suspend/resume
commit e21be0d1d7bd7f78a77613f6bcb6965e72b22fc1 upstream.
Save and restore top PLL related configuration registers for big (APLL)
and LITTLE (KPLL) cores during suspend/resume cycle. So far, CPU clocks
were reset to default values after suspend/resume cycle and performance
after system resume was affected when performance governor has been selected.
Fixes: 773424326b51 ("clk: samsung: exynos5420: add more registers to restore list")
Signed-off-by: Marian Mihailescu <mihailescu2m@gmail.com>
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
[ Upstream commit e9323b664ce29547d996195e8a6129a351c39108 ]
Properly save and restore all top PLL related configuration registers
during suspend/resume cycle. So far driver only handled EPLL and RPLL
clocks, all other were reset to default values after suspend/resume cycle.
This caused for example lower G3D (MALI Panfrost) performance after system
resume, even if performance governor has been selected.
Reported-by: Reported-by: Marian Mihailescu <mihailescu2m@gmail.com>
[ Upstream commit b33228029d842269e17bba591609e83ed422005d ]
Ensure that clocks for core SoC modules (including TZPC0..9 modules)
are enabled for suspend/resume cycle. This fixes suspend/resume
support on Exynos5422-based Odroid XU3/XU4 boards.
Suggested-by: Joonyoung Shim <jy0922.shim@samsung.com>
Signed-off-by: Sylwester Nawrocki <snawrocki@kernel.org>
[ Upstream commit c07c1a0f68d0f2f7ca9aff924e2772526027b019 ]
The TOP "aclk400_mscl" clock should be kept enabled all the time
to allow proper access to power management control for MSC power
domain and devices that are a part of it. This change is required
for the scaler to work properly after domain power on/off sequence.
Fixes: 318fa46cc60d ("clk/samsung: exynos542x: mark some clocks as critical")
Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
[ Upstream commit 318fa46cc60d37fec1e87dbf03a82aca0f5ce695 ]
Some parent clocks of the Exynos542x clock blocks, which have separate
power domains (like DISP, MFC, MSC, GSC, FSYS and G2D) must be always
enabled to access any register related to power management unit or devices
connected to it. For the time being, until a proper solution based on
runtime PM is applied, mark those clocks as critical (instead of ignore
unused or even no flags) to prevent disabling them.
Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Tested-by: Javier Martinez Canillas <javier@osg.samsung.com> [Exynos5800 Peach Pi Chromebook]
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
This patch adds the mux/divider clocks for CMU_CDREX (DRAM Express
Controller) which generates the clocks for DRAM and NoC (Network on Chip)
bus. There is differnet source of MUX_MX_MSPLL_CCORE between exynos5420
and exynos5422, so each MUX_MX_MSPLL_CCORE uses the different parent source
group.
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
The aclk333 clock needs to be ungated during the MFC power domain switch,
so set the clock ID to allow the Exynos power domain logic to lookup this
clock if is defined in the MFC PD device tree node.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Tested-by: Marek Szyprowski <m.szyprowski@samsung.com>
The exynos5420_clk_sleep_init() function and arrays with initialization
data of PLLs can be moved to init section because they are referenced
only from other init-level symbols.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
All of initialization data can be made const.
The samsung_clk_init() cannot return NULL. Either it returns allocated
memory or it panics.
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
This patch adds the clock id for ACLK clock which is source clock
of AMBA AXI bus. This clock should be handled in the bus frequency
scaling driver.
Tested-by: Markus Reichl <m.reichl@fivetechno.de>
Tested-by: Anand Moon <linux.amoon@gmail.com>
This flag is a no-op now. Remove usage of the flag.
Proper source for MFC block is mout_user_aclk333 (in datasheet named
USER_MUX_ACLK_333), not the output of CLKDIV_ACLK_333 MUX.
Fix cpu clock configuration data for Exynos5422/5800 SoCs
(they use higher PCLK_DBG divider values than Exynos5420 and
support additional frequencies).
Based on Hardkernel's kernel for ODROID-XU3 board.
Cc: Thomas Abraham <thomas.ab@samsung.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
cpu clock
With the addition of the new Samsung specific cpu-clock type, the
arm clock can be represented as a cpu-clock type. Add the CPU clock
configuration data and instantiate the CPU clock type for Exynos5420.
Changes by Bartlomiej:
- split Exynos5420 support from the original patches
- moved E5420_[EGL,KFC]_DIV0() macros to clk-exynos5420.c
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
This patch adds clocks, which are required for preserving parent clock
configuration on GSCL power domain on/off.
Clock provider drivers generally shouldn't include clk.h because
it's the consumer API. Only include clk.h in files that are
using it. The clkdev.h header isn't always used either, so remove
it and add in slab.h where files were relying on it to include
slab for them.
Cc: Chanwoo Choi <cw00.choi@samsung.com>
Cc: Sylwester Nawrocki <s.nawrocki@samsung.com>
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Add missing static to local (file-scope only) symbols.
Commit ae43b3289186 ("ARM: 8202/1: dmaengine: pl330: Add runtime Power
Management support v12") added pm support for the pl330 dma driver but
it makes the clock for the Exynos5420 MDMA0 DMA controller to be gated
during suspend and this in turn makes its parent clock aclk266_g2d to
be gated. But the clock needs to be ungated prior suspend to allow the
system to be suspend and resumed correctly.
Add GATE_BUS_TOP register to the list of registers to be restored when
the system enters into a suspend state so aclk266_g2d will be ungated.
Thanks to Abhilash Kesavan for figuring out that this was the issue.
Fixes: ae43b32 ("ARM: 8202/1: dmaengine: pl330: Add runtime Power Management support v12")
Cc: stable@vger.kernel.org # 3.19+
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Tested-by: Kevin Hilman <khilman@linaro.org>
Tested-by: Abhilash Kesavan <a.kesavan@samsung.com>
Acked-by: Tomasz Figa <tomasz.figa@gmail.com>
When a power domain is powered off on Exynos5420 SoC, the input clocks of
the devices attached to this power domain are re-parented to oscclk and
restored to the original parent after powering on the power domain.
So a reference to the input and parent clocks for the devices attached to
a power domain are needed to be able to do the re-parenting. The DISP1 pd
includes modules which uses the following clocks:
ACLK_200_DISP1 (MIXER and HDMILINK)
ACLK_300_DISP1 (FIMD1)
ACLK_400_DISP1 (Internal Buses)
Each of these clocks are generated as the output of a clock mux so add an
ID for all of these clock muxes and their parents to be referenced in the
DISP1 power domain device node.
Acked-by: Michael Turquette <mturquette@linaro.org>
Signed-off-by: Kukjin Kim <kgene@kernel.org>
git://git.linaro.org/people/mike.turquette/linux
Pull clock framework updates from Mike Turquette:
"The clock framework changes for 3.17 are mostly additions of new clock
drivers and fixes/enhancements to existing clock drivers. There are
also some non-critical fixes and improvements to the framework core.
Changes to the clock framework core include:
- improvements to printks on errors
- flattening the previously hierarchal structure of per-clock entries
in debugfs
- allow per-clock debugfs entries that are specific to a particular
clock driver
- configure initial clock parent and/or initial clock rate from
Device Tree
- several feature enhancements to the composite clock type
- misc fixes
New clock drivers added include:
- TI Palmas PMIC
- Allwinner A23 SoC
- Qualcomm APQ8084 and IPQ8064 SoCs
- Rockchip rk3188, rk3066 and rk3288 SoCs
- STMicroelectronics STiH407 SoC
- Cirrus Logic CLPS711X SoC
Many fixes, feature enhancements and further clock tree support for
existing clock drivers also were merged, such as Samsung's "ARMCLK
down" power saving feature for their Exynos4 & Exynos5 SoCs"
* tag 'clk-for-linus-3.17' of git://git.linaro.org/people/mike.turquette/linux: (86 commits)
clk: Add missing of_clk_set_defaults export
clk: checking wrong variable in __set_clk_parents()
clk: Propagate any error return from debug_init()
clk: clps711x: Add DT bindings documentation
clk: Add CLPS711X clk driver
clk: st: Use round to closest divider flag
clk: st: Update frequency tables for fs660c32 and fs432c65
clk: st: STiH407: Support for clockgenA9
clk: st: STiH407: Support for clockgenD0/D2/D3
clk: st: STiH407: Support for clockgenC0
clk: st: Add quadfs reset handling
clk: st: Add polarity bit indication
clk: st: STiH407: Support for clockgenA0
clk: st: STiH407: Support for A9 MUX Clocks
clk: st: STiH407: Support for Flexgen Clocks
clk: st: Adds Flexgen clock binding
clk: st: Remove uncessary (void *) cast
clk: st: use static const for clkgen_pll_data tables
clk: st: use static const for stm_fs tables
clk: st: Update ST clock binding documentation
Register the PLL configuration data for APLL and KPLL on Exynos5420. This
configuration data table specifies PLL coefficients for supported PLL
clock speeds when a 24MHz clock is supplied as the input clock source
for these PLLs.
Cc: Tomasz Figa <t.figa@samsung.com>
Reviewed-by: Amit Daniel Kachhap <amit.daniel@samsung.com>
Tested-by: Arjun K.V <arjun.kv@samsung.com>
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Prior to suspending the system, we need to ensure that certain
clock source and gate registers are unmasked.
while at it, add these clks to save/restore list also.
Signed-off-by: Vikas Sajjan <vikas.sajjan@samsung.com>
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
Array of struct of_device_id may be be const as expected by
of_match_table field and of_find_matching_node_and_match() function.
Reviewed-by: Jingoo Han <jg1.han@samsung.com>
Pull clock driver fixes from Mike Turquette:
"This batch of fixes is for a handful of clock drivers from Allwinner,
Samsung, ST & TI. Most of them are of the "this hardware won't work
without this fix" variety, including patches that fix platforms that
did not boot under certain configurations. Other fixes are the result
of changes to the clock core introduced in 3.15 that had subtle
impacts on the clock drivers.
There are no fixes to the clock framework core in this pull request"
* tag 'clk-fixes-for-linus' of git://git.linaro.org/people/mike.turquette/linux:
clk: spear3xx: Set proper clock parent of uart1/2
clk: spear3xx: Use proper control register offset
clk: qcom: HDMI source sel is 3 not 2
clk: sunxi: fix devm_ioremap_resource error detection code
clk: s2mps11: Fix double free corruption during driver unbind
clk: ti: am43x: Fix boot with CONFIG_SOC_AM33XX disabled
clk: exynos5420: Remove aclk66_peric from the clock tree description
clk/exynos5250: fix bit number for tv sysmmu clock
clk: s3c64xx: Hookup SPI clocks correctly
clk: samsung: exynos4: Remove SRC_MASK_ISP gates
clk: samsung: add more aliases for s3c24xx
clk: samsung: fix several typos to fix boot on s3c2410
clk: ti: set CLK_SET_RATE_NO_REPARENT for ti,mux-clock
clk: ti: dra7: return error code in failure case
clk: ti: apll: not allocating enough data
Adds IDs for MUX clocks to be used by power domain for MFC
for doing re-parenting while pd on/off.
Signed-off-by: Arun Kumar K <arun.kk@samsung.com>
Signed-off-by: Shaik Ameer Basha <shaik.ameer@samsung.com>
Acked-by: Tomasz Figa <t.figa@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Ensure the clock provider is not registered until after all its related
clocks were created and are ready to use. Currently there are races
possible and any (of_)clk_get() call right after a clock provider's
clk_init_cb callback call may fail.
The "aclk66_peric" clock is a gate clock with a whole bunch of gates
underneath it. This big gate isn't very useful to include in our
clock tree. If any of the children need to be turned on then the big
gate will need to be on anyway. ...and there are plenty of other "big
gates" that aren't described in our clock tree, some of which shut off
collections of clocks that have no relationship in the hierarchy so
are hard to model.
"aclk66_peric" is causing earlyprintk problems since it gets disabled
as part of the boot process, so let's just remove it.
Strangely (and for no good reason) this clock is exported as part of
the common clock bindings. Remove it since there are no in-kernel
device trees using it and no reason anyone out of tree should refer to
it either.
Signed-off-by: Doug Anderson <dianders@chromium.org>
Exynos5800 clock structure is mostly similar to 5420 with only
a small delta changes. So the 5420 clock file is re-used for
5800 also. The common clocks for both are seggreagated and few
clocks which are different for both are separately initialized.
Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com>
This patch adds more register offsets to the list for
preserving their values during S2R.
Signed-off-by: Rahul Sharma <rahul.sharma@samsung.com>
This patch adds some missing miscellaneous clocks specific
to exynos5420.
This patch adds the missing MAU block specific clocks.
This patch fixes the wrong register offset for sclk_bpll clock.
Reviewed-by: Alim Akhtar <alim.akhtar@samsung.com>
This patch corrects the wrong parent-child relationship
between sysmmu-mfc clocks.
This patch adds more clocks from FSYS and FSYS2 blocks
and uses GATE_IP_* registers for gating IPs.
This patch adds missing clocks for WCORE block.
This patch fixes some parent-child relationships according
to the latest datasheet and adds more clocks related to
PERIS and GEN blocks.
This patch includes,
1] renaming of the HSI2C clocks
2] renaming of spi clocks according to the datasheet
3] fixes for child-parent relationships
4] adding of more clocks related to PERIC block
5] use GATE_IP_* offsets instead of GATE_BUS_*
This patch corrects some child-parent clock relationships,
and updates the clocks according to the latest datasheet.
This patch adds missing clocks of G2D block. It also removes
the aclkg3d alias from G3D block clocks.
This patch fixes the parent clocks for mscl sysmmu.
This patch adds the missing GSCL and MSCL block clocks
and corrects some wrong parent-child relationships.
This patch adds minimum set of clocks to gate ISP block for
power saving.
This patch renames the mux parent arrays as per the naming
convension followed by the other exynos specific clock drivers.
And it also renames "mout_cpu_kfc" clock to "mout_kfc".
Adds IDs for the clocks needed by the ARM Mali GPU
in exynos5420.
Set it as per the user manual.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
This patch adds gating clock for SSS(Security SubSystem)
module on Exynos5250/5420.
Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
[t.figa: Fixed sort order and group name.]
Samsung CCF helper functions do not provide support to
register multiple Clock Providers for a given SoC. Due to
this limitation, SoC platforms are not able to use these
helpers for registering multiple clock providers and are
forced to bypass this layer.
This layer is modified accordingly to enable the support
for multiple clock providers.
Clock file for exynos4, exynos5250, exynos5420, exynos5440,
S3c64xx, S3c24xx are also modified as per changed helper functions.
[t.figa: Modified s3c2410 clock driver as well]
Since all SoC drivers have been moved to local suspend/resume handling,
the old code can be safely dropped.
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Thomas Abraham <thomas.ab@samsung.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
