path: root/drivers/cpufreq/Kconfig.arm
2013-05-12cpufreq: ARM big LITTLE: Fix Kconfig entriesViresh Kumar
This fixes usage of "depends on" and "select" options in Kconfig for ARM big LITTLE cpufreq driver. Otherwise we get these warnings: warning: (ARM_DT_BL_CPUFREQ) selects ARM_BIG_LITTLE_CPUFREQ which has unmet direct dependencies (ARCH_HAS_CPUFREQ && CPU_FREQ && ARM && ARM_CPU_TOPOLOGY) Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-05-12cpufreq: ARM big LITTLE: Select PM_OPPViresh Kumar
The ARM big LITTLE cpufreq driver uses the OPP layer for its functionality. Select it in Kconfig. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-24ARM: S5pv210: compiling issue, ARM_S5PV210_CPUFREQ needs CONFIG_CPU_FREQ_TABLE=yChen Gang
For arm S5pv210 with allmodconfig, ARM_S5PV210_CPUFREQ need CONFIG_CPU_FREQ_TABLE=y, or will cause compiling issue. The related operation: + arm-linux-gnu-ld -EL -p --no-undefined -X --build-id -X -o .tmp_vmlinux1 -T /root/linux-next/arch/arm/kernel/vmlinux.lds arch/arm/kernel/head.o init/built-in.o --start-group usr/built-in.o arch/arm/nwfpe/built-in.o arch/arm/vfp/built-in.o arch/arm/kernel/built-in.o arch/arm/mm/built-in.o arch/arm/common/built-in.o arch/arm/net/built-in.o arch/arm/crypto/built-in.o arch/arm/mach-s5pv210/built-in.o arch/arm/plat-samsung/built-in.o kernel/built-in.o mm/built-in.o fs/built-in.o ipc/built-in.o security/built-in.o crypto/built-in.o block/built-in.o arch/arm/lib/lib.a lib/lib.a arch/arm/lib/built-in.o lib/built-in.o drivers/built-in.o sound/built-in.o firmware/built-in.o net/built-in.o --end-group The related errors: drivers/built-in.o: In function `s5pv210_target': drivers/cpufreq/s5pv210-cpufreq.c:225: undefined reference to `cpufreq_frequency_table_target' drivers/cpufreq/s5pv210-cpufreq.c:237: undefined reference to `cpufreq_frequency_table_target' drivers/built-in.o: In function `s5pv210_verify_speed': drivers/cpufreq/s5pv210-cpufreq.c:182: undefined reference to `cpufreq_frequency_table_verify' drivers/built-in.o: In function `s5pv210_cpu_init': drivers/cpufreq/s5pv210-cpufreq.c:556: undefined reference to `cpufreq_frequency_table_get_attr' drivers/cpufreq/s5pv210-cpufreq.c:560: undefined reference to `cpufreq_frequency_table_cpuinfo' make: *** [vmlinux] Error 1 Signed-off-by: Chen Gang <gang.chen@asianux.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-10cpufreq: exynos: Add cpufreq driver for exynos5440Amit Daniel Kachhap
This patch adds dvfs support for exynos5440 SOC. This soc has 4 cores and they scale at same frequency. The nature of exynos5440 clock controller is different from previous exynos controllers so not using the common exynos cpufreq framework. The major difference being interrupt notification for frequency change. Also, OPP library is used for device tree parsing to get different parameters like frequency, voltage etc. Since the opp library sorts the frequency table in ascending order so they are again re-arranged in descending order. This will have one-to-one mapping with the clock controller state management logic. Signed-off-by: Amit Daniel Kachhap <amit.daniel@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-10cpufreq: sa11x0: move cpufreq driver to drivers/cpufreqViresh Kumar
This patch moves cpufreq driver of ARM based sa11x0 platform to drivers/cpufreq. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-08cpufreq: integrator: move cpufreq driver to drivers/cpufreqViresh Kumar
This patch moves cpufreq driver of ARM based integrator platform to drivers/cpufreq. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-08cpufreq: ARM: Arrange drivers in alphabetical orderViresh Kumar
Normally we keep drivers in alphabetical inside Kconfig and Makefile and over time this was broken for ARM cpufreq drivers. Fix it. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-02cpufreq: ARM big LITTLE: Add generic cpufreq driver and its DT glueViresh Kumar
big LITTLE is ARM's new Architecture focussing power/performance needs of modern world. More information about big LITTLE can be found here: http://www.arm.com/products/processors/technologies/biglittleprocessing.php http://lwn.net/Articles/481055/ In order to keep cpufreq support for all big LITTLE platforms simple/generic, this patch tries to add a generic cpufreq driver layer for all big LITTLE platforms. The driver is divided into two parts: - Core driver: Generic and shared across all big LITTLE SoC's - Glue drivers: Per platform drivers providing ops to the core driver This patch adds in a generic glue driver which would extract information from Device Tree. Future SoC's can either reuse the DT glue or write their own depending on the need. Signed-off-by: Sudeep KarkadaNagesha <sudeep.karkadanagesha@arm.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-09cpufreq: kirkwood: Add a cpufreq driver for Marvell Kirkwood SoCsAndrew Lunn
The Marvell Kirkwood SoCs have simple cpufreq support in hardware. The CPU can either use the a high speed cpu clock, or the slower DDR clock. Add a driver to swap between these two clock sources. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-02-09cpufreq: add imx6q-cpufreq driverShawn Guo
Add an imx6q-cpufreq driver for Freescale i.MX6Q SoC to handle the hardware specific frequency and voltage scaling requirements. The driver supports module build and is instantiated by the platform device/driver mechanism, so that it will not be instantiated on other platforms, as IMX is built with multiplatform support. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-02-02cpufreq / highbank: add support for highbank cpufreqMark Langsdorf
Highbank processors depend on the external ECME to perform voltage management based on a requested frequency. Communication between the A9 cores and the ECME happens over the pl320 IPC channel. Signed-off-by: Mark Langsdorf <mark.langsdorf@calxeda.com> Reviewed-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-11drivers/cpufreq: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-27cpufreq: SPEAr: Add CPUFreq driverDeepak Sikri
SPEAr is an ARM based family of SoCs. This patch adds in support of cpufreq driver for SPEAr SoCs. It is supported via DT only and so bindings are present in binding document. Signed-off-by: Deepak Sikri <deepak.sikri@st.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-04-13cpufreq: OMAP: fix build errors: depends on ARCH_OMAP2PLUSKevin Hilman
The OMAP driver needs a 'depends on ARCH_OMAP2PLUS' since it only builds for OMAP2+ platforms. This 'depends on' was in the original patch from Russell King, but was erroneously removed by me when making this option user-selectable in commit b09db45c (cpufreq: OMAP driver depends CPUfreq tables.) This patch remedies that. Apologies to Russell King for breaking his originally working patch. Also, thanks to Grazvydas Ignotas for reporting the same problem. Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-04EXYNOS: fix dependency for EXYNOS_CPUFREQKukjin Kim
This fixes the CPUFREQ dependency for regarding EXYNOS SoCs such as EXYNOS4210, EXYNOS4X12 and EXYNOS5250. Its cpufreq driver should be built with selection of SoC arch part. Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-03-23Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq Pull cpufreq updates for 3.4 from Dave Jones: new drivers and some fixes. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: provide disable_cpufreq() function to disable the API. EXYNOS5250: Add support cpufreq for EXYNOS5250 EXYNOS4X12: Add support cpufreq for EXYNOS4X12 [CPUFREQ] CPUfreq ondemand: update sampling rate without waiting for next sampling [CPUFREQ] Add S3C2416/S3C2450 cpufreq driver [CPUFREQ] Fix exposure of ARM_EXYNOS4210_CPUFREQ [CPUFREQ] EXYNOS4210: update the name of EXYNOS clock register [CPUFREQ] EXYNOS: Initialize locking_frequency with initial frequency [CPUFREQ] s3c64xx: Fix mis-cherry pick of VDDINT Fix up trivial conflicts in Kconfig and Makefile due to just changes next to each other (OMAP2PLUS changes vs some new EXYNOS cpufreq drivers).
2012-03-14EXYNOS5250: Add support cpufreq for EXYNOS5250Jaecheol Lee
This patch adds support cpufreq for EXYNOS5250 SoC. Basically, the exynos-cpufreq.c is used commonly and exynos5250-cpufreq.c is used for EXYNOS5250(two Cortex-A15 cores) SoC. Signed-off-by: Jaecheol Lee <jc.lee@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2012-03-14EXYNOS4X12: Add support cpufreq for EXYNOS4X12Jaecheol Lee
This patch adds support cpufreq for EXYNOS4X12 SoCs. Basically, the exynos-cpufreq.c is used commonly and exynos4x12-cpufreq.c is used for EXYNOS4212(two Cortex-A9 cores) and EXYNOS4412(four Cortex-A9 cores) SoCs. Signed-off-by: Jaecheol Lee <jc.lee@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2012-02-29[CPUFREQ] Add S3C2416/S3C2450 cpufreq driverHeiko Stübner
The S3C2416/S3C2450 SoCs support two sources for the armclk. The first source is the so called armdiv which divides the msysclk down to provide necessary cpu rates. In this mode the core voltage must be always at 1.3V. The frequency from the armdiv is not allowed to be lower than the hclk frequency. In the second mode the armclk can be sourced directly from the hclk in the so called "dynamic voltags scaling" (dvs) mode. Here the armdiv isn't used at all. Also in this mode the core voltage may be lowered. Existing hardware and tests with it suggest 1.0V as sufficient. When changing the clock source to the armdiv from the hclk, the SoC shows stability issues if the new frequency is higher than the current hclk frequency. Hence the driver always forces the armdiv to the hclk frequency before the source change and lets the cpufreq issue another set_target call for higher frequencies. To mark the hclk frequency as lower as the corresponding armdiv frequency it is set 1MHz below the real frequency. This lets the cpufreq framework change between 133MHz based on hclk and 133MHz based on armdiv at will. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Tested-by: Andrey Gusakov <dron0gus@gmail.com> Signed-off-by: Dave Jones <davej@redhat.com>
2012-02-29[CPUFREQ] Fix exposure of ARM_EXYNOS4210_CPUFREQRussell King
exynos4210-cpufreq.c is not buildable on non-exynos builds, so it's pointless allowing this option to be exposed. Fix this by adding a dependency on ARCH_EXYNOS. drivers/cpufreq/exynos4210-cpufreq.c:20:29: error: mach/regs-clock.h: No such file or directory drivers/cpufreq/exynos4210-cpufreq.c:21:26: error: mach/cpufreq.h: No such file or directory Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: cpufreq@vger.kernel.org Cc: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2012-02-21cpufreq: OMAP driver depends CPUfreq tablesRussell King
The OMAP driver depends on CPUfreq table support for creating a table of frequencies from the OPP layer. Ensure that it's build to avoid link-time errors. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> [khilman@ti.com: make user-selectable, but default y] Signed-off-by: Kevin Hilman <khilman@ti.com>
2012-01-08[CPUFREQ] EXYNOS: Make EXYNOS common cpufreq driverJaecheol Lee
To support various EXYNOS series SoCs commonly, added exynos common structure. exynos-cpufreq.c => EXYNOS series common cpufreq driver exynos4210-cpufreq.c => EXYNOS4210 support cpufreq driver Signed-off-by: Jaecheol Lee <jc.lee@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-07-13[CPUFREQ] Move compile for S3C64XX cpufreq to /drivers/cpufreqKukjin Kim
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-07-13[CPUFREQ] Move ARM Samsung cpufreq drivers to drivers/cpufreq/Kukjin Kim
According to discussion of the ARM arch subsystem migration, ARM cpufreq drivers move to drivers/cpufreq. So this patch adds Kconfig.arm for ARM like x86 and adds Samsung S5PV210 and EXYNOS4210 cpufreq driver compile in there. As a note, otherw will be moved. Cc: Dave Jones <davej@redhat.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
