Currently Exynos cpufreq drivers rely on globally mapped
clock controller registers to configure frequency of CPU
cores. This is obviously wrong and will be removed in near
future, but to enable support for multi-platform builds
without introducing a regression it needs to be worked
around.
This patch hacks the code to look for clock controller node
in device tree and map its registers using of_iomap(),
instead of relying on global mapping, so dependencies on
platform headers are removed and the driver can compile
again with multiplatform support.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Currently cpufreq frequency table has two fields: frequency and driver_data.
driver_data is only for drivers' internal use and cpufreq core shouldn't use
it at all. But with the introduction of BOOST frequencies, this assumption
was broken and we started using it as a flag instead.
There are two problems due to this:
- It is against the description of this field, as driver's data is used by
the core now.
- if drivers fill it with -3 for any frequency, then those frequencies are
never considered by cpufreq core as it is exactly same as value of
CPUFREQ_BOOST_FREQ, i.e. ~2.
The best way to get this fixed is by creating another field flags which
will be used for such flags. This patch does that. Along with that various
drivers need modifications due to the change of struct cpufreq_frequency_table.
Reviewed-by: Gautham R Shenoy <ego@linux.vnet.ibm.com>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Pull ACPI and power management updates from Rafael Wysocki:
"As far as the number of commits goes, the top spot belongs to ACPI
this time with cpufreq in the second position and a handful of PM
core, PNP and cpuidle updates. They are fixes and cleanups mostly, as
usual, with a couple of new features in the mix.
The most visible change is probably that we will create struct
acpi_device objects (visible in sysfs) for all devices represented in
the ACPI tables regardless of their status and there will be a new
sysfs attribute under those objects allowing user space to check that
status via _STA.
Consequently, ACPI device eject or generally hot-removal will not
delete those objects, unless the table containing the corresponding
namespace nodes is unloaded, which is extremely rare. Also ACPI
container hotplug will be handled quite a bit differently and cpufreq
will support CPU boost ("turbo") generically and not only in the
acpi-cpufreq driver.
Specifics:
- ACPI core changes to make it create a struct acpi_device object for
every device represented in the ACPI tables during all namespace
scans regardless of the current status of that device. In
accordance with this, ACPI hotplug operations will not delete those
objects, unless the underlying ACPI tables go away.
- On top of the above, new sysfs attribute for ACPI device objects
allowing user space to check device status by triggering the
execution of _STA for its ACPI object. From Srinivas Pandruvada.
- ACPI core hotplug changes reducing code duplication, integrating
the PCI root hotplug with the core and reworking container hotplug.
- ACPI core simplifications making it use ACPI_COMPANION() in the
code "glueing" ACPI device objects to "physical" devices.
- ACPICA update to upstream version 20131218. This adds support for
the DBG2 and PCCT tables to ACPICA, fixes some bugs and improves
debug facilities. From Bob Moore, Lv Zheng and Betty Dall.
- Init code change to carry out the early ACPI initialization
earlier. That should allow us to use ACPI during the timekeeping
initialization and possibly to simplify the EFI initialization too.
From Chun-Yi Lee.
- Clenups of the inclusions of ACPI headers in many places all over
from Lv Zheng and Rashika Kheria (work in progress).
- New helper for ACPI _DSM execution and rework of the code in
drivers that uses _DSM to execute it via the new helper. From
Jiang Liu.
- New Win8 OSI blacklist entries from Takashi Iwai.
- Assorted ACPI fixes and cleanups from Al Stone, Emil Goode, Hanjun
Guo, Lan Tianyu, Masanari Iida, Oliver Neukum, Prarit Bhargava,
Rashika Kheria, Tang Chen, Zhang Rui.
- intel_pstate driver updates, including proper Baytrail support,
from Dirk Brandewie and intel_pstate documentation from Ramkumar
Ramachandra.
- Generic CPU boost ("turbo") support for cpufreq from Lukasz
Majewski.
- powernow-k6 cpufreq driver fixes from Mikulas Patocka.
- cpufreq core fixes and cleanups from Viresh Kumar, Jane Li, Mark
Brown.
- Assorted cpufreq drivers fixes and cleanups from Anson Huang, John
Tobias, Paul Bolle, Paul Walmsley, Sachin Kamat, Shawn Guo, Viresh
Kumar.
- cpuidle cleanups from Bartlomiej Zolnierkiewicz.
- Support for hibernation APM events from Bin Shi.
- Hibernation fix to avoid bringing up nonboot CPUs with ACPI EC
disabled during thaw transitions from Bjørn Mork.
- PM core fixes and cleanups from Ben Dooks, Leonardo Potenza, Ulf
Hansson.
- PNP subsystem fixes and cleanups from Dmitry Torokhov, Levente
Kurusa, Rashika Kheria.
- New tool for profiling system suspend from Todd E Brandt and a
cpupower tool cleanup from One Thousand Gnomes"
* tag 'pm+acpi-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (153 commits)
thermal: exynos: boost: Automatic enable/disable of BOOST feature (at Exynos4412)
cpufreq: exynos4x12: Change L0 driver data to CPUFREQ_BOOST_FREQ
Documentation: cpufreq / boost: Update BOOST documentation
cpufreq: exynos: Extend Exynos cpufreq driver to support boost
cpufreq / boost: Kconfig: Support for software-managed BOOST
acpi-cpufreq: Adjust the code to use the common boost attribute
cpufreq: Add boost frequency support in core
intel_pstate: Add trace point to report internal state.
cpufreq: introduce cpufreq_generic_get() routine
ARM: SA1100: Create dummy clk_get_rate() to avoid build failures
cpufreq: stats: create sysfs entries when cpufreq_stats is a module
cpufreq: stats: free table and remove sysfs entry in a single routine
cpufreq: stats: remove hotplug notifiers
cpufreq: stats: handle cpufreq_unregister_driver() and suspend/resume properly
cpufreq: speedstep: remove unused speedstep_get_state
platform: introduce OF style 'modalias' support for platform bus
PM / tools: new tool for suspend/resume performance optimization
ACPI: fix module autoloading for ACPI enumerated devices
ACPI: add module autoloading support for ACPI enumerated devices
ACPI: fix create_modalias() return value handling
Use common clock framework (CCF) APIs to set the clock rates
instead of direct register manipulation. This now updates the
sysfs entry (cpuinfo_cur_freq) correctly which did not reflect
the correct value until now. While at it clean up the PLL s-div
parameter setting as it is handled by the PLL driver.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup
From Kukjin Kim:
Samsung cleanup 2nd for v3.14
- remove <mach/regs-clock.h> for exynos
- remove <mach/regs-irq.h> for exynos
- local <mach/regs-pmu.h> into mach-exynos
- select PM_GENERIC_DOMAINS for ARCH_EXYNOS4
instead of each SOC_EXYNOS4XXX in Kconfig
- call pm_genpd_poweroff_unused() instead of via
exynos_pm_late_initcall() because no need to
handle whether CONFIG_PM_GENERIC_DOMAINS is enalbed
* tag 'samsung-cleanup-2' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
ARM: EXYNOS: Kill exynos_pm_late_initcall()
ARM: EXYNOS: Consolidate selection of PM_GENERIC_DOMAINS for Exynos4
PM / devfreq: use inclusion <mach/map.h> instead of <plat/map-s5p.h>
ARM: EXYNOS: remove <mach/regs-clock.h> for exynos
ARM: EXYNOS: local definitions for cpuidle.c into mach-exynos dir
cpufreq: exynos: move definitions for exynos-cpufreq into drivers/cpufreq/
ARM: EXYNOS: local definitions for pm.c into mach-exynos dir
PM / devfreq: move definitions for exynos4_bus into drivers/devfreq
ARM: EXYNOS: cleanup <mach/regs-clock.h>
ARM: EXYNOS: cleanup <mach/regs-irq.h>
ARM: EXYNOS: local regs-pmu.h header file
ARM: EXYNOS: remove inclusion <mach/regs-pmu.h> into another headers
ARM: EXYNOS: cleanup <mach/regs-pmu.h>
This moves regarding exynos-cpufreq definitions into drivers/cpufreq/
exynos-cpufreq.h because they are used only for the cpufreq driver.
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
The init functions are linked statically (no support for
dynamic loading) and have no other users. Hence remove
EXPORT_SYMBOL for these functions.
Pull ARM SoC cleanups from Arnd Bergmann:
"A large number of cleanups, all over the platforms. This is dominated
largely by the Samsung platforms (s3c, s5p, exynos) and a few of the
others moving code out of arch/arm into more appropriate subsystems.
The clocksource and irqchip drivers are now abstracted to the point
where platforms that are already cleaned up do not need to even
specify the driver they use, it can all get configured from the device
tree as we do for normal device drivers. The clocksource changes
basically touch every single platform in the process.
We further clean up the use of platform specific header files here,
with the goal of turning more of the platforms over to being
"multiplatform" enabled, which implies that they cannot expose their
headers to architecture independent code any more.
It is expected that no functional changes are part of the cleanup.
The overall reduction in total code lines is mostly the result of
removing broken and obsolete code."
* tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (133 commits)
ARM: mvebu: correct gated clock documentation
ARM: kirkwood: add missing include for nsa310
ARM: exynos: move exynos4210-combiner to drivers/irqchip
mfd: db8500-prcmu: update resource passing
drivers/db8500-cpufreq: delete dangling include
ARM: at91: remove NEOCORE 926 board
sunxi: Cleanup the reset code and add meaningful registers defines
ARM: S3C24XX: header mach/regs-mem.h local
ARM: S3C24XX: header mach/regs-power.h local
ARM: S3C24XX: header mach/regs-s3c2412-mem.h local
ARM: S3C24XX: Remove plat-s3c24xx directory in arch/arm/
ARM: S3C24XX: transform s3c2443 subirqs into new structure
ARM: S3C24XX: modify s3c2443 irq init to initialize all irqs
ARM: S3C24XX: move s3c2443 irq code to irq.c
ARM: S3C24XX: transform s3c2416 irqs into new structure
ARM: S3C24XX: modify s3c2416 irq init to initialize all irqs
ARM: S3C24XX: move s3c2416 irq init to common irq code
ARM: S3C24XX: Modify s3c_irq_wake to use the hwirq property
ARM: S3C24XX: Move irq syscore-ops to irq-pm
clocksource: always define CLOCKSOURCE_OF_DECLARE
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Add missing 'static' qualifiers.
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com>
The variable 'max_support_idx, min_support_idx, pm_lock_idx"
are never used, so remove the unused variable.
This patch adds support 1.7GHz max frequency for EXYNOS5250
Signed-off-by: Jaecheol Lee <jc.lee@samsung.com>
This patch adds support cpufreq for EXYNOS5250 SoC. Basically,
the exynos-cpufreq.c is used commonly and exynos5250-cpufreq.c
is used for EXYNOS5250(two Cortex-A15 cores) SoC.
Signed-off-by: Dave Jones <davej@redhat.com>
