path: root/drivers/clk/clk-u300.c
2013-08-27clk: u300: Fix incorrect placement of __initconstSachin Kamat
__initconst should be placed between the variable name and equal sign for the variable to be placed in the intended section. While at it also make 'u300_clk_lookup' static as it is used only in this file. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-06-17ARM: u300: convert MMC/SD clock to device treeLinus Walleij
This converts the last of the U300 clocks to being probed from the device tree. Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300: move the gated system controller clocks to DTLinus Walleij
This moves the slow, fast, AHB bridge and "rest" clocks on the U300 system controller over to registration from the device tree. Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17clk: move the U300 fixed and fixed-factor to DTLinus Walleij
This converts the fixed and fixed-factor clocks in the U300 platform to register themselves from the device tree. Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300: push down syscon registersLinus Walleij
Get rid of the <mach/syscon.h> header as a prerequisite for multiplatform support. Do this by pushing the registers down to their respective drivers and deleting the unused remainder. Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-07-11ARM: u300: convert to common clockLinus Walleij
This converts the U300 clock implementation over to use the common struct clk and moves the implementation down into drivers/clk. Since VCO isn't used in tree it was removed, it's not hard to put it back in if need be. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> [mturquette@linaro.org: trivial Makefile conflict] Signed-off-by: Mike Turquette <mturquette@linaro.org>
