The policy->transition_latency field is used for multiple purposes
today and its not straight forward at all. This is how it is used:
A. Set the correct transition_latency value.
B. Set it to CPUFREQ_ETERNAL because:
1. We don't want automatic dynamic switching (with
ondemand/conservative) to happen at all.
2. We don't know the transition latency.
This patch handles the B.1. case in a more readable way. A new flag for
the cpufreq drivers is added to disallow use of cpufreq governors which
have dynamic_switching flag set.
All the current cpufreq drivers which are setting transition_latency
unconditionally to CPUFREQ_ETERNAL are updated to use it. They don't
need to set transition_latency anymore.
There shouldn't be any functional change after this patch.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Reviewed-by: Dominik Brodowski <linux@dominikbrodowski.net>
This patch fixes coccinelle error regarding usage of IS_ERR and
PTR_ERR instead of PTR_ERR_OR_ZERO.
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Need use 'clk' instead of 'mclk', which is the original removed local
variable.
The related original commit:
"652ed95 cpufreq: introduce cpufreq_generic_get() routine"
The related error with allmodconfig for unicore32:
CC drivers/cpufreq/unicore2-cpufreq.o
drivers/cpufreq/unicore2-cpufreq.c: In function ‘ucv2_target’:
drivers/cpufreq/unicore2-cpufreq.c:48: error: ‘struct cpufreq_policy’ has no member named ‘mclk’
make[2]: *** [drivers/cpufreq/unicore2-cpufreq.o] Error 1
make[1]: *** [drivers/cpufreq] Error 2
make: *** [drivers] Error 2
Fixes: 652ed95d5fa6 (cpufreq: introduce cpufreq_generic_get() routine)
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
Cc: 3.14+ <stable@vger.kernel.org> # 3.14+
CPUFreq core has new infrastructure that would guarantee serialized calls to
target() or target_index() callbacks. These are called
cpufreq_freq_transition_begin() and cpufreq_freq_transition_end().
This patch converts existing drivers to use these new set of routines.
Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
CPUFreq drivers that use clock frameworks interface,i.e. clk_get_rate(),
to get CPUs clk rate, have similar sort of code used in most of them.
This patch adds a generic ->get() which will do the same thing for them.
All those drivers are required to now is to set .get to cpufreq_generic_get()
and set their clk pointer in policy->clk during ->init().
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
In the current code, if we fail during a frequency transition, we
simply send the POSTCHANGE notification with the old frequency. This
isn't enough.
One of the core users of these notifications is the code responsible
for keeping loops_per_jiffy aligned with frequency changes. And mostly
it is written as:
if ((val == CPUFREQ_PRECHANGE && freq->old < freq->new) ||
(val == CPUFREQ_POSTCHANGE && freq->old > freq->new)) {
update-loops-per-jiffy...
So, suppose we are changing to a higher frequency and failed during
transition, then following will happen:
- CPUFREQ_PRECHANGE notification with freq-new > freq-old
- CPUFREQ_POSTCHANGE notification with freq-new == freq-old
The first one will update loops_per_jiffy and second one will do
nothing. Even if we send the 2nd notification by exchanging values of
freq-new and old, some users of these notifications might get
unstable.
This can be fixed by simply calling cpufreq_notify_post_transition()
with error code and this routine will take care of sending
notifications in the correct order.
[rjw: Folded 3 patches into one, rebased unicore2 changes]
Many common initializations of struct policy are moved to core now and hence
this driver doesn't need to do it. This patch removes such code.
Most recent of those changes is to call ->get() in the core after calling
->init().
Most of the users of cpufreq_verify_within_limits() calls it for
limiting with min/max from policy->cpuinfo. We can make that code
simple by introducing another routine which will do this for them
automatically.
This patch adds another routine cpufreq_verify_within_cpu_limits()
and updates others to use it.
Acked-by: Dirk Brandewie <dirk.j.brandewie@intel.com>
This local symbol is used only in this file.
Fix the following sparse warnings:
drivers/cpufreq/unicore2-cpufreq.c:27:5: warning: symbol 'ucv2_verify_speed' was not declared. Should it be static?
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
This patch moves cpufreq driver of UNICORE-2 architecture to drivers/cpufreq.
Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
