A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
If cpufreq_generic_init() fails we jump into the resource
cleanup path which contains a of_node_put() call. Another
instance of this has already been called at that time
resulting a double decrement of the refcount.
Fix this by calling of_node_put() only after we are sure
that nothing has gone wrong.
Fixes: d2f31f1da54f "cpufreq: cpu0: Move per-cluster initialization code to ->init()"
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
The naming convention of this driver was always under the scanner, people
complained that it should have a more generic name than cpu0, as it manages all
CPUs that are sharing clock lines.
Also, in future it will be modified to support any number of clusters with
separate clock/voltage lines.
Lets rename it to 'cpufreq_dt' from 'cpufreq_cpu0'.
Tested-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
