path: root/drivers/cpufreq/maple-cpufreq.c
2016-04-09cpufreq: Use consistent prefixing via pr_fmtJoe Perches
Use the more common kernel style adding a define for pr_fmt. Miscellanea: o Remove now unused PFX defines Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-09cpufreq: Convert printk(KERN_<LEVEL> to pr_<level>Joe Perches
Use the more common logging style. Miscellanea: o Coalesce formats o Realign arguments o Add a missing space between a coalesced format Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-04-07cpufreq: create another field .flags in cpufreq_frequency_tableViresh Kumar
Currently cpufreq frequency table has two fields: frequency and driver_data. driver_data is only for drivers' internal use and cpufreq core shouldn't use it at all. But with the introduction of BOOST frequencies, this assumption was broken and we started using it as a flag instead. There are two problems due to this: - It is against the description of this field, as driver's data is used by the core now. - if drivers fill it with -3 for any frequency, then those frequencies are never considered by cpufreq core as it is exactly same as value of CPUFREQ_BOOST_FREQ, i.e. ~2. The best way to get this fixed is by creating another field flags which will be used for such flags. This patch does that. Along with that various drivers need modifications due to the change of struct cpufreq_frequency_table. Reviewed-by: Gautham R Shenoy <ego@linux.vnet.ibm.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-31cpufreq: move freq change notifications to cpufreq coreViresh Kumar
Most of the drivers do following in their ->target_index() routines: struct cpufreq_freqs freqs; freqs.old = old freq... freqs.new = new freq... cpufreq_notify_transition(policy, &freqs, CPUFREQ_PRECHANGE); /* Change rate here */ cpufreq_notify_transition(policy, &freqs, CPUFREQ_POSTCHANGE); This is replicated over all cpufreq drivers today and there doesn't exists a good enough reason why this shouldn't be moved to cpufreq core instead. There are few special cases though, like exynos5440, which doesn't do everything on the call to ->target_index() routine and call some kind of bottom halves for doing this work, work/tasklet/etc.. They may continue doing notification from their own code as flag: CPUFREQ_ASYNC_NOTIFICATION is already set for them. All drivers are also modified in this patch to avoid breaking 'git bisect', as double notification would happen otherwise. Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Russell King <linux@arm.linux.org.uk> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-25cpufreq: Implement light weight ->target_index() routineViresh Kumar
Currently, the prototype of cpufreq_drivers target routines is: int target(struct cpufreq_policy *policy, unsigned int target_freq, unsigned int relation); And most of the drivers call cpufreq_frequency_table_target() to get a valid index of their frequency table which is closest to the target_freq. And they don't use target_freq and relation after that. So, it makes sense to just do this work in cpufreq core before calling cpufreq_frequency_table_target() and simply pass index instead. But this can be done only with drivers which expose their frequency table with cpufreq core. For others we need to stick with the old prototype of target() until those drivers are converted to expose frequency tables. This patch implements the new light weight prototype for target_index() routine. It looks like this: int target_index(struct cpufreq_policy *policy, unsigned int index); CPUFreq core will call cpufreq_frequency_table_target() before calling this routine and pass index to it. Because CPUFreq core now requires to call routines present in freq_table.c CONFIG_CPU_FREQ_TABLE must be enabled all the time. This also marks target() interface as deprecated. So, that new drivers avoid using it. And Documentation is updated accordingly. It also converts existing .target() to newly defined light weight .target_index() routine for many driver. Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Russell King <linux@arm.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rjw@rjwysocki.net>
2013-10-16cpufreq: maple: use cpufreq_generic_init()Viresh Kumar
Use generic cpufreq_generic_init() routine instead of replicating the same code here. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-16cpufreq: maple: don't initialize part of policy set by coreViresh Kumar
Many common initializations of struct policy are moved to core now and hence this driver doesn't need to do it. This patch removes such code. Most recent of those changes is to call ->get() in the core after calling ->init(). Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-16cpufreq: maple: Use generic cpufreq routinesViresh Kumar
Most of the CPUFreq drivers do similar things in .exit() and .verify() routines and .attr. So its better if we have generic routines for them which can be used by cpufreq drivers then. This patch uses these generic routines in the maple driver. Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-09-30cpufreq: maple: use cpufreq_table_validate_and_show()Viresh Kumar
Lets use cpufreq_table_validate_and_show() instead of calling cpufreq_frequency_table_cpuinfo() and cpufreq_frequency_table_get_attr(). Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-08-23Merge branch 'cpu_of_node' of git://linux-arm.org/linux-skn into pm-cpufreq-nextRafael J. Wysocki
Pull DT/core/cpufreq cpu_ofnode updates for v3.12 from Sudeep KarkadaNagesha. * 'cpu_of_node' of git://linux-arm.org/linux-skn: cpufreq: pmac32-cpufreq: remove device tree parsing for cpu nodes cpufreq: pmac64-cpufreq: remove device tree parsing for cpu nodes cpufreq: maple-cpufreq: remove device tree parsing for cpu nodes cpufreq: arm_big_little: remove device tree parsing for cpu nodes cpufreq: kirkwood-cpufreq: remove device tree parsing for cpu nodes cpufreq: spear-cpufreq: remove device tree parsing for cpu nodes cpufreq: highbank-cpufreq: remove device tree parsing for cpu nodes cpufreq: cpufreq-cpu0: remove device tree parsing for cpu nodes cpufreq: imx6q-cpufreq: remove device tree parsing for cpu nodes drivers/bus: arm-cci: avoid parsing DT for cpu device nodes ARM: mvebu: remove device tree parsing for cpu nodes ARM: topology: remove hwid/MPIDR dependency from cpu_capacity of/device: add helper to get cpu device node from logical cpu index driver/core: cpu: initialize of_node in cpu's device struture ARM: DT/kernel: define ARM specific arch_match_cpu_phys_id of: move of_get_cpu_node implementation to DT core library powerpc: refactor of_get_cpu_node to support other architectures openrisc: remove undefined of_get_cpu_node declaration microblaze: remove undefined of_get_cpu_node declaration
2013-08-21cpufreq: maple-cpufreq: remove device tree parsing for cpu nodesSudeep KarkadaNagesha
Now that the cpu device registration initialises the of_node(if available) appropriately for all the cpus, parsing here is redundant. This patch removes all DT parsing and uses cpu->of_node instead. Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Sudeep KarkadaNagesha <sudeep.karkadanagesha@arm.com>
2013-08-10cpufreq: Drop the owner field from struct cpufreq_driverViresh Kumar
We don't need to set .owner = THIS_MODULE any more in cpufreq drivers as this field isn't used any more by the cpufreq core. This patch removes it and updates all dependent drivers accordingly. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-02cpufreq: Notify all policy->cpus in cpufreq_notify_transition()Viresh Kumar
policy->cpus contains all online cpus that have single shared clock line. And their frequencies are always updated together. Many SMP system's cpufreq drivers take care of this in individual drivers but the best place for this code is in cpufreq core. This patch modifies cpufreq_notify_transition() to notify frequency change for all cpus in policy->cpus and hence updates all users of this API. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-02-02cpufreq: Set all cpus in policy->cpus for single cluster SoCsViresh Kumar
With following patch, we need to set policy->cpus with mask of all possible cpus and policy->related_cpus would be filled automatically by the core. commit 4948b355e90080cd5ec1e91189f65a01e4186ef2 Author: Viresh Kumar <viresh.kumar@linaro.org> Date: Tue Jan 29 14:39:08 2013 +0000 cpufreq: Simplify cpufreq_add_dev() Lets fix it for all single cluster SoCs. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2011-07-19powerpc/cpufreq: Add cpufreq driver for Momentum Maple boardsDmitry Eremin-Solenikov
Add simple cpufreq driver for Maple-based boards (ppc970fx evaluation kit and others). Driver is based on a cpufreq driver for 64-bit powermac boxes with all pmac-dependant features removed and simple cleanup applied. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
