path: root/drivers/cpufreq
2012-05-02ARM: ux500: core U9540 supportLinus Walleij
This adds support for the U9540 variant of the U8500 series. This is an application processor without internal modem. This is the most basic part with ASIC ID, CPU-related fixes, IRQ list, register ranges, timer, UART, and L2 cache setup. This is based on a patch by Michel Jaouen which was rewritten to fit with the latest 3.3 kernel. ChangeLog v1->v2: deleted the irqs-db9540.h file since we expect to migrate to using Device Tree for getting the IRQs to devices. ChangeLog v2->v3: introduced a fixed virtual offset for the ROM as suggested by Arnd Bergmann. Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Sebastien Pasdeloup <sebastien.pasdeloup-nonst@stericsson.com> Signed-off-by: Michel Jaouen <michel.jaouen@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-04-13cpufreq: OMAP: fix build errors: depends on ARCH_OMAP2PLUSKevin Hilman
The OMAP driver needs a 'depends on ARCH_OMAP2PLUS' since it only builds for OMAP2+ platforms. This 'depends on' was in the original patch from Russell King, but was erroneously removed by me when making this option user-selectable in commit b09db45c (cpufreq: OMAP driver depends CPUfreq tables.) This patch remedies that. Apologies to Russell King for breaking his originally working patch. Also, thanks to Grazvydas Ignotas for reporting the same problem. Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-05Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: SoC fixes: from Olof Johansson: "A bunch of fixes for regressions (and a few other problems) in 3.4-rc1: - Fix for regression of mach/io.h cleanup on platforms with PCI or PCMCIA (adding back the include file on those for now) - AT91 fixes for usb and spi - smsc911x ethernet fixes for i.MX - smsc911x fixes for OMAP - gpio fixes for Tegra - A handful of build error and warning fixes for various platforms - cpufreq kconfig dependencies, build and lowlevel debug fixes for Samsung platforms In other words, more or less the regular collection of -rc1/2 type material. A few of them, in particular the smsc911x for OMAP series, aren't technically regressions for 3.4, but they're valid fixes and we're still relatively early in the rc cycle so it seems appropriate to include them." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (60 commits) ARM: fix __io macro for PCMCIA ARM: EXYNOS: Fix compiler warning in dma.c file ARM: EXYNOS: fix ISO C90 warning ARM: OMAP2+: hwmod: Fix wrong SYSC_TYPE1_XXX_MASK bit definitions ARM: OMAP2+: hwmod: Make omap_hwmod_softreset wait for reset status ARM: OMAP2+: hwmod: Restore sysc after a reset ARM: OMAP2+: omap_hwmod: Allow io_ring wakeup configuration for all modules ARM: OMAP3: clock data: fill in some missing clockdomains ARM: OMAP4: clock data: Force a DPLL clkdm/pwrdm ON before a relock ARM: OMAP4: clock data: fix mult and div mask for USB_DPLL ARM: OMAP2+: powerdomain: Wait for powerdomain transition in pwrdm_state_switch() gpio: tegra: Iterate over the correct number of banks gpio: tegra: fix register address calculations for Tegra30 EXYNOS: fix dependency for EXYNOS_CPUFREQ ARM: at91: dt: remove unit-address part for memory nodes ARM: at91: fix check of valid GPIO for SPI and USB USB: ehci-atmel: add needed of.h header file ARM: at91/NAND DT bindings: add comments ARM: at91/at91sam9x5.dtsi: fix NAND ale/cle in DT file USB: ohci-at91: trivial return code name change ...
2012-04-04EXYNOS: fix dependency for EXYNOS_CPUFREQKukjin Kim
This fixes the CPUFREQ dependency for regarding EXYNOS SoCs such as EXYNOS4210, EXYNOS4X12 and EXYNOS5250. Its cpufreq driver should be built with selection of SoC arch part. Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-03-29drivers/cpufreq/db8500-cpufreq: remove references to cpu_*_map.Rusty Russell
This has been obsolescent for a while; time for the final push. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Dave Jones <davej@redhat.com> Cc: cpufreq@vger.kernel.org Cc: Sundar Iyer <sundar.iyer@stericsson.com> Cc: Martin Persson <martin.persson@stericsson.com> Cc: Jonas Aaberg <jonas.aberg@stericsson.com>
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Merge tag 'mfd_3.4-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFD changes from Samuel Ortiz: - 4 new drivers: Freescale i.MX on-chip Anatop, Ricoh's RC5T583 and TI's TPS65090 and TPS65217. - New variants support (8420, 8520 ab9540), cleanups and bug fixes for the abx500 and db8500 ST-E chipsets. - Some minor fixes and update for the wm8994 from Mark. - The beginning of a long term TWL cleanup effort coming from the TI folks. - Various fixes and cleanups for the s5m, TPS659xx, pm860x, and MAX8997 drivers. Fix up trivial conflicts due to duplicate patches and header file cleanups (<linux/device.h> removal etc). * tag 'mfd_3.4-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (97 commits) gpio/twl: Add DT support to gpio-twl4030 driver gpio/twl: Allocate irq_desc dynamically for SPARSE_IRQ support mfd: Detach twl6040 from the pmic mfd driver mfd: Replace twl-* pr_ macros by the dev_ equivalent and do various cleanups mfd: Micro-optimization on twl4030 IRQ handler mfd: Make twl4030 SIH SPARSE_IRQ capable mfd: Move twl-core IRQ allocation into twl[4030|6030]-irq files mfd: Remove references already defineid in header file from twl-core mfd: Remove unneeded header from twl-core mfd: Make twl-core not depend on pdata->irq_base/end ARM: OMAP2+: board-omap4-*: Do not use anymore TWL6030_IRQ_BASE in board files mfd: Return twl6030_mmc_card_detect IRQ for board setup Revert "mfd: Add platform data for MAX8997 haptic driver" mfd: Add support for TPS65090 mfd: Add some da9052-i2c section annotations mfd: Build rtc5t583 only if I2C config is selected to y. mfd: Add anatop mfd driver mfd: Fix compilation error in tps65910.h mfd: Add 8420 variant to db8500-prcmu mfd: Add 8520 PRCMU variant to db8500-prcmu ...
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-23Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq Pull cpufreq updates for 3.4 from Dave Jones: new drivers and some fixes. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: provide disable_cpufreq() function to disable the API. EXYNOS5250: Add support cpufreq for EXYNOS5250 EXYNOS4X12: Add support cpufreq for EXYNOS4X12 [CPUFREQ] CPUfreq ondemand: update sampling rate without waiting for next sampling [CPUFREQ] Add S3C2416/S3C2450 cpufreq driver [CPUFREQ] Fix exposure of ARM_EXYNOS4210_CPUFREQ [CPUFREQ] EXYNOS4210: update the name of EXYNOS clock register [CPUFREQ] EXYNOS: Initialize locking_frequency with initial frequency [CPUFREQ] s3c64xx: Fix mis-cherry pick of VDDINT Fix up trivial conflicts in Kconfig and Makefile due to just changes next to each other (OMAP2PLUS changes vs some new EXYNOS cpufreq drivers).
2012-03-23Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq Pull cpufreq fixes from Dave Jones: "I meant to get some of these in for 3.3 final, but left things too late, so I've got two trees this time." * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: cpufreq: OMAP: specify range for voltage scaling cpufreq: OMAP: scale voltage along with frequency cpufreq: OMAP driver depends CPUfreq tables
2012-03-14provide disable_cpufreq() function to disable the API.Konrad Rzeszutek Wilk
useful for disabling cpufreq altogether. The cpu frequency scaling drivers and cpu frequency governors will fail to register. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Dave Jones <davej@redhat.com>
2012-03-14EXYNOS5250: Add support cpufreq for EXYNOS5250Jaecheol Lee
This patch adds support cpufreq for EXYNOS5250 SoC. Basically, the exynos-cpufreq.c is used commonly and exynos5250-cpufreq.c is used for EXYNOS5250(two Cortex-A15 cores) SoC. Signed-off-by: Jaecheol Lee <jc.lee@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2012-03-14EXYNOS4X12: Add support cpufreq for EXYNOS4X12Jaecheol Lee
This patch adds support cpufreq for EXYNOS4X12 SoCs. Basically, the exynos-cpufreq.c is used commonly and exynos4x12-cpufreq.c is used for EXYNOS4212(two Cortex-A9 cores) and EXYNOS4412(four Cortex-A9 cores) SoCs. Signed-off-by: Jaecheol Lee <jc.lee@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2012-03-06mfd: Remove db8500-prcmu U8400 legacyDaniel Willerud
This removes the U8400 legacy from PRCMU and cpufreq drivers. This platform has no current in-kernel users. Signed-off-by: Daniel Willerud <daniel.willerud@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-03-02cpufreq: OMAP: specify range for voltage scalingAfzal Mohammed
Specify voltage in ranges for regulator. Range used is tolerance specified for OPP. This helps to achieve DVFS with a wider range of regulators. Cc: Kevin Hilman <khilman@ti.com> Cc: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Afzal Mohammed <afzal@ti.com>
2012-02-29[CPUFREQ] CPUfreq ondemand: update sampling rate without waiting for next ↵MyungJoo Ham
sampling When a new sampling rate is shorter than the current one, (e.g., 1 sec --> 10 ms) regardless how short the new one is, the current ondemand mechanism wait for the previously set timer to be expired. For example, if the user has just expressed that the sampling rate should be 10 ms from now and the previous was 1000 ms, the new rate may become effective 999 ms later, which could be not acceptable for the user if the user has intended to speed up sampling because the system is expected to react to CPU load fluctuation quickly from __now__. In order to address this issue, we need to cancel the previously set timer (schedule_delayed_work) and reset the timer if resetting timer is expected to trigger the delayed_work ealier. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2012-02-29[CPUFREQ] Add S3C2416/S3C2450 cpufreq driverHeiko Stübner
The S3C2416/S3C2450 SoCs support two sources for the armclk. The first source is the so called armdiv which divides the msysclk down to provide necessary cpu rates. In this mode the core voltage must be always at 1.3V. The frequency from the armdiv is not allowed to be lower than the hclk frequency. In the second mode the armclk can be sourced directly from the hclk in the so called "dynamic voltags scaling" (dvs) mode. Here the armdiv isn't used at all. Also in this mode the core voltage may be lowered. Existing hardware and tests with it suggest 1.0V as sufficient. When changing the clock source to the armdiv from the hclk, the SoC shows stability issues if the new frequency is higher than the current hclk frequency. Hence the driver always forces the armdiv to the hclk frequency before the source change and lets the cpufreq issue another set_target call for higher frequencies. To mark the hclk frequency as lower as the corresponding armdiv frequency it is set 1MHz below the real frequency. This lets the cpufreq framework change between 133MHz based on hclk and 133MHz based on armdiv at will. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Tested-by: Andrey Gusakov <dron0gus@gmail.com> Signed-off-by: Dave Jones <davej@redhat.com>
2012-02-29[CPUFREQ] Fix exposure of ARM_EXYNOS4210_CPUFREQRussell King
exynos4210-cpufreq.c is not buildable on non-exynos builds, so it's pointless allowing this option to be exposed. Fix this by adding a dependency on ARCH_EXYNOS. drivers/cpufreq/exynos4210-cpufreq.c:20:29: error: mach/regs-clock.h: No such file or directory drivers/cpufreq/exynos4210-cpufreq.c:21:26: error: mach/cpufreq.h: No such file or directory Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: cpufreq@vger.kernel.org Cc: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2012-02-29[CPUFREQ] EXYNOS4210: update the name of EXYNOS clock registerKukjin Kim
According to replacing the name of EXYNOS clock registers, this patch updates exynos4210-cpufreq.c file where it is used. Cc: Jaecheol Lee <jc.lee@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2012-02-29[CPUFREQ] EXYNOS: Initialize locking_frequency with initial frequencyTushar Behera
As per definition, locking_frequency is the initial frequency which is set by boot-loader. Hence the value is updated with the initial value during boot time init call. This code was present in exynos210-cpufreq.c before this consolidation patch. - a125a17fa61a ([CPUFREQ] EXYNOS: Make EXYNOS common cpufreq driver). Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Signed-off-by: Dave Jones <davej@redhat.com>
2012-02-29[CPUFREQ] s3c64xx: Fix mis-cherry pick of VDDINTMark Brown
We don't have any of the other code for VDDINT, including the variable declaration, so don't try to get it as we can't build. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dave Jones <davej@redhat.com>
2012-02-21cpufreq: OMAP: scale voltage along with frequencyKevin Hilman
Use the regulator framework to get the voltage regulator associated with the MPU voltage domain and use it to scale voltage along with frequency. While here, CONFIG_CPU_FREQ_DEBUG doesn't exist anymore, so move debug prints to use dev_dbg(). Special thanks to Afzal Mohammed for suggestions on more robust error checking. Cc: Afzal Mohammed <afzal@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
2012-02-21cpufreq: OMAP driver depends CPUfreq tablesRussell King
The OMAP driver depends on CPUfreq table support for creating a table of frequencies from the OPP layer. Ensure that it's build to avoid link-time errors. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> [khilman@ti.com: make user-selectable, but default y] Signed-off-by: Kevin Hilman <khilman@ti.com>
2012-02-13powernow-k6: Really enable auto-loadingBen Hutchings
Commit fa8031aefec0cf7ea6c2387c93610d99d9659aa2 ('cpufreq: Add support for x86 cpuinfo auto loading v4') added a device ID table to this driver, but didn't declare it as the module device ID table. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Thomas Renninger <trenn@suse.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-13powernow-k7: Fix CPU family numberBen Hutchings
Commit fa8031aefec0cf7ea6c2387c93610d99d9659aa2 ('cpufreq: Add support for x86 cpuinfo auto loading v4') seems to have inadvertently changed the matched CPU family number from 6 to 7. Change it back. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Thomas Renninger <trenn@suse.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-02cpufreq/gx: Fix the compile errorAlan Cox
Someone forgot to test this one it seems. Signed-off-by: Alan Cox <alan@linux.intel.com> Acked-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-26cpufreq: Add support for x86 cpuinfo auto loading v4Andi Kleen
This marks all the x86 cpuinfo tables to the CPU specific device drivers, to allow auto loading by udev. This should simplify the distribution startup scripts for this greatly. I didn't add MODULE_DEVICE_IDs to the centrino and p4-clockmod drivers, because those probably shouldn't be auto loaded and the acpi driver be used instead (not fully sure on that, would appreciate feedback) The old nforce drivers autoload based on the PCI ID. ACPI cpufreq is autoloaded in another patch. v3: Autoload gx based on PCI IDs only. Remove cpu check (Dave Jones) v4: Use newly introduce HW_PSTATE feature for powernow-k8 loading Cc: Dave Jones <davej@redhat.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-11Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: (23 commits) [CPUFREQ] EXYNOS: Removed useless headers and codes [CPUFREQ] EXYNOS: Make EXYNOS common cpufreq driver [CPUFREQ] powernow-k8: Update copyright, maintainer and documentation information [CPUFREQ] powernow-k8: Fix indexing issue [CPUFREQ] powernow-k8: Avoid Pstate MSR accesses on systems supporting CPB [CPUFREQ] update lpj only if frequency has changed [CPUFREQ] cpufreq:userspace: fix cpu_cur_freq updation [CPUFREQ] Remove wall variable from cpufreq_gov_dbs_init() [CPUFREQ] EXYNOS4210: cpufreq code is changed for stable working [CPUFREQ] EXYNOS4210: Update frequency table for cpu divider [CPUFREQ] EXYNOS4210: Remove code about bus on cpufreq [CPUFREQ] s3c64xx: Use pr_fmt() for consistent log messages cpufreq: OMAP: fixup for omap_device changes, include <linux/module.h> cpufreq: OMAP: fix freq_table leak cpufreq: OMAP: put clk if cpu_init failed cpufreq: OMAP: only supports OPP library cpufreq: OMAP: dont support !freq_table cpufreq: OMAP: deny initialization if no mpudev cpufreq: OMAP: move clk name decision to init cpufreq: OMAP: notify even with bad boot frequency ...
2012-01-08[CPUFREQ] EXYNOS: Removed useless headers and codesJaecheol Lee
This patch removes no referencing header files and cleaned up useless code. Signed-off-by: Jaecheol Lee <jc.lee@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2012-01-08[CPUFREQ] EXYNOS: Make EXYNOS common cpufreq driverJaecheol Lee
To support various EXYNOS series SoCs commonly, added exynos common structure. exynos-cpufreq.c => EXYNOS series common cpufreq driver exynos4210-cpufreq.c => EXYNOS4210 support cpufreq driver Signed-off-by: Jaecheol Lee <jc.lee@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2012-01-07Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (73 commits) arm: fix up some samsung merge sysdev conversion problems firmware: Fix an oops on reading fw_priv->fw in sysfs loading file Drivers:hv: Fix a bug in vmbus_driver_unregister() driver core: remove __must_check from device_create_file debugfs: add missing #ifdef HAS_IOMEM arm: time.h: remove device.h #include driver-core: remove sysdev.h usage. clockevents: remove sysdev.h arm: convert sysdev_class to a regular subsystem arm: leds: convert sysdev_class to a regular subsystem kobject: remove kset_find_obj_hinted() m86k: gpio - convert sysdev_class to a regular subsystem mips: txx9_sram - convert sysdev_class to a regular subsystem mips: 7segled - convert sysdev_class to a regular subsystem sh: dma - convert sysdev_class to a regular subsystem sh: intc - convert sysdev_class to a regular subsystem power: suspend - convert sysdev_class to a regular subsystem power: qe_ic - convert sysdev_class to a regular subsystem power: cmm - convert sysdev_class to a regular subsystem s390: time - convert sysdev_class to a regular subsystem ... Fix up conflicts with 'struct sysdev' removal from various platform drivers that got changed: - arch/arm/mach-exynos/cpu.c - arch/arm/mach-exynos/irq-eint.c - arch/arm/mach-s3c64xx/common.c - arch/arm/mach-s3c64xx/cpu.c - arch/arm/mach-s5p64x0/cpu.c - arch/arm/mach-s5pv210/common.c - arch/arm/plat-samsung/include/plat/cpu.h - arch/powerpc/kernel/sysfs.c and fix up cpu_is_hotpluggable() as per Greg in include/linux/cpu.h
2012-01-06Merge branch 'driver-core-next' into Linux 3.2Greg Kroah-Hartman
This resolves the conflict in the arch/arm/mach-s3c64xx/s3c6400.c file, and it fixes the build error in the arch/x86/kernel/microcode_core.c file, that the merge did not catch. The microcode_core.c patch was provided by Stephen Rothwell <sfr@canb.auug.org.au> who was invaluable in the merge issues involved with the large sysdev removal process in the driver-core tree. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06[CPUFREQ] powernow-k8: Update copyright, maintainer and documentation ↵Andreas Herrmann
information Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Signed-off-by: Dave Jones <davej@redhat.com>
2012-01-06[CPUFREQ] powernow-k8: Fix indexing issueAndreas Herrmann
The driver uses the pstate number from the status register as index in its table of ACPI pstates (powernow_table). This is wrong as this is not a 1-to-1 mapping. For example we can have _PSS information to just utilize Pstate 0 and Pstate 4, ie. powernow-k8: Core Performance Boosting: on. powernow-k8: 0 : pstate 0 (2200 MHz) powernow-k8: 1 : pstate 4 (1400 MHz) In this example the driver's powernow_table has just 2 entries. Using the pstate number (4) as index into this table is just plain wrong. Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Signed-off-by: Dave Jones <davej@redhat.com>
2012-01-06[CPUFREQ] powernow-k8: Avoid Pstate MSR accesses on systems supporting CPBAndreas Herrmann
Due to CPB we can't directly map SW Pstates to Pstate MSRs. Get rid of the paranoia check. (assuming that the ACPI Pstate information is correct.) Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Signed-off-by: Dave Jones <davej@redhat.com>
2012-01-06[CPUFREQ] update lpj only if frequency has changedAfzal Mohammed
During scaling up of cpu frequency, loops_per_jiffy is updated upon invoking PRECHANGE notifier. If setting to new frequency fails in cpufreq driver, lpj is left at incorrect value. Hence update lpj only if cpu frequency is changed, i.e. upon invoking POSTCHANGE notifier. Penalty would be that during time period between changing cpu frequency & invocation of POSTCHANGE notifier, udelay(x) may not gurantee minimal delay of 'x' us for frequency scaling up operation. Perhaps a better solution would be to define CPUFREQ_ABORTCHANGE & handle accordingly, but then it would be more intrusive (using ABORTCHANGE may help drivers also; if any has registered notifier and expect POST for a PRECHANGE, their needs can be taken care using ABORT) Signed-off-by: Afzal Mohammed <afzal@ti.com> Signed-off-by: Dave Jones <davej@redhat.com>
2012-01-06[CPUFREQ] cpufreq:userspace: fix cpu_cur_freq updationAfzal Mohammed
CPU frequency is guranteed to be changed on notifier callback with CPUFREQ_POSTCHANGE. Notifier callback with CPUFREQ_PRECHANGE does not gurantee a change in frequency; after it, if cpufreq driver is unable to change CPU to new frequency. This results in wrong information being fed to user (if setting CPU frequency fails) upon doing like, cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed Hence in userspace governer update cpu_cur_freq only if notifier has been called with POSTCHANGE. Signed-off-by: Afzal Mohammed <afzal@ti.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-12-21cpu: convert 'cpu' and 'machinecheck' sysdev_class to a regular subsystemKay Sievers
This moves the 'cpu sysdev_class' over to a regular 'cpu' subsystem and converts the devices to regular devices. The sysdev drivers are implemented as subsystem interfaces now. After all sysdev classes are ported to regular driver core entities, the sysdev implementation will be entirely removed from the kernel. Userspace relies on events and generic sysfs subsystem infrastructure from sysdev devices, which are made available with this conversion. Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Borislav Petkov <bp@amd64.org> Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Cc: Len Brown <lenb@kernel.org> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Dave Jones <davej@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-19Merge branch 'sched/core' of ↵Martin Schwidefsky
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into cputime-tip Conflicts: drivers/cpufreq/cpufreq_conservative.c drivers/cpufreq/cpufreq_ondemand.c drivers/macintosh/rack-meter.c fs/proc/stat.c fs/proc/uptime.c kernel/sched/core.c
2011-12-15[S390] cputime: add sparse checking and cleanupMartin Schwidefsky
Make cputime_t and cputime64_t nocast to enable sparse checking to detect incorrect use of cputime. Drop the cputime macros for simple scalar operations. The conversion macros are still needed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-12-09[CPUFREQ] Remove wall variable from cpufreq_gov_dbs_init()Kamalesh Babulal
CPUFREQ Remove wall variable from cpufreq_gov_dbs_init() Remove wall variable from cpufreq_gov_dbs_init() as get_cpu_idle_time_us() no longer updates the last_update_time unconditionally. Passing non-NULL last_update_time address will result in accounting additional idle time with update_ts_time_stats() before returning idle_sleeptime. Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Dave Jones <davej@redhat.com> -- drivers/cpufreq/cpufreq_ondemand.c | 3 +-- 1 files changed, 1 insertions(+), 2 deletions(-)
2011-12-09[CPUFREQ] EXYNOS4210: cpufreq code is changed for stable workingJaecheol Lee
This patch is modify code for stable working 1. Remove unused register access code 2. Change sequence for frequency changing Signed-off-by: Jaecheol Lee <jc.lee@samsung.com> Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Jongpill Lee <boyko.lee@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-12-09[CPUFREQ] EXYNOS4210: Update frequency table for cpu dividerJaecheol Lee
This patch is changes frequency table for cpu divider for stable frequency. Signed-off-by: Jaecheol Lee <jc.lee@samsung.com> Signed-off-by: Jongpill Lee <boyko.lee@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-12-09[CPUFREQ] EXYNOS4210: Remove code about bus on cpufreqJaecheol Lee
This patch removes code for bus on cpufreq because the code for bus frequency changing moves to busfreq driver. So code about bus on cpufreq is not necessary. Signed-off-by: Jaecheol Lee <jc.lee@samsung.com> Signed-off-by: Jongpill Lee <boyko.lee@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-12-09[CPUFREQ] s3c64xx: Use pr_fmt() for consistent log messagesMark Brown
They're already consistent but it saves remembering to do so. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-12-06sched/accounting: Change cpustat fields to an arrayGlauber Costa
This patch changes fields in cpustat from a structure, to an u64 array. Math gets easier, and the code is more flexible. Signed-off-by: Glauber Costa <glommer@parallels.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Paul Tuner <pjt@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1322498719-2255-2-git-send-email-glommer@parallels.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-02Merge branch 'for_3.3/omap-cpufreq' of ↵Dave Jones
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into next
2011-11-11[CPUFREQ] db8500: fix build error due to undeclared i variableAxel Lin
The variable i is removed by commit ded8433 "[CPUFREQ] db8500: remove unneeded for loop iteration over freq_table", but current code to print available frequencies still uses the i variable. Thus add the i variable back to fix below buld error: CC drivers/cpufreq/db8500-cpufreq.o drivers/cpufreq/db8500-cpufreq.c: In function 'db8500_cpufreq_init': drivers/cpufreq/db8500-cpufreq.c:123: error: 'i' undeclared (first use in this function) drivers/cpufreq/db8500-cpufreq.c:123: error: (Each undeclared identifier is reported only once drivers/cpufreq/db8500-cpufreq.c:123: error: for each function it appears in.) make[2]: *** [drivers/cpufreq/db8500-cpufreq.o] Error 1 make[1]: *** [drivers/cpufreq] Error 2 make: *** [drivers] Error 2 This patch also fixes using uninitialized i variable as array index. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Dave Jones <davej@redhat.com>
2011-11-10cpufreq: OMAP: fixup for omap_device changes, include <linux/module.h>Kevin Hilman
Minor fixups to work starting with v3.2: - use the new omap_device API for getting a device by name. - need to include <linux/module.h> Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-11-08cpufreq: OMAP: fix freq_table leakNishanth Menon
We use a single frequency table for multiple CPUs. But, with OMAP4, since we have multiple CPUs, the cpu_init call for CPU1 causes freq_table previously allocated for CPU0 to be overwritten. In addition, we dont free the table on exit path. We solve this by maintaining an atomic type counter to ensure just a single table exists at a given time. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
