path: root/drivers/clocksource/timer-nps.c
2016-06-28clocksources: Switch back to the clksrc tableDaniel Lezcano
All the clocksource drivers's init function are now converted to return an error code. CLOCKSOURCE_OF_DECLARE is no longer used as well as the clksrc-of table. Let's convert back the names: - CLOCKSOURCE_OF_DECLARE_RET => CLOCKSOURCE_OF_DECLARE - clksrc-of-ret => clksrc-of Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> For exynos_mct and samsung_pwm_timer: Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> For arch/arc: Acked-by: Vineet Gupta <vgupta@synopsys.com> For mediatek driver: Acked-by: Matthias Brugger <matthias.bgg@gmail.com> For the Rockchip-part Acked-by: Heiko Stuebner <heiko@sntech.de> For STi : Acked-by: Patrice Chotard <patrice.chotard@st.com> For the mps2-timer.c and versatile.c changes: Acked-by: Liviu Dudau <Liviu.Dudau@arm.com> For the OXNAS part : Acked-by: Neil Armstrong <narmstrong@baylibre.com> For LPC32xx driver: Acked-by: Sylvain Lemieux <slemieux.tyco@gmail.com> For Broadcom Kona timer change: Acked-by: Ray Jui <ray.jui@broadcom.com> For Sun4i and Sun5i: Acked-by: Chen-Yu Tsai <wens@csie.org> For Meson6: Acked-by: Carlo Caione <carlo@caione.org> For Keystone: Acked-by: Santosh Shilimkar <ssantosh@kernel.org> For NPS: Acked-by: Noam Camus <noamca@mellanox.com> For bcm2835: Acked-by: Eric Anholt <eric@anholt.net>
2016-06-28clocksource/drivers/nps: Convert init function to return errorDaniel Lezcano
The init functions do not return any error. They behave as the following: - panic, thus leading to a kernel crash while another timer may work and make the system boot up correctly or - print an error and let the caller unaware if the state of the system Change that by converting the init functions to return an error conforming to the CLOCKSOURCE_OF_RET prototype. Proper error handling (rollback, errno value) will be changed later case by case, thus this change just return back an error or success in the init function. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-05-09clocksource: Add NPS400 timers driverNoam Camus
Add internal tick generator which is shared by all cores. Each cluster of cores view it through dedicated address. This is used for SMP system where all CPUs synced by same clock source. Signed-off-by: Noam Camus <noamc@ezchip.com> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Rob Herring <robh+dt@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: John Stultz <john.stultz@linaro.org> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
