[ Upstream commit 2137a109a5e39c2bdccfffe65230ed3fadbaac0e ]
In case the upstream clock are not set, which can happen in case the
VC5 has no valid upstream clock, the $src variable is used uninited
by regmap_update_bits(). Check for this condition and return -EINVAL
in such case.
Note that in case the VC5 has no valid upstream clock, the VC5 can
not operate correctly. That is a hardware property of the VC5. The
internal oscilator present in some VC5 models is also considered
upstream clock.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Alexey Firago <alexey_firago@mentor.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Stephen Boyd <sboyd@kernel.org>
Cc: linux-renesas-soc@vger.kernel.org
[sboyd@kernel.org: Added comment about probe preventing this from
happening in the first place]
Signed-off-by: Stephen Boyd <sboyd@kernel.org>
Update IDT VersaClock 5 driver to support 5P49V5925. This chip has only
external clock input, four fractional dividers (FODs) and five clock
outputs (four universal clock outputs and one reference clock output at
OUT0_SELB_I2C).
Signed-off-by: Vladimir Barinov <vladimir.barinov+renesas@cogentembedded.com>
Reviewed-by: Marek Vasut <marek.vasut@gmail.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Update IDT VersaClock 5 driver to support IDT VersaClock 6 5P49V6901.
This chip has two clock inputs (external XTAL or external CLKIN), four
fractional dividers (FODs) and five clock outputs (four universal clock
outputs and one reference clock output at OUT0_SELB_I2C).
Cc: Stephen Boyd <sboyd@codeaurora.org>
Cc: Michael Turquette <mturquette@baylibre.com>
Tested-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
on Salvator-XS with the display LVDS output.
The VersaClock 6 has an input frequency doubler between the input
clock mux and the predivider. Add new capability flag and support
for this frequency doubler block into the driver.
Split the VC5 clock input mux and the predivider to more accurately
model the hardware and fix the previously incorrect assumption that
both the OUT_SEL_I2CB and the PLL are fed from the predivider.
It is in fact the clock input mux output which is directly feeding
the clock into the OUT_SEL_I2CB output, while the clock input mux
output first passes through the predivider before it is fed into
the PLL.
The output buffer input mux can be configured in either of three
states -- disabled, input from FOD, input from previous output.
Once the .prepare() callback of the output buffer is called, the
output buffer input mux must be set to either input from FOD or
input from previous output, it cannot be set to Disabled anymore
or the output won't work.
Default to the input from FOD if the output buffer input mux was
Disabled and the .prepare() was called on it.
Note that we do not set the output buffer input mux back to Disabled
in the .unprepare() callback as there is no obvious benefit of doing
so. We disable the entire output buffer in the .unprepare() callback
already.
Tested-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> # Salvator-XS with the display LVDS output.
If the output buffer input mux is set to disabled, the code in
vc5_clk_out_get_parent() would consider this an invalid setting
and warn about it, which is not necessarily the case.
In case the output buffer input mux is disabled, default to input
from FOD to have some parent and don't print the warning.
Fix trivial typo in vc5_clk_out_unprepare() , s/Enable/Disable/ .
In case the initial values of the FOD registers are not configured in
the OTP or by the bootloader, it is possible that the FOD registers
will contain zeroes. The code in vc5_fod_recalc_rate() immediately
feeds the FOD divider value obtained from the FOD registers into the
div64_u64() and if the FOD divider value is zero, triggers division
by zero exception.
Check if the FOD divider value is zero and return the frequency of
the FOD output as 0 Hz if it is so. This prevents the division by
zero exception.
Update IDT VersaClock 5 driver to support 5P49V5935. This chip has
two clock inputs (internal XTAL or external CLKIN), four fractional
dividers (FODs) and five clock outputs (four universal clock outputs
Current driver supports up to 2 FODs and up to 3 clock outputs. This
patch sets max number of supported FODs to 4 and max number of supported
clock outputs to 5.
Signed-off-by: Alexey Firago <alexey_firago@mentor.com>
Introduce vc5_chip_info structure to describe features of a particular
VC5 chip (id, number of FODs, number of outputs, flags).
For now flags are only used to indicate if chip has internal XTAL.
vc5_chip_info is set on probe from the matched of_device_id->data.
Also add defines to specify maximum number of FODs and clock outputs
supported by the driver.
With these changes it should be easier to extend driver to support
more VC5 models.
Add driver for IDT VersaClock 5 5P49V5923 and 5P49V5933 chips. These
chips have two clock inputs, XTAL or CLK, which are muxed into single
PLL/VCO input. In case of 5P49V5923, the XTAL in built into the chip
while the 5P49V5923 requires external XTAL.
The PLL feeds two fractional dividers. Each fractional divider feeds
output mux, which allows selecting between clock from the fractional
divider itself or from output mux on output N-1. In case of output
mux 0, the output N-1 is instead connected to the output from the mux
feeding the PLL.
The driver thus far supports only the 5P49V5923 and 5P49V5933, while
it should be easily extensible to the whole 5P49V59xx family of chips
as they are all pretty similar.
Reviewed-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
