bug fixes. There is more churn than usual in the framework core due to the change to introduce per-user unique struct clk pointers in 4.0. This caused several regressions to surface, some of which were sent as fixes to 4.0. New generic clock drivers were added for GPIO- and PWM-based clock controllers. Additionally the common clk-divider code recieved several fixes to the way it rounds rates" * tag 'clk-for-linus-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (91 commits) clk: check ->determine/round_rate() return value in clk_calc_new_rates clk: at91: usb: propagate rate modification to the parent clk clk: samsung: exynos4: Disable ARMCLK down feature on Exynos4210 SoC clk: don't use __initconst for non-const arrays clk: at91: change to using endian agnositc IO clk: clk-gpio-gate: Fix active low clk: Add PWM clock driver clk: Add clock driver for mb86s7x clk: pxa: pxa3xx: add missing os timer clock clk: tegra: Use the proper parent for plld_dsi clk: tegra: Use generic tegra_osc_clk_init() on Tegra114 clk: tegra: Model oscillator as clock clk: tegra: Add peripheral registers for bank Y clk: tegra: Register the proper number of resets clk: tegra: Remove needless initializations clk: tegra: Use consistent indentation clk: tegra: Various whitespace cleanups clk: tegra: Enable HDA to HDMI clocks on Tegra124 clk: tegra: Fix a bunch of sparse warnings clk: tegra: Fix typo tabel -> table ...
2015-04-12clk: at91: usb: propagate rate modification to the parent clkBoris Brezillon
The at91sam9n12 and at91sam9x5 usb clocks do not propagate rate modification requests to their parents. This causes a bug when the PLLB is left uninitialized by the bootloader (PLL multiplier set to 0, or in other words, PLL rate = 0 Hz). Implement the determinate_rate method and propagate the change rate request to the parent clk. Cc: <stable@vger.kernel.org> # v3.14+ Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Reported-by: Bo Shen <voice.shen@atmel.com> Tested-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Michael Turquette <mturquette@linaro.org>
2015-03-04clk: at91: implement suspend/resume for the PMC irqchipBoris BREZILLON
The irq line used by the PMC block is shared with several peripherals including the init timer which is registering its handler with IRQF_NO_SUSPEND. Implement the appropriate suspend/resume callback for the PMC irqchip, and inform irq core that PMC irq handler can be safely called while the system is suspended by setting IRQF_COND_SUSPEND. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Reviewed-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-21Merge tag 'clk-for-linus-3.20' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull clock framework updates from Mike Turquette: "The clock framework changes contain the usual driver additions, enhancements and fixes mostly for ARM32, ARM64, MIPS and Power-based devices. Additionally the framework core underwent a bit of surgery with two major changes: - The boundary between the clock core and clock providers (e.g clock drivers) is now more well defined with dedicated provider helper functions. struct clk no longer maps 1:1 with the hardware clock but is a true per-user cookie which helps us tracker users of hardware clocks and debug bad behavior. - The addition of rate constraints for clocks. Rate ranges are now supported which are analogous to the voltage ranges in the regulator framework. Unfortunately these changes to the core created some breakeage. We think we fixed it all up but for this reason there are lots of last minute commits trying to undo the damage" * tag 'clk-for-linus-3.20' of git://git.linaro.org/people/mike.turquette/linux: (113 commits) clk: Only recalculate the rate if needed Revert "clk: mxs: Fix invalid 32-bit access to frac registers" clk: qoriq: Add support for the platform PLL powerpc/corenet: Enable CLK_QORIQ clk: Replace explicit clk assignment with __clk_hw_set_clk clk: Add __clk_hw_set_clk helper function clk: Don't dereference parent clock if is NULL MIPS: Alchemy: Remove bogus args from alchemy_clk_fgcs_detr clkdev: Always allocate a struct clk and call __clk_get() w/ CCF clk: shmobile: div6: Avoid division by zero in .round_rate() clk: mxs: Fix invalid 32-bit access to frac registers clk: omap: compile legacy omap3 clocks conditionally clkdev: Export clk_register_clkdev clk: Add rate constraints to clocks clk: remove clk-private.h pci: xgene: do not use clk-private.h arm: omap2+ remove dead clock code clk: Make clk API return per-user struct clk instances clk: tegra: Define PLLD_DSI and remove dsia(b)_mux clk: tegra: Add support for the Tegra132 CAR IP block ...
2015-02-17Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "New and updated SoC support. Also included are some cleanups where the platform maintainers hadn't separated cleanups from new developent in separate branches. Some of the larger things worth pointing out: - A large set of changes from Alexandre Belloni and Nicolas Ferre preparing at91 platforms for multiplatform and cleaning up quite a bit in the process. - Removal of CSR's "Marco" SoC platform that never made it out to the market. We love seeing these since it means the vendor published support before product was out, which is exactly what we want! New platforms this release are: - Conexant Digicolor (CX92755 SoC) - Hisilicon HiP01 SoC - CSR/sirf Atlas7 SoC - ST STiH418 SoC - Common code changes for Nvidia Tegra132 (64-bit SoC) We're seeing more and more platforms having a harder time labelling changes as cleanups vs new development -- which is a good sign that we've come quite far on the cleanup effort. So over time we might start combining the cleanup and new-development branches more" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (124 commits) ARM: at91/trivial: unify functions and machine names ARM: at91: remove at91_dt_initialize and machine init_early() ARM: at91: change board files into SoC files ARM: at91: remove at91_boot_soc ARM: at91: move alternative initial mapping to board-dt-sama5.c ARM: at91: merge all SOC_AT91SAM9xxx ARM: at91: at91rm9200: set idle and restart from rm9200_dt_device_init() ARM: digicolor: select syscon and timer ARM: zynq: Simplify SLCR initialization ARM: zynq: PM: Fixed simple typo. ARM: zynq: Setup default gpio number for Xilinx Zynq ARM: digicolor: add low level debug support ARM: initial support for Conexant Digicolor CX92755 SoC ARM: OMAP2+: Add dm816x hwmod support ARM: OMAP2+: Add clock domain support for dm816x ARM: OMAP2+: Add board-generic.c entry for ti81xx ARM: at91: pm: remove warning to remove SOC_AT91SAM9263 usage ARM: at91: remove unused mach/system_rev.h ARM: at91: stop using HAVE_AT91_DBGUx ARM: at91: fix ordering of SRAM and PM initialization ...
2015-02-02clk: Add rate constraints to clocksTomeu Vizoso
Adds a way for clock consumers to set maximum and minimum rates. This can be used for thermal drivers to set minimum rates, or by misc. drivers to set maximum rates to assure a minimum performance level. Changes the signature of the determine_rate callback by adding the parameters min_rate and max_rate. Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> [sboyd@codeaurora.org: set req_rate in __clk_init] Signed-off-by: Michael Turquette <mturquette@linaro.org> [mturquette@linaro.org: min/max rate for sun6i_ahb1_clk_determine_rate migrated clk-private.h changes to clk.c]
2015-01-16ARM: at91: move at91rm9200_idle() to clk/at91/pmc.cAlexandre Belloni
Move at91rm9200_idle() along with at91sam9_idle() in clk/at91/pmc.c. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Michael Turquette <mturquette@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2015-01-13clk: at91: keep slow clk enabled to prevent system hangBoris Brezillon
All slow clk users are not properly claiming it (get + prepare + enable) before using it. If all users properly claiming this clock release it, the clock is disabled, but faulty users still depends on it, and the system hangs. This fix prevents the slow clock from being disabled, and should solve the hanging issue, but offending drivers should be patched to properly claim this clock. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Reported-by: Bo Shen <voice.shen@atmel.com> Cc: stable@vger.kernel.org Signed-off-by: Michael Turquette <mturquette@linaro.org>
2014-12-03clk: Change clk_ops->determine_rate to return a clk_hw as the best parentTomeu Vizoso
This is in preparation for clock providers to not have to deal with struct clk. Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Michael Turquette <mturquette@linaro.org>
2014-11-17clk: at91: usb: fix at91sam9x5 recalc, round and set rateBoris Brezillon
First check for rate == 0 in set_rate and round_rate to avoid div by zero. Then, in order to get the closest rate, round all divisions to the closest result instead of rounding them down. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Michael Turquette <mturquette@linaro.org>
2014-11-17clk: at91: usb: fix at91rm9200 round and set rateBoris Brezillon
at91rm9200_clk_usb_set_rate might fail depending on the requested rate, because the parent_rate / rate remainder is not necessarily zero. Moreover, when rounding down the calculated rate we might alter the divisor calculation and end up with an invalid divisor. To solve those problems, accept a non zero remainder, and always round division to the closest result. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Reported-by: Andreas Henriksson <andreas.henriksson@endian.se> Tested-by: Andreas Henriksson <andreas.henriksson@endian.se> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Michael Turquette <mturquette@linaro.org>
2014-10-15Merge tag 'clk-for-linus-3.18' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull clock tree updates from Mike Turquette: "The clk tree changes for 3.18 are dominated by clock drivers. Mostly fixes and enhancements to existing drivers as well as new drivers. This tag contains a bit more arch code than I usually take due to some OMAP2+ changes. Additionally it contains the restart notifier handlers which are merged as a dependency into several trees. The PXA changes are the only messy part. Due to having a stable tree I had to revert one patch and follow up with one more fix near the tip of this tag. Some dead code is introduced but it will soon become live code after 3.18-rc1 is released as the rest of the PXA family is converted over to the common clock framework. Another trend in this tag is that multiple vendors have started to push the complexity of changing their CPU frequency into the clock driver, whereas this used to be done in CPUfreq drivers. Changes to the clk core include a generic gpio-clock type and a clk_set_phase() function added to the top-level clk.h api. Due to some confusion on the fbdev mailing list the kernel boot parameters documentation was updated to further explain the clk_ignore_unused parameter, which is often required by users of the simplefb driver. Finally some fixes to the locking around the clock debugfs stuff was done to prevent deadlocks when interacting with other subsystems." * tag 'clk-for-linus-3.18' of git://git.linaro.org/people/mike.turquette/linux: (99 commits) clk: pxa clocks build system fix Revert "arm: pxa: Transition pxa27x to clk framework" clk: samsung: register restart handlers for s3c2412 and s3c2443 clk: rockchip: add restart handler clk: rockchip: rk3288: i2s_frac adds flag to set parent's rate doc/kernel-parameters.txt: clarify clk_ignore_unused arm: pxa: Transition pxa27x to clk framework dts: add devicetree bindings for pxa27x clocks clk: add pxa27x clock drivers arm: pxa: add clock pll selection bits clk: dts: document pxa clock binding clk: add pxa clocks infrastructure clk: gpio-gate: Ensure gpiod_ APIs are prototyped clk: ti: dra7-atl-clock: Mark the device as pm_runtime_irq_safe clk: ti: LLVMLinux: Move __init outside of type definition clk: ti: consider the fact that of_clk_get() might return an error clk: ti: dra7-atl-clock: fix a memory leak clk: ti: change clock init to use generic of_clk_init clk: hix5hd2: add I2C clocks clk: hix5hd2: add watchdog0 clocks ...
2014-10-08Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Arnd Bergmann: "These are changes for drivers that are intimately tied to some SoC and for some reason could not get merged through the respective subsystem maintainer tree. Most of the new code is for the Keystone Navigator driver, which is new base support that is going to be needed for their hardware accelerated network driver and other units. Most of the commits are for moving old code around from at91 and omap for things that are done in device drivers nowadays. - at91: move reset, poweroff, memory and clocksource code into drivers directories - socfpga: add edac driver (through arm-soc, as requested by Boris) - omap: move omap-intc code to drivers/irqchip - sunxi: added an RTC driver for sun6i - omap: mailbox driver related changes - keystone: support for the "Navigator" component - versatile: new reboot, led and soc drivers" * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (92 commits) bus: arm-ccn: Fix spurious warning message leds: add device tree bindings for register bit LEDs soc: add driver for the ARM RealView power: reset: driver for the Versatile syscon reboot leds: add a driver for syscon-based LEDs drivers/soc: ti: fix build break with modules MAINTAINERS: Add Keystone Multicore Navigator drivers entry soc: ti: add Keystone Navigator DMA support Documentation: dt: soc: add Keystone Navigator DMA bindings soc: ti: add Keystone Navigator QMSS driver Documentation: dt: soc: add Keystone Navigator QMSS bindings rtc: sunxi: Depend on platforms sun4i/sun7i that actually have the rtc rtc: sun6i: Add sun6i RTC driver irqchip: omap-intc: remove unnecessary comments irqchip: omap-intc: correct maximum number or MIR registers irqchip: omap-intc: enable TURBO idle mode irqchip: omap-intc: enable IP protection irqchip: omap-intc: remove unnecesary of_address_to_resource() call irqchip: omap-intc: comment style cleanup irqchip: omap-intc: minor improvement to omap_irq_pending() ...
2014-10-08Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Arnd Bergmann: "New and updated SoC support. Among the things new for this release are: - at91: Added support for the new SAMA5D4 SoC, following the earlier SAMA5D3 - bcm: Added support for BCM63XX family of DSL SoCs - hisi: Added support for HiP04 server-class SoC - meson: Initial support for the Amlogic Meson6 (aka 8726MX) platform - shmobile: added support for new r8a7794 (R-Car E2) automotive SoC Noteworthy changes to existing SoC support are: - imx: convert i.MX1 to device tree - omap: lots of power management work - omap: base support to enable moving to standard UART driver - shmobile: lots of progress for multiplatform support, still ongoing" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (171 commits) ARM: hisi: depend on ARCH_MULTI_V7 CNS3xxx: Fix debug UART. ARM: at91: fix nommu build regression ARM: meson: add basic support for MesonX SoCs ARM: meson: debug: add debug UART for earlyprintk support irq: Export handle_fasteoi_irq ARM: mediatek: Add earlyprintk support for mt6589 ARM: hisi: Fix platmcpm compilation when ARMv6 is selected ARM: debug: fix alphanumerical order on debug uarts ARM: at91: document Atmel SMART compatibles ARM: at91: add sama5d4 support to sama5_defconfig ARM: at91: dt: add device tree file for SAMA5D4ek board ARM: at91: dt: add device tree file for SAMA5D4 SoC ARM: at91: SAMA5D4 SoC detection code and low level routines ARM: at91: introduce basic SAMA5D4 support clk: at91: add a driver for the h32mx clock ARM: pxa3xx: provide specific platform_devices for all ssp ports ARM: pxa: ssp: provide platform_device_id for PXA3xx ARM: OMAP4+: Remove static iotable mappings for SRAM ARM: OMAP4+: Move SRAM data to DT ...
2014-09-22clk: at91: add a driver for the h32mx clockAlexandre Belloni
Newer SoCs have two different AHB interconnect. The AHB 32 bits Matrix interconnect (h32mx) has a clock that can be setup at the half of the h64mx clock (which is mck). The h32mx clock can not exceed 90 MHz. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-09-17Merge branch 'clk-fixes' into clk-nextMike Turquette
2014-09-02clk: at91: fix div by zero in USB clock driverBoris BREZILLON
Test rate value before calculating the div value to avoid div by zero. Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Reported-by: Gaël PORTAY <gael.portay@gmail.com> Tested-by: Gaël PORTAY <gael.portay@gmail.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-09-02clk: at91: rework rm9200 USB clock to propagate set_rate to the parent clkBoris BREZILLON
The RM9200 USB clock is actually connected to a single parent (the PLLB) on which we can apply a specific divider. The USB clock divider does not allow for fine grained control on the USB clock frequency, hence propagating the set_rate request to the parent is the only choice we have to properly configure the USB clock rate. Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Reported-by: Gaël PORTAY <gael.portay@gmail.com> Tested-by: Gaël PORTAY <gael.portay@gmail.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-09-02clk: at91: fix recalc_rate implementation of PLL driverBoris BREZILLON
Use the cached values to calculate PLL rate instead of the register values. This is required to prevent erroneous PLL rate return when the PLL rate has been configured but the PLL is not prepared yet. Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Reported-by: Gaël PORTAY <gael.portay@gmail.com> Tested-by: Gaël PORTAY <gael.portay@gmail.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-09-02clk: at91: rework PLL rate calculationBoris BREZILLON
The AT91 PLL rate configuration is done by configuring a multiplier/divider pair. The previous calculation was over-complicated (and apparently buggy). Simplify the implementation and add some comments to explain what is done here. Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Reported-by: Gaël PORTAY <gael.portay@gmail.com> Tested-by: Gaël PORTAY <gael.portay@gmail.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-09-02clk: at91: fix PLL_MAX_COUNT macro definitionBoris BREZILLON
2014-09-02clk: at91: fix num_parents test in at91sam9260 slow clk implementationBoris BREZILLON
The slow clk block provided by at91sam9260 and derived SoCs should always have 2 parents. Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-08-25Merge tag 'at91-drivers-for-3.17' of ↵Nicolas Ferre
git://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux Pull AT91 reset, poweroff and ram drivers from Maxime Ripard: "This tag holds the various new drivers introduced to move code that used to be in mach-at91 over to the proper frameworks. These files are the reboot and poweroff code for all AT91 SoCs but the RM9200, and the ram controller driver is not doing much at the time, except for grabing the RAM clock in order to leave it always enabled." Conflicts: arch/arm/mach-at91/Kconfig
2014-07-15clk: at91: remove the useless CLK_IGNORE_UNUSED flagAlexandre Belloni
The CLK_IGNORE_UNUSED flag was added on all the system clocks because of the ddrck. Now that it is handled by the ram controller driver, we can drop it. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
