Some hardware have clusters with different idle states. The current code does
not support this and fails as it expects all the idle states to be identical.
Because of this, the Mediatek mtk8173 had to create the same idle state for a
big.Little system and now the Hisilicon 960 is facing the same situation.
Solve this by simply assuming the multiple driver will be needed for all the
platforms using the ARM generic cpuidle driver which makes sense because of the
different topologies we can support with a single kernel for ARM32 or ARM64.
Every CPU has its own driver, so every single CPU can specify in the DT the
idle states.
This simple approach allows to support the future dynamIQ system, current SMP
and HMP.
Tested on:
- 96boards: Hikey 620
- 96boards: Hikey 960
- 96boards: dragonboard410c
- Mediatek 8173
Tested-by: Leo Yan <leo.yan@linaro.org>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
ARM32 and ARM64 have the same DT definitions and the same approaches.
The generic ARM cpuidle driver can be put in common for those two
architectures.
Acked-by: Kevin Hilman <khilman@linaro.org>
Acked-by: Rob Herring <robherring2@gmail.com>
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Tested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
The following patch adds coupled cpuidle support for Exynos4210 to
an existing cpuidle-exynos driver. As a result it enables AFTR mode
to be used by default on Exynos4210 without the need to hot unplug
CPU1 first.
The patch is heavily based on earlier cpuidle-exynos4210 driver from
Daniel Lezcano:
http://www.spinics.net/lists/linux-samsung-soc/msg28134.html
Changes from Daniel's code include:
- porting code to current kernels
- fixing it to work on my setup (by using S5P_INFORM register
instead of S5P_VA_SYSRAM one on Revison 1.1 and retrying poking
CPU1 out of the BOOT ROM if necessary)
- fixing rare lockup caused by waiting for CPU1 to get stuck in
the BOOT ROM (CPU hotplug code in arch/arm/mach-exynos/platsmp.c
doesn't require this and works fine)
- moving Exynos specific code to arch/arm/mach-exynos/pm.c
- using cpu_boot_reg_base() helper instead of BOOT_VECTOR macro
- using exynos_cpu_*() helpers instead of accessing registers
directly
- using arch_send_wakeup_ipi_mask() instead of dsb_sev()
(this matches CPU hotplug code in arch/arm/mach-exynos/platsmp.c)
- integrating separate exynos4210-cpuidle driver into existing
exynos-cpuidle one
Cc: Colin Cross <ccross@google.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Cc: Tomasz Figa <tomasz.figa@gmail.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Signed-off-by: Kukjin Kim <kgene@kernel.org>
Pull ACPI and power management updates from Rafael Wysocki:
"Features-wise, to me the most important this time is a rework of
wakeup interrupts handling in the core that makes them work
consistently across all of the available sleep states, including
suspend-to-idle. Many thanks to Thomas Gleixner for his help with
this work.
Second is an update of the generic PM domains code that has been in
need of some care for quite a while. Unused code is being removed, DT
support is being added and domains are now going to be attached to
devices in bus type code in analogy with the ACPI PM domain. The
majority of work here was done by Ulf Hansson who also has been the
most active developer this time.
Apart from this we have a traditional ACPICA update, this time to
upstream version 20140828 and a few ACPI wakeup interrupts handling
patches on top of the general rework mentioned above. There also are
several cpufreq commits including renaming the cpufreq-cpu0 driver to
cpufreq-dt, as this is what implements generic DT-based cpufreq
support, and a new DT-based idle states infrastructure for cpuidle.
In addition to that, the ACPI LPSS driver is updated, ACPI support for
Apple machines is improved, a few bugs are fixed and a few cleanups
are made all over.
Finally, the Adaptive Voltage Scaling (AVS) subsystem now has a tree
maintained by Kevin Hilman that will be merged through the PM tree.
Numbers-wise, the generic PM domains update takes the lead this time
with 32 non-merge commits, second is cpufreq (15 commits) and the 3rd
place goes to the wakeup interrupts handling rework (13 commits).
Specifics:
- Rework the handling of wakeup IRQs by the IRQ core such that all of
them will be switched over to "wakeup" mode in suspend_device_irqs()
and in that mode the first interrupt will abort system suspend in
progress or wake up the system if already in suspend-to-idle (or
equivalent) without executing any interrupt handlers. Among other
things that eliminates the wakeup-related motivation to use the
IRQF_NO_SUSPEND interrupt flag with interrupts which don't really
need it and should not use it (Thomas Gleixner and Rafael Wysocki)
- Switch over ACPI to handling wakeup interrupts with the help of the
new mechanism introduced by the above IRQ core rework (Rafael Wysocki)
- Rework the core generic PM domains code to eliminate code that's
not used, add DT support and add a generic mechanism by which
devices can be added to PM domains automatically during enumeration
(Ulf Hansson, Geert Uytterhoeven and Tomasz Figa).
- Add debugfs-based mechanics for debugging generic PM domains
(Maciej Matraszek).
- ACPICA update to upstream version 20140828. Included are updates
related to the SRAT and GTDT tables and the _PSx methods are in the
METHOD_NAME list now (Bob Moore and Hanjun Guo).
- Add _OSI("Darwin") support to the ACPI core (unfortunately, that
can't really be done in a straightforward way) to prevent
Thunderbolt from being turned off on Apple systems after boot (or
after resume from system suspend) and rework the ACPI Smart Battery
Subsystem (SBS) driver to work correctly with Apple platforms
(Matthew Garrett and Andreas Noever).
- ACPI LPSS (Low-Power Subsystem) driver update cleaning up the code,
adding support for 133MHz I2C source clock on Intel Baytrail to it
and making it avoid using UART RTS override with Auto Flow Control
(Heikki Krogerus).
- ACPI backlight updates removing the video_set_use_native_backlight
quirk which is not necessary any more, making the code check the
list of output devices returned by the _DOD method to avoid
creating acpi_video interfaces that won't work and adding a quirk
for Lenovo Ideapad Z570 (Hans de Goede, Aaron Lu and Stepan Bujnak)
- New Win8 ACPI OSI quirks for some Dell laptops (Edward Lin)
- Assorted ACPI code cleanups (Fabian Frederick, Rasmus Villemoes,
Sudip Mukherjee, Yijing Wang, and Zhang Rui)
- cpufreq core updates and cleanups (Viresh Kumar, Preeti U Murthy,
Rasmus Villemoes)
- cpufreq driver updates: cpufreq-cpu0/cpufreq-dt (driver name change
among other things), ppc-corenet, powernv (Viresh Kumar, Preeti U
Murthy, Shilpasri G Bhat, Lucas Stach)
- cpuidle support for DT-based idle states infrastructure, new ARM64
cpuidle driver, cpuidle core cleanups (Lorenzo Pieralisi, Rasmus
Villemoes)
- ARM big.LITTLE cpuidle driver updates: support for DT-based
initialization and Exynos5800 compatible string (Lorenzo Pieralisi,
Kevin Hilman)
- Rework of the test_suspend kernel command line argument and a new
trace event for console resume (Srinivas Pandruvada, Todd E Brandt)
- Second attempt to optimize swsusp_free() (hibernation core) to make
it avoid going through all PFNs which may be way too slow on some
systems (Joerg Roedel)
- devfreq updates (Paul Bolle, Punit Agrawal, Ãrjan Eide).
- rockchip-io Adaptive Voltage Scaling (AVS) driver and AVS entry
update in MAINTAINERS (Heiko Stübner, Kevin Hilman)
- PM core fix related to clock management (Geert Uytterhoeven)
- PM core's sysfs code cleanup (Johannes Berg)"
* tag 'pm+acpi-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (105 commits)
ACPI / fan: printk replacement
PM / clk: Fix crash in clocks management code if !CONFIG_PM_RUNTIME
PM / Domains: Rename cpu_data to cpuidle_data
cpufreq: cpufreq-dt: fix potential double put of cpu OF node
cpufreq: cpu0: rename driver and internals to 'cpufreq_dt'
PM / hibernate: Iterate over set bits instead of PFNs in swsusp_free()
cpufreq: ppc-corenet: remove duplicate update of cpu_data
ACPI / sleep: Rework the handling of ACPI GPE wakeup from suspend-to-idle
PM / sleep: Rename platform suspend/resume functions in suspend.c
PM / sleep: Export dpm_suspend_late/noirq() and dpm_resume_early/noirq()
ACPICA: Introduce acpi_enable_all_wakeup_gpes()
ACPICA: Clear all non-wakeup GPEs in acpi_hw_enable_wakeup_gpe_block()
ACPI / video: check _DOD list when creating backlight devices
PM / Domains: Move dev_pm_domain_attach|detach() to pm_domain.h
cpufreq: Replace strnicmp with strncasecmp
cpufreq: powernv: Set the cpus to nominal frequency during reboot/kexec
cpufreq: powernv: Set the pstate of the last hotplugged out cpu in policy->cpus to minimum
cpufreq: Allow stop CPU callback to be used by all cpufreq drivers
PM / devfreq: exynos: Enable building exynos PPMU as module
PM / devfreq: Export helper functions for drivers
With the introduction of DT based idle states, CPUidle drivers for ARM
can now initialize idle states data through properties in the device tree.
This patch adds code to the big.LITTLE CPUidle driver to dynamically
initialize idle states data through the updated device tree source file.
Cc: Chander Kashyap <k.chander@samsung.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
mach-kirkwood has been removed, now that kirkwood lives in mach-mvebu.
Use MACH_KIRKWOOD, which is set when kirkwood is built as part of
mach-mvebu.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
Cc: linux-pm@vger.kernel.org
Acked-by: Rafael J. Wysocki <rjw@rjwysocki.net>
Link: https://lkml.kernel.org/r/1409417172-6846-2-git-send-email-andrew@lunn.ch
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Pull ARM SoC platform changes from Olof Johansson:
"This is the bulk of new SoC enablement and other platform changes for
3.17:
- Samsung S5PV210 has been converted to DT and multiplatform
- Clock drivers and bindings for some of the lower-end i.MX 1/2
platforms
- Kirkwood, one of the popular Marvell platforms, is folded into the
mvebu platform code, removing mach-kirkwood
- Hwmod data for TI AM43xx and DRA7 platforms
- More additions of Renesas shmobile platform support
- Removal of plat-samsung contents that can be removed with S5PV210
being multiplatform/DT-enabled and the other two old platforms
being removed
New platforms (most with only basic support right now):
- Hisilicon X5HD2 settop box chipset is introduced
- Mediatek MT6589 (mobile chipset) is introduced
- Broadcom BCM7xxx settop box chipset is introduced
+ as usual a lot other pieces all over the platform code"
* tag 'soc-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (240 commits)
ARM: hisi: remove smp from machine descriptor
power: reset: move hisilicon reboot code
ARM: dts: Add hix5hd2-dkb dts file.
ARM: debug: Rename Hi3716 to HIX5HD2
ARM: hisi: enable hix5hd2 SoC
ARM: hisi: add ARCH_HISI
MAINTAINERS: add entry for Broadcom ARM STB architecture
ARM: brcmstb: select GISB arbiter and interrupt drivers
ARM: brcmstb: add infrastructure for ARM-based Broadcom STB SoCs
ARM: configs: enable SMP in bcm_defconfig
ARM: add SMP support for Broadcom mobile SoCs
Documentation: arm: misc updates to Marvell EBU SoC status
Documentation: arm: add URLs to public datasheets for the Marvell Armada XP SoC
ARM: mvebu: fix build without platforms selected
ARM: mvebu: add cpuidle support for Armada 38x
ARM: mvebu: add cpuidle support for Armada 370
cpuidle: mvebu: add Armada 38x support
cpuidle: mvebu: add Armada 370 support
cpuidle: mvebu: rename the driver from armada-370-xp to mvebu-v7
ARM: mvebu: export the SCU address
big_little CPU idle driver references functions defined in MCPM driver.
Thus make it depend on MCPM to avoid the following errors:
drivers/built-in.o: In function `bl_enter_powerdown':
drivers/cpuidle/cpuidle-big_little.c:134: undefined reference to `mcpm_cpu_powered_up'
drivers/built-in.o: In function `bl_powerdown_finisher':
drivers/cpuidle/cpuidle-big_little.c:104: undefined reference to `mcpm_set_entry_vector'
drivers/cpuidle/cpuidle-big_little.c:111: undefined reference to `mcpm_cpu_suspend'
make: *** [vmlinux] Error 1
Reported-by: Andreas Färber <afaerber@suse.de>
Signed-off-by: Sachin Kamat <sachin.kamat@samsung.com>
next/soc
Merge "mvebu SoC changes for v3.17 (round 4)" from Jason Cooper:
- Armada XP
- Fix return value check in pmsu code
- Document URLs for new public datasheets (Thanks, Marvell & free-electrons!)
- Armada 370/38x
- Add cpuidle support
- mvebu
- Fix build when no platforms are selected
- Update EBU SoC status in docs
* tag 'mvebu-soc-3.17-4' of git://git.infradead.org/linux-mvebu: (21 commits)
ARM: mvebu: make the snoop disabling optional in mvebu_v7_pmsu_idle_prepare()
ARM: mvebu: use a local variable to store the resume address
ARM: mvebu: make the cpuidle initialization more generic
ARM: mvebu: rename the armada_370_xp symbols to mvebu_v7 in pmsu.c
ARM: mvebu: use the common function for Armada 375 SMP workaround
ARM: mvebu: add a common function for the boot address work around
ARM: mvebu: sort the #include of pmsu.c in alphabetic order
ARM: mvebu: split again armada_370_xp_pmsu_idle_enter() in PMSU code
ARM: mvebu: fix return value check in armada_xp_pmsu_cpufreq_init()
clk: mvebu: extend clk-cpu for dynamic frequency scaling
ARM: mvebu: extend PMSU code to support dynamic frequency scaling
arch/arm/mach-mvebu/Kconfig
drivers/cpuidle/cpuidle-armada-370-xp.c
This driver will be able to manage the cpuidle for more SoCs than just
Armada 370 and XP. It will also support Armada 38x and potentially
other SoC of the Marvell Armada EBU family. To take this into account,
this patch renames the driver and its symbols.
It also changes the driver name from cpuidle-armada-370-xp to
cpuidle-armada-xp, because separate platform drivers will be
registered for the other SoC types. This change must be done
simultaneously in the cpuidle driver and in the PMSU code in order to
remain bisectable.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Link: https://lkml.kernel.org/r/1406120453-29291-12-git-send-email-thomas.petazzoni@free-electrons.com
Add support to select generic big-little cpuidle driver for Samsung Exynos
series SoC's. This is required for Exynos big-llittle SoC's eg, Exynos5420.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm into next
"ACPICA is the leader this time (63 commits), followed by cpufreq (28
commits), devfreq (15 commits), system suspend/hibernation (12
commits), ACPI video and ACPI device enumeration (10 commits each).
We have no major new features this time, but there are a few
significant changes of how things work. The most visible one will
probably be that we are now going to create platform devices rather
than PNP devices by default for ACPI device objects with _HID. That
was long overdue and will be really necessary to be able to use the
same drivers for the same hardware blocks on ACPI and DT-based systems
going forward. We're not expecting fallout from this one (as usual),
but it's something to watch nevertheless.
The second change having a chance to be visible is that ACPI video
will now default to using native backlight rather than the ACPI
backlight interface which should generally help systems with broken
Win8 BIOSes. We're hoping that all problems with the native backlight
handling that we had previously have been addressed and we are in a
good enough shape to flip the default, but this change should be easy
enough to revert if need be.
In addition to that, the system suspend core has a new mechanism to
allow runtime-suspended devices to stay suspended throughout system
suspend/resume transitions if some extra conditions are met
(generally, they are related to coordination within device hierarchy).
However, enabling this feature requires cooperation from the bus type
layer and for now it has only been implemented for the ACPI PM domain
(used by ACPI-enumerated platform devices mostly today).
Also, the acpidump utility that was previously shipped as a separate
tool will now be provided by the upstream ACPICA along with the rest
of ACPICA code, which will allow it to be more up to date and better
supported, and we have one new cpuidle driver (ARM clps711x).
The rest is improvements related to certain specific use cases,
cleanups and fixes all over the place.
Specifics:
- ACPICA update to upstream version 20140424. That includes a number
of fixes and improvements related to things like GPE handling,
table loading, headers, memory mapping and unmapping, DSDT/SSDT
overriding, and the Unload() operator. The acpidump utility from
upstream ACPICA is included too. From Bob Moore, Lv Zheng, David
Box, David Binderman, and Colin Ian King.
- Fixes and cleanups related to ACPI video and backlight interfaces
from Hans de Goede. That includes blacklist entries for some new
machines and using native backlight by default.
- ACPI device enumeration changes to create platform devices rather
than PNP devices for ACPI device objects with _HID by default. PNP
devices will still be created for the ACPI device object with
device IDs corresponding to real PNP devices, so that change should
not break things left and right, and we're expecting to see more
and more ACPI-enumerated platform devices in the future. From
Zhang Rui and Rafael J Wysocki.
- Updates for the ACPI LPSS (Low-Power Subsystem) driver allowing it
to handle system suspend/resume on Asus T100 correctly. From
Heikki Krogerus and Rafael J Wysocki.
- PM core update introducing a mechanism to allow runtime-suspended
devices to stay suspended over system suspend/resume transitions if
certain additional conditions related to coordination within device
hierarchy are met. Related PM documentation update and ACPI PM
domain support for the new feature. From Rafael J Wysocki.
- Fixes and improvements related to the "freeze" sleep state. They
affect several places including cpuidle, PM core, ACPI core, and
the ACPI battery driver. From Rafael J Wysocki and Zhang Rui.
- Miscellaneous fixes and updates of the ACPI core from Aaron Lu,
Bjørn Mork, Hanjun Guo, Lan Tianyu, and Rafael J Wysocki.
- Fixes and cleanups for the ACPI processor and ACPI PAD (Processor
Aggregator Device) drivers from Baoquan He, Manuel Schölling, Tony
Camuso, and Toshi Kani.
- System suspend/resume optimization in the ACPI battery driver from
Lan Tianyu.
- OPP (Operating Performance Points) subsystem updates from Chander
Kashyap, Mark Brown, and Nishanth Menon.
- cpufreq core fixes, updates and cleanups from Srivatsa S Bhat,
Stratos Karafotis, and Viresh Kumar.
- Updates, fixes and cleanups for the Tegra, powernow-k8, imx6q,
s5pv210, nforce2, and powernv cpufreq drivers from Brian Norris,
Jingoo Han, Paul Bolle, Philipp Zabel, Stratos Karafotis, and
Viresh Kumar.
- intel_pstate driver fixes and cleanups from Dirk Brandewie, Doug
Smythies, and Stratos Karafotis.
- Enabling the big.LITTLE cpufreq driver on arm64 from Mark Brown.
- Fix for the cpuidle menu governor from Chander Kashyap.
- New ARM clps711x cpuidle driver from Alexander Shiyan.
- Hibernate core fixes and cleanups from Chen Gang, Dan Carpenter,
Fabian Frederick, Pali Rohár, and Sebastian Capella.
- Intel RAPL (Running Average Power Limit) driver updates from Jacob
Pan.
- PNP subsystem updates from Bjorn Helgaas and Fabian Frederick.
- devfreq core updates from Chanwoo Choi and Paul Bolle.
- devfreq updates for exynos4 and exynos5 from Chanwoo Choi and
Bartlomiej Zolnierkiewicz.
- turbostat tool fix from Jean Delvare.
- cpupower tool updates from Prarit Bhargava, Ramkumar Ramachandra
and Thomas Renninger.
- New ACPI ec_access.c tool for poking at the EC in a safe way from
Thomas Renninger"
* tag 'pm+acpi-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (187 commits)
ACPICA: Namespace: Remove _PRP method support.
intel_pstate: Improve initial busy calculation
intel_pstate: add sample time scaling
intel_pstate: Correct rounding in busy calculation
intel_pstate: Remove C0 tracking
PM / hibernate: fixed typo in comment
ACPI: Fix x86 regression related to early mapping size limitation
ACPICA: Tables: Add mechanism to control early table checksum verification.
ACPI / scan: use platform bus type by default for _HID enumeration
ACPI / scan: always register ACPI LPSS scan handler
ACPI / scan: always register memory hotplug scan handler
ACPI / scan: always register container scan handler
ACPI / scan: Change the meaning of missing .attach() in scan handlers
ACPI / scan: introduce platform_id device PNP type flag
ACPI / scan: drop unsupported serial IDs from PNP ACPI scan handler ID list
ACPI / scan: drop IDs that do not comply with the ACPI PNP ID rule
ACPI / PNP: use device ID list for PNPACPI device enumeration
ACPI / scan: .match() callback for ACPI scan handlers
ACPI / battery: wakeup the system only when necessary
power_supply: allow power supply devices registered w/o wakeup source
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next
Pull ARM SoC driver changes from Olof Johansson:
"SoC-near driver changes that we're merging through our tree. Mostly
because they depend on other changes we have staged, but in some cases
because the driver maintainers preferred that we did it this way.
This contains a largeish cleanup series of the omap_l3_noc bus driver,
cpuidle rework for Exynos, some reset driver conversions and a long
branch of TI EDMA fixes and cleanups, with more to come next release.
The TI EDMA cleanups is a shared branch with the dmaengine tree, with
a handful of Davinci-specific fixes on top.
After discussion at last year's KS (and some more on the mailing
lists), we are here adding a drivers/soc directory. The purpose of
this is to keep per-vendor shared code that's needed by different
drivers but that doesn't fit into the MFD (nor drivers/platform)
model. We expect to keep merging contents for this hierarchy through
arm-soc so we can keep an eye on what the vendors keep adding here and
not making it a free-for-all to shove in crazy stuff"
* tag 'drivers-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (101 commits)
cpufreq: exynos: Fix driver compilation with ARCH_MULTIPLATFORM
tty: serial: msm: Remove direct access to GSBI
power: reset: keystone-reset: introduce keystone reset driver
Documentation: dt: add bindings for keystone pll control controller
Documentation: dt: add bindings for keystone reset driver
soc: qcom: fix of_device_id table
ARM: EXYNOS: Fix kernel panic when unplugging CPU1 on exynos
ARM: EXYNOS: Move the driver to drivers/cpuidle directory
ARM: EXYNOS: Cleanup all unneeded headers from cpuidle.c
ARM: EXYNOS: Pass the AFTR callback to the platform_data
ARM: EXYNOS: Move S5P_CHECK_SLEEP into pm.c
ARM: EXYNOS: Move the power sequence call in the cpu_pm notifier
ARM: EXYNOS: Move the AFTR state function into pm.c
ARM: EXYNOS: Encapsulate the AFTR code into a function
ARM: EXYNOS: Disable cpuidle for exynos5440
ARM: EXYNOS: Encapsulate boot vector code into a function for cpuidle
ARM: EXYNOS: Pass wakeup mask parameter to function for cpuidle
ARM: EXYNOS: Remove ifdef for scu_enable in pm
ARM: EXYNOS: Move scu_enable in the cpu_pm notifier
ARM: EXYNOS: Use the cpu_pm notifier for pm
Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org>
Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Add the wfi, cpu idle and cpu deep idle power states support for the
Armada XP SoCs.
All the latencies and the power consumption values used at the
"armada_370_xp_idle_driver" structure are preliminary and will be
modified in the future after running some measurements and analysis.
Based on the work of Nadav Haklai.
Signed-off-by: Nadav Haklai <nadavh@marvell.com>
Link: https://lkml.kernel.org/r/1397488214-20685-11-git-send-email-gregory.clement@free-electrons.com
Add cpuidle support for ARM Cirrus Logic CLPS711X CPUs.
This CPU has an unique internal register and write to this location
will put the system into the Idle State by halting the clock to the
processor until an interrupt is generated.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
With the move of kirkwood into mach-mvebu, drivers Kconfig need
tweeking to allow the kirkwood specific drivers to be built.
Acked-by: Mark Brown <broonie@linaro.org>
Acked-by: Kishon Vijay Abraham I <kishon@ti.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Tested-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Bryan Wu <cooloney@gmail.com>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Eduardo Valentin <eduardo.valentin@ti.com>
Pull ACPI and power management updates from Rafael J Wysocki:
- New power capping framework and the the Intel Running Average Power
Limit (RAPL) driver using it from Srinivas Pandruvada and Jacob Pan.
- Addition of the in-kernel switching feature to the arm_big_little
cpufreq driver from Viresh Kumar and Nicolas Pitre.
- cpufreq support for iMac G5 from Aaro Koskinen.
- Baytrail processors support for intel_pstate from Dirk Brandewie.
- cpufreq support for Midway/ECX-2000 from Mark Langsdorf.
- ARM vexpress/TC2 cpufreq support from Sudeep KarkadaNagesha.
- ACPI power management support for the I2C and SPI bus types from Mika
Westerberg and Lv Zheng.
- cpufreq core fixes and cleanups from Viresh Kumar, Srivatsa S Bhat,
Stratos Karafotis, Xiaoguang Chen, Lan Tianyu.
- cpufreq drivers updates (mostly fixes and cleanups) from Viresh
Kumar, Aaro Koskinen, Jungseok Lee, Sudeep KarkadaNagesha, Lukasz
Majewski, Manish Badarkhe, Hans-Christian Egtvedt, Evgeny Kapaev.
- intel_pstate updates from Dirk Brandewie and Adrian Huang.
- ACPICA update to version 20130927 includig fixes and cleanups and
some reduction of divergences between the ACPICA code in the kernel
and ACPICA upstream in order to improve the automatic ACPICA patch
generation process. From Bob Moore, Lv Zheng, Tomasz Nowicki, Naresh
Bhat, Bjorn Helgaas, David E Box.
- ACPI IPMI driver fixes and cleanups from Lv Zheng.
- ACPI hotplug fixes and cleanups from Bjorn Helgaas, Toshi Kani, Zhang
Yanfei, Rafael J Wysocki.
- Conversion of the ACPI AC driver to the platform bus type and
multiple driver fixes and cleanups related to ACPI from Zhang Rui.
- ACPI processor driver fixes and cleanups from Hanjun Guo, Jiang Liu,
Bartlomiej Zolnierkiewicz, Mathieu Rhéaume, Rafael J Wysocki.
- Fixes and cleanups and new blacklist entries related to the ACPI
video support from Aaron Lu, Felipe Contreras, Lennart Poettering,
Kirill Tkhai.
- cpuidle core cleanups from Viresh Kumar and Lorenzo Pieralisi.
- cpuidle drivers fixes and cleanups from Daniel Lezcano, Jingoo Han,
Bartlomiej Zolnierkiewicz, Prarit Bhargava.
- devfreq updates from Sachin Kamat, Dan Carpenter, Manish Badarkhe.
- Operation Performance Points (OPP) core updates from Nishanth Menon.
- Runtime power management core fix from Rafael J Wysocki and update
from Ulf Hansson.
- Hibernation fixes from Aaron Lu and Rafael J Wysocki.
- Device suspend/resume lockup detection mechanism from Benoit Goby.
- Removal of unused proc directories created for various ACPI drivers
from Lan Tianyu.
- ACPI LPSS driver fix and new device IDs for the ACPI platform scan
handler from Heikki Krogerus and Jarkko Nikula.
- New ACPI _OSI blacklist entry for Toshiba NB100 from Levente Kurusa.
- Assorted fixes and cleanups related to ACPI from Andy Shevchenko, Al
Stone, Bartlomiej Zolnierkiewicz, Colin Ian King, Dan Carpenter,
Felipe Contreras, Jianguo Wu, Lan Tianyu, Yinghai Lu, Mathias Krause,
Liu Chuansheng.
- Assorted PM fixes and cleanups from Andy Shevchenko, Thierry Reding,
Jean-Christophe Plagniol-Villard.
* tag 'pm+acpi-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (386 commits)
cpufreq: conservative: fix requested_freq reduction issue
ACPI / hotplug: Consolidate deferred execution of ACPI hotplug routines
PM / runtime: Use pm_runtime_put_sync() in __device_release_driver()
ACPI / event: remove unneeded NULL pointer check
Revert "ACPI / video: Ignore BIOS initial backlight value for HP 250 G1"
ACPI / video: Quirk initial backlight level 0
ACPI / video: Fix initial level validity test
intel_pstate: skip the driver if ACPI has power mgmt option
PM / hibernate: Avoid overflow in hibernate_preallocate_memory()
ACPI / hotplug: Do not execute "insert in progress" _OST
ACPI / hotplug: Carry out PCI root eject directly
ACPI / hotplug: Merge device hot-removal routines
ACPI / hotplug: Make acpi_bus_hot_remove_device() internal
ACPI / hotplug: Simplify device ejection routines
ACPI / hotplug: Fix handle_root_bridge_removal()
ACPI / hotplug: Refuse to hot-remove all objects with disabled hotplug
ACPI / scan: Start matching drivers after trying scan handlers
ACPI: Remove acpi_pci_slot_init() headers from internal.h
ACPI / blacklist: fix name of ThinkPad Edge E530
PowerCap: Fix build error with option -Werror=format-security
arch/arm/mach-omap2/opp.c
drivers/Kconfig
drivers/spi/spi.c
As the cpuidle driver code has no more the dependency with the pm code, the
'standby' callback being passed as a parameter to the device's platform data,
we can move the cpuidle driver in the drivers/cpuidle directory.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
drivers/cpuidle/Kconfig.arm
drivers/cpuidle/Makefile
Following the reorganization of CPU idle drivers configurations into an ARM
specific Kconfig, the existing idle drivers Kconfig entries were renamed and
moved to the Kconfig.arm file. Makefile entries were updated accordingly.
This patch renames the entries in Kconfig.arm and makefile to make the newly
added big.LITTLE CPUidle driver compliant with the new naming convention.
This updates the Calxeda cpuidle driver to use PSCI calls to powergate
cores. This also enables cpuidle for the ECX-2000.
This could possibly become a generic PSCI driver, but there are no other
PSCI users in the kernel other than mach-virt.
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Pull ARM SoC driver update from Kevin Hilman:
"This contains the ARM SoC related driver updates for v3.12. The only
thing this cycle are core PM updates and CPUidle support for ARM's TC2
big.LITTLE development platform"
* tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
cpuidle: big.LITTLE: vexpress-TC2 CPU idle driver
ARM: vexpress: tc2: disable GIC CPU IF in tc2_pm_suspend
drivers: irq-chip: irq-gic: introduce gic_cpu_if_down()
There is no more dependency with arch/arm headers, so we can safely move the
driver to the drivers/cpuidle directory.
Add Kconfig.arm for ARM cpuidle drivers and moves calxeda, kirkwood
and zynq to Kconfig.arm. Like in the cpufreq menu, "CPU Idle" menu
is added to drivers/cpuidle/Kconfig.
Signed-off-by: Sahara <keun-o.park@windriver.com>
