Before this commit sunxi_factors_register uses of_iomap(node, 0) to get
the clk registers. The sun6i prcm has factor clocks, for which we want to
use sunxi_factors_register, but of_iomap(node, 0) does not work for the prcm
factor clocks, because the prcm uses the mfd framework, so the registers
are not part of the dt-node, instead they are added to the platform_device,
as platform_device resources.
This commit makes getting the registers the callers duty, so that
sunxi_factors_register can be used with mfd instantiated platform device too.
While at it also add error checking to the of_iomap calls.
This commit also drops the __init function from sunxi_factors_register since
platform driver probe functions are not __init.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Some of the factors-style clocks on the A80 have different widths
for the mux values in the registers.
Add a .muxmask field to clk_factors_config to make it configurable.
Passing a bitmask instead of a width parameter will allow reuse
in case we support table-based muxes in the future.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Until now, the factors clock probing was done directly by sunxi_init_clocks,
with the factors registration being called directly with the clocks data passed
as an argument.
This approch has shown its limits when we added more clocks, since we couldn't
really split code with such a logic in smaller files, and led to a huge file
having all the clocks.
Introduce an intermediate probing function, so that factor clocks will be able
to directly be called by CLK_OF_DECLARE, which will in turn ease the split into
several files.
Acked-by: Hans de Goede <hdegoede@redhat.com>
The PLLs on newer Allwinner SoC's, such as the A31 and A23, have a
N multiplier factor that starts from 1, not 0.
This patch adds an option to the factor clk driver's config data
structures to specify the base value of N.
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
This commit reworks factors clock registration to be done behind a
composite clock. This allows us to additionally add a gate, mux or
divisors, as it will be needed by some future PLLs.
Signed-off-by: Emilio López <emilio@elopez.com.ar>
Acked-by: Mike Turquette <mturquette@linaro.org>
This commit implements the base CPU clocks for sunxi devices. It has
been tested using a slightly modified cpufreq driver from the
linux-sunxi 3.0 tree.
Additionally, document the new bindings introduced by this patch.
Idling:
/ # cat /sys/kernel/debug/clk/clk_summary
clock enable_cnt prepare_cnt rate
osc32k 0 0 32768
osc24M_fixed 0 0 24000000
osc24M 0 0 24000000
apb1_mux 0 0 24000000
apb1 0 0 24000000
pll1 0 0 60000000
cpu 0 0 60000000
axi 0 0 60000000
ahb 0 0 60000000
apb0 0 0 30000000
dummy 0 0 0
After "yes >/dev/null &":
osc32k 0 0 32768
osc24M 0 0 24000000
apb1 0 0 24000000
pll1 0 0 1008000000
cpu 0 0 1008000000
axi 0 0 336000000
ahb 0 0 168000000
apb0 0 0 84000000
dummy 0 0 0
Signed-off-by: Mike Turquette <mturquette@linaro.org>
