Allow clk API users to simplify their cleanup paths by providing a
managed version of clk_get() and clk_put().
Cherry-picked from mainline
a8a97db984bdc5e89d42e41891543d2daaf314cb
Change-Id: Ib36c0c82063928937166b6014fca92025bc83878
Reviewed-on: http://git-master/r/102860
Now most of ARM machines has the alsmot same __clk_get/put() macro
So place it at the arch/arm/include/asm/clkdev.h and remove the reduntant header files
But some machines don't have the same form as above. It can use the machince specific clkdev file by HAVE_MACH_CLKDEV config
Now there are only 3 caese.
1) define the clk structure with clkdev macro => Need to move clk structure to proper header file
arch/arm/mach-versatile/include/mach/clkdev.h
arch/arm/mach-realview/include/mach/clkdev.h
arch/arm/mach-vexpress/include/mach/clkdev.h
arch/arm/mach-integrator/include/mach/clkdev.h
2) export the __clk_get/put function at clock.c
arch/arm/mach-shmobile/include/mach/clkdev.h
3) demuxing the clk source
arch/arm/mach-u300/include/mach/clkdev.h
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
clkdev may incorrectly cause a clkdev entry with a NULL clk to return
-ENOENT. This is not the intention of this code; -ENOENT should only
be returned if the clock entry can not be found in the table. Fix
this.
Reported-by: Stephen Boyd <sboyd@codeaurora.org>
factorise some generic infrastructure to assist looking up struct clks
for the ARM & SH architecture.
as the code is identical at 99%
put the arch specific code for allocation as example in asm/clkdev.h
Acked-by: Paul Mundt <lethal@linux-sh.org>
