commit a208fa8f33031b9e0aba44c7d1b7e68eb0cbd29e upstream.
We need to consistently enforce that keyed hashes cannot be used without
setting the key. To do this we need a reliable way to determine whether
a given hash algorithm is keyed or not. AF_ALG currently does this by
checking for the presence of a ->setkey() method. However, this is
actually slightly broken because the CRC-32 algorithms implement
->setkey() but can also be used without a key. (The CRC-32 "key" is not
actually a cryptographic key but rather represents the initial state.
If not overridden, then a default initial state is used.)
Prepare to fix this by introducing a flag CRYPTO_ALG_OPTIONAL_KEY which
indicates that the algorithm has a ->setkey() method, but it is not
required to be called. Then set it on all the CRC-32 algorithms.
The same also applies to the Adler-32 implementation in Lustre.
Also, the cryptd and mcryptd templates have to pass through the flag
from their underlying algorithm.
Cc: stable@vger.kernel.org
Remove unneeded error handling on the result of a call to
platform_get_resource when the value is passed to
devm_ioremap_resource.
The Coccinelle semantic patch that makes this change is as follows:
// <smpl>
expression pdev,res,n,e,e1;
expression ret != 0;
identifier l;
- res = platform_get_resource(pdev, IORESOURCE_MEM, n);
... when != res
- if (res == NULL) { ... \(goto l;\|return ret;\) }
... when != res
+ res = platform_get_resource(pdev, IORESOURCE_MEM, n);
e = devm_ioremap_resource(e1, res);
// </smpl>
Signed-off-by: Amitoj Kaur Chawla <amitoj1606@gmail.com>
The sg_count function in bfin_crc.c is the same function as sg_nents.
Remove the duplicate code and use sg_nents() instead.
Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com>
[hch: split from a larger patch by Dan]
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Signed-off-by: Jens Axboe <axboe@fb.com>
Modify crypto drivers to use the generic SG helper since
both of them are equivalent and the one from crypto is redundant.
See also:
468577abe37ff7b453a9ac613e0ea155349203ae reverted in
b2ab4a57b018aafbba35bff088218f5cc3d2142e
Signed-off-by: Cristian Stoica <cristian.stoica@freescale.com>
This patch removes unnecessary KERN_ERR from bfin_crypto_crc_mod_init().
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
This is a specific implementation, <asm/unaligned.h> is the
multiplexer that has the arch-specific knowledge of which
of the implementations needs to be used, so include that.
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
dma_map_single
- The 4-byte sg_mid_buf is located in the middle of the coherence memory
sg_cpu. Don't call dma_map_single to get its physical address. Get the its
base physical address from the physical address of sg_cpu instead.
- Should set up the dma descriptor data after the 4-byte sg_mid_buf is
filled in completely from next sg buffer.
- memory copy from sg buffer should be done via virtual address.
- Remove unused reference to blackfin header
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
in case of multiple crc devices are probed.
Call platform_set_drvdata() before adding new CRC device into the list.
Move architecture independant crc header file out of the blackfin folder.
coherent memory
1) SSYNC instruction is blackfin specific and takes no effect in this driver.
2) DMA descriptor and SG middle buffer are in DMA coherent memory. No need
to flush.
3) Turn kzalloc, ioremap and request_irq into managed device APIs respectively.
If we define dev_dbg(), then there is a possible NULL pointer
dereference.
Signed-off-by: Syam Sidhardhan <s.syam@samsung.com>
Pull crypto update from Herbert Xu:
"Here is the crypto update for 3.9:
- Added accelerated implementation of crc32 using pclmulqdq.
- Added test vector for fcrypt.
- Added support for OMAP4/AM33XX cipher and hash.
- Fixed loose crypto_user input checks.
- Misc fixes"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (43 commits)
crypto: user - ensure user supplied strings are nul-terminated
crypto: user - fix empty string test in report API
crypto: user - fix info leaks in report API
crypto: caam - Added property fsl,sec-era in SEC4.0 device tree binding.
crypto: use ERR_CAST
crypto: atmel-aes - adjust duplicate test
crypto: crc32-pclmul - Kill warning on x86-32
crypto: x86/twofish - assembler clean-ups: use ENTRY/ENDPROC, localize jump labels
crypto: x86/sha1 - assembler clean-ups: use ENTRY/ENDPROC
crypto: x86/serpent - use ENTRY/ENDPROC for assember functions and localize jump targets
crypto: x86/salsa20 - assembler cleanup, use ENTRY/ENDPROC for assember functions and rename ECRYPT_* to salsa20_*
crypto: x86/ghash - assembler clean-up: use ENDPROC at end of assember functions
crypto: x86/crc32c - assembler clean-up: use ENTRY/ENDPROC
crypto: cast6-avx: use ENTRY()/ENDPROC() for assembler functions
crypto: cast5-avx: use ENTRY()/ENDPROC() for assembler functions and localize jump targets
crypto: camellia-x86_64/aes-ni: use ENTRY()/ENDPROC() for assembler functions and localize jump targets
crypto: blowfish-x86_64: use ENTRY()/ENDPROC() for assembler functions and localize jump targets
crypto: aesni-intel - add ENDPROC statements for assembler functions
crypto: x86/aes - assembler clean-ups: use ENTRY/ENDPROC, localize jump targets
crypto: testmgr - add test vector for fcrypt
The data referenced by an interrupt handler should not be freed before the
interrupt is ended. The handler is bfin_crypto_crc_handler. It may refer
to crc->regs, which is released by the iounmap.
Furthermore, the second argument to all calls to free_irq is incorrect. It
should be the same as the last argument of request_irq, which is crc,
rather than crc->dev.
The semantic match that finds the first problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@fn exists@
expression list es;
expression a,b;
identifier f;
if (...) {
... when any
free_irq(a,b);
... when any
f(es);
... when any
return ...;
expression list fn.es;
expression fn.a,fn.b;
identifier fn.f;
*f(es);
... when any
*free_irq(a,b);
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Kent Yoder <key@linux.vnet.ibm.com>
Cc: Jamie Iles <jamie@jamieiles.com>
Cc: Kim Phillips <kim.phillips@freescale.com>
Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Cc: Alex Porosanu <alexandru.porosanu@freescale.com>
The CRC peripheral is a hardware block used to compute the CRC of the block
of data. This is based on a CRC32 engine which computes the CRC value of 32b
data words presented to it. For data words of < 32b in size, this driver
pack 0 automatically into 32b data units. This driver implements the async
hash crypto framework API.
