Signed-off-by: Dave Jones <davej@redhat.com>
Commit 4bc5d3413503 is broken and causes regressions:
(1) cpufreq_driver->resume() and ->suspend() were only called on
__powerpc__, but you could set them on all architectures. In fact,
->resume() was defined and used before the PPC-related commit
42d4dc3f4e1e complained about in 4bc5d3413503.
(2) Therfore, the resume functions in acpi_cpufreq and speedstep-smi
would never be called.
(3) This means speedstep-smi would be unusuable after suspend or resume.
The _real_ problem was calling cpufreq_driver->get() with interrupts
off, but it re-enabling interrupts on some platforms. Why is ->get()
necessary?
Some systems like to change the CPU frequency behind our
back, especially during BIOS-intensive operations like suspend or
resume. If such systems also use a CPU frequency-dependant timing loop,
delays might be off by large factors. Therefore, we need to ascertain
as soon as possible that the CPU frequency is indeed at the speed we
think it is. You can do this two ways: either setting it anew, or trying
to get it. The latter is what was done, the former also has the same IRQ
issue.
So, let's try something different: defer the checking to after interrupts
are re-enabled, by calling cpufreq_update_policy() (via schedule_work()).
Timings may be off until this later stage, so let's watch out for
resume regressions caused by the deferred handling of frequency changes
behind the kernel's back.
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
arch/sparc/kernel/smp_64.c
arch/x86/kernel/cpu/perf_counter.c
arch/x86/kernel/setup_percpu.c
drivers/cpufreq/cpufreq_ondemand.c
mm/percpu.c
Conflicts in core and arch percpu codes are mostly from commit
ed78e1e078dd44249f88b1dd8c76dafb39567161 which substituted many
num_possible_cpus() with nr_cpu_ids. As for-next branch has moved all
the first chunk allocators into mm/percpu.c, the changes are moved
from arch code to mm/percpu.c.
The suspend code runs with interrupts disabled, and the powerpc workaround we
do in the cpufreq suspend hook calls the drivers ->get method.
powernow-k8's ->get does an smp_call_function_single
which needs interrupts enabled
cpufreq's suspend/resume code was added in 42d4dc3f4e1e to work around
a hardware problem on ppc powerbooks. If we make all this code
conditional on powerpc, we avoid the issue above.
The first offline/online cycle is successful, the second not.
Doing:
echo 0 >cpu1/online
echo 1 >cpu1/online
echo 0 >cpu1/online
The last command will trigger:
Jul 22 14:39:50 linux kernel: [ 593.210125] ------------[ cut here ]------------
Jul 22 14:39:50 linux kernel: [ 593.210139] WARNING: at lib/kref.c:43 kref_get+0x23/0x2b()
Jul 22 14:39:50 linux kernel: [ 593.210144] Hardware name: To Be Filled By O.E.M.
Jul 22 14:39:50 linux kernel: [ 593.210148] Modules linked in: powernow_k8
Jul 22 14:39:50 linux kernel: [ 593.210158] Pid: 378, comm: kondemand/2 Tainted: G W 2.6.31-rc2 #38
Jul 22 14:39:50 linux kernel: [ 593.210163] Call Trace:
Jul 22 14:39:50 linux kernel: [ 593.210171] [<ffffffff812008e8>] ? kref_get+0x23/0x2b
Jul 22 14:39:50 linux kernel: [ 593.210181] [<ffffffff81041926>] warn_slowpath_common+0x77/0xa4
Jul 22 14:39:50 linux kernel: [ 593.210190] [<ffffffff81041962>] warn_slowpath_null+0xf/0x11
Jul 22 14:39:50 linux kernel: [ 593.210198] [<ffffffff812008e8>] kref_get+0x23/0x2b
Jul 22 14:39:50 linux kernel: [ 593.210206] [<ffffffff811ffa19>] kobject_get+0x1a/0x22
Jul 22 14:39:50 linux kernel: [ 593.210214] [<ffffffff813e815d>] cpufreq_cpu_get+0x8a/0xcb
Jul 22 14:39:50 linux kernel: [ 593.210222] [<ffffffff813e87d1>] __cpufreq_driver_getavg+0x1d/0x67
Jul 22 14:39:50 linux kernel: [ 593.210231] [<ffffffff813ea18f>] do_dbs_timer+0x158/0x27f
Jul 22 14:39:50 linux kernel: [ 593.210240] [<ffffffff810529ea>] worker_thread+0x200/0x313
The output continues on every do_dbs_timer ondemand freq checking poll.
This regression was introduced by git commit:
3f4a782b5ce2698b1870b5a7b573cd721d4fce33
The policy is released when the cpufreq device is removed in:
__cpufreq_remove_dev():
/* if this isn't the CPU which is the parent of the kobj, we
* only need to unlink, put and exit
Not creating the symlink is not sever at all.
As long as:
sysfs_remove_link(&sys_dev->kobj, "cpufreq");
handles it gracefully that the symlink did not exist.
Possibly no error should be returned at all, because ondemand
governor would still provide the same functionality.
Userspace in userspace gov case might be confused if the link
is missing.
Resolves http://bugzilla.kernel.org/show_bug.cgi?id=13903
CC: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
CC: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Thomas Renninger <trenn@suse.de>
Suspend/Resume fails on multi socket, multi core systems because the cpufreq
code erroneously sets the per_cpu policy_cpu value when a logical cpu is
offline.
This most notably results in missing sysfs files that are used to set the
cpu frequencies of the various cpus.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Commit ee88415caf736b89500f16e0a545614541a45005
introduced this regression when it removed enable bit in cpu_dbs_info_s.
That added a possibility of dbs_cpufreq_notifier getting called for a
CPU that is not yet managed by conservative governor. That will happen
as the transition notifier is set as soon as one CPU switches to
conservative governor and other CPUs can get a NULL pointer dereference
without the enable bit check. Add the enable bit back again.
Reported-by: Lermytte Christophe <Christophe.Lermytte@thomson.net>
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
managed_policy is out of scope for the non-smp case.
Declare it locally where used (twice)
OK, I've tried to clean it up the best I could, but please test this with
concurrent cpu hotplug and cpufreq add/remove in loops. I'm sure we will make
other interesting findings.
This is step one of fixing the overall locking dependency mess in cpufreq.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
CC: rjw@sisk.pl
CC: mingo@elte.hu
CC: Shaohua Li <shaohua.li@intel.com>
CC: Pekka Enberg <penberg@cs.helsinki.fi>
CC: Dave Young <hidave.darkstar@gmail.com>
CC: "Rafael J. Wysocki" <rjw@sisk.pl>
CC: Rusty Russell <rusty@rustcorp.com.au>
CC: sven.wegener@stealer.net
CC: cpufreq@vger.kernel.org
CC: Thomas Renninger <trenn@suse.de>
Redesign the locking inside conservative driver. Make dbs_mutex handle all the
global state changes inside the driver and invent a new percpu mutex
to serialize percpu timer and frequency limit change.
Redesign the locking inside ondemand driver. Make dbs_mutex handle all the
Commit b14893a62c73af0eca414cfed505b8c09efc613c although it was very
much needed to properly cleanup ondemand timer, opened-up a can of worms
related to locking dependencies in cpufreq.
Patch here defines the need for dbs_mutex and cleans up its usage in
ondemand governor. This also resolves the lockdep warnings reported here
http://lkml.indiana.edu/hypermail/linux/kernel/0906.1/01925.html
http://lkml.indiana.edu/hypermail/linux/kernel/0907.0/00820.html
and few others..
Percpu variable definition is about to be updated such that all percpu
symbols including the static ones must be unique. Update percpu
variable definitions accordingly.
* as,cfq: rename ioc_count uniquely
* cpufreq: rename cpu_dbs_info uniquely
* xen: move nesting_count out of xen_evtchn_do_upcall() and rename it
* mm: move ratelimits out of balance_dirty_pages_ratelimited_nr() and
rename it
* ipv4,6: rename cookie_scratch uniquely
* x86 perf_counter: rename prev_left to pmc_prev_left, irq_entry to
pmc_irq_entry and nmi_entry to pmc_nmi_entry
* perf_counter: rename disable_count to perf_disable_count
* ftrace: rename test_event_disable to ftrace_test_event_disable
* kmemleak: rename test_pointer to kmemleak_test_pointer
* mce: rename next_interval to mce_next_interval
[ Impact: percpu usage cleanups, no duplicate static percpu var names ]
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Jeremy Fitzhardinge <jeremy@xensource.com>
Cc: linux-mm <linux-mm@kvack.org>
Cc: Steven Rostedt <srostedt@redhat.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Update the documentation accordingly.
Cleanup and use printk_once.
With this patch you have following minimal sampling rate restrictions:
Kernel restrictions:
If CONFIG_NO_HZ is set, the limit is 10ms fixed.
If CONFIG_NO_HZ is not set or no_hz=off boot parameter is used, the
limits depend on the CONFIG_HZ option:
HZ=1000: min=20000us (20ms)
HZ=250: min=80000us (80ms)
HZ=100: min=200000us (200ms)
HW restrictions:
Do not sample/poll more often than HW latency * 100 exported by the low
level cpufreq HW driver
The higher value of above restrictions is the minimal sampling rate
that can be set (and can be seen via ondemand/sampling_rate_min sysfs file)
Default sampling rate still is HW latency * 1000, but this will now end
up in lower values on latest (Intel and AMD) hardware as these can switch
really fast and sampling rate mostly was limited to the 80ms or 200ms
(depending on whether HZ=250 or HZ=1000 is used).
Cc: Pallipadi Venkatesh <venkatesh.pallipadi@intel.com>
These are defined as static cpumask_var_t so if MAXSMP is not used,
they are cleared already. Avoid surprises when MAXSMP is enabled.
Signed-off-by: Yinghai Lu <yinghai.lu@kernel.org>
* Rafael J. Wysocki (rjw@sisk.pl) wrote:
> This message has been generated automatically as a part of a report
> of regressions introduced between 2.6.28 and 2.6.29.
> The following bug entry is on the current list of known regressions
> introduced between 2.6.28 and 2.6.29. Please verify if it still should
> be listed and let me know (either way).
> Bug-Entry : http://bugzilla.kernel.org/show_bug.cgi?id=13186
> Subject : cpufreq timer teardown problem
> Submitter : Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
> Date : 2009-04-23 14:00 (24 days old)
> References : http://marc.info/?l=linux-kernel&m=124049523515036&w=4
> Handled-By : Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
> Patch : http://patchwork.kernel.org/patch/19754/
> http://patchwork.kernel.org/patch/19753/
(updated changelog)
cpufreq fix timer teardown in ondemand governor
The problem is that dbs_timer_exit() uses cancel_delayed_work() when it should
use cancel_delayed_work_sync(). cancel_delayed_work() does not wait for the
workqueue handler to exit.
The ondemand governor does not seem to be affected because the
"if (!dbs_info->enable)" check at the beginning of the workqueue handler returns
immediately without rescheduling the work. The conservative governor in
2.6.30-rc has the same check as the ondemand governor, which makes things
usually run smoothly. However, if the governor is quickly stopped and then
started, this could lead to the following race :
dbs_enable could be reenabled and multiple do_dbs_timer handlers would run.
This is why a synchronized teardown is required.
The following patch applies to, at least, 2.6.28.x, 2.6.29.1, 2.6.30-rc2.
Depends on patch
cpufreq: remove rwsem lock from CPUFREQ_GOV_STOP call
CC: Andrew Morton <akpm@linux-foundation.org>
CC: gregkh@suse.de
CC: stable@kernel.org
CC: Ingo Molnar <mingo@elte.hu>
CC: rjw@sisk.pl
CC: Ben Slusky <sluskyb@paranoiacs.org>
(re-send with updated changelog)
cpufreq fix timer teardown in conservative governor
Depends on patch
The following patch applies to 2.6.30-rc2. Stable kernels have a similar
issue which should also be fixed, but the code changed between 2.6.29
and 2.6.30, so this patch only applies to 2.6.30-rc.
CC: gregkh@suse.de
CC: rjw@sisk.pl
The patches linked above depend on the following patch to remove
circular locking dependency :
(the following issue was faced when using cancel_delayed_work_sync() in the
timer teardown (which fixes a race).
* KOSAKI Motohiro (kosaki.motohiro@jp.fujitsu.com) wrote:
> Hi
> my box output following warnings.
> it seems regression by commit 7ccc7608b836e58fbacf65ee4f8eefa288e86fac.
> A: work -> do_dbs_timer() -> cpu_policy_rwsem
> B: store() -> cpu_policy_rwsem -> cpufreq_governor_dbs() -> work
Hrm, I think it must be due to my attempt to fix the timer teardown race
in ondemand governor mixed with new locking behavior in 2.6.30-rc.
The rwlock seems to be taken around the whole call to
cpufreq_governor_dbs(), when it should be only taken around accesses to
the locked data, and especially *not* around the call to
dbs_timer_exit().
Reverting my fix attempt would put the teardown race back in place
(replacing the cancel_delayed_work_sync by cancel_delayed_work).
Instead, a proper fix would imply modifying this critical section :
cpufreq.c: __cpufreq_remove_dev()
if (cpufreq_driver->target)
__cpufreq_governor(data, CPUFREQ_GOV_STOP);
unlock_policy_rwsem_write(cpu);
To make sure the __cpufreq_governor() callback is not called with rwsem
held. This would allow execution of cancel_delayed_work_sync() without
being nested within the rwsem.
Applies on top of the 2.6.30-rc5 tree.
Required to remove circular dep in teardown of both conservative and
ondemande governors so they can use cancel_delayed_work_sync().
CPUFREQ_GOV_STOP does not modify the policy, therefore this locking seemed
unneeded.
CC: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Greg KH <greg@kroah.com>
CC: Chris Wright <chrisw@sous-sol.org>
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: (35 commits)
[CPUFREQ] Prevent p4-clockmod from auto-binding to the ondemand governor.
[CPUFREQ] Make cpufreq-nforce2 less obnoxious
[CPUFREQ] p4-clockmod reports wrong frequency.
[CPUFREQ] powernow-k8: Use a common exit path.
[CPUFREQ] Change link order of x86 cpufreq modules
[CPUFREQ] conservative: remove 10x from def_sampling_rate
[CPUFREQ] conservative: fixup governor to function more like ondemand logic
[CPUFREQ] conservative: fix dbs_cpufreq_notifier so freq is not locked
[CPUFREQ] conservative: amend author's email address
[CPUFREQ] Use swap() in longhaul.c
[CPUFREQ] checkpatch cleanups for acpi-cpufreq
[CPUFREQ] powernow-k8: Only print error message once, not per core.
[CPUFREQ] ondemand/conservative: sanitize sampling_rate restrictions
[CPUFREQ] ondemand/conservative: deprecate sampling_rate{min,max}
[CPUFREQ] powernow-k8: Always compile powernow-k8 driver with ACPI support
[CPUFREQ] Introduce /sys/devices/system/cpu/cpu*/cpufreq/cpuinfo_transition_latency
[CPUFREQ] checkpatch cleanups for powernow-k8
[CPUFREQ] checkpatch cleanups for ondemand governor.
[CPUFREQ] checkpatch cleanups for powernow-k7
[CPUFREQ] checkpatch cleanups for speedstep related drivers.
This reverts commit e088e4c9cdb618675874becb91b2fd581ee707e6.
Removing the sysfs interface for p4-clockmod was flagged as a
regression in bug 12826.
Course of action:
- Find out the remaining causes of overheating, and fix them
if possible. ACPI should be doing the right thing automatically.
If it isn't, we need to fix that.
- mark p4-clockmod ui as deprecated
- try again with the removal in six months.
It's not really feasible to printk about the deprecation, because
it needs to happen at all the sysfs entry points, which means adding
a lot of strcmp("p4-clockmod".. calls to the core, which.. bleuch.
AMD users get particular hit by this issue (bug 8081) as it caps at
typically 90 seconds as the minimum period for a frequency change.
Harsh eh? Years ago I borked this buy puting the 10x in the wrong
place...I fix that by removing it altogether.
Signed-off-by: Alexander Clouter <alex@digriz.org.uk>
As conservative is based off ondemand the codebases occasionally need to be
resync'd. This patch, although ugly, does this.
When someone added the dbs_cpufreq_notifier section to the governor the
code ended up causing the frequency to only fall. This is because
requested_freq is tinkered with and that should only modified if it has
an invlaid value due to changes in the available frequency ranges
This should fix #10055.
Amend author's email address.
Limit sampling rate to transition_latency * 100 or kernel limits.
If sampling_rate is tried to be set too low, set the lowest allowed value.
The same info can be obtained via the transition_latency sysfs file
It's not only useful for the ondemand and conservative governors, but
also for userspace daemons to know about the HW transition latency of
the CPU.
It is especially useful for userspace to know about this value when
the ondemand or conservative governors are run. The sampling rate
control value depends on it and for userspace being able to set sane
tuning values there it has to know about the transition latency.
ondemand micro-accounting of idle time changes broke ignore_nice_load
sysfs setting due to a thinko in the code.
The bug entry:
http://bugzilla.kernel.org/show_bug.cgi?id=12310
Reported-by: Jim Bray <jimsantelmo@gmail.com>
* 'cpus4096-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
[IA64] fix typo in cpumask_of_pcibus()
x86: fix x86_32 builds for summit and es7000 arch's
cpumask: use work_on_cpu in acpi-cpufreq.c for read_measured_perf_ctrs
cpumask: use work_on_cpu in acpi-cpufreq.c for drv_read and drv_write
cpumask: use cpumask_var_t in acpi-cpufreq.c
cpumask: use work_on_cpu in acpi/cstate.c
cpumask: convert struct cpufreq_policy to cpumask_var_t
cpumask: replace CPUMASK_ALLOC etc with cpumask_var_t
x86: cleanup remaining cpumask_t ops in smpboot code
cpumask: update pci_bus_show_cpuaffinity to use new cpumask API
cpumask: update local_cpus_show to use new cpumask API
ia64: cpumask fix for is_affinity_mask_valid()
It is always "an" if there is a vowel _spoken_ (not written).
So it is:
"an hour" (spoken vowel)
but
"a uniform" (spoken 'j')
Signed-off-by: Frederik Schwarzer <schwarzerf@gmail.com>
Impact: use new cpumask API to reduce memory usage
This is part of an effort to reduce structure sizes for machines
configured with large NR_CPUS. cpumask_t gets replaced by
cpumask_var_t, which is either struct cpumask[1] (small NR_CPUS) or
struct cpumask * (large NR_CPUS).
Signed-off-by: Mike Travis <travis@sgi.com>
Acked-by: Dave Jones <davej@redhat.com>
Previously driver resume would always set the current policy min/max with
the cpuinfo min/max, defined by user_policy.min/max. Resulting in a reset
of policy settings when policy.min/max != cpuinfo.min/max when coming out
of suspend. Now user_policy is saved as the policy instead of cpuinfo to
preserve what the user actually set.
Signed-off-by: Mike Chan <mike@android.com>
p4-clockmod has a long history of abuse. It pretends to be a CPU
frequency scaling driver, even though it doesn't actually change
the CPU frequency, but instead just modulates the frequency with
wait-states.
The biggest misconception is that when running at the lower 'frequency'
p4-clockmod is saving power. This isn't the case, as workloads running
slower take longer to complete, preventing the CPU from entering deep C states.
However p4-clockmod does have a purpose. It can prevent overheating.
Having it hooked up to the cpufreq interfaces is the wrong way to achieve
cooling however. It should instead be hooked up to ACPI.
This diff introduces a means for a cpufreq driver to register with the
cpufreq core, but not present a sysfs interface.
Use get_cpu()/put_cpu() in cpufreq_ondemand init routine, instead of
smp_processor_id() to avoid the following BUG:
[ 35.313118] BUG: using smp_processor_id() in preemptible [00000000] code=: modprobe/4952
[ 35.313132] caller is cpufreq_gov_dbs_init+0xa/0x8f [cpufreq_ondemand]
[ 35.313140] Pid: 4952, comm: modprobe Not tainted 2.6.27-rc5-mm1 #23
[ 35.313145] Call Trace:
[ 35.313158] [<ffffffff80361ff7>] debug_smp_processor_id+0xd7/0xe0
[ 35.313167] [<ffffffffa010800a>] cpufreq_gov_dbs_init+0xa/0x8f [cpufreq_ondemand]
[ 35.313176] [<ffffffff8020903b>] _stext+0x3b/0x160
[ 35.313185] [<ffffffff804768c5>] __mutex_unlock_slowpath+0xe5/0x190
[ 35.313195] [<ffffffff8026236a>] trace_hardirqs_on_caller+0xca/0x140
[ 35.313205] [<ffffffff8026ef4c>] sys_init_module+0xdc/0x210
[ 35.313212] [<ffffffff8020b7cb>] system_call_fastpath+0x16/0x1b
Signed-off-by: Andrea Righi <righi.andrea@gmail.com>
We don't need to export the governors for use as the default governor,
because the default governor will be built-in anyway and we can access
the symbol directly.
This also fixes the following sparse warnings:
drivers/cpufreq/cpufreq_conservative.c:578:25: warning: symbol 'cpufreq_gov_conservative' was not declared. Should it be static?
drivers/cpufreq/cpufreq_ondemand.c:582:25: warning: symbol 'cpufreq_gov_ondemand' was not declared. Should it be static?
drivers/cpufreq/cpufreq_performance.c:39:25: warning: symbol 'cpufreq_gov_performance' was not declared. Should it be static?
drivers/cpufreq/cpufreq_powersave.c:38:25: warning: symbol 'cpufreq_gov_powersave' was not declared. Should it be static?
drivers/cpufreq/cpufreq_userspace.c:190:25: warning: symbol 'cpufreq_gov_userspace' was not declared. Should it be static?
Signed-off-by: Sven Wegener <sven.wegener@stealer.net>
Use get_cpu_idle_time_us() to get micro-accounted idle information.
This enables ondemand to get more accurate idle and busy timings
than the jiffy based calculation. As a result, we can decrease
the ondemand safety gaurd band from 80-10 to 95-3.
Results in more aggressive power savings.
Use a parameter for down differential, instead of hardcoded 10%. Follow-on
patch changes the down-differential dynamically, based on whether
we are using idle micro-accounting or not.
idle-microaccounting
Preparatory changes for doing idle micro-accounting in ondemand governor.
get_cpu_idle_time() gets extra parameter and returns idle time and also the
wall time that corresponds to the idle time measurement.
coordination
Change the load calculation algorithm in ondemand to work well with software
coordination of frequency across the dependent cpus.
Multiply individual CPU utilization with the average freq of that logical CPU
during the measurement interval (using getavg call). And find the max CPU
utilization number in terms of CPU freq. That number is then used to
get to the target freq for next sampling interval.
Add a cpu parameter to __cpufreq_driver_getavg(). This is needed for software
cpufreq coordination where policy->cpu may not be same as the CPU on which we
want to getavg frequency.
A follow-on patch will use this parameter to getavg freq from all cpus
in policy->cpus.
Change since last patch. Fix the offline/online and suspend/resume
oops reported by Youquan Song <youquan.song@intel.com>
Venki Pallipadi made a similar change to the ondemand governor a while
back (in commit 28287033e12463c8ff89f1ea8038783d0360391c). It seems to
work just as well in the conservative governor, leading to fewer wakeups
as reported by powertop.
Signed-off-by: Ben Slusky <sluskyb@paranoiacs.org>
cpufreq_cpu_put
After calling cpufreq_cpu_get, error handling code should call
cpufreq_cpu_put.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@r@
expression x,E;
statement S;
position p1,p2,p3;
if ((x = cpufreq_cpu_get@p1(...)) == NULL || ...) S
... when != x
if (x == NULL || ...) S
if@p3 (...) { ... when != cpufreq_cpu_put(x)
when != if (x) { ... cpufreq_cpu_put(x); ...}
return@p2 ...;
return x;
return 0;
x = E
E = x
cpufreq_cpu_put(x)
@exists@
position r.p1,r.p2,r.p3;
expression x;
int ret != 0;
statement S;
* x = cpufreq_cpu_get@p1(...)
* if@p3 (...)
S
* return@p2 \(NULL\|ret\);
// </smpl>
Add error handling for cpufreq_register_governor() error
Cc: cpufreq@lists.linux.org.uk
