when nosmp set, only 1 core enabled. try to access disable core will halt.
dts need added arm,primecell-periphid = <id> for none-boot core
otherwise amba_device_add will halt when read peripheral id.
Signed-off-by: Frank Li <Frank.Li@freescale.com>
Some DT specification will represent CPU nodes with address
cells greater than one, making the current code fail. Using
the proper retrieval helper function ensure the correct hwid
for CPUs is read properly with different address cell size.
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
There are some extra spaces, so just remove them from these lines.
Signed-off-by: Kaixu Xia <xiakaixu@huawei.com>
When founding a component that has orphan connections, we should
validate if it match the newly added device. If it does not match,
only then should the @still_orphan flag should be set.
The tested result as follows.
pre:
/sys/bus/coresight/devices # echo 1 > e3c42000.etb/enable_sink
/sys/bus/coresight/devices # echo 1 > e3c7c000.ptm/enable_source
[ 15.527692] Unable to handle kernel NULL pointer dereference at virtual address 00000124
[ 15.555142] pgd = c2294000
[ 15.564226] [00000124] *pgd=3d393831, *pte=00000000, *ppte=00000000
[ 15.585391] Internal error: Oops: 817 [#1] PREEMPT SMP ARM
[ 15.603807] CPU: 0 PID: 144 Comm: sh Not tainted 3.17.0-rc1-12634-g1222fe0-dirty #3
[ 15.629490] task: ed3803c0 ti: c213a000 task.ti: c213a000
[ 15.647627] PC is at coresight_build_paths+0x1c/0x314
[ 15.664579] LR is at coresight_build_paths+0x6c/0x314
[ 15.681526] pc : [<c02da20c>] lr : [<c02da25c>] psr: 20000013
[ 15.681526] sp : c213be88 ip : c02da800 fp : 00000000
[ 15.720023] r10: 00000002 r9 : ed13250c r8 : 00000001
[ 15.737549] r7 : c213bee8 r6 : ffffffea r5 : 00000000 r4 : 00000124
[ 15.759446] r3 : ed216f24 r2 : 00000001 r1 : c213bee8 r0 : 00000000
[ 15.781346] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
post:
[ 59.934255] coresight-etb10 e3c42000.etb: ETB enabled
[ 59.951317] coresight-replicator replicator0: REPLICATOR enabled
[ 59.971581] coresight-funnel e3c41000.funnel: FUNNEL inport 0 enabled
[ 59.993334] coresight-etm3x e3c7c000.ptm: ETM tracing enabled
A validity check should be made on the remote device, i.e rdev,
rather than the current device.
Outports is a member of the struct pdata and should be
a better choice.
Debugfs isn't used for coresight configuration, so the corresponding
comments should be changed.
The coresight TRM specify that a component's trace ID should
be other than 0.
module_amba_driver() makes the code simpler by eliminating
boilerplate code.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
boilerplate code.
boilerplate code.
boilerplate code.
There are some missing unlocks on the error paths.
Fixes: a939fc5a71ad ('coresight-etm: add CoreSight ETM/PTM driver')
There is no need of .owner field for driver using
module_platform_driver.
Signed-off-by: Pankaj Dubey <pankaj.dubey@samsung.com>
fixes a typo %s/eveyone/everyone/ in function CS_UNLOCK.
This driver manages CoreSight ETM (Embedded Trace Macrocell) that
supports processor tracing. Currently supported version are ARM
ETMv3.x and PTM1.x.
Signed-off-by: Pratik Patel <pratikp@codeaurora.org>
coresight-etm3x: adding missing error checking
This driver manages non-configurable CoreSight Replicator that
takes a single input trace data stream and replicates it to
produce two identical trace data output streams. Replicators
are typically used to route single interleaved trace data
stream to two or more sinks.
This driver manages CoreSight Funnel which acts as a link.
Funnels have multiple input ports (typically 8) each of which
represents an input trace data stream. These multiple input trace
data streams are interleaved into a single output stream coming
out of the Funnel.
This driver manages CoreSight ETB (Embedded Trace Buffer) which
acts as a circular buffer sink collecting generated trace data.
This driver manages CoreSight TPIU (Trace Port Interface Unit)
which acts as a sink. TPIU is typically connected to some offchip
hardware hosting a storage buffer.
This driver manages CoreSight TMC (Trace Memory Controller) which
can act as a link or a sink depending upon its configuration. It
can present itself as an ETF (Embedded Trace FIFO) or ETR
(Embedded Trace Router).
ETF when configured in circular buffer mode acts as a trace
collection sink. When configured in HW fifo mode it acts as link.
ETR always acts as a sink and can be used to route data to memory
allocated in RAM.
CoreSight components are compliant with the ARM CoreSight
architecture specification and can be connected in various
topologies to suit a particular SoC tracing needs. These trace
components can generally be classified as sources, links and
sinks. Trace data produced by one or more sources flows through
the intermediate links connecting the source to the currently
selected sink.
The CoreSight framework provides an interface for the CoreSight trace
drivers to register themselves with. It's intended to build up a
topological view of the CoreSight components and configure the
correct serie of components on user input via sysfs.
For eg., when enabling a source, the framework builds up a path
consisting of all the components connecting the source to the
currently selected sink(s) and enables all of them.
The framework also supports switching between available sinks
and provides status information to user space applications
through the debugfs interface.
