[ Upstream commit 6333ed8f26cf77311088d2e2b7cf16d8480bcbb2 ]
NX842 coprocessor sets 3rd bit in CR register with XER[S0] which is
nothing to do with NX request. Since this bit can be set with other
valuable return status, mast this bit.
One of other bits (INITIATED, BUSY or REJECTED) will be returned for
any given NX request.
Signed-off-by: Haren Myneni <haren@us.ibm.com>
commit e514cc0a492a3f39ef71b31590a7ef67537ee04b upstream.
The props->ap[] array is defined like this:
struct alg_props ap[NX_MAX_FC][NX_MAX_MODE][3];
So we can see that if msc->fc and msc->mode are == to NX_MAX_FC or
NX_MAX_MODE then we're off by one.
Fixes: ae0222b7289d ('powerpc/crypto: nx driver code supporting nx encryption')
Using non-constant time memcmp() makes the verification of the authentication
tag in the decrypt path vulnerable to timing attacks. Fix this by using
crypto_memneq() instead.
Cc: stable@vger.kernel.org
Signed-off-by: David Gstir <david@sigma-star.at>
This patch adds CRC generation and validation support for nx-842.
Add CRC flag so that nx842 coprocessor includes CRC during compression
and validates during decompression.
Also changes in 842 SW compression to append CRC value at the end
of template and checks during decompression.
Pull crypto updates from Herbert Xu:
"Here is the crypto update for 4.3:
API:
- the AEAD interface transition is now complete.
- add top-level skcipher interface.
Drivers:
- x86-64 acceleration for chacha20/poly1305.
- add sunxi-ss Allwinner Security System crypto accelerator.
- add RSA algorithm to qat driver.
- add SRIOV support to qat driver.
- add LS1021A support to caam.
- add i.MX6 support to caam"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (163 commits)
crypto: algif_aead - fix for multiple operations on AF_ALG sockets
crypto: qat - enable legacy VFs
MPI: Fix mpi_read_buffer
crypto: qat - silence a static checker warning
crypto: vmx - Fixing opcode issue
crypto: caam - Use the preferred style for memory allocations
crypto: caam - Propagate the real error code in caam_probe
crypto: caam - Fix the error handling in caam_probe
crypto: caam - fix writing to JQCR_MS when using service interface
crypto: hash - Add AHASH_REQUEST_ON_STACK
crypto: testmgr - Use new skcipher interface
crypto: skcipher - Add top-level skcipher interface
crypto: cmac - allow usage in FIPS mode
crypto: sahara - Use dmam_alloc_coherent
crypto: caam - Add support for LS1021A
crypto: qat - Don't move data inside output buffer
crypto: vmx - Fixing GHASH Key issue on little endian
crypto: vmx - Fixing AES-CTR counter bug
crypto: null - Add missing Kconfig tristate for NULL2
crypto: nx - Add forward declaration for struct crypto_aead
The file nx.h has function prototypes that use struct crypto_aead.
However, as crypto/aead.h is not included we don't have a definition
for it. This patch adds a forward declaration to fix this.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
This patch removes the CRYPTO_ALG_AEAD_NEW flag now that everyone
has been converted.
Commit 000851119e80 changed sha256/512 update functions to
pass more data to nx_build_sg_list(), which ends with
sg list overflows and usually with update functions failing
for data larger than max_sg_len * NX_PAGE_SIZE.
This happens because:
- both "total" and "to_process" are updated, which leads to
"to_process" getting overflowed for some data lengths
For example:
In first iteration "total" is 50, and let's assume "to_process"
is 30 due to sg limits. At the end of first iteration "total" is
set to 20. At start of 2nd iteration "to_process" overflows on:
to_process = total - to_process;
- "in_sg" is not reset to nx_ctx->in_sg after each iteration
- nx_build_sg_list() is hitting overflow because the amount of data
passed to it would require more than sgmax elements
- as consequence of previous item, data stored in overflowed sg list
may no longer be aligned to SHA*_BLOCK_SIZE
This patch changes sha256/512 update functions so that "to_process"
respects sg limits and never tries to pass more data to
nx_build_sg_list() to avoid overflows. "to_process" is calculated
as minimum of "total" and sg limits at start of every iteration.
Fixes: 000851119e80 ("crypto: nx - Fix SHA concurrence issue and sg
limit bounds")
Signed-off-by: Jan Stancek <jstancek@redhat.com>
Cc: Leonidas Da Silva Barbosa <leosilva@linux.vnet.ibm.com>
Cc: Marcelo Henrique Cerri <mhcerri@linux.vnet.ibm.com>
Cc: Fionnuala Gunter <fin@linux.vnet.ibm.com>
CTR hardware implementation does not match with kernel spec causing a counter bug
where just low 8 bytes are used for counter, when should be all 16bytes.
Since we already have other counter modes working according with specs
not worth to keep CTR itself on NX.
Signed-off-by: Leonidas S. Barbosa <leosilva@linux.vnet.ibm.com>
One of the debug messages in the NX 842 PowerNV driver is missing
the required be32_to_cpu() wrapper when accessing the __be32 field
csb->count. Add the wrapper so the message will show the correct count.
Signed-off-by: Dan Streetman <ddstreet@ieee.org>
Return success instead of error if compression succeeds but the output is
larger than the input.
It's unlikely that the caller will use the compressed data since it's
larger than the original uncompressed data, but there was no error and
returning an error code is incorrect. Further, for testing small input
buffers, the output is likely to be larger than the input and success
needs to be returned to verify the test.
Remove the common 'platform' registration module, and move the crypto
compression driver registration into each of the pSeries and PowerNV
platform NX 842 drivers. Change the nx-842.c code into simple common
functions that each platform driver uses to perform constraints-based
buffer changes, i.e. realigning and/or resizing buffers to match the
driver's hardware requirements.
The common 'platform' module was my mistake to create - since each
platform driver will only load/operate when running on its own
platform (i.e. a pSeries platform or a PowerNV platform), they can
directly register with the crypto subsystem, using the same alg and
driver name. This removes unneeded complexity.
The last commit merged nx-842.c's code into nx-842-crypto.c. It
did not rename nx-842-crypto.c to nx-842.c, in order to let the
patch more clearly show what was merged. This just renames
nx-842-crypto.c to nx-842.c, with no changes to its code.
Merge the nx-842.c code into nx-842-crypto.c.
This allows later patches to remove the 'platform' driver, and instead
allow each platform driver to directly register with the crypto
compression api.
Replace the duplicated finishing code (set destination buffer length and
set return code to 0) in the case of decompressing a buffer with no header
with a goto to the success case of decompressing a buffer with a header.
This is a trivial change that allows both success cases to use common code,
and includes the pr_debug() msg in both cases as well.
Don't register the pSeries driver when parsing the device tree returns
ENODEV.
The nx842_probe() function in the pSeries driver returns error instead
of registering as a crypto compression driver, when it receives an
error return value from the nx842_OF_upd() function that probes the
device tree nodes, except when ENODEV is returned. However ENODEV
should not be a special case and the driver should not register when
there is no hw device, or the hw device is disabled.
Move the kzalloc() calls in nx842_probe() and nx842_OF_upd() to the top
of the functions, before taking the devdata spinlock.
Since kzalloc() without GFP_ATOMIC can sleep, it can't be called while
holding a spinlock. Move the calls to before taking the lock.
Remove the 'status' field from the pSeries NX driver data.
The 'status' field isn't used by the driver at all; it simply checks the
devicetree status node at initialization, and returns success if 'okay'
and failure otherwise.
Remove the __init and __exit modifiers from the VIO driver probe and
remove functions.
The driver functions should not be marked __init/__exit because they
can/will be called during runtime, not only at module init and exit.
This patch converts the nx ccm and 4309 implementations to the
new AEAD interface.
This patch converts rfc4106 to the new calling convention where
the IV is now part of the AD and needs to be skipped. This patch
also makes use of type-safe AEAD functions where possible.
The transform context is shared memory and must not be written
to without locking. This patch adds locking to nx-842 to prevent
context corruption.
Merge the crypto tree to pull in the nx reentrancy patch.
This patch fixes a host of reentrancy bugs in the nx driver. The
following algorithms are affected:
* CCM
* GCM
* CTR
* XCBC
* SHA256
* SHA512
The crypto API allows a single transform to be used by multiple
threads simultaneously. For example, IPsec will use a single tfm
to process packets for a given SA. As packets may arrive on
multiple CPUs that tfm must be reentrant.
The nx driver does try to deal with this by using a spin lock.
Unfortunately only the basic AES/CBC/ECB algorithms do this in
the correct way.
The symptom of these bugs may range from the generation of incorrect
output to memory corruption.
While we never would successfully load on the wrong machine type, there
is extra output by default regardless of machine type.
For instance, on a PowerVM LPAR, we see the following:
nx_compress_powernv: loading
nx_compress_powernv: no coprocessors found
even though those coprocessors could never be found.
Signed-off-by: Nishanth Aravamudan <nacc@linux.vnet.ibm.com>
Cc: Dan Streetman <ddstreet@us.ibm.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: linux-crypto@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
If the device-tree indicates the nx-842 device's status is 'disabled',
we emit two messages:
nx_compress_pseries ibm,compression-v1: nx842_OF_upd_status: status 'disabled' is not 'okay'.
nx_compress_pseries ibm,compression-v1: nx842_OF_upd: device disabled
Given that 'disabled' is a valid state, and we are going to emit that
the device is disabled, only print out a non-'okay' status if it is not
'disabled'.
While there is no technical reason that both nx-842.c and
nx-842-pseries.c can have the same name for the init/exit functions, it
is a bit confusing with initcall_debug. Rename the pseries specific
functions appropriately
The current documention mentions explicitly that EINVAL should be
returned if the device is not available, but nx842_OF_upd_status()
always returns 0. However, nx842_probe() specifically checks for
non-ENODEV returns from nx842_of_upd() (which in turn calls
nx842_OF_upd_status()) and emits an extra error in that case. It seems
like the proper return code of a disabled device is ENODEV.
The nx driver reads two crucial paramters from the firmware for
each crypto algorithm, the maximum SG list length and byte limit.
Unfortunately those two parameters may be bogus, or worse they
may be absent altogether. When this happens the algorithms will
still register successfully but will fail when used or tested.
This patch adds checks to report any firmware entries which are
found to be bogus, and avoid registering algorithms which have
bogus parameters. A warning is also printed when an algorithm
is not registered because of this as there may have been no firmware
entries for it at all.
Reported-by: Ondrej Moriš <omoris@redhat.com>
Add support to the nx-842-pseries.c driver for running in little endian
mode.
The pSeries platform NX 842 driver currently only works as big endian.
This adds cpu_to_be*() and be*_to_cpu() in the appropriate places to
work in LE mode also.
This patch fixes a number of problems in crypto driver Kconfig
entries:
1. Select BLKCIPHER instead of BLKCIPHER2. The latter is internal
and should not be used outside of the crypto API itself.
2. Do not select ALGAPI unless you use a legacy type like
CRYPTO_ALG_TYPE_CIPHER.
3. Select the algorithm type that you are implementing, e.g., AEAD.
4. Do not select generic C code such as CBC/ECB unless you use them
as a fallback.
5. Remove default n since that is the default default.
This patch converts the nx GCM implementations to the new AEAD
interface. This is compile-tested only.
Replace the NX842_MEM_COMPRESS define with a function that returns the
specific platform driver's required working memory size.
The common nx-842.c driver refuses to load if there is no platform
driver present, so instead of defining an approximate working memory
size that's the maximum approximate size of both platform driver's
size requirements, the platform driver can directly provide its
specific, i.e. sizeof(struct nx842_workmem), size requirements which
the 842-nx crypto compression driver will use.
This saves memory by both reducing the required size of each driver
to the specific sizeof() amount, as well as using the specific loaded
platform driver's required amount, instead of the maximum of both.
Move the contents of the include/linux/nx842.h header file into the
drivers/crypto/nx/nx-842.h header file. Remove the nx842.h header
file and its entry in the MAINTAINERS file.
The include/linux/nx842.h header originally was there because the
crypto/842.c driver needed it to communicate with the nx-842 hw
driver. However, that crypto compression driver was moved into
the drivers/crypto/nx/ directory, and now can directly include the
nx-842.h header. Nothing else needs the public include/linux/nx842.h
header file, as all use of the nx-842 hardware driver will be through
the "842-nx" crypto compression driver, since the direct nx-842 api is
very limited in the buffer alignments and sizes that it will accept,
and the crypto compression interface handles those limitations and
allows any alignment and size buffers.
Reduce the nx-842 pSeries driver minimum buffer size from 128 to 8.
Also replace the single use of IO_BUFFER_ALIGN macro with the standard
and correct DDE_BUFFER_ALIGN.
The hw sometimes rejects buffers that contain padding past the end of the
8-byte aligned section where it sees the "end" marker. With the minimum
buffer size set too high, some highly compressed buffers were being padded
and the hw was incorrectly rejecting them; this sets the minimum correctly
so there will be no incorrect padding.
Change the nx-842 common driver to wait for loading of both platform
drivers, and fail loading if the platform driver pointer is not set.
Add an independent platform driver pointer, that the platform drivers
set if they find they are able to load (i.e. if they find their platform
devicetree node(s)).
The problem is currently, the main nx-842 driver will stay loaded even
if there is no platform driver and thus no possible way it can do any
compression or decompression. This allows the crypto 842-nx driver
to load even if it won't actually work. For crypto compression users
(e.g. zswap) that expect an available crypto compression driver to
actually work, this is bad. This patch fixes that, so the 842-nx crypto
compression driver won't load if it doesn't have the driver and hardware
available to perform the compression.
The crypto layer already checks maxauthsize when setauthsize is
called. So there is no need to check it again within setauthsize.
Remove the null checks for tfm, src, slen, dst, dlen; tfm will never
be null and the other fields are always expected to be set correctly.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Add crypto compression alg for 842 hardware compression and decompression,
using the alg name "842" and driver_name "842-nx".
This uses only the PowerPC coprocessor hardware for 842 compression. It
also uses the hardware for decompression, but if the hardware fails it will
fall back to the 842 software decompression library, so that decompression
never fails (for valid 842 compressed buffers). A header must be used in
most cases, due to the hardware's restrictions on the buffers being
specifically aligned and sized.
Due to the header this driver adds, compressed buffers it creates cannot be
directly passed to the 842 software library for decompression. However,
compressed buffers created by the software 842 library can be passed to
this driver for hardware 842 decompression (with the exception of buffers
containing the "short data" template, as lib/842/842.h explains).
Simplify the pSeries NX-842 driver: do not expect incoming buffers to be
exactly page-sized; do not break up input buffers to compress smaller
blocks; do not use any internal headers in the compressed data blocks;
remove the software decompression implementation; implement the pSeries
nx842_constraints.
This changes the pSeries NX-842 driver to perform constraints-based
compression so that it only needs to compress one entire input block at a
time. This removes the need for it to split input data blocks into
multiple compressed data sections in the output buffer, and removes the
need for any extra header info in the compressed data; all that is moved
(in a later patch) into the main crypto 842 driver. Additionally, the
842 software decompression implementation is no longer needed here, as
the crypto 842 driver will use the generic software 842 decompression
function as a fallback if any hardware 842 driver fails.
Add driver for NX-842 hardware on the PowerNV platform.
This allows the use of the 842 compression hardware coprocessor on
Add "constraints" for the NX-842 driver. The constraints are used to
indicate what the current NX-842 platform driver is capable of. The
constraints tell the NX-842 user what alignment, min and max length, and
length multiple each provided buffers should conform to. These are
required because the 842 hardware requires buffers to meet specific
constraints that vary based on platform - for example, the pSeries
max length is much lower than the PowerNV max length.
Add NX-842 frontend that allows using either the pSeries platform or
PowerNV platform driver (to be added by later patch) for the NX-842
hardware. Update the MAINTAINERS file to include the new filenames.
Update Kconfig files to clarify titles and descriptions, and correct
dependencies.
Move the entire NX-842 driver for the pSeries platform from the file
nx-842.c to nx-842-pseries.c. This is required by later patches that
add NX-842 support for the PowerNV platform.
This patch does not alter the content of the pSeries NX-842 driver at
all, it only changes the filename.
Bug happens when a data size less than SHA block size is passed.
Since first attempt will be saved in buffer, second round attempt
get into two step to calculate op.inlen and op.outlen. The issue
resides in this step. A wrong value of op.inlen and outlen was being
calculated.
This patch fix this eliminate the nx_sha_build_sg_list, that is
useless in SHA's algorithm context. Instead we call nx_build_sg_list
directly and pass a previous calculated max_sg_len to it.
In NX we need to pass always a 16 multiple size nx_sg_list to
co processor. Trim function handle with this assuring all nx_sg_lists
are 16 multiple size, although data was not being considerated when
crop was done. It was causing an unalignment between size of the list
and data, corrupting csbcpb fields returning a -23 H_ST_PARM error, or
invalid operation.
This patch fix this recalculating how much data should be put back
in to_process variable what assures the size of sg_list will be
correct with size of the data.
Modify crypto drivers to use the generic SG helper since
both of them are equivalent and the one from crypto is redundant.
See also:
468577abe37ff7b453a9ac613e0ea155349203ae reverted in
b2ab4a57b018aafbba35bff088218f5cc3d2142e
Signed-off-by: Cristian Stoica <cristian.stoica@freescale.com>
Pull crypto update from Herbert Xu:
- The crypto API is now documented :)
- Disallow arbitrary module loading through crypto API.
- Allow get request with empty driver name through crypto_user.
- Allow speed testing of arbitrary hash functions.
- Add caam support for ctr(aes), gcm(aes) and their derivatives.
- nx now supports concurrent hashing properly.
- Add sahara support for SHA1/256.
- Add ARM64 version of CRC32.
- Misc fixes.
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (77 commits)
crypto: tcrypt - Allow speed testing of arbitrary hash functions
crypto: af_alg - add user space interface for AEAD
crypto: qat - fix problem with coalescing enable logic
crypto: sahara - add support for SHA1/256
crypto: sahara - replace tasklets with kthread
crypto: sahara - add support for i.MX53
crypto: sahara - fix spinlock initialization
crypto: arm - replace memset by memzero_explicit
crypto: powerpc - replace memset by memzero_explicit
crypto: sha - replace memset by memzero_explicit
crypto: sparc - replace memset by memzero_explicit
crypto: algif_skcipher - initialize upon init request
crypto: algif_skcipher - removed unneeded code
crypto: algif_skcipher - Fixed blocking recvmsg
crypto: drbg - use memzero_explicit() for clearing sensitive data
crypto: drbg - use MODULE_ALIAS_CRYPTO
crypto: include crypto- module prefix in template
crypto: user - add MODULE_ALIAS
crypto: sha-mb - remove a bogus NULL check
crytpo: qat - Fix 64 bytes requests
The OF_RECONFIG notifier callback uses a different structure depending
on whether it is a node change or a property change. This is silly, and
not very safe. Rework the code to use the same data structure regardless
of the type of notifier.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
Cc: <linuxppc-dev@lists.ozlabs.org>
The previous limits were estimated locally in a single step
basead on bound values, however it was not correct since
when given certain scatterlist the function nx_build_sg_lists
was consuming more sg entries than allocated causing a
memory corruption and crashes.
e.g.: in the worst case we could have one sg entry for a single byte.
This patch fixes it modifying the logic of the bound limit
moving it to nx_sg_build_lists and set a correct sg_max limit,
adding a trim function to ensure the bound in sg_list. Also fixing
nx_build_sg_list NULL and untreated return in case of overflow.
