path: root/drivers/crypto/atmel-sha-regs.h
2013-03-10crypto: atmel-sha - add support for latest release of the IP (0x410)Nicolas Royer
Updates from IP release 0x320 to 0x400: - add DMA support (previous IP revision use PDC) - add DMA double input buffer support - add SHA224 support Update from IP release 0x400 to 0x410: - add SHA384 and SHA512 support Signed-off-by: Nicolas Royer <nicolas@eukrea.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Eric Bénard <eric@eukrea.com> Tested-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-07-11crypto: atmel - add Atmel SHA1/SHA256 driverNicolas Royer
