Change our locking strategy to be the same as the conservative
and ondemand governor for GOV_START and GOV_STOP to allow
for correct handling of multiple CPUs
Bug 1049258
Change-Id: I15ab620e2f9d47b00ec8186c224eb719b9735aa7
Signed-off-by: Matt Wagner <mwagner@nvidia.com>
Reviewed-on: http://git-master/r/133360
Reviewed-by: Satya Popuri <spopuri@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Sends kobject_uevent signal back to userspace to signal that
the cpufreq governor has been set to interactive
Bug 1039141
Change-Id: I699e9d5834a1874b36c675764c080112ccba0f9f
Reviewed-on: http://git-master/r/131224
CPU clock is now capped at an normal frequency that is below
its maximum and allowed to run at a high frequency
only once within a period of time. By default the delay is set to
5*DOWN_DELAY, allowing a maximum of 20% high frequency time.
Sysfs knobs were also added that allows userspace tuning
Bug 1003531
Change-Id: Ie4a0e565630187bdacd6f31b1f35778eb31bfc81
Signed-off-by: Xiao Bo Zhao <xiaoboz@nvidia.com>
Reviewed-on: http://git-master/r/118163
Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com>
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
GVS: Gerrit_Virtual_Submit
Cosmetics: introducing a macro to define unsigned long sysfs nodes.
Change-Id: I594a527dc977437405167237e8d5ac6d3a3167d2
Signed-off-by: Ilan Aelion <iaelion@nvidia.com>
Reviewed-on: http://git-master/r/113020
Reviewed-by: Matthew Longnecker <mlongnecker@nvidia.com>
Restrict go_maxspeed_load and max_boost at mid-range frequencies.
Change-Id: I9e3c59bbe708b428e12ce4dbef2144be09751d5a
Signed-off-by: satya popuri <spopuri@nvidia.com>
Reviewed-on: http://git-master/r/111754
Reviewed-by: Karthikeyan Samynathan <ksamynathan@nvidia.com>
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Tune *timer_rate* used to increase cpu frequency.
bug 980120
Signed-off-by: Shridhar Rasal <srasal@nvidia.com>
Reviewed-on: http://git-master/r/96525
(cherry picked from commit f8bcc67d13d72deb7b506b4a1cad581f3caf45dd)
Change-Id: Iacc2e3f030c225a4aadbfc4611fe9e64d9181fa0
Reviewed-on: http://git-master/r/99989
Reviewed-by: Shridhar Rasal <srasal@nvidia.com>
Tested-by: Shridhar Rasal <srasal@nvidia.com>
GVS: Gerrit_Virtual_Submit <kchilds@nvidia.com>
To get better performance setting it to 85% from 95%
bug 941275
Change-Id: I08bc711ea159d070cf6b62ce25506c8a5bdd7ac4
Reviewed-on: http://git-master/r/91159
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
set determined target freq always
bug 941275
Change-Id: If72936ed145867abd32b43c5c5100290df2fc187
Reviewed-on: http://git-master/r/91010
The new sysfs node io_is_busy enables the interactive governor to
account any time spent by the CPU waiting for IO as non-idle time.
This helps us improve run-time of IO bound tasks by making up for
lost IO time in speeding up the CPU bound parts of the task.
Reviewed on http://git-master/r/#change,86894
cherry picked from 13a15aadc1134b5dae05cdcf9687396644f87411
Change-Id: I4a14ed7fef5fbce00054bb02d52d2d3e0f011f70
Reviewed-on: http://git-master/r/89218
Tested-by: Satya Popuri <spopuri@nvidia.com>
We prefer a min_sample_time of 30ms. This is tied to our cluster switch
and auto-hotplug artificial delays.
original commit message:
cpufreq: reduce min_sample_time
Reduce the minimum amount of time the interactive governor spends at a
frequency before ramping down. This parameter (min_sample_time) was 80ms
now reduced to 30 ms based on perf and power sweep numbers.
Reviewed-on: http://git-master/r/86900 (cherry picked from commit
581f20a5b7b8c3e4ee2c211b28dbc81510af2ae7).
Change-Id: I24f4cd52737950fd4e78a36b4ee34a84551e0e12
Reviewed-on: http://git-master/r/89217
Change our added attributes' store functions to Google style
Change-Id: I5dc641112085698918e87b52378fe3a5bfe44360
Signed-off-by: Peter Boonstoppel <pboonstoppel@nvidia.com>
Reviewed-on: http://git-master/r/84452
Reduce permissions on the max_boost and go_maxspeed_load, the init
scripts will change their owner so the current users continue to work.
Bug 906796
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/79096
(cherry picked from commit f1d91095baff48e58a04af0062f579f394094b47)
Change-Id: Id9542a202bcf02f886cfee9c0bbe69cc83b8c200
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/82726
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
max_boost and go_maxspeed_load need to be writable for service that
controls balanced power mode
Cherry-picked from: http://git-master/r/#change,57965
Change-Id: I0e3a39ddf317a0f7ba3bb4908afc8a100db1b883
Signed-off-by: Daniel Solomon <daniels@nvidia.com>
Reviewed-on: http://git-master/r/65602
Reviewed-by: Simone Willett <swillett@nvidia.com>
Attribute store functions used to return 0 upon success, but should
return count instead.
Change-Id: I2ab15e536d9affbf80bbcb2e557c6d217d5a9dfa
Reviewed-on: http://git-master/r/68554
Tested-by: Daniel Solomon <daniels@nvidia.com>
Allows you to specify a max increase in frequency, disabled by default.
Cherry-pick from: http://git-master/r/#change,57928
Change-Id: I8174e31faceaa7c27adfe52515e951a4092a39f3
Reviewed-on: http://git-master/r/65601
When governor starts initialize time_in_idle and idle_exit_time
variables with current data, and restart timer. This is required
to properly start governor on busy CPU that would not enter idle
state for a long time.
(cherry picked from commit 876dc6eddc68054e6abe23f6287cfbf5302a75b9)
(cherry picked from commit d0024f3ad1e4c6d4885355df3fda02435ccc471d)
Change-Id: I992ca9193cb95e64cc9ef8bfb86675b32ad6d43d
Reviewed-on: http://git-master/r/61712
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: Ra79d9a3ca97b0cfd49fb642ba7cafb98c11c04f1
Updated target frequency calculation algorithm to take into account
current rate CPU is running at:
- When CPU is running below go_maxspeed_load threshold, adjust the
target frequency based on current rate to reach tunable sustainable
load (instead of applying cpu load to max possible cpu rate).
Tuned by setting new node ("0" falls back to using max_rate):
/sys/devices/system/cpu/cpufreq/interactive/sustain_load
- When CPU is running at/above go_maxspeed_load threshold, ramp the
target frequency starting from current exponentially with tunable base
(instead of immediate jump to maximum cpu rate).
Tuned by setting new node ("0" falls back to jump to max_rate):
/sys/devices/system/cpu/cpufreq/interactive/boost_factor
Defaults for the new tunning parameters are set to "0" - so no changes
in governor default behavior.
Original-Change-Id: Ie845d747239ba177e6f06b73965c3213649f8135
Reviewed-on: http://git-master/r/34583
Tested-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Chih-Lung Huang <lhuang@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Narendra Damahe <ndamahe@nvidia.com>
Rebase-Id: Re898a7b96d3c1b7343e773aab9788e4ff2b1d7f8
This reverts commit 6f312490bcf93bf51ad4ba8d4965a952f521cb7d.
Rebase-Id: Rf54be39acd2c92decd9e5c4522d2b2e47589d84e
This reverts commit 460145c8b1d2ff8a2488baa10d7421e1d8179b7d.
Rebase-Id: Racc6c054ac5c67c38dec7281c7190c6650bfb8bd
This reverts commit d7e7e4f15c62464dfa5d2c58d73bc66f131795bc.
Rebase-Id: R4a8c8c91c64c2c1d64ecb22dfe8a7c2cd133fd39
This reverts commit 4714e5222b5a9b11030eda6df7b8159034be0008.
Rebase-Id: Rc7c804305f9c37c4b93d5d7eecce0b9b93499e27
Change-Id: Ie9952f07b38667f2932474090044195c57976faa
Signed-off-by: Todd Poynor <toddpoynor@google.com>
* Add attribute hispeed_freq, which defaults to max.
* Rename go_maxspeed_load to go_hispeed_load.
* If hit go_hispeed_load and at min speed, go to hispeed_freq;
if hit go_hispeed_load and already above min speed go to max
speed.
Change-Id: I1050dec5f013fc1177387352ba787a7e1c68703e
Change-Id: Ieffb2aa56b5290036285c948718be7be0d3af9e8
Calculate intermediate speed by applyng CPU load to current speed, not
max speed.
Change-Id: Idecf598b9a203b07c989c5d9e9c6efc67a1afc2e
Lower the default time at which a higher speed is allowed to run
before lowering based on lower CPU load from 80ms to 20ms. Most
Android devices should trade power for performance here,
although tablets and non-battery-powered devices may want to
override this default.
Change-Id: I1a4f7faeca12793c51d5b92db30a63cca8d4f1be
Modify default timer from 30ms to 10ms, sampling 2 jiffies after
idle exit on ARM as in Honeycomb.
Modify default go_maxspeed_load from 85% loaded to 95% loaded, for
use in phones where power savings is more important (tablets may be
best served overriding this).
Change-Id: I3361a6279979bfae1df5262666a2e30ea7a44328
The following dump was seen sometimes while resuming,
the only division by zero on this function can happen after
delta_time is reassigned, since at the start of the
function, there is jump that protects against values
less than 1000.
After that, If delta_time and delta_idle == 0,
we will hit a div 0
Division by zero in kernel.
Backtrace:
[<c0057184>] (dump_backtrace+0x0/0x110) from [<c05d5ecc>] (dump_stack+0x18/0x1c)
r6:010f3000 r5:c113dfb0 r4:c004afb0 r3:c6ff0000
[<c05d5eb4>] (dump_stack+0x0/0x1c) from [<c00572cc>] (__div0+0x1c/0x20)
[<c00572b0>] (__div0+0x0/0x20) from [<c02195d4>] (Ldiv0+0x8/0x10)
[<c03dfd64>] (cpufreq_interactive_timer+0x0/0x2c0) from [<c00a7efc>] (run_timer_softirq+0x154/0x260)
[<c00a7da8>] (run_timer_softirq+0x0/0x260) from [<c00a0c8c>] (__do_softirq+0xc8/0x194)
[<c00a0bc4>] (__do_softirq+0x0/0x194) from [<c00a1008>] (irq_exit+0xb4/0xb8)
[<c00a0f54>] (irq_exit+0x0/0xb8) from [<c00584b4>] (ipi_timer+0x44/0x48)
r4:c004a040 r3:00000001
[<c0058470>] (ipi_timer+0x0/0x48) from [<c004c3e4>] (do_local_timer+0x68/0x84)
r5:c004ae2c r4:c07991e8
[<c004c37c>] (do_local_timer+0x0/0x84) from [<c0052948>] (__irq_svc+0x48/0xe0)
Change-Id: I639882db67b8d711c5710778ebc212f0f6a998e3
Acked-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Axel Haslam <axelhaslam@ti.com>
The interactive governor relies on quirks of the Tegra 2 cpufreq
implementation for handling SMP systems where the CPUs do not have
separate rate controls. It needs to determine the maximum rate
for all CPUs covered by the policy and set that speed.
Change-Id: I1ed9fa171e5a9c45a1fa5944e3fa823eb157e81f
Fix up checkpatch warning introduced by long lines in timer_rate
patch.
Change-Id: I22b105dafb1b49390799bb7577464da03f0f8afb
Signed-off-by: Allen Martin <amartin@nvidia.com>
Cleanup some style warnings reported by checkpatch
Change-Id: Ie2e6903d52867fb3347e009d7efa3bc4ca755cea
Add a new sysfs control that tunes the rate of the timer used to
Change-Id: I1aa13ae54bb43aff5b3688984d2955f56aae1658
This adds better error checking on tunable parameters on sysfs
interfaces. Also fixes return value from these functions, previously
on success they would return 0 which would cause a infinite loop.
Change-Id: Ic05038492166f8673d007202092471f98a2f0dfa
Convert interactive governor to use idle notifier instead of
hooking pm_idle directly.
Change-Id: I47e007f330468ac559240a0ae8a3cb06a89ccb67
Remove debug trace code in preparation of upstreaming
Change-Id: I0905885e75031f5e9d7cb06878fb68c1fd06d4fe
Change-Id: Id5267f04067bf023f6b140b4de2e88ef7287e941
Don't reference the saved copy of the CPU's cpufreq policy
pointer after the governor has been stopped for the CPU.
When the governor is stopped for a CPU:
* Use del_timer_sync() to wait for a currently-running timer
function to stop.
* Delete the timer when the governor is stopped for the
associated CPU, not when the last CPU is stopped.
* Flush any speed down work ongoing.
* Reset the timestamp that is used to tell if the timer function
has had a chance to run since last idle exit.
Check the governor enabled flag for the CPU before re-arming the
timer from within the timer function and at idle exit (in case
stopping the governor at runtime).
Check the governor enabled flag for the CPU in the worker
function and thread before using the policy pointer. (There is
still a tiny window in the thread that needs more work to close.)
Change-Id: Ifaddf7a495a8dae15a579a57bdc654f7c47f6ada
Need to use irqsave/restore spin locking for cpumasks since these
are accessed in timers and in thread context.
Change-Id: I4a53eaf0ced7e73b445feddba90ec11482de9126
This governor is designed for latency-sensitive workloads, such as
interactive user interfaces. The interactive governor aims to be
significantly more responsive to ramp CPU quickly up when CPU-intensive
activity begins.
Existing governors sample CPU load at a particular rate, typically
every X ms. This can lead to under-powering UI threads for the period of
time during which the user begins interacting with a previously-idle system
until the next sample period happens.
The 'interactive' governor uses a different approach. Instead of sampling
the CPU at a specified rate, the governor will check whether to scale the
CPU frequency up soon after coming out of idle. When the CPU comes out of
idle, a timer is configured to fire within 1-2 ticks. If the CPU is very
busy from exiting idle to when the timer fires then we assume the CPU is
underpowered and ramp to MAX speed.
If the CPU was not sufficiently busy to immediately ramp to MAX speed, then
the governor evaluates the CPU load since the last speed adjustment,
choosing the highest value between that longer-term load or the short-term
load since idle exit to determine the CPU speed to ramp to.
A realtime thread is used for scaling up, giving the remaining tasks the
CPU performance benefit, unlike existing governors which are more likely to
schedule rampup work to occur after your performance starved tasks have
completed.
The tuneables for this governor are:
/sys/devices/system/cpu/cpufreq/interactive/min_sample_time:
The minimum amount of time to spend at the current frequency before
ramping down. This is to ensure that the governor has seen enough
historic CPU load data to determine the appropriate workload.
Default is 80000 uS.
/sys/devices/system/cpu/cpufreq/interactive/go_maxspeed_load
The CPU load at which to ramp to max speed. Default is 85.
Change-Id: Ib2b362607c62f7c56d35f44a9ef3280f98c17585
Signed-off-by: Mike Chan <mike@android.com>
Bug: 3152864
