path: root/drivers/cpufreq/Kconfig
2012-09-09cpufreq: Add a generic cpufreq-cpu0 driverShawn Guo
It adds a generic cpufreq driver for CPU0 frequency management based on clk, regulator, OPP and device tree support. It can support both uniprocessor (UP) and those symmetric multiprocessor (SMP) systems which share clock and voltage across all CPUs. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: AnilKumar Ch <anilkumar@ti.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-07-25Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (99 commits) drivers/virt: add missing linux/interrupt.h to fsl_hypervisor.c powerpc/85xx: fix mpic configuration in CAMP mode powerpc: Copy back TIF flags on return from softirq stack powerpc/64: Make server perfmon only built on ppc64 server devices powerpc/pseries: Fix hvc_vio.c build due to recent changes powerpc: Exporting boot_cpuid_phys powerpc: Add CFAR to oops output hvc_console: Add kdb support powerpc/pseries: Fix hvterm_raw_get_chars to accept < 16 chars, fixing xmon powerpc/irq: Quieten irq mapping printks powerpc: Enable lockup and hung task detectors in pseries and ppc64 defeconfigs powerpc: Add mpt2sas driver to pseries and ppc64 defconfig powerpc: Disable IRQs off tracer in ppc64 defconfig powerpc: Sync pseries and ppc64 defconfigs powerpc/pseries/hvconsole: Fix dropped console output hvc_console: Improve tty/console put_chars handling powerpc/kdump: Fix timeout in crash_kexec_wait_realmode powerpc/mm: Fix output of total_ram. powerpc/cpufreq: Add cpufreq driver for Momentum Maple boards powerpc: Correct annotations of pmu registration functions ... Fix up trivial Kconfig/Makefile conflicts in arch/powerpc, drivers, and drivers/cpufreq
2011-07-19powerpc/cpufreq: Add cpufreq driver for Momentum Maple boardsDmitry Eremin-Solenikov
Add simple cpufreq driver for Maple-based boards (ppc970fx evaluation kit and others). Driver is based on a cpufreq driver for 64-bit powermac boxes with all pmac-dependant features removed and simple cleanup applied. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-07-13[CPUFREQ] Move ARM Samsung cpufreq drivers to drivers/cpufreq/Kukjin Kim
According to discussion of the ARM arch subsystem migration, ARM cpufreq drivers move to drivers/cpufreq. So this patch adds Kconfig.arm for ARM like x86 and adds Samsung S5PV210 and EXYNOS4210 cpufreq driver compile in there. As a note, otherw will be moved. Cc: Dave Jones <davej@redhat.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-05-19[CPUFREQ] Move x86 drivers to drivers/cpufreq/Dave Jones
2011-05-04[CPUFREQ] use dynamic debug instead of custom infrastructureDominik Brodowski
With dynamic debug having gained the capability to report debug messages also during the boot process, it offers a far superior interface for debug messages than the custom cpufreq infrastructure. As a first step, remove the old cpufreq_debug_printk() function and replace it with a call to the generic pr_debug() function. How can dynamic debug be used on cpufreq? You need a kernel which has CONFIG_DYNAMIC_DEBUG enabled. To enabled debugging during runtime, mount debugfs and $ echo -n 'module cpufreq +p' > /sys/kernel/debug/dynamic_debug/control for debugging the complete "cpufreq" module. To achieve the same goal during boot, append ddebug_query="module cpufreq +p" as a boot parameter to the kernel of your choice. For more detailled instructions, please see Documentation/dynamic-debug-howto.txt Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Dave Jones <davej@redhat.com>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06trivial: fix an -> a typos in documentation and commentsFrederik Schwarzer
It is always "an" if there is a vowel _spoken_ (not written). So it is: "an hour" (spoken vowel) but "a uniform" (spoken 'j') Signed-off-by: Frederik Schwarzer <schwarzerf@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-04-28[CPUFREQ] allow use of the powersave governor as the default oneAlessandro Guido
Allow use of the powersave cpufreq governor as the default one for EMBEDDED configs. Signed-off-by: Alessandro Guido <alessandro.guido@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Jones <davej@redhat.com>
2008-02-06[CPUFREQ] fix configuration help messageStefano Brivio
cpufreq support can't be built as a module. Fix the related configuration help message. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: Dave Jones <davej@redhat.com>
2007-10-04[CPUFREQ] allow ondemand and conservative cpufreq governors to be used as ↵Thomas Renninger
default Depending on the transition latency of the HW for cpufreq switches, the ondemand or conservative governor cannot be used with certain cpufreq drivers. Still the ondemand should be the default governor on a wide range of systems. This patch allows this and lets the governor fallback to the performance governor at cpufreq driver load time, if the driver does not support fast enough frequency switching. Main benefit is that on e.g. installation or other systems without userspace support a working dynamic cpufreq support can be achieved on most systems by simply loading the cpufreq driver. This is especially essential for recent x86(_64) laptop hardware which may rely on working dynamic cpufreq OS support. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Jones <davej@redhat.com>
2007-04-26[CPUFREQ] cleanup kconfig optionsMike Frysinger
Adds proper lines to help output of kconfig so people can find the module names. Also fixed some broken leading spaces versus tabs. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-10[CPUFREQ] CPU_FREQ_TABLE shouldn't be a def_tristateAdrian Bunk
CPU_FREQ_TABLE enables helper code and gets select'ed when it's required. Building it as a module when it's not required doesn't seem to make much sense. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Jones <davej@redhat.com>
2006-11-21[PATCH] Fix CPU_FREQ_GOV_ONDEMAND=y compile errorDave Jones
The ONDEMAND governor needs FREQ_TABLE Signed-off-by: Mattia Dongili <malattia@linux.it> Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-03[CPUFREQ] Update LART site URLErik Mouw
Update LART site URL. The LART website moved to http://www.lartmaker.nl/. This patch updates the URL in CpuFreq specific files. Signed-off-by: Erik Mouw <erik@bitwizard.nl> Signed-off-by: Dave Jones <davej@redhat.com>
2005-05-31[CPUFREQ] Conservative cpufreq governerDave Jones
A new cpufreq module, based on the ondemand one with my additional patches just posted. This one is more suitable for battery environments where its probably more appealing to have the cpu freq gracefully increase and decrease rather than flip between the min and max freq's. N.B. Bruno Ducrot pointed out that the amd64's "do have unacceptable latency between min and max freq transition, due to the step-by-step requirements (200MHz IIRC)"; so AMD64 users would probably benefit from this too. Signed-off-by: Alexander Clouter <alex-kernel@digriz.org.uk> Signed-off-by: Dave Jones <davej@redhat.com>
2005-05-31[CPUFREQ] Add warning comment about default governors.Dave Jones
This comes up time and time again. Until its fixed, place this comment in the Kconfig which should stem the flow of resubmissions. Signed-off-by: Rob Weryk <rjweryk@uwo.ca> Signed-off-by: Dave Jones <davej@redhat.com>
