Properly allocate enough memory to respect the fallback.
Signed-off-by: Will Thomas <will.thomas@imgtec.com>
Currently the probe function only emits an output on success
when debug is specifically enabled. It would be more useful
if this happens by default.
Signed-off-by: James Hartley <james.hartley@imgtec.com>
Reviewed-by: Will Thomas <will.thomas@imgtec.com>
Currently the img-hash accelerator does not probe
successfully due to a change in the checks made during
registration with the crypto framework. This is due to
import and export functions not being defined. Correct
this.
Current img hash claims sys and periph gate clocks
and this can be gated in system suspend scenarios.
Add support for Device pm ops for img hash to gate
the clocks claimed by img hash.
Signed-off-by: Govindraj Raja <Govindraj.Raja@imgtec.com>
Burst length of 16 drives the hash accelerator out of spec
and causes stability issues in some cases. Reduce this to
stop data being lost.
Reviewed-by: James Hartley <james.hartley@imgtec.com>
Move 0 length buffer to end of structure to stop overwriting
fallback request data. This doesn't cause a bug itself as the
buffer is never used alongside the fallback but should be
changed.
Sporadic null pointer exceptions came from here. Fix them.
Trival change, fix spelling mistake 'aquire' -> 'acquire' in
dev_err message.
"hdev->req->nbytes" is an unsigned int so we so we lose the upper 3 bits
to the shift wrap bug.
GCC complains about that %u is the wrong format string for size_t and
also that "ret" is unused.
crypto: img-hash - Add missing semicolon to fix build error
There is a missing semicolon after MODULE_DEVICE_TABLE.
This adds support for the Imagination Technologies hash accelerator which
provides hardware acceleration for SHA1 SHA224 SHA256 and MD5 hashes.
Reviewed-by: Andrew Bresticker <abrestic@chromium.org>
