If we add a template first-fragment operation, always update the
template to be a mid-fragment. This ensures that mid-fragments
always follow on from a first fragment in every case.
This means we can move the first to mid-fragment update code out of
mv_cesa_ahash_dma_add_data().
Add a helper to add the fragment operation block followed by the DMA
entry to launch the operation.
Although at the moment this pattern only strictly appears at one site,
two other sites can be factored as well by slightly changing the order
in which the DMA operations are performed. This should be harmless as
the only thing which matters is to have all the data loaded into SRAM
prior to launching the operation.
Multiple locations in the driver test the operation context fragment
type, checking whether it is a first fragment or not. Introduce a
mv_cesa_mac_op_is_first_frag() helper, which returns true if the
fragment operation is for a first fragment.
mv_cesa_get_op_cfg() does not write to its argument, it only reads.
So, let's make it const.
Ensure that the template operation is fully initialised, otherwise we
end up loading data from the kernel stack into the engines, which can
upset the hash results.
The endianness of the bit length used in the final stage depends on the
endianness of the algorithm - md5 hashes need it to be in little endian
format, whereas SHA hashes need it in big endian format. Use the
previously added algorithm endianness flag to control this.
Rather than determining whether we're using a MD5 hash by looking at
the digest size, switch to a cleaner solution using a per-request flag
initialised by the method type.
Currently, we read/write the state in CPU endian, but on the final
request, we convert its endian according to the requested algorithm.
(md5 is little endian, SHA are big endian.)
Always keep creq->state in CPU native endian format, and perform the
necessary conversion when copying the hash to the result.
There's an easier way to get at the hash transform - rather than
using crypto_ahash_tfm(ahash), we can get it directly from
req->base.tfm.
As all the import functions and export functions are virtually
identical, factor out their common parts into a generic
mv_cesa_ahash_import() and mv_cesa_ahash_export() respectively. This
performs the actual import or export, and we pass the data pointers and
length into these functions.
We have to switch a % const operation to do_div() in the common import
function to avoid provoking gcc to use the expensive 64-bit by 64-bit
modulus operation.
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Attempting to use the sha1 digest for openssh via openssl reveals that
the result from the hash is wrong: this happens when we export the
state from one socket and import it into another via calling accept().
The reason for this is because the operation is reset to "initial block"
state, whereas we may be past the first fragment of data to be hashed.
Arrange for the operation code to avoid the initialisation of the state,
thereby preserving the imported state.
When a AF_ALG fd is accepted a second time (hence hash_accept() is
used), hash_accept_parent() allocates a new private context using
sock_kmalloc(). This context is uninitialised. After use of the new
fd, we eventually end up with the kernel complaining:
marvell-cesa f1090000.crypto: dma_pool_free cesa_padding, c0627770/0 (bad dma)
where c0627770 is a random address. Poisoning the memory allocated by
the above sock_kmalloc() produces kernel oopses within the marvell hash
code, particularly the interrupt handling.
The following simplfied call sequence occurs:
hash_accept()
crypto_ahash_export()
marvell hash export function
af_alg_accept()
hash_accept_parent() <== allocates uninitialised struct hash_ctx
crypto_ahash_import()
marvell hash import function
hash_ctx contains the struct mv_cesa_ahash_req in its req.__ctx member,
and, as the marvell hash import function only partially initialises
this structure, we end up with a lot of members which are left with
whatever data was in memory prior to sock_kmalloc().
Add zero-initialisation of this structure.
Acked-by: Boris Brezillon <boris.brezillon@free-electronc.com>
Several of the algorithms in marvell/hash.c have a statesize of zero.
When an AF_ALG accept() on an already-accepted file descriptor to
calls into hash_accept(), this causes:
char state[crypto_ahash_statesize(crypto_ahash_reqtfm(req))];
to be zero-sized, but we still pass this to:
err = crypto_ahash_export(req, state);
which proceeds to write to 'state' as if it was a "struct md5_state",
"struct sha1_state" etc. Add the necessary initialisers for the
.statesize member.
The mv_cesa_queue_req() function calls crypto_enqueue_request() to
enqueue a request. In the normal case (i.e the queue isn't full), this
function returns -EINPROGRESS. The current Marvell CESA crypto driver
takes this into account and cleans up the request only if an error
occured, i.e if the return value is not -EINPROGRESS.
Unfortunately this causes problems with
CRYPTO_TFM_REQ_MAY_BACKLOG-flagged requests. When such a request is
passed to crypto_enqueue_request() and the queue is full,
crypto_enqueue_request() will return -EBUSY, but will keep the request
enqueued nonetheless. This situation was not properly handled by the
Marvell CESA driver, which was anyway cleaning up the request in such
a situation. When later on the request was taken out of the backlog
and actually processed, a kernel crash occured due to the internal
driver data structures for this structure having been cleaned up.
To avoid this situation, this commit adds a
mv_cesa_req_needs_cleanup() helper function which indicates if the
request needs to be cleaned up or not after a call to
crypto_enqueue_request(). This helper allows to do the cleanup only in
the appropriate cases, and all call sites of mv_cesa_queue_req() are
fixed to use this new helper function.
Reported-by: Vincent Donnefort <vdonnefort@gmail.com>
Fixes: db509a45339fd ("crypto: marvell/cesa - add TDMA support")
Cc: <stable@vger.kernel.org> # v4.2+
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Tested-by: Vincent Donnefort <vdonnefort@gmail.com>
platform_driver does not need to set an owner because
platform_driver_register() will set it.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
To be consistent with other kernel interface namings, rename
of_get_named_gen_pool() to of_gen_pool_get(). In the original function
name "_named" suffix references to a device tree property, which contains
a phandle to a device and the corresponding device driver is assumed to
register a gen_pool object.
Due to a weak relation and to avoid any confusion (e.g. in future
possible scenario if gen_pool objects are named) the suffix is removed.
[sfr@canb.auug.org.au: crypto/marvell/cesa - fix up for of_get_named_gen_pool() rename]
Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Philipp Zabel <p.zabel@pengutronix.de>
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Boris BREZILLON <boris.brezillon@free-electrons.com>
Add the Kirkwood and Dove SoC descriptions, and control the allhwsupport
module parameter to avoid probing the CESA IP when the old CESA driver is
enabled (unless it is explicitly requested to do so).
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Add the Orion SoC description, and select this implementation by default
to support non-DT probing: Orion is the only platform where non-DT boards
are declaring the CESA block.
Control the allhwsupport module parameter to avoid probing the CESA IP when
the old CESA driver is enabled (unless it is explicitly requested to do
so).
The old and new marvell CESA drivers both support Orion and Kirkwood SoCs.
Add a module parameter to choose whether these SoCs should be attached to
the new or the old driver.
The default policy is to keep attaching those IPs to the old driver if it
is enabled, until we decide the new CESA driver is stable/secure enough.
Add CESA IP description for all the missing armada SoCs (XP, 375 and 38x).
Add support for SHA256 operations.
Add support for MD5 operations.
Add support for Triple-DES operations.
Add support for DES operations.
The CESA IP supports CPU offload through a dedicated DMA engine (TDMA)
which can control the crypto block.
When you use this mode, all the required data (operation metadata and
payload data) are transferred using DMA, and the results are retrieved
through DMA when possible (hash results are not retrieved through DMA yet),
thus reducing the involvement of the CPU and providing better performances
in most cases (for small requests, the cost of DMA preparation might
exceed the performance gain).
Note that some CESA IPs do not embed this dedicated DMA, hence the
activation of this feature on a per platform basis.
The existing mv_cesa driver supports some features of the CESA IP but is
quite limited, and reworking it to support new features (like involving the
TDMA engine to offload the CPU) is almost impossible.
This driver has been rewritten from scratch to take those new features into
account.
This commit introduce the base infrastructure allowing us to add support
for DMA optimization.
It also includes support for one hash (SHA1) and one cipher (AES)
algorithm, and enable those features on the Armada 370 SoC.
Other algorithms and platforms will be added later on.
