When system not boot up all cores, such as adding max_cpus=n,
n<NR_CPUS, then the conservative governor will increase the cpu
frequncy to the highest freq and never get to down.
Signed-off-by: Lin Fuzhen <fuzhen.lin@freescale.com>
arch/arm/configs/imx6_defconfig
arch/arm/configs/imx6_updater_defconfig
arch/arm/configs/imx6s_defconfig
arch/arm/include/asm/dma-mapping.h
arch/arm/kernel/smp.c
arch/arm/mach-mx6/Kconfig
arch/arm/mach-mx6/board-mx6dl_arm2.h
arch/arm/mach-mx6/board-mx6dl_sabresd.h
arch/arm/mach-mx6/board-mx6q_arm2.c
arch/arm/mach-mx6/board-mx6q_arm2.h
arch/arm/mach-mx6/board-mx6q_sabreauto.c
arch/arm/mach-mx6/board-mx6q_sabreauto.h
arch/arm/mach-mx6/board-mx6q_sabrelite.c
arch/arm/mach-mx6/board-mx6q_sabresd.c
arch/arm/mach-mx6/board-mx6q_sabresd.h
arch/arm/mach-mx6/board-mx6sl_arm2.c
arch/arm/mach-mx6/board-mx6sl_arm2.h
arch/arm/mach-mx6/board-mx6solo_sabreauto.h
arch/arm/mach-mx6/bus_freq.c
arch/arm/mach-mx6/clock.c
arch/arm/mach-mx6/clock_mx6sl.c
arch/arm/mach-mx6/cpu.c
arch/arm/mach-mx6/crm_regs.h
arch/arm/mach-mx6/devices-imx6q.h
arch/arm/mach-mx6/devices.c
arch/arm/mach-mx6/mx6_anatop_regulator.c
arch/arm/mach-mx6/pcie.c
arch/arm/mach-mx6/system.c
arch/arm/mm/dma-mapping.c
arch/arm/plat-mxc/devices/Makefile
arch/arm/plat-mxc/devices/platform-imx-dcp.c
arch/arm/plat-mxc/devices/platform-imx-ocotp.c
arch/arm/plat-mxc/devices/platform-imx-rngb.c
arch/arm/plat-mxc/devices/platform-mxc_hdmi.c
arch/arm/plat-mxc/include/mach/devices-common.h
arch/arm/plat-mxc/include/mach/esdhc.h
arch/arm/plat-mxc/include/mach/iomux-mx6dl.h
arch/arm/plat-mxc/include/mach/iomux-mx6q.h
arch/arm/plat-mxc/include/mach/memory.h
arch/arm/plat-mxc/include/mach/mx6.h
arch/arm/plat-mxc/include/mach/mxc_edid.h
arch/arm/plat-mxc/include/mach/mxc_hdmi.h
arch/arm/plat-mxc/system.c
drivers/Kconfig
drivers/char/hw_random/fsl-rngc.c
drivers/cpufreq/Makefile
drivers/cpufreq/cpufreq_interactive.c
drivers/crypto/Kconfig
drivers/crypto/caam/caamalg.c
drivers/crypto/caam/compat.h
drivers/crypto/caam/ctrl.c
drivers/crypto/caam/desc_constr.h
drivers/crypto/caam/intern.h
drivers/crypto/dcp.c
drivers/dma/pch_dma.c
drivers/input/keyboard/gpio_keys.c
drivers/input/touchscreen/egalax_ts.c
drivers/input/touchscreen/max11801_ts.c
drivers/media/video/mxc/capture/Kconfig
drivers/media/video/mxc/capture/adv7180.c
drivers/media/video/mxc/capture/ipu_csi_enc.c
drivers/media/video/mxc/capture/ipu_prp_vf_sdc.c
drivers/media/video/mxc/capture/ipu_prp_vf_sdc_bg.c
drivers/media/video/mxc/capture/mxc_v4l2_capture.c
drivers/media/video/mxc/capture/ov5640_mipi.c
drivers/media/video/mxc/output/mxc_vout.c
drivers/misc/Kconfig
drivers/misc/Makefile
drivers/mmc/card/block.c
drivers/mmc/core/mmc.c
drivers/mmc/host/mmci.c
drivers/mmc/host/sdhci-esdhc-imx.c
drivers/mmc/host/sdhci.c
drivers/mmc/host/sdhci.h
drivers/mxc/Kconfig
drivers/mxc/Makefile
drivers/mxc/asrc/mxc_asrc.c
drivers/mxc/gpu-viv/arch/XAQ2/hal/kernel/gc_hal_kernel_context.c
drivers/mxc/gpu-viv/arch/XAQ2/hal/kernel/gc_hal_kernel_hardware.c
drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel.c
drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel.h
drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel_command.c
drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel_event.c
drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal.h
drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal_base.h
drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal_options.h
drivers/mxc/gpu-viv/hal/os/linux/kernel/gc_hal_kernel_os.c
drivers/mxc/ipu3/ipu_device.c
drivers/mxc/vpu/mxc_vpu.c
drivers/net/fec.c
drivers/net/wireless/Makefile
drivers/power/sabresd_battery.c
drivers/regulator/core.c
drivers/tty/serial/imx.c
drivers/usb/core/hub.c
drivers/usb/gadget/arcotg_udc.c
drivers/usb/gadget/fsl_updater.c
drivers/usb/gadget/inode.c
drivers/usb/host/ehci-hub.c
drivers/video/mxc/ldb.c
drivers/video/mxc/mipi_dsi.c
drivers/video/mxc/mxc_dispdrv.c
drivers/video/mxc/mxc_dispdrv.h
drivers/video/mxc/mxc_edid.c
drivers/video/mxc/mxc_elcdif_fb.c
drivers/video/mxc/mxc_ipuv3_fb.c
drivers/video/mxc/mxc_spdc_fb.c
drivers/video/mxc_hdmi.c
drivers/watchdog/imx2_wdt.c
fs/proc/base.c
include/linux/mmc/host.h
include/linux/mmc/sdhci.h
include/linux/mxc_v4l2.h
kernel/power/main.c
sound/soc/codecs/mxc_hdmi.c
sound/soc/codecs/mxc_spdif.c
sound/soc/codecs/wm8962.c
sound/soc/imx/Kconfig
sound/soc/imx/Makefile
sound/soc/imx/imx-cs42888.c
sound/soc/imx/imx-esai.c
sound/soc/imx/imx-wm8958.c
sound/soc/imx/imx-wm8962.c
Consider the below scenario: there is one CPU enter idle state before
switch happen, and the CPU frequency is set on high point(1G with userspace
cpufreq profile). After cpufreq profile is switched to interactive, all of the
cpus's target_freq will be set to the current CPU frequency 1G. Then after one
sample window, interactive profile will revalue the current cpu loading in
every cpu(except idle cpu), and get the desired frequency and compared with
target_freq to decide up or down frequency. Until all of cpus's target_freq
is lower than desired frequency , down frequency will happen. But the idle
CPU's frequency has been set on 1G , so cpu frequency miss the chance to set
lower cpu frequency , although there is no loading in all of cpus.CPU frequency
will be down unless the idled CPU exit idle to revalue cpu loading and get the
right target_freq, in the worst case, it will never happen.
Now we can do this:
If we judge cpu idle state and set taget_freq to lowest frequency when switch
to interactive, then CPU frequency modify will never be blocked on idled CPU.
Signed-off-by: Robin Gong <B38343@freescale.com>
Interactive governor is too early to start, and kernel boot
up speed is impacted, use late_initcall instead of fs_initcall.
Signed-off-by: Anson Huang <b20788@freescale.com>
1. When system not boot up all cores, interactive governor
will not work;
2. Adjust the default timer_rate to 50ms instead of 20ms to
avoid too many freq up/down change.
fix some build warnings when using GCC 4.6.2:
drivers/cpufreq/cpufreq_interactive.c:127:6:
warning:'irq_count' may be used uninitialized in this function [-Wuninitialized]
drivers/media/video/mxc/output/mxc_vout.c:1346:5:
warning: 'ret' may be used uninitialized in this function [-Wuninitialized]
drivers/video/mxc/mxc_ipuv3_fb.c:1329:23:
warning: operation on 'mxc_fbi->cur_ipu_buf' may be undefined [-Wsequence-point]
drivers/video/mxc/mxc_ipuv3_fb.c:1376:24:
drivers/video/mxc/mxc_ipuv3_fb.c:1377:24:
Signed-off-by: Jason Liu <r64343@freescale.com>
Add irq count to CPUFreq as a freq change condition.
Because some devices' working mode is unable to issue
CPUFreq change because of low CPU loading, but the cpu
freq will impact these devices' performace significantly.
Interactive govervor will sample the cpu loading as well
as the irq count which is registered. If the
loading or the irq count exceed the threshold we set,
governor will issue an CPUFreq change request.
These devices' irq threshold and enable/disable can be modified
via /sys/devices/system/cpu/cpufreq/interactive/irq_scaling
echo 0xAABBBC to change the default setting as below
AA : irq number
BBB: threshold
C :enable or disable
Currently only enable USDHC3, USDHC4, GPU, SATA and
USB by default, we can add device to the init struct which is
located in arch/arm/mach-mx6/irq.c.
cpufreq: interactive: New 'interactive' governor
This governor is designed for latency-sensitive workloads, such as
interactive user interfaces. The interactive governor aims to be
significantly more responsive to ramp CPU quickly up when CPU-intensive
activity begins.
Existing governors sample CPU load at a particular rate, typically
every X ms. This can lead to under-powering UI threads for the period of
time during which the user begins interacting with a previously-idle system
until the next sample period happens.
The 'interactive' governor uses a different approach. Instead of sampling
the CPU at a specified rate, the governor will check whether to scale the
CPU frequency up soon after coming out of idle. When the CPU comes out of
idle, a timer is configured to fire within 1-2 ticks. If the CPU is very
busy from exiting idle to when the timer fires then we assume the CPU is
underpowered and ramp to MAX speed.
If the CPU was not sufficiently busy to immediately ramp to MAX speed, then
the governor evaluates the CPU load since the last speed adjustment,
choosing the highest value between that longer-term load or the short-term
load since idle exit to determine the CPU speed to ramp to.
A realtime thread is used for scaling up, giving the remaining tasks the
CPU performance benefit, unlike existing governors which are more likely to
schedule rampup work to occur after your performance starved tasks have
completed.
The tuneables for this governor are:
/sys/devices/system/cpu/cpufreq/interactive/min_sample_time:
The minimum amount of time to spend at the current frequency before
ramping down. This is to ensure that the governor has seen enough
historic CPU load data to determine the appropriate workload.
/sys/devices/system/cpu/cpufreq/interactive/go_maxspeed_load
The CPU load at which to ramp to max speed.
arch/arm/mach-mx6/mx6_ddr_freq.S
arch/arm/mach-mx6/mx6_mmdc.c
arch/arm/mach-mx6/mx6_suspend.S
arch/arm/mach-mx6/mx6_wfi.S
arch/arm/mach-mx6/plat_hotplug.c
arch/arm/mach-mx6/pm.c
arch/arm/plat-mxc/cpufreq.c
drivers/mtd/nand/gpmi-nand/gpmi-lib.c
drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel_mmu.c
drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal_enum.h
drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal_version.h
drivers/mxc/gpu-viv/hal/os/linux/kernel/gc_hal_kernel_driver.c
drivers/mxc/ipu3/vdoa.c
drivers/power/max8903_charger.c
Apply min_sample_time to the last time the current target speed
was originally requested or re-validated as appropriate for the
current load, not to the time since the current speed was
originally set. Avoids periodic dips in speed during bursty
loads.
Change-Id: I250bda657985de60373f9897cc41f480664d51a1
Signed-off-by: Todd Poynor <toddpoynor@google.com>
If load is above go_hispeed_load, always go to at least hispeed_freq,
even when reducing speed from a higher speed, not just when jumping
up from minimum speed. Avoids running at a lower than intended
speed after a burst of even higher load.
Change-Id: I5b9d2a15ba25ce609b21bac7c724265cf6838dee
Evaluate spikes in load (below go_hispeed_load) against the maximum
speed supported by the device, not the current speed (which tends to
make it too difficult to raise speed to intermediate levels until
very busy).
Change-Id: Ib937006abf8bedb60891a739acd733e89b732ae0
will not work;
arch/arm/mach-mx6/localtimer.c
drivers/mxc/gpu-viv/hal/os/linux/kernel/gc_hal_kernel_device.c
drivers/usb/otg/fsl_otg.c
include/linux/fsl_devices.h
sound/soc/imx/imx-hdmi-dma.c
AA : irq number
BBB: threshold
activity begins.
completed.
Change-Id: Ic13614a3da2faa2d4bd215ca3eb7191614f0cf66
commit a8eb28480e9b637cc78b9aa5e08612ba97e1317a upstream.
The driver uses the pstate number from the status register as index in
its table of ACPI pstates (powernow_table). This is wrong as this is
not a 1-to-1 mapping.
For example we can have _PSS information to just utilize Pstate 0 and
Pstate 4, ie.
powernow-k8: Core Performance Boosting: on.
powernow-k8: 0 : pstate 0 (2200 MHz)
powernow-k8: 1 : pstate 4 (1400 MHz)
In this example the driver's powernow_table has just 2 entries. Using
the pstate number (4) as index into this table is just plain wrong.
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Signed-off-by: Dave Jones <davej@redhat.com>
commit 201bf0f129e1715a33568d1563d9a75b840ab4d3 upstream.
Due to CPB we can't directly map SW Pstates to Pstate MSRs. Get rid of
the paranoia check. (assuming that the ACPI Pstate information is
correct.)
Change-Id: Ie9952f07b38667f2932474090044195c57976faa
* Add attribute hispeed_freq, which defaults to max.
* Rename go_maxspeed_load to go_hispeed_load.
* If hit go_hispeed_load and at min speed, go to hispeed_freq;
if hit go_hispeed_load and already above min speed go to max
speed.
Change-Id: I1050dec5f013fc1177387352ba787a7e1c68703e
Change-Id: Ieffb2aa56b5290036285c948718be7be0d3af9e8
Calculate intermediate speed by applyng CPU load to current speed, not
max speed.
Change-Id: Idecf598b9a203b07c989c5d9e9c6efc67a1afc2e
Lower the default time at which a higher speed is allowed to run
before lowering based on lower CPU load from 80ms to 20ms. Most
Android devices should trade power for performance here,
although tablets and non-battery-powered devices may want to
override this default.
Change-Id: I1a4f7faeca12793c51d5b92db30a63cca8d4f1be
Modify default timer from 30ms to 10ms, sampling 2 jiffies after
idle exit on ARM as in Honeycomb.
Modify default go_maxspeed_load from 85% loaded to 95% loaded, for
use in phones where power savings is more important (tablets may be
best served overriding this).
Change-Id: I3361a6279979bfae1df5262666a2e30ea7a44328
The following dump was seen sometimes while resuming,
the only division by zero on this function can happen after
delta_time is reassigned, since at the start of the
function, there is jump that protects against values
less than 1000.
After that, If delta_time and delta_idle == 0,
we will hit a div 0
Division by zero in kernel.
Backtrace:
[<c0057184>] (dump_backtrace+0x0/0x110) from [<c05d5ecc>] (dump_stack+0x18/0x1c)
r6:010f3000 r5:c113dfb0 r4:c004afb0 r3:c6ff0000
[<c05d5eb4>] (dump_stack+0x0/0x1c) from [<c00572cc>] (__div0+0x1c/0x20)
[<c00572b0>] (__div0+0x0/0x20) from [<c02195d4>] (Ldiv0+0x8/0x10)
[<c03dfd64>] (cpufreq_interactive_timer+0x0/0x2c0) from [<c00a7efc>] (run_timer_softirq+0x154/0x260)
[<c00a7da8>] (run_timer_softirq+0x0/0x260) from [<c00a0c8c>] (__do_softirq+0xc8/0x194)
[<c00a0bc4>] (__do_softirq+0x0/0x194) from [<c00a1008>] (irq_exit+0xb4/0xb8)
[<c00a0f54>] (irq_exit+0x0/0xb8) from [<c00584b4>] (ipi_timer+0x44/0x48)
r4:c004a040 r3:00000001
[<c0058470>] (ipi_timer+0x0/0x48) from [<c004c3e4>] (do_local_timer+0x68/0x84)
r5:c004ae2c r4:c07991e8
[<c004c37c>] (do_local_timer+0x0/0x84) from [<c0052948>] (__irq_svc+0x48/0xe0)
Change-Id: I639882db67b8d711c5710778ebc212f0f6a998e3
Acked-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Axel Haslam <axelhaslam@ti.com>
commit e71f5cc402ecb42b407ae52add7b173bf1c53daa upstream.
per_cpu(processors, n) can be NULL, resulting in:
Loading CPUFreq modules[ 437.661360] BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffffa0434314>] pcc_cpufreq_cpu_init+0x74/0x220 [pcc_cpufreq]
It's better to avoid the oops by failing the driver, and allowing the
system to boot.
Signed-off-by: Naga Chumbalkar <nagananda.chumbalkar@hp.com>
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Len Brown <lenb@kernel.org>
The interactive governor relies on quirks of the Tegra 2 cpufreq
implementation for handling SMP systems where the CPUs do not have
separate rate controls. It needs to determine the maximum rate
for all CPUs covered by the policy and set that speed.
Change-Id: I1ed9fa171e5a9c45a1fa5944e3fa823eb157e81f
Fix up checkpatch warning introduced by long lines in timer_rate
patch.
Change-Id: I22b105dafb1b49390799bb7577464da03f0f8afb
Signed-off-by: Allen Martin <amartin@nvidia.com>
Cleanup some style warnings reported by checkpatch
Change-Id: Ie2e6903d52867fb3347e009d7efa3bc4ca755cea
Update the Kconfig help paragraph to give more detail about
interactive governor.
Change-Id: I607b817b370accac3a685001649a15e2f7894f59
Add a new sysfs control that tunes the rate of the timer used to
increase cpu frequency
Change-Id: I1aa13ae54bb43aff5b3688984d2955f56aae1658
This adds better error checking on tunable parameters on sysfs
interfaces. Also fixes return value from these functions, previously
on success they would return 0 which would cause a infinite loop.
Change-Id: Ic05038492166f8673d007202092471f98a2f0dfa
Convert interactive governor to use idle notifier instead of
hooking pm_idle directly.
Change-Id: I47e007f330468ac559240a0ae8a3cb06a89ccb67
Remove debug trace code in preparation of upstreaming
Change-Id: I0905885e75031f5e9d7cb06878fb68c1fd06d4fe
I came across a memory leak during a cyclic cpu-online-offline test.
Signed-off-by: Yu Luming <luming.yu@intel.com>
Change-Id: Id5267f04067bf023f6b140b4de2e88ef7287e941
This patch augments the pstate transition code to error out
(instead of returning 0) when an incorrect pstate is provided.
Suggested-by: Borislav Petkov <bp@alien8.de>
CC: andre.przywara@amd.com
CC: Mark.Langsdorf@amd.com
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
(vid case).
Before this patch if we failed the vid transition would still try to
submit the "new" frequencies to cpufreq.
That is incorrect - also we could submit a non-existing frequency value
which would cause cpufreq to crash. The ultimate fix is in cpufreq
to deal with incorrect values, but this patch improves the error
recovery in the AMD powernowk8 driver.
The failure that was reported was as follows:
powernow-k8: Found 1 AMD Athlon(tm) 64 Processor 3700+ (1 cpu cores) (version 2.20.00)
powernow-k8: fid 0x2 (1000 MHz), vid 0x12
powernow-k8: fid 0xa (1800 MHz), vid 0xa
powernow-k8: fid 0xc (2000 MHz), vid 0x8
powernow-k8: fid 0xe (2200 MHz), vid 0x8
Marking TSC unstable due to cpufreq changes
powernow-k8: fid trans failed, fid 0x2, curr 0x0
BUG: unable to handle kernel paging request at ffff880807e07b78
IP: [<ffffffff81479163>] cpufreq_stats_update+0x46/0x5b
And transition fails and data->currfid ends up with 0. Since
the machine does not support 800Mhz value when the calculation is
done ('find_khz_freq_from_fid(data->currfid);') it reports the
new frequency as 800000 which is bogus. This patch fixes
the issue during target setting.
The patch however does not fix the issue in 'powernowk8_cpu_init'
where the pol->cur can also be set with the 800000 value:
pol->cur = find_khz_freq_from_fid(data->currfid);
dprintk("policy current frequency %d kHz\n", pol->cur);
/* min/max the cpu is capable of */
if (cpufreq_frequency_table_cpuinfo(pol, data->powernow_table)) {
The fix for that looks to update cpufreq_frequency_table_cpuinfo to
check pol->cur.... but that would cause an regression in how the
acpi-cpufreq driver works (it sets cpu->cur after calling
cpufreq_frequency_table_cpuinfo). Instead the fix will be to let
cpufreq gracefully handle bogus data (another patch).
Acked-by: Borislav Petkov <bp@alien8.de>
Reported-by: Tobias Diedrich <ranma+xen@tdiedrich.de>
Tested-by: Tobias Diedrich <ranma+xen@tdiedrich.de>
[v1: Rebased on v3.0-rc2, reduced patch to deal with vid case]
If the driver submitted an non-existing pol>cur value (say it
used the default initialized value of zero), when the cpufreq
stats tries to setup its initial values it incorrectly sets
stat->last_index to -1 (or 0xfffff...). And cpufreq_stats_update
tries to update at that index location and fails.
This can be caused by:
stat->last_index = freq_table_get_index(stat, policy->cur);
not finding the appropiate frequency in the table (b/c the policy->cur
is wrong) and we end up crashing. The fix however is
concentrated in the 'cpufreq_stats_update' as the last_index
(and old_index) are updated there. Which means it can reset
the last_index to -1 again and on the next iteration cause a crash.
Without this patch, the following crash is observed:
.. snip..
Pid: 1, comm: swapper Not tainted 3.0.0-rc2 #45 MICRO-STAR INTERNATIONAL CO., LTD MS-7094/MS-7094
..snip..
Call Trace:
[<ffffffff81479248>] cpufreq_stat_notifier_trans+0x48/0x7c
[<ffffffff81095d68>] notifier_call_chain+0x32/0x5e
[<ffffffff81095e6b>] __srcu_notifier_call_chain+0x47/0x63
[<ffffffff81095e96>] srcu_notifier_call_chain+0xf/0x11
[<ffffffff81477e7a>] cpufreq_notify_transition+0x111/0x134
[<ffffffff8147b0d4>] powernowk8_target+0x53b/0x617
[<ffffffff8147723a>] __cpufreq_driver_target+0x2e/0x30
[<ffffffff8147a127>] cpufreq_governor_dbs+0x339/0x356
[<ffffffff81477394>] __cpufreq_governor+0xa8/0xe9
[<ffffffff81477525>] __cpufreq_set_policy+0x132/0x13e
[<ffffffff8147848d>] cpufreq_add_dev_interface+0x272/0x28c
Ensures that cpufreq_stats_free_table is called before
__cpufreq_remove_dev on cpu hotplug (which also occurs during
suspend on SMP systems) to make sure that sysfs_remove_group
can get called before the cpufreq kobj is freed. Otherwise,
the sysfs file structures are leaked.
Change-Id: I87e55277272f5cfad47e9e7c92630e990bb90069
Signed-off-by: Colin Cross <ccross@android.com>
Don't reference the saved copy of the CPU's cpufreq policy
pointer after the governor has been stopped for the CPU.
When the governor is stopped for a CPU:
* Use del_timer_sync() to wait for a currently-running timer
function to stop.
* Delete the timer when the governor is stopped for the
associated CPU, not when the last CPU is stopped.
* Flush any speed down work ongoing.
* Reset the timestamp that is used to tell if the timer function
has had a chance to run since last idle exit.
Check the governor enabled flag for the CPU before re-arming the
timer from within the timer function and at idle exit (in case
stopping the governor at runtime).
Check the governor enabled flag for the CPU in the worker
function and thread before using the policy pointer. (There is
still a tiny window in the thread that needs more work to close.)
Change-Id: Ifaddf7a495a8dae15a579a57bdc654f7c47f6ada
Need to use irqsave/restore spin locking for cpumasks since these
are accessed in timers and in thread context.
Change-Id: I4a53eaf0ced7e73b445feddba90ec11482de9126
