[ Upstream commit 6e88098ca43a3d80ae86908f7badba683c8a0d84 ]
When building without CONFIG_HW_RANDOM_PPC4XX, I hit the following build failure:
drivers/crypto/amcc/crypto4xx_core.c: In function 'crypto4xx_probe':
drivers/crypto/amcc/crypto4xx_core.c:1407:20: error: passing argument 1 of 'ppc4xx_trng_probe' from incompatible pointer type [-Werror=incompatible-pointer-types]
In file included from drivers/crypto/amcc/crypto4xx_core.c:50:0:
drivers/crypto/amcc/crypto4xx_trng.h:28:20: note: expected 'struct crypto4xx_device *' but argument is of type 'struct crypto4xx_core_device *'
drivers/crypto/amcc/crypto4xx_core.c: In function 'crypto4xx_remove':
drivers/crypto/amcc/crypto4xx_core.c:1434:21: error: passing argument 1 of 'ppc4xx_trng_remove' from incompatible pointer type [-Werror=incompatible-pointer-types]
drivers/crypto/amcc/crypto4xx_trng.h:30:20: note: expected 'struct crypto4xx_device *' but argument is of type 'struct crypto4xx_core_device *'
This patch fix the needed argument of ppc4xx_trng_probe()/ppc4xx_trng_remove() in that case.
Fixes: 5343e674f32f ("crypto4xx: integrate ppc4xx-rng into crypto4xx")
Signed-off-by: Corentin Labbe <clabbe@baylibre.com>
commit 746c908c4d72e49068ab216c3926d2720d71a90d upstream.
This patch fixes a crash that can happen during probe
when the available dma memory is not enough (this can
happen if the crypto4xx is built as a module).
The descriptor window mapping would end up being free'd
twice, once in crypto4xx_build_pdr() and the second time
in crypto4xx_destroy_sdr().
Fixes: 5d59ad6eea82 ("crypto: crypto4xx - fix crypto4xx_build_pdr, crypto4xx_build_sdr leak")
Cc: <stable@vger.kernel.org>
Signed-off-by: Christian Lamparter <chunkeey@gmail.com>
commit 95566aa75cd6b3b404502c06f66956b5481194b3 upstream.
There is a possible double free issue in ppc4xx_trng_probe():
85: dev->trng_base = of_iomap(trng, 0);
86: of_node_put(trng); ---> released here
87: if (!dev->trng_base)
88: goto err_out;
110: ierr_out:
111: of_node_put(trng); ---> double released here
This issue was detected by using the Coccinelle software.
We fix it by removing the unnecessary of_node_put().
Signed-off-by: Wen Yang <wen.yang99@zte.com.cn>
Cc: Allison Randal <allison@lohutok.net>
Cc: Armijn Hemel <armijn@tjaldur.nl>
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: linux-crypto@vger.kernel.org
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
[ Upstream commit fc340115ffb8235c1bbd200c28855e6373d0dd1a ]
This patch fixes cts(cbc(aes)) test when cbc-aes-ppc4xx is used.
alg: skcipher: Test 1 failed (invalid result) on encryption for cts(cbc-aes-ppc4xx)
00000000: 4b 10 75 fc 2f 14 1b 6a 27 35 37 33 d1 b7 70 05
00000010: 97
alg: skcipher: Failed to load transform for cts(cbc(aes)): -2
The CTS cipher mode expect the IV (req->iv) of skcipher_request
to contain the last ciphertext block after the {en,de}crypt
operation is complete.
Fix this issue for the AMCC Crypto4xx hardware engine.
The tcrypt test case for cts(cbc(aes)) is now correctly passed.
driver : cts(cbc-aes-ppc4xx)
module : cts
priority : 300
refcnt : 1
selftest : passed
internal : no
type : skcipher
async : yes
blocksize : 16
min keysize : 16
max keysize : 32
ivsize : 16
chunksize : 16
walksize : 16
[ Upstream commit 8c2b43d2d85b48a97d2f8279278a4aac5b45f925 ]
Add an of_node_put when a tested device node is not available.
The semantic patch that fixes this problem is as follows
(http://coccinelle.lip6.fr):
// <smpl>
identifier f;
local idexpression e;
expression x;
e = f(...);
... when != of_node_put(e)
when != x = e
when != e = x
when any
if (<+...of_device_is_available(e)...+>) {
return e;
+ of_node_put(e);
return ...;
// </smpl>
Fixes: 5343e674f32fb ("crypto4xx: integrate ppc4xx-rng into crypto4xx")
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
commit 5d59ad6eea82ef8df92b4109615a0dde9d8093e9 upstream.
If one of the later memory allocations in rypto4xx_build_pdr()
fails: dev->pdr (and/or) dev->pdr_uinfo wouldn't be freed.
crypto4xx_build_sdr() has the same issue with dev->sdr.
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit a728a196d253530f17da5c86dc7dfbe58c5f7094 upstream.
alg entries are only added to the list, after the registration
was successful. If the registration failed, it was never added
to the list in the first place.
[ Upstream commit 778f81d6cdb7d25360f082ac0384d5103f04eca5 ]
If crypto4xx is used in conjunction with dm-crypt, the available
ring buffer elements are not enough to handle the load properly.
On an aes-cbc-essiv:sha256 encrypted swap partition the read
performance is abyssal: (tested with hdparm -t)
/dev/mapper/swap_crypt:
Timing buffered disk reads: 14 MB in 3.68 seconds = 3.81 MB/sec
The patch increases both PPC4XX_NUM_SD and PPC4XX_NUM_PD to 256.
This improves the performance considerably:
Timing buffered disk reads: 104 MB in 3.03 seconds = 34.31 MB/sec
Furthermore, PPC4XX_LAST_SD, PPC4XX_LAST_GD and PPC4XX_LAST_PD
can be easily calculated from their respective PPC4XX_NUM_*
constant.
This patch integrates the ppc4xx-rng driver into the existing
crypto4xx. This is because the true random number generator
is controlled and part of the security core.
The sg_nents_for_len() function could fail, this patch add a check for
its return value.
Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com>
The get_sg_count function of amcc is the same as sg_nents_for_len from
lib/scatterlist.c
This platform driver has a OF device ID table but the OF module
alias information is not created so module autoloading won't work.
Signed-off-by: Luis de Bethencourt <luis@debethencourt.com>
Compare pointer-typed values to NULL rather than 0.
The semantic patch that makes this change is available
in scripts/coccinelle/null/badzero.cocci
Even if bus is not hot-pluggable, the devices can be bound and unbound
from the driver via sysfs, so we should not be using __init/__exit
annotations on probe() and remove() methods. The only exception is
drivers registered with platform_driver_probe() which specifically
disables sysfs bind/unbind attributes.
Remove the function get_dynamic_sa_offset_iv_field() that is not used anywhere.
This was partially found by using a static code analysis program called cppcheck.
Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
References to __exit functions must be wrapped with __exit_p.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Cc: Robert Jennings <rcj@linux.vnet.ibm.com>
Cc: Marcelo Henrique Cerri <mhcerri@linux.vnet.ibm.com>
Cc: Fionnuala Gunter <fin@linux.vnet.ibm.com>
Driver core sets it to NULL upon probe failure or release.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Commit b5b4bb3f6a11f9 (of: only include prom.h on sparc) removed implicit
includes of of_*.h headers by powerpc's prom.h. Some components were
missed in initial clean-up patch, so add the necessary includes to fix
powerpc builds.
Cc: Tejun Heo <tj@kernel.org>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: linux-ide@vger.kernel.org
These local symbols are used only in this file.
Fix the following sparse warnings:
drivers/crypto/amcc/crypto4xx_alg.c:35:6: warning: symbol 'set_dynamic_sa_command_0' was not declared. Should it be static?
drivers/crypto/amcc/crypto4xx_alg.c:55:6: warning: symbol 'set_dynamic_sa_command_1' was not declared. Should it be static?
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
Move the err_request_irq error label up to reflect that tasklet_init and
irq_of_parse_and_map have taken place.
This patch converts the drivers in drivers/crypto/* to use the
module_platform_driver() macro which makes the code smaller and a bit
simpler.
Cc: James Hsiao <jhsiao@amcc.com>
Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Cc: Kim Phillips <kim.phillips@freescale.com>
Acked-by: Vladimir Zapolskiy <vzapolskiy@gmail.com>
Acked-by: Jamie Iles <jamie@jamieiles.com>
The Security function on the AMCC SoCs has multiple engines within a
single MMIO range. The crypto driver currently enables the 3DES
functionality by doing a blind write to the device control register.
This can unintentionally disable other functions like the PKA or TRNG
when the driver is loaded.
Perform a read/modify/write to enable the 3DES function instead.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Get rid of old users of of_platform_driver in arch/powerpc. Most
of_platform_driver users can be converted to use the platform_bus
directly.
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: Makefile - replace the use of <module>-objs with <module>-y
crypto: hifn_795x - use cancel_delayed_work_sync()
crypto: talitos - sparse check endian fixes
crypto: talitos - fix checkpatch warning
crypto: talitos - fix warning: 'alg' may be used uninitialized in this function
crypto: cryptd - Adding the AEAD interface type support to cryptd
crypto: n2_crypto - Niagara2 driver needs to depend upon CRYPTO_DES
crypto: Kconfig - update broken web addresses
crypto: omap-sham - Adjust DMA parameters
crypto: fips - FIPS requires algorithm self-tests
crypto: omap-aes - OMAP2/3 AES hw accelerator driver
crypto: updates to enable omap aes
padata: add missing __percpu markup in include/linux/padata.h
MAINTAINERS: Add maintainer entries for padata/pcrypt
Changed <module>-objs to <module>-y in Makefile.
Signed-off-by: Tracey Dent <tdent48227@gmail.com>
of_device is just an alias for platform_device, so remove it entirely. Also
replace to_of_device() with to_platform_device() and update comment blocks.
This patch was initially generated from the following semantic patch, and then
edited by hand to pick up the bits that coccinelle didn't catch.
-struct of_device
+struct platform_device
Reviewed-by: David S. Miller <davem@davemloft.net>
Fixes build error caused by the OF device_node
pointer being moved into struct device
.name, .match_table and .owner are duplicated in both of_platform_driver
and device_driver. This patch is a removes the extra copies from struct
of_platform_driver and converts all users to the device_driver members.
This patch is a pretty mechanical change. The usage model doesn't change
and if any drivers have been missed, or if anything has been fixed up
incorrectly, then it will fail with a compile time error, and the fixup
will be trivial. This patch looks big and scary because it touches so
many files, but it should be pretty safe.
Acked-by: Sean MacLennan <smaclennan@pikatech.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The match_table field of the struct of_device_id is constant in <linux/of_platform.h>
so it is worth to make the initialization data also constant.
The semantic match that finds this kind of pattern is as follows:
// <smpl>
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
struct I1 {
const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
struct I1 y = {
.x = E,
@c@
identifier r.I2;
identifier s.E;
const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+ const
struct I2 E[] = ...;
// </smpl>
Signed-off-by: Márton Németh <nm127@freemail.hu>
Cc: Julia Lawall <julia@diku.dk>
Cc: cocci@diku.dk
The crypto4xx SHA implementation keeps the hash state in the tfm
data structure. This breaks a fundamental requirement of ahash
implementations that they must be reentrant.
This patch disables the broken implementation.
This patch changes crypto4xx to use the new style ahash type.
In particular, we now use ahash_alg to define ahash algorithms
instead of crypto_alg.
This is achieved by introducing a union that encapsulates the
new type and the existing crypto_alg structure. They're told
apart through a u32 field containing the type value.
This patch makes crypto4xx use crypto_ahash_set_reqsize to avoid
accessing crypto_ahash directly.
This patch adds support for AMCC ppc4xx security device driver. This is the
initial release that includes the driver framework with AES and SHA1 algorithms
support.
The remaining algorithms will be released in the near future.
Signed-off-by: James Hsiao <jhsiao@amcc.com>
