[ Upstream commit 0e7d4d932ffc23f75efb31a8c2ac2396c1b81c55 ]
This patch fixes two typos related to unregistering algorithms supported by
SAHARAH 3. In sahara_register_algs the wrong algorithms are unregistered
in case of an error. In sahara_unregister_algs the wrong array is used to
determine the iteration count.
Signed-off-by: Michael Müller <michael@fds-team.de>
This patch replaces use of the obsolete ablkcipher with skcipher.
It also removes shash_fallback which is totally unused.
Currently the sahara driver fails to probe:
sahara: probe of 63ff8000.crypto failed with error -22
This happens since commit 8996eafdcbad ("crypto: ahash - ensure statesize
is non-zero"), which requires statesize to be filled.
Pass the statesize members for sha1 and sha256, so we can probe
the driver successfully again.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Based on commit 434b421241f2d0 ("crypto: caam - avoid needlessly saving and
restoring caam_hash_ctx") from Russell King.
When exporting and importing the hash state, we will only export and
import into hashes which share the same struct crypto_ahash pointer.
(See hash_accept->af_alg_accept->hash_accept_parent.)
This means that saving the sahara_ctx structure on export, and
restoring it on import is a waste of resources. So, remove this code.
As pointed out by Herbert Xu we should not include the mutex in the
exported state, so let's just get rid of it.
The sahara_dump_descriptors and sahara_dump_links functions attempt
to print a dma_addr_t value with a 0x%08x format string, which
produces a warning when dma_addr_t is 64-bit wide:
drivers/crypto/sahara.c:419:120: warning: format '%x' expects argument of type 'unsigned int', but argument 5 has type 'dma_addr_t {aka long long unsigned int}' [-Wformat=]
This changes the code to use the %pad format string that is meant
for dma_addr_t, which avoids the warning and gives us the correct
output in all configurations.
The sahara hardware uses DMA descriptors with 32-bit addresses, but
dma_addr_t is variable size depending on whether we want to support
any devices that use 64-bit DMA addresses in hardware.
This means that the definition of the DMA descriptor structure is wrong,
and we helpfully get a compiler warning about them too:
drivers/crypto/sahara.c:423:372: warning: format '%x' expects argument of type 'unsigned int', but argument 4 has type 'dma_addr_t {aka long long unsigned int}' [-Wformat=]
This changes the definition of the sahara_hw_desc and sahara_hw_link
structures to only contain fixed-length members, which is required
to make the driver work on ARM LPAE mode, and avoids most of the
gcc warnings we get.
The two unsigned int variables nb_in_sg and nb_out_sg can be assigned
signed value (-EINVAL) from sg_nents_for_len().
Furthermore they are used only by dma_map_sg and dma_unmap_sg which wait
for an signed int, so they must be set as int.
Fixes: 6c2b74d4774f ("crypto: sahara - check return value of sg_nents_for_len")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com>
The sg_nents_for_len() function could fail, this patch add a check for
its return value.
Some array of const char are not set as const.
This patch fix that.
The sahara driver use two dma_map_sg path according to SG are chained
or not.
Since dma_map_sg can handle both case, clean the code with all
references to sg chained.
Thus removing the sahara_sha_unmap_sg function.
The sahara_sg_length function of the sahara driver is the same
as sg_nents_for_len from lib/scatterlist.c
Pull SG updates from Jens Axboe:
"This contains a set of scatter-gather related changes/fixes for 4.3:
- Add support for limited chaining of sg tables even for
architectures that do not set ARCH_HAS_SG_CHAIN. From Christoph.
- Add sg chain support to target_rd. From Christoph.
- Fixup open coded sg->page_link in crypto/omap-sham. From
Christoph.
- Fixup open coded crypto ->page_link manipulation. From Dan.
- Also from Dan, automated fixup of manual sg_unmark_end()
manipulations.
- Also from Dan, automated fixup of open coded sg_phys()
implementations.
- From Robert Jarzmik, addition of an sg table splitting helper that
drivers can use"
* 'for-4.3/sg' of git://git.kernel.dk/linux-block:
lib: scatterlist: add sg splitting function
scatterlist: use sg_phys()
crypto/omap-sham: remove an open coded access to ->page_link
scatterlist: remove open coded sg_unmark_end instances
crypto: replace scatterwalk_sg_chain with sg_chain
target/rd: always chain S/G list
scatterlist: allow limited chaining without ARCH_HAS_SG_CHAIN
This patch moves the data allocated using dma_alloc_coherent to the
corresponding managed interface. To be compatible with the change,
various gotos are replaced with direct returns and unneeded labels
are dropped.
Signed-off-by: Vaishali Thakkar <vthakkar1994@gmail.com>
[hch: split from a larger patch by Dan]
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Signed-off-by: Jens Axboe <axboe@fb.com>
clk_prepare_enable() may fail, so we should better check its return value
and propagate it in the case of error.
The AES implementation still assumes, that the hw_desc[0] has a valid
key as long as no new key needs to be set; consequentialy it always
sets the AES key header for the first descriptor and puts data into
the second one (hw_desc[1]).
Change this to only update the key in the hardware, when a new key is
to be set and use the first descriptor for data otherwise.
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
With commit
7e77bdebff5cb1e9876c561f69710b9ab8fa1f7e crypto: af_alg - fix backlog handling
in place, the backlog works under all circumstances where it previously failed, atleast
for the sahara driver. Use it.
All possible code-paths will assign ret to suitable values so this
default value is not needed.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
A failure of sahara_hw_descriptor_create() with -EINVAL due to scatter list
out of bounds/invalid would not be reported back. This patch just passes on
the -EINVAL so it is visible in sahara_queue_manage().
return type of wait_for_completion_timeout is unsigned long not int, this
patch adds appropriate variables of type unsigned long.
Modify crypto drivers to use the generic SG helper since
both of them are equivalent and the one from crypto is redundant.
See also:
468577abe37ff7b453a9ac613e0ea155349203ae reverted in
b2ab4a57b018aafbba35bff088218f5cc3d2142e
Signed-off-by: Cristian Stoica <cristian.stoica@freescale.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
Add support for the MDHA unit in the SAHARA core.
The MDHA can generate hash digests for MD5 and SHA1 in version 3 and
additionally SHA224 and SHA256 in version 4.
Add the SHA1 and SHA256 algorithms to the driver.
The implementation was tested with the in-kernel testmgr and a userspace
testprogram using AF_ALG with+without upto 128 pthreads on each AES and
SHA256 on i.MX53.
In preparation for SHA support, replace the tasklets with a kthread that
manages one crypto_queue for the core.
As the Sahara can only process one AES or SHA request at a time, we make
sure that the queue serializes all requests from userspace. Instead of a
watchdog timer we now use a completion mechanism in the queue manager
thread.
This makes the control flow more obvious and guarantees, that only one
request is dequeued until the completion is completed.
The Sahara on the i.MX53 is of version 4. Add support for probing the
device.
The driver uses a spinlock, but never initializes it.
Fix this.
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Use devm_ioremap_resource() in order to make the code simpler,
and remove redundant return value check of platform_get_resource()
because the value is checked by devm_ioremap_resource().
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
The data structure of_match_ptr() protects is always compiled in.
Hence of_match_ptr() is not needed.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Cc: Javier Martin <javier.martin@vista-silicon.com>
There is a typo here. "dev->hw_link[]" is an array, not a pointer, so
the check is nonsense. We should be checking recently allocated
"dev->hw_link[0]" instead.
This local symbol is used only in this file.
Fix the following sparse warnings:
drivers/crypto/sahara.c:420:6: warning: symbol 'sahara_watchdog' was not declared. Should it be static?
The sahara crypto driver has an incorrect MODULE_DEVICE_TABLE, which
prevents us from actually building this driver as a loadable module.
sahara_dt_ids is a of_device_id array, so we have to use
MODULE_DEVICE_TABLE(of, ...).
Cc: Herbert Xu <herbert@gondor.apana.org.au>
SAHARA2 HW module is included in the i.MX27 SoC from
Freescale. It is capable of performing cipher algorithms
such as AES, 3DES..., hashing and RNG too.
This driver provides support for AES-CBC and AES-ECB
by now.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Signed-off-by: Javier Martin <javier.martin@vista-silicon.com>
