commit 1b82feb6c5e1996513d0fb0bbb475417088b4954 upstream.
It seems that smp_processor_id() is only used for a best-effort
load-balancing, refer to qat_crypto_get_instance_node(). It's not feasible
to disable preemption for the duration of the crypto requests. Therefore,
just silence the warning. This commit is similar to e7a9b05ca4
("crypto: cavium - Fix smp_processor_id() warnings").
Silences the following splat:
BUG: using smp_processor_id() in preemptible [00000000] code: cryptomgr_test/2904
caller is qat_alg_ablkcipher_setkey+0x300/0x4a0 [intel_qat]
CPU: 1 PID: 2904 Comm: cryptomgr_test Tainted: P O 4.14.69 #1
Call Trace:
dump_stack+0x5f/0x86
check_preemption_disabled+0xd3/0xe0
skcipher_setkey_ablkcipher+0x2b/0x40
__test_skcipher+0x1f3/0xb20
? cpumask_next_and+0x26/0x40
? find_busiest_group+0x10e/0x9d0
? preempt_count_add+0x49/0xa0
? try_module_get+0x61/0xf0
? crypto_mod_get+0x15/0x30
? __kmalloc+0x1df/0x1f0
? __crypto_alloc_tfm+0x116/0x180
? crypto_skcipher_init_tfm+0xa6/0x180
? crypto_create_tfm+0x4b/0xf0
test_skcipher+0x21/0xa0
alg_test_skcipher+0x3f/0xa0
alg_test.part.6+0x126/0x2a0
? finish_task_switch+0x21b/0x260
? __schedule+0x1e9/0x800
? __wake_up_common+0x8d/0x140
cryptomgr_test+0x40/0x50
kthread+0xff/0x130
? cryptomgr_notify+0x540/0x540
? kthread_create_on_node+0x70/0x70
ret_from_fork+0x24/0x50
Fixes: ed8ccaef52 ("crypto: qat - Add support for SRIOV")
Cc: stable@vger.kernel.org
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nokia.com>
commit ba439a6cbfa2936a6713f64cb499de7943673fe3 upstream.
The following KASAN warning was printed when booting a 64-bit kernel
on some systems with Intel CPUs:
[ 44.512826] ==================================================================
[ 44.520165] BUG: KASAN: stack-out-of-bounds in find_first_bit+0xb0/0xc0
[ 44.526786] Read of size 8 at addr ffff88041e02fc50 by task kworker/0:2/124
[ 44.535253] CPU: 0 PID: 124 Comm: kworker/0:2 Tainted: G X --------- --- 4.18.0-12.el8.x86_64+debug #1
[ 44.545858] Hardware name: Intel Corporation PURLEY/PURLEY, BIOS BKVDTRL1.86B.0005.D08.1712070559 12/07/2017
[ 44.555682] Workqueue: events work_for_cpu_fn
[ 44.560043] Call Trace:
[ 44.562502] dump_stack+0x9a/0xe9
[ 44.565832] print_address_description+0x65/0x22e
[ 44.570683] ? find_first_bit+0xb0/0xc0
[ 44.570689] kasan_report.cold.6+0x92/0x19f
[ 44.578726] find_first_bit+0xb0/0xc0
[ 44.578737] adf_probe+0x9eb/0x19a0 [qat_c62x]
[ 44.578751] ? adf_remove+0x110/0x110 [qat_c62x]
[ 44.591490] ? mark_held_locks+0xc8/0x140
[ 44.591498] ? _raw_spin_unlock+0x30/0x30
[ 44.591505] ? trace_hardirqs_on_caller+0x381/0x570
[ 44.604418] ? adf_remove+0x110/0x110 [qat_c62x]
[ 44.604427] local_pci_probe+0xd4/0x180
[ 44.604432] ? pci_device_shutdown+0x110/0x110
[ 44.617386] work_for_cpu_fn+0x51/0xa0
[ 44.621145] process_one_work+0x8fe/0x16e0
[ 44.625263] ? pwq_dec_nr_in_flight+0x2d0/0x2d0
[ 44.629799] ? lock_acquire+0x14c/0x400
[ 44.633645] ? move_linked_works+0x12e/0x2a0
[ 44.637928] worker_thread+0x536/0xb50
[ 44.641690] ? __kthread_parkme+0xb6/0x180
[ 44.645796] ? process_one_work+0x16e0/0x16e0
[ 44.650160] kthread+0x30c/0x3d0
[ 44.653400] ? kthread_create_worker_on_cpu+0xc0/0xc0
[ 44.658457] ret_from_fork+0x3a/0x50
[ 44.663557] The buggy address belongs to the page:
[ 44.668350] page:ffffea0010780bc0 count:0 mapcount:0 mapping:0000000000000000 index:0x0
[ 44.676356] flags: 0x17ffffc0000000()
[ 44.680023] raw: 0017ffffc0000000 ffffea0010780bc8 ffffea0010780bc8 0000000000000000
[ 44.687769] raw: 0000000000000000 0000000000000000 00000000ffffffff 0000000000000000
[ 44.695510] page dumped because: kasan: bad access detected
[ 44.702578] Memory state around the buggy address:
[ 44.707372] ffff88041e02fb00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 44.714593] ffff88041e02fb80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 44.721810] >ffff88041e02fc00: 00 00 00 00 00 00 f1 f1 f1 f1 04 f2 f2 f2 f2 f2
[ 44.729028] ^
[ 44.734864] ffff88041e02fc80: f2 f2 00 00 00 00 f3 f3 f3 f3 00 00 00 00 00 00
[ 44.742082] ffff88041e02fd00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 44.749299] ==================================================================
Looking into the code:
int ret, bar_mask;
for_each_set_bit(bar_nr, (const unsigned long *)&bar_mask,
It is casting a 32-bit integer pointer to a 64-bit unsigned long
pointer. There are two problems here. First, the 32-bit pointer address
may not be 64-bit aligned. Secondly, it is accessing an extra 4 bytes.
This is fixed by changing the bar_mask type to unsigned long.
Cc: <stable@vger.kernel.org>
Signed-off-by: Waiman Long <longman@redhat.com>
commit 685ce0626840e2673fe64ea8807684f7324fec5f upstream.
Zero embedded ram in DH85x devices. This is not
needed for newer generations as it is done by HW.
Signed-off-by: Giovanni Cabiddu <giovanni.cabiddu@intel.com>
commit 3484ecbe0e9deb94afb0b9b6172d77e98eb72b94 upstream.
Some accelerators of the c62x series have only two bars.
This patch skips BAR0 if the accelerator does not have it.
Merge the crypto tree to pull in vmx ghash fix.
Fix a memory leak in an error path in uc loader.
Fix incorrect value of ADF_C3XXX_ACCELERATORS_MASK.
Signed-off-by: Maksim Lukoshkov <maksim.lukoshkov@intel.com>
Copy const_tab array into DMA-able memory (accesible by qat hw).
Increase value of supported key sizes for qat_aes_xts.
aes-xts keys consists of keys of equal size concatenated.
Fixes: def14bfaf30d ("crypto: qat - add support for ctr(aes) and xts(aes)")
Reported-by: Wenqian Yu <wenqian.yu@intel.com>
There is not need to drop leading zeros from the RSA output
operations results.
Signed-off-by: Salvatore Benedetto <salvatore.benedetto@intel.com>
Add DH support under kpp api. Drop struct qat_rsa_request and
introduce a more generic struct qat_asym_request and share it
between RSA and DH requests.
Extend qat driver to use RSA CRT mode when all CRT related components are
present in the private key. Simplify code in qat_rsa_setkey by adding
qat_rsa_clear_ctx.
Different product families will use FLR or SBR.
Virtual Function devices have no reset method.
Signed-off-by: Conor McLoughlin <conor.mcloughlin@intel.com>
Drop all asn1 related code and use the new rsa_helper
functions rsa_parse_[pub|priv]_key for parsing the key
alloc_workqueue replaces deprecated create_workqueue().
The workqueue device_reset_wq has workitem &reset_data->reset_work per
adf_reset_dev_data. The workqueue pf2vf_resp_wq is a workqueue for
PF2VF responses has workitem &pf2vf_resp->pf2vf_resp_work per pf2vf_resp.
The workqueue adf_vf_stop_wq is used to call adf_dev_stop()
asynchronously.
Dedicated workqueues have been used in all cases since the workitems
on the workqueues are involved in operation of crypto which can be used in
the IO path which is depended upon during memory reclaim. Hence,
WQ_MEM_RECLAIM has been set to gurantee forward progress under memory
pressure.
Since there are only a fixed number of work items, explicit concurrency
limit is unnecessary.
Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Acked-by: Tejun Heo <tj@kernel.org>
The sizeof(*ctx->dec_cd) and sizeof(*ctx->enc_cd) are equal,
but we should use the correct one for freeing memory anyway.
Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com>
Change the adf_ctl_stop_devices to a void function.
The adf_vf_isr.c should only be build if CONFIG_PCI_IOV is enabled
Fix copy and paste typo adf_isr.c
Merge the crypto tree to pull in the qat adf_init_pf_wq fix.
Fix undefined reference issue reported by kbuild test robot.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Merge the crypto tree to pull in the qat adf_init_pf_wq change.
The pf2vf_resp_wq is a global so it has to be created at init
and destroyed at exit, instead of per device.
Tested-by: Suresh Marikkannu <sureshx.marikkannu@intel.com>
Fix Section mismatch warinig in adf_exit_vf_wq()
IRQs need to be enabled when VFs go down in case some VF to PF
comms happens.
Tested-by: Suman Bangalore Sathyanarayana <sumanx.bangalore.sathyanarayana@intel.com>
Before VF sends a signal to PF it should check if PF
is still running.
The vf2pf_init and vf2pf_exit are exactly the same for all VFs
so move them to common and reuse.
VFs call adf_dev_stop() from a PF to VF interrupt bottom half.
This causes an oops "scheduling while atomic", because it tries
to acquire a mutex to un-register crypto algorithms.
This patch fixes the issue by calling adf_dev_stop() asynchronously.
Changes in v2:
- change kthread to a work queue.
It returns always zero anyway.
When stopping devices it is not enought to loop backwards.
We need to explicitly stop all VFs first.
Signed-off-by: Tudor Ambarus <tudor-dan.ambarus@nxp.com>
memcopying to a (null pointer + offset) will result
in memory corruption or undefined behaviour.
Remove redundant nrbg rings.
Signed-off-by: Ahsan Atta <ahsan.atta@intel.com>
FW requires the const_tab to be 1024 bytes aligned.
The default arbiter configuration for ring weights and response ordering
is exactly what we want so we don't need to configure anything more.
This will also fix the problem where number of bundles is different
between different devices.
Reported-by: Ahsan Atta <ahsan.atta@intel.com>
The definition of icp_qat_uof_regtype should be coherent with
the definition in firmware compiler.
Signed-off-by: Yang Pingchao <pingchao.yang@intel.com>
Fix a leak on error path in qat asym
Reported-by: Salvatore Benedetto <salvatore.benedetto@intel.com>
req_alloc functions already take into account the request data structure
when allocating memory.
-This is required to support 32bit adf_ctl
utility on a 64bit driver
adf_dev_restore(accel_dev) was called in adf_dev_shutdown,no
need to call it in adf_device_reset_worker after adf_dev_shutdown
was called.
change name for c6x dev type to more generic.
There is no esram on C3xxx devices so we don't need to wait for
it to initialize.
Change the variable times data type and timeout conditon since the value
of times should be -1 after loop.
Reported-by : Struk, Tadeusz <tadeusz.struk@intel.com>
c3xxx doesn't have the esram BAR and only has 6 ue.
Resending again. The fw name suppoed to be 895xcc instead of 895xxcc.
Sorry for the noise.
Rename dh895xcc mmp fw to make it consistent with other mmp images.
Use list_for_each_entry*() instead of list_for_each*() to simplify
the code.
Signed-off-by: Geliang Tang <geliangtang@163.com>
Change the timeout condition since the times value would be -1 after
running MAX_RETRY_TIMES.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
