path: root/drivers/clocksource/h8300_timer8.c
2016-06-28clocksources: Switch back to the clksrc tableDaniel Lezcano
All the clocksource drivers's init function are now converted to return an error code. CLOCKSOURCE_OF_DECLARE is no longer used as well as the clksrc-of table. Let's convert back the names: - CLOCKSOURCE_OF_DECLARE_RET => CLOCKSOURCE_OF_DECLARE - clksrc-of-ret => clksrc-of Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> For exynos_mct and samsung_pwm_timer: Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> For arch/arc: Acked-by: Vineet Gupta <vgupta@synopsys.com> For mediatek driver: Acked-by: Matthias Brugger <matthias.bgg@gmail.com> For the Rockchip-part Acked-by: Heiko Stuebner <heiko@sntech.de> For STi : Acked-by: Patrice Chotard <patrice.chotard@st.com> For the mps2-timer.c and versatile.c changes: Acked-by: Liviu Dudau <Liviu.Dudau@arm.com> For the OXNAS part : Acked-by: Neil Armstrong <narmstrong@baylibre.com> For LPC32xx driver: Acked-by: Sylvain Lemieux <slemieux.tyco@gmail.com> For Broadcom Kona timer change: Acked-by: Ray Jui <ray.jui@broadcom.com> For Sun4i and Sun5i: Acked-by: Chen-Yu Tsai <wens@csie.org> For Meson6: Acked-by: Carlo Caione <carlo@caione.org> For Keystone: Acked-by: Santosh Shilimkar <ssantosh@kernel.org> For NPS: Acked-by: Noam Camus <noamca@mellanox.com> For bcm2835: Acked-by: Eric Anholt <eric@anholt.net>
2016-06-28clocksource/drivers/h8300_timer8: Convert init function to return errorDaniel Lezcano
The init functions do not return any error. They behave as the following: - panic, thus leading to a kernel crash while another timer may work and make the system boot up correctly or - print an error and let the caller unaware if the state of the system Change that by converting the init functions to return an error conforming to the CLOCKSOURCE_OF_RET prototype. Proper error handling (rollback, errno value) will be changed later case by case, thus this change just return back an error or success in the init function. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2015-12-16clocksource/drivers/h8300: Use ioread / iowriteYoshinori Sato
Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2015-12-16clocksource/drivers/h8300: Initializer cleanup.Yoshinori Sato
2015-12-16clocksource/drivers/h8300: Simplify delta handlingYoshinori Sato
2015-12-15h8300: Rename ctlr_out/in[bwl] to raw_read/write[bwl]Daniel Lezcano
For the sake of consistency, let rename all ctrl_out/in calls to the write/read calls so we have the same API consistent with the other architectures hence open the door for the increasing of the test compilation coverage. The unsigned long coercive cast is removed because all variables are set to the right type "void __iomem *". Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2015-12-15clocksource/drivers/h8300_timer8: Retrieve the clock rate at init timeDaniel Lezcano
The current code retrieves the rate value when the timer is enabled which occurs each time a timer is re-armed. Except if the clock frequency has changed magically I don't see why this should be done each time. Retrieve the clock rate value at init time only. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2015-12-15clocksource/drivers/h8300_timer8: Remove irq and lock legacy codeDaniel Lezcano
The time framawork takes care of disabling the interrupts and takes a lock to prevent races. Remove the legacy code in the driver taking care of the races. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2015-12-15clocksource/drivers/h8300_timer8: Remove pointless irq re-entrant safe codeDaniel Lezcano
The current code assumes the interrupt function is re-entrant. That is not correct. An interrupt handler is never invoked concurrently. The interrupt line is masked on all processors. Remove the chewing flags in the code. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2015-12-15clocksource/drivers/h8300_timer8: Fix irq return value checkDaniel Lezcano
The value returned in case of error for the 'irq_of_parse_and_map' function is zero in case of error. Fix the check in the init code. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2015-12-15clocksource/drivers/h8300_timer8: Remove PERIODIC and ONESHOT macroDaniel Lezcano
Specify the delta as parameter for the timer8_clock_event_start function instead of using a macro to tell PERIODIC or ONESHOT. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2015-12-15clocksource/drivers/h8300_timer8: Remove unused macrosDaniel Lezcano
2015-12-15clocksource/drivers/h8300_timer8: Remove unused headersDaniel Lezcano
2015-12-15clocksource/drivers/h8300_timer8: Fix compilation error with dev_warnDaniel Lezcano
The dev_warn is using the platform driver which was removed in the previous patch. Let's replace dev_warn by pr_warn. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2015-12-15clocksource/drivers/h8300: Cleanup startup and remove module code.Yoshinori Sato
Remove some legacy code and replace it by the clksrc-of code. Do some cleanup and code consolidation. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2015-10-15clocksource/drivers/h8300_*: Remove unneeded memset()sAlexey Klimov
Memory for timer16_priv, timer8_priv and tpu_priv structs is allocated by devm_kzalloc() in corresponding probe functions of drivers. No need to zero it one more time. Signed-off-by: Alexey Klimov <alexey.klimov@linaro.org> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2015-08-10clockevents/drivers/h8300_timer8: Migrate to new 'set-state' interfaceViresh Kumar
Migrate h8300_timer8 driver to the new 'set-state' interface provided by clockevents core, the earlier 'set-mode' interface is marked obsolete now. This also enables us to implement callbacks for new states of clockevent devices, for example: ONESHOT_STOPPED. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2015-06-23h8300: fix typo.Yoshinori Sato
2015-06-23h8300: clocksourceYoshinori Sato
h8300_timer8: 8bit clockevent device h8300_timer16 / h8300_tpu: 16bit clocksource Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp>
