path: root/drivers/clocksource/meson6_timer.c
2016-06-28clocksources: Switch back to the clksrc tableDaniel Lezcano
All the clocksource drivers's init function are now converted to return an error code. CLOCKSOURCE_OF_DECLARE is no longer used as well as the clksrc-of table. Let's convert back the names: - CLOCKSOURCE_OF_DECLARE_RET => CLOCKSOURCE_OF_DECLARE - clksrc-of-ret => clksrc-of Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> For exynos_mct and samsung_pwm_timer: Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> For arch/arc: Acked-by: Vineet Gupta <vgupta@synopsys.com> For mediatek driver: Acked-by: Matthias Brugger <matthias.bgg@gmail.com> For the Rockchip-part Acked-by: Heiko Stuebner <heiko@sntech.de> For STi : Acked-by: Patrice Chotard <patrice.chotard@st.com> For the mps2-timer.c and versatile.c changes: Acked-by: Liviu Dudau <Liviu.Dudau@arm.com> For the OXNAS part : Acked-by: Neil Armstrong <narmstrong@baylibre.com> For LPC32xx driver: Acked-by: Sylvain Lemieux <slemieux.tyco@gmail.com> For Broadcom Kona timer change: Acked-by: Ray Jui <ray.jui@broadcom.com> For Sun4i and Sun5i: Acked-by: Chen-Yu Tsai <wens@csie.org> For Meson6: Acked-by: Carlo Caione <carlo@caione.org> For Keystone: Acked-by: Santosh Shilimkar <ssantosh@kernel.org> For NPS: Acked-by: Noam Camus <noamca@mellanox.com> For bcm2835: Acked-by: Eric Anholt <eric@anholt.net>
2016-06-28clocksource/drivers/meson6_timer.c: Convert init function to return errorDaniel Lezcano
The init functions do not return any error. They behave as the following: - panic, thus leading to a kernel crash while another timer may work and make the system boot up correctly or - print an error and let the caller unaware if the state of the system Change that by converting the init functions to return an error conforming to the CLOCKSOURCE_OF_RET prototype. Proper error handling (rollback, errno value) will be changed later case by case, thus this change just return back an error or success in the init function. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2015-08-10clockevents/drivers/meson6: Migrate to new 'set-state' interfaceViresh Kumar
Migrate meson6 driver to the new 'set-state' interface provided by clockevents core, the earlier 'set-mode' interface is marked obsolete now. This also enables us to implement callbacks for new states of clockevent devices, for example: ONESHOT_STOPPED. Cc: Carlo Caione <carlo@caione.org> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Acked-by: Carlo Caione <carlo@caione.org>
2014-09-29ARM: meson6: clocksource: Add Meson6 timer supportCarlo Caione
Meson6 SoCs are equipped with 5 32-bit timers, called TIMER_A, TIMER_B, TIMER_C, TIMER_D and TIMER_E. The driver is providing clocksource support for the 32-bit counter using TIMER_E. Clockevents are also supported using TIMER_A. Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Carlo Caione <carlo@caione.org> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Reviewed-by: Matthias Brugger <matthias.bgg@gmail.com>
