path: root/drivers/clocksource/scx200_hrt.c
2012-02-22clocksource: scx200_hrt: Fix the buildIngo Molnar
This commit: 12d6d41276de: clocksource: scx200_hrt: Convert scx200 to use clocksource_register_hz Breaks the build on x86-32: drivers/clocksource/scx200_hrt.c: In function ‘init_hrt_clocksource’: drivers/clocksource/scx200_hrt.c:95:0: error: unterminated argument list invoking macro "pr_info" drivers/clocksource/scx200_hrt.c:84:2: error: ‘pr_info’ undeclared (first use in this function) It could not possibly have been build tested, because it had this mismerge: pr_info("enabling scx200 high-res timer (%s MHz +%d ppm)\n", printk(KERN_INFO "enabling scx200 high-res timer (%s MHz +%d ppm)\n", mhz27 ? "27":"1", ppm); Cc: Jim Cromie <jim.cromie@gmail.com> Cc: John Stultz <john.stultz@linaro.org> Link: http://lkml.kernel.org/n/tip-jceb26fns5w7tv8edlivhxpa@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-02-01clocksource: scx200_hrt: Convert scx200 to use clocksource_register_hzJohn Stultz
Converts the scx200 clocksource to using clocksource_register_hz. CC: Jim Cromie <jim.cromie@gmail.com> Tested-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2012-02-01clocksource: scx200_hrt: use pr_<level> instead of printkJim Cromie
Switch from printk to using pr_<level>. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> [added commit msg & tweaked subject -jstultz] Signed-off-by: John Stultz <john.stultz@linaro.org>
2009-04-21clocksource: pass clocksource to read() callbackMagnus Damm
Pass clocksource pointer to the read() callback for clocksources. This allows us to share the callback between multiple instances. [hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods] [akpm@linux-foundation.org: cleanup] Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] clocksource: replace is_continuous by a flag fieldThomas Gleixner
Using a flag filed allows to encode more than one information into a variable. Preparatory patch for the generic clocksource verification. [mingo@elte.hu: convert vmitime.c to the new clocksource flag] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-04[PATCH] scx200_hrt: fix precedence bug manifesting as 27x clock in 1 MHz modeJim Cromie
Fix paren-placement / precedence bug breaking initialization for 1 MHz clock mode. Also fix comment spelling error, and fence-post (off-by-one) error on symbol used in request_region. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=7242 Thanks alexander.krause@erazor-zone.de, dzpost@dedekind.net, for the reports and patch test, and phelps@mantara.com for the independent patch and verification. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Cc: <alexander.krause@erazor-zone.de> Cc: <dzpost@dedekind.net> Cc: <phelps@mantara.com> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] GTOD: add scx200 HRT clocksourceJim Cromie
Add a GTOD clocksource driver based on the Geode SCx200's Hi-Res Timer. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
