commit c552ffb5c93d9d65aaf34f5f001c4e7e8484ced1 upstream.
When using single_open() for opening, single_release() should be
used instead of seq_release(), otherwise there is a memory leak.
Fixes: 09ae5d37e093 ("crypto: zip - Add Compression/Decompression statistics")
Cc: <stable@vger.kernel.org>
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
[ Upstream commit 41798036430015ad45137db2d4c213cd77fd0251 ]
The cavium/zip implementation of the deflate compression algorithm is
incorrectly being registered under the generic driver name, which
prevents the generic implementation from being registered with the
crypto API when CONFIG_CRYPTO_DEV_CAVIUM_ZIP=y. Similarly the lzs
algorithm (which does not currently have a generic implementation...)
is incorrectly being registered as lzs-generic.
Fix the naming collision by adding a suffix "-cavium" to the
cra_driver_name of the cavium/zip algorithms.
Fixes: 640035a2dc55 ("crypto: zip - Add ThunderX ZIP driver core")
Cc: Mahipal Challa <mahipalreddy2006@gmail.com>
Cc: Jan Glauber <jglauber@cavium.com>
commit c782a8c43e94ba6c09e9de2d69b5e3a5840ce61c upstream.
After issuing a request an endless loop was used to read the
completion state from memory which is asynchronously updated
by the ZIP coprocessor.
Add an upper bound to the retry attempts to prevent a CPU getting stuck
forever in case of an error. Additionally, add a read memory barrier
and a small delay between the reading attempts.
Signed-off-by: Jan Glauber <jglauber@cavium.com>
Reviewed-by: Robert Richter <rrichter@cavium.com>
Cc: stable <stable@vger.kernel.org> # 4.14
commit 37ff02acaa3d7be87ecb89f198a549ffd3ae2403 upstream.
Enabling virtual mapped kernel stacks breaks the thunderx_zip
driver. On compression or decompression the executing CPU hangs
in an endless loop. The reason for this is the usage of __pa
by the driver which does no longer work for an address that is
not part of the 1:1 mapping.
The zip driver allocates a result struct on the stack and needs
to tell the hardware the physical address within this struct
that is used to signal the completion of the request.
As the hardware gets the wrong address after the broken __pa
conversion it writes to an arbitrary address. The zip driver then
waits forever for the completion byte to contain a non-zero value.
Allocating the result struct from 1:1 mapped memory resolves this
bug.
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
kernelci.org reports a build-time regression on linux-next, with a harmless
warning in x86 allmodconfig:
drivers/crypto/cavium/zip/zip_main.c:489:18: warning: format '%ld' expects argument of type 'long int', but argument 7 has type 'long long int' [-Wformat=]
drivers/crypto/cavium/zip/zip_main.c:489:18: warning: format '%ld' expects argument of type 'long int', but argument 6 has type 'long long int' [-Wformat=]
drivers/crypto/cavium/zip/zip_main.c:489:18: warning: format '%ld' expects argument of type 'long int', but argument 5 has type 'long long int' [-Wformat=]
The return type for atomic64_read() unfortunately differs between
architectures, with some defining it as atomic_long_read() and others
returning a 64-bit type explicitly. Fixing this in general would be nice,
but also require changing other users of these functions, so the simpler
workaround is to add a cast here that avoids the warnings on the default
build.
There is a typo here. It should be "stats" instead of "state". The
impact is that we clear 224 bytes instead of 80 and we zero out memory
that we shouldn't.
Add statistics for compression/decompression hardware offload
under debugfs.
Signed-off-by: Mahipal Challa <Mahipal.Challa@cavium.com>
This contains changes for adding compression/decompression h/w offload
functionality for both DEFLATE and LZS.
Add a driver for the ZIP engine found on Cavium ThunderX SOCs.
The ZIP engine supports hardware accelerated compression and
decompression. It includes 2 independent ZIP cores and supports:
- DEFLATE compression and decompression (RFC 1951)
- LZS compression and decompression (RFC 2395 and ANSI X3.241-1994)
- ADLER32 and CRC32 checksums for ZLIB (RFC 1950) and GZIP (RFC 1952)
The ZIP engine is presented as a PCI device. It supports DMA and
scatter-gather.
