path: root/drivers/clk
2011-04-30CLKDEV: Fix clkdev return value for NULL clk caseRussell King
clkdev may incorrectly cause a clkdev entry with a NULL clk to return -ENOENT. This is not the intention of this code; -ENOENT should only be returned if the clock entry can not be found in the table. Fix this. Reported-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-26ARM: 6483/1: arm & sh: factorised duplicated clkdev.cJean-Christop PLAGNIOL-VILLARD
factorise some generic infrastructure to assist looking up struct clks for the ARM & SH architecture. as the code is identical at 99% put the arch specific code for allocation as example in asm/clkdev.h Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
