path: root/drivers/crypto/geode-aes.c
2008-01-11[CRYPTO] geode: Add __dev{init,exit} annotationsAdrian Bunk
This patch adds __dev{init,exit} annotations. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] geode: Use correct encrypt/decrypt function in fallbackSebastian Siewior
crypto_blkcipher_decrypt is wrong because it does not care about the IV. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] geode: do not copy the IV too oftenSebastian Siewior
There is no reason to keep the IV in the private structre. Instead keep just a pointer to make the patch smaller :) This also remove a few memcpy()s Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] geode: Add fallback for unsupported modesSebastian Siewior
The Geode AES crypto engine supports only 128 bit long key. This patch adds fallback for other key sizes which are required by the AES standard. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Acked-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] geode: move defines into a headerfileSebastian Siewior
This patch moves macros in geode-aes.c into geode-aes.h. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] geode: relax in busy loop and care about return valueSebastian Siewior
The code waits in a busy loop until the hardware finishes the encryption or decryption process. This wants a cpu_relax() :) The busy loop finishes either if the encryption is done or if the counter is zero. If the latter is true than the hardware failed. Since this should not happen, leave sith a BUG(). Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] geode: use consistent IV copySebastian Siewior
It is enough if the IV is copied before and after the while loop. With DM-Crypt is seems not be required to save the IV after encrytion because a new one is used in the request (dunno about other users). It is not save to load the IV within while loop and not save afterwards because we mill end up with the wrong IV if the request goes consists of more than one page. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] aes: Move common defines into a header fileSebastian Siewior
This three defines are used in all AES related hardware. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] geode: remove aliasSebastian Siewior
alias isn't required because the module provides PCI ids. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-11[CRYPTO] geode: Fix not inplace encryptionSebastian Siewior
Currently the Geode AES module fails to encrypt or decrypt if the coherent bits are not set what is currently the case if the encryption does not occur inplace. However, the encryption works on my Geode machine _only_ if the coherent bits are always set. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Acked-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] aes: Rename aes to aes-genericSebastian Siewior
Loading the crypto algorithm by the alias instead of by module directly has the advantage that all possible implementations of this algorithm are loaded automatically and the crypto API can choose the best one depending on its priority. Additionally it ensures that the generic implementation as well as the HW driver (if available) is loaded in case the HW driver needs the generic version as fallback in corner cases. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-05-24[CRYPTO] geode: Fix in-place operations and set keyJordan Crouse
Allow in-place crypto operations. Also remove the coherent user flag (we use it automagically now), and by default use the user written key rather then the HW hidden key - this makes crypto just work without any special considerations, and thats OK, since its our only usage model. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-03-06[PATCH] geode-aes: use unsigned long for spin_lock_irqsaveAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-07[CRYPTO] geode: Convert pci_module_init() to pci_register_driver()Richard Knutsson
Replace uses of the obsolete pci_module_init function. Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-12-06[CRYPTO] geode: Make needlessly global geode_aes_crypt() staticAdrian Bunk
On Tue, Nov 14, 2006 at 01:41:25AM -0800, Andrew Morton wrote: >... > Changes since 2.6.19-rc5-mm2: >... > git-cryptodev.patch >... > git trees >... This patch makes the needlessly global geode_aes_crypt() static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-12-06[PATCH] crypto: Add support for the Geode LX AES hardwareJordan Crouse
Add a driver to support the AES hardware on the Geode LX processor. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
